ZM15.SIDE
ZM15.SIDE
    PULS
    BRACKETSIDEMNTFORDIMENSION
ZM15.SIDE 数据手册
ZM11.SIDE, ZM12.SIDE ZM13.SIDE, ZM14.SIDE, ZM15.SIDE Side Mounting Bracket 1. GENERAL DESCRIPTION BRACKET FOR FLAT MOUNTING This accessory is used to mount Dimension power supplies and other Dimension units sideways to reduce the installation depth. The two aluminum brackets and the black plastic slide must be removed from the units, to allow mounting of the zinc-plated steel bracket. Two mounting options are possible: ■ Panel mount ■ 35mm DIN-Rail mount 2. DIMENSIONS AND INSTALLATION DATA The drawings on the left show the bracket for DIN-rail mounting. The total installation depth is the B dimension plus 6mm plus the height of the DIN-Rail. In case the unit is panel mounted, the B dimension shows the required installation depth. Aug. 2019 / Rev. 1.3 DS-ZMXX.SIDE-EN / All parameters are specified at 25°C ambient unless otherwise noted. The information presented in this document is believed to be accurate and reliable and may change without notice. www.pulspower.com Phone +49 89 9278 0 Germany 1/3 ZM11.SIDE, ZM12.SIDE ZM13.SIDE, ZM14.SIDE, ZM15.SIDE Side Mounting Bracket Power Supply QS3.XXX Use Bracket ZM11.SIDE A B C Length Width Height 89mm 38mm 32mm 145mm 65mm 37mm Bracket Weight 140g QS5.XXX ZM12.SIDE 104mm 46mm 40mm 145mm 65mm 44mm 160g QS10.XXX ZM13.SIDE 104mm 66mm 60mm 145mm 65mm 63mm 180g QT20.XXX ZM14.SIDE 124mm 74mm 65mm 145mm 65mm 76mm 195g QS20.XXX ZM15.SIDE 124mm 88mm 82mm 145mm 65mm 84.5mm 205g YR2.DIODE ZM11.SIDE 89mm 38mm 32mm 145mm 65mm 37mm 140g YRM2.DIODE ZM11.SIDE 104mm 38mm 32mm 145mm 65mm 37mm 140g UF20.XXX ZM14.SIDE 89mm 79mm 64mm 145mm 65mm 76mm 195g CS3.XXX ZM11.SIDE 89mm 38mm 32mm 145mm 65mm 37mm 140g CS5.XXX ZM11.SIDE 104mm 38mm 32mm 145mm 65mm 37mm 140g CS10.XXX ZM13.SIDE 60mm 145mm 65mm 63mm 180g 104mm 66mm Aug. 2019 / Rev. 1.3 DS-ZMXX.SIDE-EN / All parameters are specified at 25°C ambient unless otherwise noted. The information presented in this document is believed to be accurate and reliable and may change without notice. www.pulspower.com Phone +49 89 9278 0 Germany 2/3 ZM11.SIDE, ZM12.SIDE ZM13.SIDE, ZM14.SIDE, ZM15.SIDE Side Mounting Bracket 3. ASSEMBLY AND MOUNTING INSTRUCTIONS Fig. 3-1 Detaching DIN-Rail brackets Detach the two aluminium brackets by removing the four screws with a Torx screwdriver (Torx 10). Save the screws for step 3. Fig. 3-2 Detach slide Fig. 3-3 Mounting steel bracket Remove the plastic lock mechanism by using a flat-blade screwdriver to move the lock downwards while at the same time pushing the plastic slide upwards. Detach the plastic slide. Mount the steel brackets with the same screws from the DIN-Rail brackets using caution not to over-tighten the screws! Recommended tightening torque is 0.6Nm. (5.3lb.in). Fig. 3-4 Panel Mount Two mounting options: - Panel Mount - DIN-Rail Mount Fig. 3-5 DIN-Rail Mount Preparation for DIN-Rail mounting: Install the two aluminium brackets and the plastic slide (detached from the unit before) onto the side mounting plant with the additional screws provided. 4. ORDER NUMBERS Accessory ZM11.SIDE ZM12.SIDE ZM13.SIDE ZM14.SIDE ZM15.SIDE Side-mounting Bracket Kit 145x65x37mm Side-mounting Bracket Kit 145x65x44mm Side-mounting Bracket Kit 145x65x63mm Side-mounting Bracket Kit 145x65x76mm Side-mounting Bracket Kit 145x65x84.5mm Aug. 2019 / Rev. 1.3 DS-ZMXX.SIDE-EN / All parameters are specified at 25°C ambient unless otherwise noted. The information presented in this document is believed to be accurate and reliable and may change without notice. www.pulspower.com Phone +49 89 9278 0 Germany 3/3
ZM15.SIDE 价格&库存
很抱歉,暂时无法提供与“ZM15.SIDE”相匹配的价格&库存,您可以联系我们找货
ZM15.SIDE
  • 1+197.074721+25.46052
库存:1
