PBK-1-9
PBK-1-9
    CUIDEVICES
    AC/DCCONVERTER9V1W
PBK-1-9 数据手册
Additional Resources: Product Page date 02/02/2018 page 1 of 7 SERIES: PBK-1 │ DESCRIPTION: AC-DC POWER SUPPLY up to 1 W continuous output compact SIP package single regulated outputs from 5~24 V 3,000 Vac isolation over current and short circuit protections CE, UL60950-1 safety approval wide input voltage: 70~400 Vdc (85~264 Vac) efficiency up to 68% PBK-1-5 output voltage output current output power ripple and noise1 efficiency2 (Vdc) max (mA) max (W) max (mVp-p) typ (%) 200 1 150 61 111 1 150 66 83 1 150 67 67 1 150 67 1 150 68 5 PBK-1-9 9 12 PBK-1-15 15 PBK-1-24 Note: N PBK-1-12 TI MODEL N U • • • • • • • • ED FEATURES 24 42 1. Measured at 20 MHz bandwidth, see Test Configuration section. 2. At 230 Vac. PBK-1- XX - X Base Number Output Voltage D IS C O PART NUMBER KEY cui.com Orientation “blank” = vertical B = right-angle Additional Resources: Product Page CUI Inc │ SERIES: PBK-1 │ DESCRIPTION: AC-DC POWER SUPPLY date 02/02/2018 │ page 2 of 7 INPUT conditions/description max units voltage 85 70 264 400 Vac Vdc frequency 47 63 Hz 120 60 mA mA current at 115 Vac at 230 Vac inrush current at 115 Vac at 230 Vac min 10 20 no load power consumption input fuse 1 A/250 V, slow-blow type (external, required) conditions/description min W max units 470 150 100 μF μF μF ±1.5 ±2 % ±2.5 ±3 % ±10 ±5 % % typ 10 line regulation at full load load regulation at 10%~100% load voltage set accuracy 5 Vdc output models all other models hold-up time at 115 Vac at 230 Vac switching frequency PROTECTIONS % 80 300 N temperature coefficient TI capacitive load 5 Vdc output models 9 Vdc output models all other models N output current A A 0.5 U OUTPUT parameter typ ED parameter conditions/description short circuit protection hiccup, continuous, auto restart over current protection auto restart O parameter min ms ms 50 ±0.1 typ kHz %/°C max 120 units % SAFETY & COMPLIANCE parameter conditions/description min input to output, for 1 minute typ max 3,000 IS C isolation voltage safety approvals UL60950-1, CE safety class Class II conducted emissions CISPR32/EN55032 external circuit required, Class A (see figure 2); Class B (see figure 3) radiated emissions CISPR32/EN55032 external circuit required, Class A (see figure 2); Class B (see figure 3) ESD IEC/EN61000-4-2 Class B, contact ±4 kV radiated immunity IEC/EN61000-4-3 Class A, 10V/m (external circuit required, see figure 3) EFT/burst Vac IEC/EN61000-4-4 Class B, ±2 kV (external circuit required, see figure 2) IEC/EN61000-4-4 Class B, ±4 kV (external circuit required, see figure 3) surge IEC/EN61000-4-5 Class B, ±1 kV/±2 kV (external circuit required, see figure 3) conducted immunity IEC/EN61000-4-6 Class A, 3 Vr.m.s (external circuit required, see figure 3) voltage dips & interruptions IEC/EN61000-4-11 Class B, 0%-70% (external circuit required, see figure 3) MTBF as per MIL-HDBK-217F, 25°C RoHS 2011/65/EU D units 300,000 cui.com hours Additional Resources: Product Page CUI Inc │ SERIES: PBK-1 │ DESCRIPTION: AC-DC POWER SUPPLY date 02/02/2018 │ page 3 of 7 ENVIRONMENTAL parameter conditions/description min operating temperature humidity non-condensing units 85 °C -25 105 °C 85 EFFICIENCY CURVES 80 75 70 65 LS01-15B05S 60 55 60 LS01-15B24S LS01-15B12S PBK-1-5 LS01-15B05S PBK-1-12 PBK-1-24 N PBK-1-12 LS01-15B24S PBK-1-24 LS01-15B12S Efficie ncy(%) PBK-1-5 70 U 80 50 40 230 20 264 10 O N Input Voltage (Vac) D IS C 85 TI 30 50 % effieciency vs. output load (at 230 Vac) effieciency vs. input voltage (full load) Efficie ncy(%) typ ED storage temperature max -25 cui.com 50 Output Current (%) 100 Additional Resources: Product Page CUI Inc │ SERIES: PBK-1 │ DESCRIPTION: AC-DC POWER SUPPLY date 02/02/2018 │ page 4 of 7 SOLDERABILITY conditions/description min typ max units for 3~5 seconds 350 360 370 °C wave soldering for 5~10 seconds 255 260 265 °C parameter conditions/description min dimensions vertical: 35 x 11 x 25 right-angle: 35 x 13 x 25 material UL94V-0 MECHANICAL typ max units mm mm weight 8 g U MECHANICAL DRAWING VERTICAL ORIENTATION O N TI N units: mm[inch] tolerance: ±0.5[±0.020] pin tolerance: ±0.1[±0.004] Top View PCB Layout PIN CONNECTIONS PIN Front View IS C D ED parameter hand soldering FUNCTION 1 -Vin (N) 3 +Vin (L) 5 +V(CAP) 7 -V(CAP) 10 -Vo 12 +Vo Note: 1. It is required to add C1 between pins 5 & 7 (see application circuits). Bottom View cui.com Additional Resources: Product Page CUI Inc │ SERIES: PBK-1 │ DESCRIPTION: AC-DC POWER SUPPLY date 02/02/2018 │ page 5 of 7 MECHANICAL DRAWING (CONTINUED) RIGHT-ANGLE ORIENTATION N U ED units: mm[inch] tolerance: ±0.5[±0.020] pin tolerance: ±0.1[±0.004] Side View Top View PCB Layout N TI Front View PIN CONNECTIONS PIN FUNCTION 1 -Vin (N) 3 +Vin (L) 5 +V(CAP) 7 -V(CAP) 10 -Vo 12 +Vo O Note: 1. It is required to add C1 between pins 5 & 7 (see application circuits). IS C Bottom View TEST CONFIGURATION Figure 1 Table 1 C o nn ec t Os c illo grap h P ro be C o pp e r s he e t C1 $& 1 +Vo  L1   C2 AC -D C    -Vo C3 C4 Lo ad F U SE D $& / Recommended External Circuit Components VOUT (Vdc) C11 C21 L11 C31 C4 CY0 (Y1 capacitor) 5 10μF/400V 150μF/35V 2.2μH 68μF/35V 0.1μF/50V 1nF/400Vac 9 10μF/400V 150μF/35V 2.2μH 68μF/35V 0.1μF/50V 1nF/400Vac 12 10μF/400V 100μF/35V 2.2μH 68μF/35V 0.1μF/50V 1nF/400Vac 15 10μF/400V 100μF/35V 2.2μH 68μF/35V 0.1μF/50V 1nF/400Vac 24 10μF/400V 100μF/35V 2.2μH 68μF/35V 0.1μF/50V 1nF/400Vac Note: CY0 cui.com 1. Required components. 2. 1 A/250 V fuse required. Additional Resources: Product Page CUI Inc │ SERIES: PBK-1 │ DESCRIPTION: AC-DC POWER SUPPLY date 02/02/2018 │ page 6 of 7 TYPICAL APPLICATION CIRCUIT Figure 2 ķ L2 17& + V in ( L) A C -D C C1 + M OV1 -V(c a p ) - V in ( N ) C 3 TV S C 4 RL + +V (ca p ) AC (N) L1 C2 + Vo + - Vo C Y0 Table 2 VOUT (Vdc) C11 L2 C21,2 L11 C31 U Recommended External Circuit Components ED )86( A C ( L) C4 CY0 FUSE1 TVS NTC MOV1 10μF/400V 4.7mH 150μF/35V 2.2μH 68μF/35V 0.1μF/50V 1nF/400Vac 1A/250V SMBJ7.0A 5D-9 S14K350 10μF/400V 4.7mH 150μF/35V 2.2μH 68μF/35V 0.1μF/50V 1nF/400Vac 1A/250V SMBJ12A 5D-9 S14K350 12 10μF/400V 4.7mH 100μF/35V 2.2μH 68μF/35V 0.1μF/50V 1nF/400Vac 1A/250V SMBJ20A 5D-9 S14K350 15 10μF/400V 4.7mH 100μF/35V 2.2μH 68μF/35V 0.1μF/50V 1nF/400Vac 1A/250V SMBJ20A 5D-9 S14K350 24 10μF/400V 4.7mH 100μF/35V 2.2μH 68μF/35V 0.1μF/50V 1nF/400Vac 1A/250V SMBJ30A 5D-9 S14K350 TI N 5 9 Note: 1. Required components. 2. When 5 Vdc model is operating in the -25~0C or 55~85C range, C2 needs to be a 270 μF/16 V solid capacitor. EMC RECOMMENDED CIRCUIT LD M FUSE N A C ( L) LC M M O V2 CX O Figure 3 + V in ( L) AC -DC C Y2 C1 +V(c a p ) + C3 + + TV S C 4 RL -V ( c a p ) -Vo -V in ( N ) C Y0 Table 3 Recommended External Circuit Components MOV2 S14K350 CY1, CY2 1nF/400Vac CX 0.1μF/275Vac LCM 3.5mH LDM 5mH FUSE 1A/250V, slow blow Note: Also refer to Table 2. D IS C C 2 L1 C Y1 AC (N) Notes: + Vo 1. 2. 3. 4. C1 and C3 are electrolytic capacitors. They are required for both AC input and DC input. For AC input, C1 is used as a filter capacitor. The recommended C1 value is 10 μF/400 V. For DC input, C1 is used as an EMC filter capacitor. The recommended C1 value is 10μF/400V. When the input voltage is above 370VDC, we recommend a 10μF/450V capacitor. C2 and C3 are output filer capacitors, we recommend high frequency and low impedance electrolytic capacitors. For capacitance and rated ripple current of capacitors refer to the datasheets provided by the manufacturers, voltage derating of capacitors should be 80% or above. 5. C4 is a ceramic capacitor which is used to filter high frequency noise. C2, C3 and L1 form a pi-type filter circuit. For current of L1 and L2 refer to the datasheets provided by the manufacturers, current derating should be 80% or above. TVS is a recommended component to protect post-circuits (if converter fails). We recommend using a 5D-9 external input NTC. 6. For standard EMC requirements, please refer to figure 2. If a higher EMC is required, please refer to figure 3. 7. All specifications measured at Ta=25C, humidity
PBK-1-9 价格&库存
很抱歉,暂时无法提供与“PBK-1-9”相匹配的价格&库存,您可以联系我们找货
