Additional Resources:
Product Page
3D Model
date
04/13/2022
page
1 of 8
SERIES: VHK150W │ DESCRIPTION: DC-DC CONVERTER
FEATURES
up to 150 W isolated output
rugged metal enclosure with integrated heat sink
4:1 input range (9~36 Vdc, 18~75 Vdc)
single output from 5~48 Vdc
1,500 Vdc isolation
over current, over temperature, over voltage,
and short circuit protections
• remote on/off
• efficiency up to 90%
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
and noise1
efficiency
range
(Vdc)
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
typ
VHK150W-Q24-S5
9 ~ 36
5
25
125
100
87
VHK150W-Q24-S12
9 ~ 36
12
12.5
150
150
86
VHK150W-Q24-S15
9 ~ 36
15
10
150
150
86
VHK150W-Q24-S24
9 ~ 36
24
6.5
156
240
86.5
VHK150W-Q24-S28
9 ~ 36
28
5.4
150
280
87
VHK150W-Q24-S48
9 ~ 36
48
3.12
150
480
84
VHK150W-Q48-S5
18 ~ 75
5
25
125
100
90
VHK150W-Q48-S12
18 ~ 75
12
12.5
150
150
88
VHK150W-Q48-S15
18 ~ 75
15
10
150
150
88
VHK150W-Q48-S24
18 ~ 75
24
6.5
156
240
87.5
VHK150W-Q48-S28
18 ~ 75
28
5.4
150
280
89
VHK150W-Q48-S48
18 ~ 75
48
3.12
150
480
87
Note:
1. Ripple and noise are measured at full load, 20 MHz BW with 10µF tantalum capacitor and 1µF ceramic capacitor across output.
PART NUMBER KEY
VHK150W - QXX - SXX X
Base Number
Input Voltage
Output Voltage
cui.com
Remote On/Off Control
"blank" = positive logic
N = negative logic
Product Page
3D Model
CUI Inc │ SERIES: VHK150W │ DESCRIPTION: DC-DC CONVERTER
date 04/13/2022 │ page 2 of 8
INPUT
parameter
conditions/description
operating input voltage
24 Vdc input models
48 Vdc input models
typ
max
units
9
18
24
48
36
75
Vdc
Vdc
24 Vdc input
power up
power down
8.8
8
Vdc
Vdc
48 Vdc input
power up
power down
17
16
Vdc
Vdc
under voltage shutdown
positive logic
CTRL1
negative logic
models ON (>3.5 Vdc or open circuit)
models OFF (0~1.8 Vdc)
models ON (0~1.8 Vdc)
models OFF (>3.5 Vdc or open circuit)
filter
pi filter
input fuse
30A time delay fuse for 24 Vin models,
15A time delay fuse for 48 Vin models
Note:
min
1. Open collector refer to -Vin
OUTPUT
parameter
maximum capacitive load
5 V output models
12 V output models
15 V output models
24 V input, 24 & 28 V output models
48 V input, 24 & 28 V output models
48 V output models
min
typ
47
max
units
30,000
12,500
10,000
1,800
2,200
1,000
μF
μF
μF
μF
μF
μF
line regulation
measured from high line to low line
±0.2
load regulation2
measured from full load to zero load
±0.2
±1.5
2
voltage accuracy
2
adjustability
±10
switching frequency
transient response
250
25% step load change
kHz
500
temperature coefficient
Note:
±0.03
µs
%/°C
2. A 47 μF aluminum capacitor is required on the output for 48 Vdc output models.
PROTECTIONS
parameter
continuous
over current protection
% nominal output current
min
110
over voltage protection
over temperature protection
typ
115
shutdown
max
units
140
140
110
°C
SAFETY AND COMPLIANCE
parameter
isolation voltage
for 1 minute: input to output; input to case;
output to case
min
isolation resistance
RoHS
typ
max
units
1,500
Vdc
10
MΩ
2011/65/EU (CE)
ENVIRONMENTAL
parameter
min
operating temperature
see derating curve
storage temperature
cui.com
typ
max
units
-40
85
°C
-55
105
°C
Product Page
3D Model
date 04/13/2022 │ page 3 of 8
MECHANICAL
parameter
dimensions
4.23 x 4.01 x 1.50 [107.5 x 101.8 x 38.0 mm]
min
case material
steel and aluminum extrusion
weight
typ
MECHANICAL DRAWING
units: inch[mm]
general tolerance: ±0.04[±1.0]
wire range: 22~12 AWG
screw size: #6-32
connector tightening torque: 1.4 N∙m (max)
PIN CONNECTIONS
FUNCTION
1
-Vo
2
-S
3
trim
4
+S
5
+Vo
6
case
7
on/off
-Vin
9
+Vin
4.23[107.5]
4.09[104.0]
4.23[107.5]
4.23[107.5]
4.09[104.0]
4.09[104.0]
3.58[91.0]
3.58[91.0]
3.58[91.0]
4.006[101.76]
4.006[101.76]
4.006[101.76]
8
1.50[38.0]
Jumper
2.76[70.0]
1.50[38.0]
1.50[38.0]
Jumper
Jumper
2.76[70.0]
2.76[70.0]
cui.com
units
inch
502
PIN
max
g
Product Page
3D Model
date 04/13/2022 │ page 4 of 8
DERATING CURVES
TEST CONFIGURATION
Figure 1
Table 1
External Components
24 Vdc input models
L1
1.2μH
C1
220μF, ESR < 0.1Ω at 100 KHz
Cin
330μF, ESR < 0.7Ω at 100 KHz
48 Vdc input models
Note:
L1
12μH
C1
Cin
33μF, ESR < 0.7Ω at 100 KHz
Input reflected-ripple current is measured with an inductor L1 and Capacitor C1 to simulate source impedance.
cui.com
Product Page
3D Model
date 04/13/2022 │ page 5 of 8
EMC RECOMMENDED CIRCUITS
EN55022 CLASS A
Figure 2
Recommended Circuit for EN55022 Class A
Table 2
Class A Recommended Components
Model
C11
C21
C32
C42
C52
C62
L1
L2
VHK150W-Q24-S5
100 μF/50 V
100 μF/50 V
NC
NC
NC
NC
SHORT
0.5 mH
VHK150W-Q24-S12
100 μF/50 V
100 μF/50 V
NC
NC
NC
NC
SHORT
0.5 mH
VHK150W-Q24-S15
100 μF/50 V
100 μF/50 V
NC
NC
NC
NC
SHORT
0.5 mH
VHK150W-Q24-S24
100 μF/50 V
100 μF/50 V
680 pF
680 pF
470 pF
680 pF
SHORT
0.5 mH
VHK150W-Q24-S28
100 μF/50 V
100 μF/50 V
2200 pF
NC
680 pF
2200 pF
SHORT
0.6 mH
VHK150W-Q24-S48
100 μF/50 V
100 μF/50 V
1000 pF
NC
470 pF
1000 pF
SHORT
0.6 mH
VHK150W-Q48-S5
47 μF/100 V
47 μF/100 V
NC
NC
NC
NC
SHORT
0.5 mH
VHK150W-Q48-S12
47 μF/100 V
47 μF/100 V
NC
680 pF
NC
NC
SHORT
0.5 mH
VHK150W-Q48-S15
47 μF/100 V
47 μF/100 V
680 pF
1000 pF
NC
NC
SHORT
0.5 mH
VHK150W-Q48-S24
47 μF/100 V
47 μF/100 V
680 pF
680 pF
470 pF
680 pF
SHORT
0.5 mH
VHK150W-Q48-S28
47 μF/100 V
47 μF/100 V
2200 pF
NC
680 pF
2200 pF
SHORT
0.6 mH
VHK150W-Q48-S48
47 μF/100 V
47 μF/100 V
2200 pF
1500 pF
1500 pF
2200 pF
SHORT
0.5 mH
Notes:
1. Aluminum capacitor
2. Ceramic capacitor
cui.com
Product Page
3D Model
date 04/13/2022 │ page 6 of 8
EMC RECOMMENDED CIRCUITS (CONTINUED)
EN55022 CLASS B
Figure 3
Recommended Circuit for EN55022 Class B
Table 3
Class B Recommended Components
Model
C11
C21
C32
C42
C52
C62
C72
C82
L1
L2
VHK150W-Q24-S5
220 μF/50 V
220 μF/50 V
VHK150W-Q24-S12
220 μF/50 V
220 μF/50 V
680 pF
NC
NC
NC
NC
NC
3 μH
0.5 mH
680 pF
680 pF
NC
NC
NC
NC
3 μH
VHK150W-Q24-S15
220 μF/50 V
220 μF/50 V
0.5 mH
680 pF
NC
NC
NC
NC
NC
3 μH
0.5 mH
VHK150W-Q24-S24
220 μF/50 V
VHK150W-Q24-S28
220 μF/50 V
220 μF/50 V
1000 pF
1000 pF
470 pF
680 pF
470 pF
330 pF
3 μH
0.5 mH
220 μF/50 V
2200 pF x2
1000 pF
470 pF
2200 pF x2
470 pF
470 pF
3.4 μH
VHK150W-Q24-S48
0.6 mH
220 μF/50 V
220 μF/50 V
2200 pF x4
1000 pF
1000 pF
2200 pF x4
NC
NC
3.4 μH
0.6 mH
VHK150W-Q48-S5
120 μF/100 V
120 μF/100 V
NC
680 pF
NC
NC
NC
NC
3 μH
0.5 mH
VHK150W-Q48-S12
120 μF/100 V
120 μF/100 V
NC
680 pF
NC
NC
NC
NC
3 μH
0.5 mH
VHK150W-Q48-S15
120 μF/100 V
120 μF/100 V
1000 pF
1000 pF
470 pF
1000 pF
330 pF
680 pF
3 μH
0.5 mH
VHK150W-Q48-S24
120 μF/100 V
120 μF/100 V
1000 pF
1000 pF
470 pF
1000 pF
330 pF
680 pF
3 μH
0.5 mH
VHK150W-Q48-S28
120 μF/100 V
120 μF/100 V
1000 pF
1000 pF
470 pF
1000 pF
470 pF
470 pF
3.4 μH
0.6 mH
120 μF/100 V
2200 pF
+ 470 pF
1000 pF
2200 pF
+ 470 pF
NC
NC
SHORT
0.5 mH
VHK150W-Q48-S48
Notes:
82 μF/100 V
1500 pF
cui.com
Product Page
3D Model
date 04/13/2022 │ page 7 of 8
APPLICATION NOTES
1. Output Voltage Trimming
Leave open if not used.
Figure 4
Formula for Trim Resistor
Application Circuit for Trim pin
Rtrim - up = (
Rtrim - down =
R2 ))
R2 + R3
R2R3
)(kΩ)
Vo - Vo, nom
R2 + R3
R1(Vr - Vf (
R1(Vo - Vr)
- R2 (kΩ)
Vo, nom - Vo
Note: Rtrim-up is the external resistor in kΩ
Rtrim-down is the external resistor in kΩ
VO, nom is the nominal output voltage
VO is the desired output voltage
R1, R2, R3, and Vr are internal (see Table 4).
Table 4
Note:
Vout
(Vdc)
R1
(kΩ)
R2
(kΩ)
R3
(kΩ)
Vr
(V)
Vf
(V)
5
2.32
3.3
9.1
51
5.1
2.5
0.46
15
12
56
8.25
2.5
0.46
24
7.5
2.5
0.46
28
23.7
150
6.2
2.6
0.64
48
36
270
5.1
2.5
0.46
1. All specifications are measured at Ta=25°C, nominal input voltage and full output load unless otherwise specified.
cui.com
Product Page
3D Model
date 04/13/2022 │ page 8 of 8
REVISION HISTORY
rev.
description
date
1.0
initial release
10/11/2006
1.01
new template applied
12/21/2011
1.02
misc. updates and corrections
03/13/2012
1.03
updated mechanical drawing
03/27/2012
1.04
V-Infinity branding removed
09/06/2012
1.05
added 28 V output models
11/05/2012
1.06
misc. updates, added 5 V output models for both 24 and 48 V inputs
11/16/2012
1.07
updated spec
03/14/2013
1.08
added trimming and EMI information
12/17/2013
1.09
updated spec
01/05/2015
1.10
updated derating curves
06/18/2015
1.11
company logo updated
02/08/2021
1.12
derating curve and circuit figures updated
09/07/2021
1.13
mechanical tolerance updated
04/13/2022
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a two (2) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
很抱歉,暂时无法提供与“VHK150W-Q48-S15”相匹配的价格&库存,您可以联系我们找货
