Additional Resources:
Product Page
3D Model
date
04/13/2022
page
1 of 8
SERIES: VHK100W │ DESCRIPTION: DC-DC CONVERTER
FEATURES
up to 100 W isolated output
rugged metal enclosure with integrated heat sink
4:1 input range (9~36 Vdc, 18~75 Vdc)
single output from 3.3~48 Vdc
1,500 Vdc isolation
over current, over temperature, over voltage,
and short circuit protections
• remote on/off
• efficiency up to 87%
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
and noise1
efficiency
range
(Vdc)
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
typ
VHK100W-Q24-S3R3
9 ~ 36
3.3
100
80
VHK100W-Q24-S5
9 ~ 36
5
100
82
VHK100W-Q24-S12
9 ~ 36
12
8.3
100
150
84
VHK100W-Q24-S15
9 ~ 36
15
6.7
100
150
85.5
VHK100W-Q24-S24
9 ~ 36
24
4.17
100
240
85
VHK100W-Q24-S28
9 ~ 36
28
3.57
100
280
86
VHK100W-Q24-S48
9 ~ 36
48
2.08
100
480
84
VHK100W-Q48-S3R3
18 ~ 75
3.3
100
79
VHK100W-Q48-S5
18 ~ 75
5
100
84.5
VHK100W-Q48-S12
18 ~ 75
12
8.3
100
150
85.5
VHK100W-Q48-S15
18 ~ 75
15
6.7
100
150
86.5
VHK100W-Q48-S24
18 ~ 75
24
4.17
100
240
87
VHK100W-Q48-S28
18 ~ 75
28
3.57
100
280
86
VHK100W-Q48-S48
18 ~ 75
48
2.08
100
480
85
Note:
1. Ripple and noise are measured at full load, 20 MHz BW with 10µF tantalum capacitor and 1µF ceramic capacitor across output. The 48 Vdc output models only require
the 1µF ceramic capacitor across the output.
PART NUMBER KEY
VHK100W - QXX - SXX X
Base Number
Input Voltage
Output Voltage
cui.com
Remote On/Off Control
"blank" = positive logic
N = negative logic
Product Page
3D Model
CUI Inc │ SERIES: VHK100W │ DESCRIPTION: DC-DC CONVERTER
date 04/13/2022 │ page 2 of 8
INPUT
parameter
conditions/description
operating input voltage
24 Vdc input models
48 Vdc input models
typ
max
units
9
18
24
48
36
75
Vdc
Vdc
24 Vdc input
power up
power down
8.8
8
Vdc
Vdc
48 Vdc input
power up
power down
17
16
Vdc
Vdc
under voltage shutdown
positive logic
CTRL1
negative logic
models ON (>3.5 Vdc or open circuit)
models OFF (0~1.8 Vdc)
models ON (0~1.8 Vdc)
models OFF (>3.5 Vdc or open circuit)
filter
pi filter
input fuse
20A time delay fuse for 24 Vin models,
10A time delay fuse for 48 Vin models
Note:
min
1. Open collector refer to -Vin
OUTPUT
parameter
maximum capacitive load
3.3 and 5 V output models
12 V output models
15 V output models
24 & 28 V output models
48 V output models
line regulation2
load regulation
2
min
typ
max
units
20,000
8,300
6,700
2,200
470
μF
μF
μF
μF
μF
measured from high line to low line
±0.2
measured from full load to zero load
±0.2
±1.5
47
voltage accuracy2
adjustability
±10
switching frequency
250
kHz
transient response
25% step load change
500
temperature coefficient
Note:
±0.03
µs
%/°C
2. A 47 μF aluminum capacitor is required on the output for 48 Vdc output models.
PROTECTIONS
parameter
continuous
over current protection
% nominal output current
min
over voltage protection
over temperature protection
max
units
110
140
115
140
shutdown
typ
105
°C
SAFETY AND COMPLIANCE
parameter
min
isolation voltage
for 1 minute: input to output; input to case;
output to case
isolation resistance
RoHS
typ
max
units
1,500
Vdc
10
MΩ
2011/65/EU (CE)
ENVIRONMENTAL
parameter
min
max
units
operating temperature
see derating curve
-40
85
°C
-55
105
°C
storage temperature
cui.com
typ
Product Page
3D Model
date 04/13/2022 │ page 3 of 8
MECHANICAL
parameter
dimensions
4.23 x 4.01 x 1.50 [107.5 x 101.8 x 38.0 mm]
min
case material
steel and aluminum extrusion
weight
typ
MECHANICAL DRAWING
units: inch[mm]
general tolerance: ±0.04[±1.0]
wire range: 22~12 AWG
screw size: #6-32
connector tightening torque: 1.4 N∙m (max)
PIN CONNECTIONS
FUNCTION
1
-Vo
2
-S
3
trim
4
+S
5
+Vo
6
case
7
on/off
-Vin
9
+Vin
4.23[107.5]
4.23[107.5]
4.09[104.0]
4.09[104.0]
1.50[38.0]
1.50[38.0]
Jumper
Jumper
3.58[91.0]
3.58[91.0]
3.58[91.0]
4.006[101.76]
4.006[101.76]
4.006[101.76]
8
2.76[70.0]
2.76[70.0]
cui.com
units
inch
502
PIN
max
g
Product Page
3D Model
date 04/13/2022 │ page 4 of 8
DERATING CURVES
TEST CONFIGURATION
Figure 1
Table 1
External components
Note:
L1
12μH
C1
220μF, ESR < 0.1Ω at 100 KHz
Cin
33μF, ESR < 0.7Ω at 100 KHz
Input reflected-ripple current is measured with an inductor L1 and Capacitor C1 to simulate source impedance.
EMC RECOMMENDED CIRCUITS
EN55022 CLASS A
Figure 2
Recommended Circuit for EN55022 Class A
(for all models)
cui.com
Product Page
3D Model
date 04/13/2022 │ page 5 of 8
EMC RECOMMENDED CIRCUITS (CONTINUED)
EN55022 CLASS A
Table 2
Class A Recommended Components
Model
C11
C21
L1
VHK100W-Q24-S3R3
47 μF/50 V
47 μF/50 V
3.4 μH
VHK100W-Q24-S5
47 μF/50 V
47 μF/50 V
3.4 μH
VHK100W-Q24-S12
47 μF/50 V
47 μF/50 V
3.4 μH
VHK100W-Q24-S15
47 μF/50 V
47 μF/50 V
3.4 μH
VHK100W-Q24-S24
47 μF/50 V
47 μF/50 V
3.4 μH
VHK100W-Q24-S28
47 μF/50 V
47 μF/50 V
3.4 μH
VHK100W-Q24-S48
47 μF/50 V
47 μF/50 V
3.4 μH
VHK100W-Q48-S3R3
47 μF/100 V
47 μF/100 V
3.4 μH
VHK100W-Q48-S5
47 μF/100 V
47 μF/100 V
3.4 μH
VHK100W-Q48-S12
47 μF/100 V
47 μF/100 V
3.4 μH
VHK100W-Q48-S15
47 μF/100 V
47 μF/100 V
3.4 μH
VHK100W-Q48-S24
47 μF/100 V
47 μF/100 V
3.4 μH
VHK100W-Q48-S28
47 μF/100 V
47 μF/100 V
3.4 μH
VHK100W-Q48-S48
47 μF/100 V
47 μF/100 V
3.4 μH
Note:
EN55022 CLASS B
1. Aluminum capacitors
Figure 3
Recommended Circuit for EN55022 Class B
(for all 3.3, 5, 12, 15, 24, & 28 Vdc output models)
cui.com
Product Page
3D Model
date 04/13/2022 │ page 6 of 8
EN55022 CLASS B
Figure 4
(for all 48 Vdc output models)
Table 3
Class B Recommended Components
Model
C11
C21
C32
L1
VHK100W-Q24-S3R3
220 μF/50 V
220 μF/50 V
NC
3.4 μH
VHK100W-Q24-S5
220 μF/50 V
220 μF/50 V
NC
3.4 μH
VHK100W-Q24-S12
220 μF/50 V
220 μF/50 V
NC
3.4 μH
VHK100W-Q24-S15
220 μF/50 V
220 μF/50 V
NC
3.4 μH
VHK100W-Q24-S24
220 μF/50 V
220 μF/50 V
NC
3.4 μH
VHK100W-Q24-S28
220 μF/50 V
220 μF/50 V
NC
3.4 μH
VHK100W-Q24-S48
100 μF/50 V
100 μF/50 V
2200 pF/2 KV
0.53 mH
VHK100W-Q48-S3R3
47 μF/100 V
47 μF/100 V
NC
3.4 μH
VHK100W-Q48-S5
47 μF/100 V
47 μF/100 V
NC
3.4 μH
VHK100W-Q48-S12
47 μF/100 V
47 μF/100 V
NC
3.4 μH
VHK100W-Q48-S15
47 μF/100 V
47 μF/100 V
NC
3.4 μH
VHK100W-Q48-S24
47 μF/100 V
47 μF/100 V
NC
3.4 μH
VHK100W-Q48-S28
47 μF/100 V
47 μF/100 V
NC
3.4 μH
VHK100W-Q48-S48
47 μF/100 V
47 μF/100 V
2200 pF/2 KV
0.53 mH
Note:
2. Ceramic capacitors
cui.com
Product Page
3D Model
date 04/13/2022 │ page 7 of 8
APPLICATION NOTES
1. Output Voltage Trimming
Leave open if not used.
Figure 5
Formula for Trim Resistor
Application Circuit for Trim pin
Rtrim - up = (
Rtrim - down =
R2 ))
R 2 + R3
R2R3
)(KΩ)
Vo - Vo, nom
R 2 + R3
R1(Vr - Vf (
R1(Vo - Vr)
- R2 (KΩ)
Vo, nom - Vo
Note: Rtrim-up is the external resistor in KΩ
Rtrim-down is the external resistor in KΩ
VO, nom is the nominal output voltage
VO is the desired output voltage
R1, R2, R3, and Vr are internal (see Table 4).
Vout
(Vdc)
Table 4
Note:
R2
(KΩ)
R3
(KΩ)
Vr
(V)
Vf
(V)
3.3
3
12
4.3
1.24
0.46
5
2.32
3.3
9.1
51
5.1
2.5
0.46
15
12
56
8.25
2.5
0.46
24
7.5
2.5
0.46
28
23.7
150
6.2
2.5
0.53
48
36
270
5.1
2.5
0.46
1. All specifications are measured at Ta=25°C, nominal input voltage and full output load unless otherwise specified.
cui.com
R1
(KΩ)
Product Page
3D Model
date 04/13/2022 │ page 8 of 8
REVISION HISTORY
rev.
description
date
1.0
initial release
10/11/2006
1.01
new template applied
12/21/2011
1.02
misc. updates and corrections
03/13/2012
1.03
updated mechanical drawing
03/27/2012
1.04
V-Infinity branding removed
06/27/2012
1.05
updated spec
03/14/2013
1.06
added trimming and EMI information
12/16/2013
1.07
company logo updated
02/08/2021
1.08
derating curve and circuit figures updated
09/06/2021
1.09
mechanical tolerance updated
04/13/2022
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a two (2) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
很抱歉,暂时无法提供与“VHK100W-Q48-S24”相匹配的价格&库存,您可以联系我们找货
