PYB20-Q24-S12-DIN
PYB20-Q24-S12-DIN
    CUIDEVICES
    模块
    DC/DC CONVERTER 12V 20W DIN
PYB20-Q24-S12-DIN 数据手册
Additional Resources: Product Page | 3D Model date 01/18/2021 page 1 of 7 SERIES: PYB20-DIN │ DESCRIPTION: DC-DC CONVERTER FEATURES • • • • • • • • • • • • up to 20 W isolated output industry standard pinout 4:1 input range (9~36 Vdc, 18~75 Vdc) smaller package single/dual regulated outputs 1,500 Vdc isolation continuous short circuit, over current protection, over voltage protection reverse polarity protection temperature range (-40~85°C) six-sided metal shielding efficiency up to 88% EN 62368-1 MODEL input voltage output voltage output current output power ripple and noise1 efficiency typ (Vdc) range (Vdc) (Vdc) min (mA) max (mA) max (W) max (mVp-p) typ (%) PYB20-Q24-S3-DIN 24 9~36 3.3 250 5000 16.5 100 84 PYB20-Q24-S5-DIN 24 9~36 5 200 4000 20 100 88 PYB20-Q24-S12-DIN 24 9~36 12 84 1667 20 100 87 PYB20-Q24-S15-DIN 24 9~36 15 67 1333 20 100 88 PYB20-Q24-S24-DIN 24 9~36 24 42 834 20 100 88 PYB20-Q24-D5-DIN 24 9~36 ±5 ±100 ±2000 20 100 84 PYB20-Q24-D12-DIN 24 9~36 ±12 ±42 ±834 20 100 86 PYB20-Q24-D15-DIN 24 9~36 ±15 ±33 ±667 20 100 86 PYB20-Q48-S3-DIN 48 18~75 3.3 250 5000 16.5 100 84 PYB20-Q48-S5-DIN 48 18~75 5 200 4000 20 100 88 PYB20-Q48-S12-DIN 48 18~75 12 84 1667 20 100 87 PYB20-Q48-S15-DIN 48 18~75 15 67 1333 20 100 88 PYB20-Q48-S24-DIN 48 18~75 24 42 834 20 100 88 PYB20-Q48-D5-DIN 48 18~75 ±5 ±100 ±2000 20 100 84 PYB20-Q48-D12-DIN 48 18~75 ±12 ±42 ±834 20 100 86 PYB20-Q48-D15-DIN 48 18~75 ±15 ±33 ±667 20 100 87 Notes: 1. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 µF ceramic and 10 µF electrolytic capacitors on the output. PART NUMBER KEY PYB20 - QXX - XXX - X - DIN Mounting Type DIN = DIN-rail mount Base Number Input Voltage Notes: *Discontinued heatsink versions. Output S = single D = dual Output Voltage cui.com Heatsink* "blank" = no heatsink H = with heatsink Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: PYB20-DIN │ DESCRIPTION: DC-DC CONVERTER date 01/18/2021 │ page 2 of 7 INPUT parameter conditions/description operating input voltage 24 Vdc input models 48 Vdc input models min typ max units 9 18 24 48 36 75 Vdc Vdc start-up voltage 24 Vdc input models 48 Vdc input models 9 17.8 Vdc Vdc under voltage shutdown1 24 Vdc input models 48 Vdc input models 7.5 16 surge voltage for maximum of 1 second 24 Vdc input models 48 Vdc input models -0.7 -0.7 start-up time nominal input, constant load filter pi filter Vdc Vdc 50 100 Vdc Vdc 10 ms 1 mA models ON (CTRL open or connect TTL high level, 2.5~12 Vdc) CTRL models OFF (CTRL connect GND or low level, 0~1.2 Vdc) 2 input current (models OFF) Notes: 1. Contact CUI if you are planning to use this feature in your application. 2. CTRL pin voltage is referenced to GND. OUTPUT parameter conditions/description typ max units line regulation full load, input voltage from low to high min ±0.2 ±0.5 % load regulation 5% to 100% load ±0.5 ±1 % cross regulation dual output models: main output 50% load, secondary output from 10% to 100% load ±5 % ±1 ±3 % ±0.5 ±1 % voltage accuracy voltage balance 3 dual output, balanced loads adjustability4 ±10 % kHz switching frequency PWM mode 300 transient recovery time 25% load step change 300 500 μs transient response deviation 25% load step change ±3 ±5 % temperature coefficient 100% load ±0.02 %/°C max units Note: 3. For dual output models, unbalanced loads should not exceed ±5%. If ±5% is exceeded, it may not meet all specifications. 4. Output trimming available on single output models only. PROTECTIONS parameter conditions/description short circuit protection hiccup, continuous, automatic recovery min over current protection over voltage protection 3.3 Vdc output models 5 Vdc output models 12 Vdc output models 15 Vdc output models 24 Vdc output models typ 160 % 3.9 6.2 15 18 30 Vdc Vdc Vdc Vdc Vdc SAFETY AND COMPLIANCE parameter conditions/description min isolation voltage input to output for 1 minute at 1 mA max. 1,500 Vdc isolation resistance input to output at 500 Vdc 1,000 MΩ cui.com typ max units Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: PYB20-DIN │ DESCRIPTION: DC-DC CONVERTER date 01/18/2021 │ page 3 of 7 SAFETY AND COMPLIANCE (CONTINUED) parameter conditions/description safety approvals certified to 62368-1: EN min typ conducted emissions CISPR22/EN55022, class A, class B (external circuit required, see Figure 1-b) radiated emissions CISPR22/EN55022, class A, class B (external circuit required, see Figure 1-b) ESD IEC/EN61000-4-2, class B, contact ± 4kV radiated immunity IEC/EN61000-4-3, class A, 10V/m EFT/burst IEC/EN61000-4-4, class B, ± 2kV (external circuit required, see Figure 1-a) surge IEC/EN61000-4-5, class B, ± 2kV (external circuit required, see Figure 1-a) conducted immunity IEC/EN61000-4-6, class A, 3 Vr.m.s voltage dips & interruptions IEC/EN61000-4-29, class B, 0%-70% MTBF as per MIL-HDBK-217F @ 25°C RoHS 2011/65/EU max 1,000,000 units hours ENVIRONMENTAL parameter conditions/description min max units operating temperature see derating curves -40 85 °C -55 125 °C 5 95 % 105 °C storage temperature storage humidity non-condensing case temperature at full load, Ta=71°C vibration 10~55 Hz for 30 min. along X, Y and Z axis typ 10 G MECHANICAL parameter conditions/description dimensions DIN-rail mount: 76 x 31.5 x 25.8 DIN-rail mount with heatsink: 76 x 31.5 x 29.7 min case material aluminum alloy weight DIN-rail mount DIN-rail mount with heatsink typ units mm mm 70 78 cui.com max g g Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: PYB20-DIN │ DESCRIPTION: DC-DC CONVERTER date 01/18/2021 │ page 4 of 7 MECHANICAL DRAWING DIN-RAIL MOUNT units: mm[inch] tolerance: ±0.50[±0.02] wire range: 24~12 AWG mounts to TS35 rails PIN CONNECTIONS PIN Single Output Dual Output 1 CTRL CTRL 2 GND GND 3 Vin Vin 4 0V -Vo 5 Trim 0V 6 +Vo +Vo Top View Front View DIN-RAIL MOUNT WITH HEATSINK units: mm[inch] tolerance: ±0.50[±0.02] wire range: 24~12 AWG mounts to TS35 rails PIN CONNECTIONS PIN Single Output Dual Output 1 CTRL CTRL 2 GND GND 3 Vin Vin 4 0V -Vo 5 Trim 0V 6 +Vo +Vo Top View Front View cui.com Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: PYB20-DIN │ DESCRIPTION: DC-DC CONVERTER date 01/18/2021 │ page 5 of 7 DERATING CURVES With heatsink 100 Load (%) 80 Without heatsink 60 Safe operating area 40 20 -40 -20 0 20 40 55 60 85 Ambient Temperature (°C) EMC RECOMMENDED CIRCUIT Table 1 Figure 1 Vin LDM1 FUSE CY1 Vin C0 M OV GND Recommended external circuit components Vin (Vdc) (a) + DC / DC C1 (b) GND CY2 FUSE +Vo Cout LOAD -Vo ( 0 V) MOV 48 Choose according to input current S14K35 S14K60 LDM1 4.7μH 4.7μH C0 330μF/50V 330μF/100V C1 1μF/50V 1μF/100V CY1 1nF/2kV 1nF/2kV CY2 1nF/2kV 1nF/2kV Note: cui.com 24 1. See Table 2 for Cout values. Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: PYB20-DIN │ DESCRIPTION: DC-DC CONVERTER date 01/18/2021 │ page 6 of 7 APPLICATION NOTES 1. Recommended circuit This series has been tested according to the following recommended testing circuit before leaving the factory. This series should be tested under load (see Figure 2). If you want to further decrease the input/output ripple, you can increase the capacitance accordingly or choose capacitors with low ESR (see Table 2). However, the capacitance of the output filter capacitor must be appropriate. If the capacitance is too high, a startup problem might arise. For every channel of the output, to ensure safe and reliable operation, the maximum capacitance must be less than the maximum capacitive load (see Table 3). Figure 2 Single Output Dual Output Vin +Vo Vin Cin DC DC DC Cin Cou t 0V GND Cin (µF) Cout (µF) 3.3 100 470 -- 5 100 470 ±5 12 100 220 ±12 15 100 220 ±15 100 100 -- 24 0V Cou t -Vo Table 3 Single Vout (Vdc) Note: DC GND Table 2 +Vo Cout Dual Vout (Vdc) Cin (µF) Max. Capacitive Load1 (μF) Cout (µF) Single Vout (Vdc) Max. Capacitive Load (μF) Dual Vout (Vdc) -- -- 3.3 10200 -- -- 100 220 5 4020 5 4800 100 100 12 1035 12 800 100 100 15 705 15 500 -- -- 470 -- -- 1 1. For each output. 24 Note: 1. For each output. 2. Output voltage trimming Leave open if not used. Figure 3 Application Circuit for Trim pin (part in broken line is the interior of models) R1 R2 RT R1 R3 Trim V re f R3 RT aR 2 R2-a -R3 a= Vref R1 Vo’ - Vref down : R T= aR 1 R1-a -R3 a= Vo’ - Vref R2 Vref Trim R2 0V 0V Tr im up up : R T= + Vo +Vo V re f Formula for Trim Resistor Note: Tr im down Table 4 Note: Value for R1, R2, R3, and Vref refer to Table 4 RT: Trim Resistor a: User-defined parameter, no actual meanings Vo': The trim up/down voltage Vout (Vdc) R1 (kΩ) R2 (kΩ) R3 (kΩ) Vref (V) 3.3 4.801 2.863 15 1.24 5 2.883 2.864 10 2.5 12 10.971 2.864 17.8 2.5 15 14.497 2.864 17.8 2.5 24 24.872 2.863 20 2.5 1. Minimum load shouldn't be less than 5%, otherwise ripple may increase dramatically. Operation under minimum load will not damage the converter, however, they may not meet all specifications listed. 2. Maximum capacitive load is tested at input voltage range and full load. 3. All specifications are measured at Ta=25°C, humidity
PYB20-Q24-S12-DIN 价格&库存
很抱歉,暂时无法提供与“PYB20-Q24-S12-DIN”相匹配的价格&库存,您可以联系我们找货
