2650-350
2650-350
    VECTOR
    模块
    PWR SUPPLY 350W CPCI CLSD FRM
2650-350 数据手册
20 Power Supplies CompactPCI® 3U Power Supplies 75 Watt 150 Watt 75 Watt - 1 slot wide (4 HP) 350 Watt These three power supplies are compliant with PICMG 2.11, defining electrical, mechanical and packaging standards. The 3U format offers space saving advantages and the range of power levels from 75 Watt to 350 Watt, offer broad design latitude. There are AC and DC versions of each supply. The AC versions feature autoranging power input from 100 to 240 VAC and the DC versions from 36 to 72 VDC. 150 Watt - 2 slots wide (8 HP) If desired, other input voltage levels as well as modifications of output to suit your particular needs can be accommodated. Also, the metal case, including front panel, can be customized on request. 350 Watt - 3 slots wide (12 HP) Common Features: • 3U High • Modular design with P47 connector • Current share, redundant (N+1) & Hot Swap • EMC card panel with ejector/injector • Meets cPCI power specifications PICMG 2.11 • AC input versions: Universal 100-240 VAC (50-60 Hz) • DC input versions: 36-72 VDC • Requires outside air source • Thermal protection • Short circuit protection • Designed to meet FCC pt 15 class A, CISPR 22 class A • UL 1950, CSA 22.2-950, VDE EN 60950 A Fine Technology Group Specifications subject to change without notice. 21 Power Supplies Specifications Air Flow Power Supply Specifications Input Voltage Range 2600-075 2600-150 2600-350 100-240 VAC 47 - 440 Hz 10A max @ 110 VAC 20A max @ 220 VAC cold start 75% typ. full power 100-240 VAC 47 - 440 Hz 14A max @ 110 VAC 40A max @ 220 VAC cold start 72% typ. full power 100-240 VAC 47 - 440 Hz 14A max @ 110 VAC 40A max @ 220 VAC cold start 75% typ. full power V1 V2 V3 V4 Minimum Load Requirement Total Output Power Limit Power Factor Correction +5V@5A +3.3V@10A +12V@1A -12V@0.25A V1 & V2: 1A 115% of max rated Power N/A Ripple Noise (all outputs) 1% P to P will full load or 50Mv, whichever is greater 1 Sec 8 ms at full load +5V@20A +3.3V@7A +12V@2A -12V@1A V1 & V2: 1A 115% of max rated Power .99 at 110 VAC .98 at 220 VAC 1% P to P will full load or 50Mv, whichever is greater 1 Sec 8 ms at full load Multiple power supplies can be operated in parallel and will share +5V current to within 10% V1 & V2 to a .25V drop in load +5V@30A +3.3V@40A +12V@7A -12V@1A V1 & V2: 2A 115% of max rated Power .99 at 110 VAC .98 at 220 VAC 1% P to P will full load or 50Mv, whichever is greater 1 Sec. 8 ms at full load Input Voltage Range Input Frequency Input Surge Current Efficiency OUTPUT Turn-on Time Hold-up Time Current Sharing Remote Sense ENVIRONMENTAL & PROTECTION Operating Temperature Range V1 & V2 to a .25V drop in load 0 oC to 70oC; Derate linearly from full power at 40oC with 200lfm to half power at 70oC with 200 lfm; Supply shuts down at thermal limit and restarts automatically when thermal condition is relieved. 200 lfm at 40oC, forced air through the power supply Cooling Requirements @ full power Storage Temperature Range Relative Humidity Vibration Altitude Over Current Protection V1 & V2 to a .25V drop in load -40 oC +85oC -40 oC +85oC -40oC +85oC 5% to 95%, non-condensing 5% to 95%, non-condensing 5% to 95%, non-condensing MIL 810E MIL 810E MIL 810E 6,000 ft. est 6,000ft. est 6,000 ft. est 115% of nominal. If condition occurs, current will foldback Thermal switch shuts down the supply if critical temperatures are exceeded. Unit will automatically restart when acceptable temperatures return. Thermal Protection Over Voltage Protection Shutdown occurs at 125% of output voltages. Output latches and reset requires a recycling of the input power Short Circuit Protection All Voltages All Voltages All Voltages 1 lb 1 oz 3U X 4HP (0.8”)W X 160mm P47 Connector 2 lbs 4 oz 3U X 8HP (1.6”)W X 160mm P47 Connector 2 lbs 14 oz 3U X 12HP (2.4”)W X 160mm P47 Connector AC: UL 1950, CUL22.2-950 VDE EN 60950, pending AC: UL 1950, CUL22.2-950 VDE EN 60950, pending AC: UL 1950, CUL22.2-950 VDE EN 60950, pending PHYSICAL Weight Dimensions Mating Connector RATINGS Agency 11115 Vanowen St., North Hollywood, CA 91605 Phone (818) 985-8208 Toll-Free (800) 423-5659 Web site: http://www.vectorelect.com A Fine Technology Group
2650-350 价格&库存
很抱歉,暂时无法提供与“2650-350”相匹配的价格&库存,您可以联系我们找货
