313080006
313080006
    SEEED(矽递科技)
    模块
    CPT-C5 power converter 12V 24V switch to 5V电压转换器开关
313080006 数据手册
Page 1 of 2 (images/P1130253.jpg) CPT-C5 power converter 12V/24V switch to 5V SKU: 313080006 Description CPT-C5 is a power converter module output 5V. Low heat, adopt synchronous rectification technology (5A long-term without any additional cooling measures). Page 2 of 2 Features • Conversion efficiency of 96%. • Epoxy Glue, waterproof, shock, moisture, suitable for harsh environments. • Short circuit protection, over current, over temperature protection, when the fault is solve then back to work. • Ultra-small size 66 * 60 * 23mm(L * W * H, without cable), about 100 grams. Specifications • • • • • • • • • • Input voltage DC12/24V (8-35V) Output voltage: 5V Output Power: 25W Soft-start time: 500mS Operating temperature: Industrial (- 40 °C to +85°C ) Full load temperature: 50 °C Load Regulation: ± 1% Voltage regulation: ± 2% Dynamic response speed: 5% 200uS Input reverse polarity protection: No, if necessary, add a series diode at input port Applications ideas • • • • Solar power Taxi advertising screen LCD TV Monitoring systems Overview Designer: Others Other Products From This Designer (http://www.seeedstudio.com/depot/Others-m-24.html?ref=pinfo) Weight: 113 g (http://www.seeedstudio.com/depot/Shenzhen-2U-t-11.html?ref=pinfo) http://www.seeedstudio.com/depot/CPTC5-power-converter-12V24V-switch-to-5V-p-106... 12/2/2015
313080006 价格&库存
很抱歉,暂时无法提供与“313080006”相匹配的价格&库存,您可以联系我们找货
  • 4+74.895504+9.68019
