Additional Resources:
Product Page
rev.
page
1 of 3
date
09/2009
DESCRIPTION: screw terminal dc-dc converter
SERIES: PTK15-T
Features
10-36VDC
10-36VDC
10-36VDC
10-36VDC
10-36VDC
10-36VDC
10-36VDC
20-72VDC
20-72VDC
20-72VDC
20-72VDC
20-72VDC
20-72VDC
20-72VDC
ue
Output
Voltage
Output
Current
(max)
4.0A
3.0A
1.25A
1.0A
1.5A
0.625A
0.5A
4.0A
3.0A
1.25A
1.0A
1.5A
0.625A
0.5A
Ripple & Noise 2
mV P-P
in
Input
Voltage
3.3VDC
5VDC
12VDC
15VDC
±5VDC
±12VDC
±15VDC
3.3VDC
5VDC
12VDC
15VDC
±5VDC
±12VDC
±15VDC
co
PTK15-Q24-S3-T
PTK15-Q24-S5-T
PTK15-Q24-S12-T
PTK15-Q24-S15-T
PTK15-Q24-D5-T
PTK15-Q24-D12-T
PTK15-Q24-D15-T
PTK15-Q48-S3-T
PTK15-Q48-S5-T
PTK15-Q48-S12-T
PTK15-Q48-S15-T
PTK15-Q48-D5-T
PTK15-Q48-D12-T
PTK15-Q48-D15-T
Output
Power
(max)
13.2W
15.0W
15.0W
15.0W
15.0W
15.0W
15.0W
13.2W
15.0W
15.0W
15.0W
15.0W
15.0W
15.0W
nt
MODEL 1
d
·U-frame with screw terminals
·Industry standard pin out
·Wide 4:1 input range
·Fully isolated
·Output voltage trimmable
·Output on/off control
·Over-current protection
·Over-voltage protection
·Six-sided EMI shielding
·Constant switching frequency
·High efficiency
·Compact size 2.25”x3.0”x0.67”
·-40°C~85°C Models available
·3 year warranty
75
75
120
150
50/50
120/120
150/150
75
75
120
150
50/50
120/120
150/150
Efficiency
(Typ.)
80%
85%
86%
84%
85%
87%
87%
80%
85%
87%
87%
85%
86%
87%
Note: 1 All models are also available in an extended temperature range of -40°C~85°C. For these models,
append “M” to the model number, e.g. PTK15-Q48-S5M.
D
is
2 Ripple & noise measured with a 20MHz bandwidth, off a 10 μF electrolytic and a 0.1 μF ceramic cap in parallel at
ouptut.
20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383
www.v-infinity.com
Product Page
rev.
page
2 of 3
date
09/2009
SERIES: PTK15-T
Input
Remote on/off control
Switching frequency
Conditions/Description
Min
10
2.5V
0V
Output turn-on 3
Output turn-off
Constant
OUTPUT
Minimum load
Ripple and noise
KHz
Min
Nom
Max
Units
With external trim resistors
-5%
+5%
Single output
-2%
+2%
Dual output
-3%
+3%
Single output models
-0.25%
+0.25%
Dual output models
-2.5%
+2.5%
Triple: main output (Vout)
-0.25%
+0.25%
auxillary outputs (+Vaux / -Vaux)
-5%
+5%
Single output models - no load to full load
-0.25%
+0.25%
Dual output models - balanced loads
-2.5%
+2.5%
-0.25%
+0.25%
auxillary outputs(+Vaux / -Vaux) - with 10% load
-5%
+5%
on Vout and balanced loads on +Vaux and -Vaux
Converters will not be damaged if loading conditions are less than minimum specified loads,
but regulation specs may not be met 4
See chart
in
Load regulation²
Units
VDC
VDC
nt
Line regulation
(Low line to high line)
Max
36
72
5.5V
0.8V
ue
Note: 3 Output defaults to “on” when there is no connection to the “CNT” pin.
Parameter
Output trim range
Set point accuracy
Nom
24
48
(open)
(short)
250
d
Parameter
Input voltage range
Note: 4 Single output: no min. load required, Dual output: 10%, Triple output: balanced load
co
PROTECTION
Parameter
Over-current
Over-voltage
Continuous auto recovery 5
Internally zener clamped 5
Min
105%
110%
Nom
Max
135%
140%
Units
Note: 5 Continuous operation in a protected state may compromise long-term reliability.
is
GENERAL
Continuous/Description
Min
Typical at full load
78%
Input/case, input/output, output/case
500
at 500 VDC
100M
Approved to UL60950, CSA C22.2 No. 60950, TUV EN60950
MTBF
Operating temperature
MIL-HDBK-217F
Regular models - see derating curve.
Extended temperature models
D
Parameter
Efficiency
Dielectric withstand
Insulation resistance
Agency standards
Case material
Material flammability
Weight
Storage temperature
Humidity
Nom
Max
83%
Units
VAC
Ohms
Zn
94 V-0
Operating(non-condensing)
80
(2.82)
470k
-20
-40
-40
5%
grams
(ounces)
hours
+71
°C
+85
°C
+105
°C
95%
RH
www.v-infinity.com
Product Page
rev.
page
3 of 3
date
09/2009
ue
d
SERIES: PTK15-T
Single Output
*DIN rail mounting kit available (part# STK-DIN)
D
is
co
nt
in
Dual Output
V-Infinity reserves the right to make changes to its products or to discontinue any product or service without notice, and to advise customers to verify the most up-to-date product
information before placing orders. V-Infinity assumes no liability or responsibility for customer's applications using V-Infinity products other than repair or replacing (at V-I's option) VInfinity products not meeting V-I's published specifications. Nothing will be covered outside of standard product warranty.
www.v-infinity.com
很抱歉,暂时无法提供与“PTK15-Q24-S12-T”相匹配的价格&库存,您可以联系我们找货
