TD-PFC-500
TD-PFC-500
    TELCODIUM
    AC/DCCONVERTER400V500W
TD-PFC-500 数据手册
Power Factor Corrector (PFC) MODULE P O W E R S U P P LY T E C H N O L O G Y TD-PFC-500 Technical Specification 100 to 500W Power Module FEATURES • • • • • • High-Efficiency Direct connection with ideal diode module Low profile, small size Low harmonic distortion High efficiency interleaved technology Vertical or horizontal mount PRODUCT OVERVIEW The Telcodium PFC module uses high efficiency interleaved technology with a fast switching mosfet for low loss and low emi integrated in a small form factor module. The Telcodium PFC module uses advanced switching technology to reduce the harmonic distortion under CISPR norm with greater efficiency from low line to high line input and across the load range. APPLICATIONS • Power supply design with high efficiency PFC boost • High efficiency equipment design • Convection cooling equipment Preliminary and subject to change without notice www.telcodium.com ©2017 TELCODIUM INC. P O W E R S U P P LY T E C H N O L O G Y Figure 1. SPECIFICATIONS PARAMETERS MIN TYP MAX UNITS NOTES -40 -45 - 95 125 C C Limited by bulk capacitor 20 10 - 95 95 % % RH RH 85 45 11.00 tbd 140.00 0.99 3 12.00 - 265 65 50 500 6 17.00 tbd 160.00 Vrms Hz 380 390 400 Vdc 0 420 100 Tbd Tbd - (+/-)0.3 (+/-)2 1.3 460 390 % % A Vdc uf Absolute maximum rating Operating temperature Storage temperature Humidity (non condensing) Operating Non-Operating Input characteristic (L to N) Operating input voltage AC input continuous Operating input frequency Power Factor of AC input line Total Harmonic distortion of AC input current Inrush of AC input current Maximum input power Maximum input current Aux input voltage Aux input current Thermal Shutdown % A W A Vdc mA C See Graphic See Graphic Vin>85Vrms Vin=85Vrms Output characteristics Output voltage set point Output voltage regulation Over line Over load Operating output current range Output over voltage shutdown threshold Output capacitor (bulk) Preliminary and subject to change without notice www.telcodium.com tbd Note1 ©2017 TELCODIUM INC. 2 P O W E R S U P P LY T E C H N O L O G Y Efficiency 50% load 100% load 96 97 - % % See Graphic 1 See Graphic 1 10^6 HRS Tb=70C Reliability Characteristics Calculated MTBF (MIL-217) MIL-HDBK-217F 10 EMC With Ideal diode and EMC AC Filter Operating output current range Output over voltage shutdown threshold Output capacitor (bulk) Figure 2. et 3. Electrostatic discharge immunity Radiated radio frequency immunity Electrical Fast transients/burst Line surge immunity Conducted immunity Power Frequency mag field Voltage dip immunity OUTLINE DRAWING EN5501 1 EN61000-3-2 EN61000-3-3 EN61000-4-2 EN61000-4-3 EN61000-4-4 EN61000-4-5 En61000-4-6 EN61000-4-8 EN61000-4-11 EN5502 2 FCC Part 15 Standards Compliance UL 60950-1/R2011-12 CAN/CSA-C22.2 No. 60950-1/A1:2011 EN60950-1/A12:2011 CE marking Mechanical Size (WxHxL) Weight Note1 3.5x1.25x0.775 inch 88.9x31.75x20 mm 75 g For 20mS hold time at 500W , min 330uf at 450Vdc Table 1 Preliminary and subject to change without notice www.telcodium.com ©2017 TELCODIUM INC. 3 P O W E R S U P P LY T E C H N O L O G Y OUTLINE DRAWING Figure 2. Top View Isometric View ✓ See design guide PCB layout for proper clearance and trace width routing ✓ Connector TE 640385-5, 0.156" (3.96mm) Preliminary and subject to change without notice www.telcodium.com ©2017 TELCODIUM INC. 4 P O W E R S U P P LY T E C H N O L O G Y Figure 3. ELECTRICAL CONNECTIONS Pinout description • • • • • • • • • • • • • Pin1: DC rectified input full wave rectified (from bridge) Pin2: AC line input Pin3: AC Neutral input Pin4: Ground non-isolated section Pin5: Auxiliary 12Vdc power source (100mA max), see design guide Pin6-8: Vout 390Vdc Pin9-11: External bulk capacitor (negative) connection P12-13,15: Ground non-isolated section P14: VCC 12-17vdc, input from local DC-DC P16: nc P17: ENABLE PFC (Active Low) P18: VCC 3V3, input pin from TD CPU Module or regulated 3.3V dc source 25mA P19: Isolated ground (Caution: do not connect with AGND) ✓ See design guide for connections Symbol Preliminary and subject to change without notice Top View Pinout www.telcodium.com ©2017 TELCODIUM INC. 5 P O W E R S U P P LY T E C H N O L O G Y RoHS COMPLIANCE The EU led RoHS (Restriction of Hazardous Substances) Directive bans the use of Lead, Cadmium, Hexavalent Chromium, Mercury, Polybrominated Biphenyls (PBB), and Polybrominated Diphenyl Ether (PBDE) in Electrical and Electronic Equipment. Telcodium product is 6/6 RoHS compliant. For more information please refer to the Telcodium website RoHS addendum. Preliminary and subject to change without notice www.telcodium.com ©2017 TELCODIUM INC. 6 P O W E R S U P P LY T E C H N O L O G Y HEADQUARTERS TELCODIUM INC. 91 De la Barre, Boucherville, Quebec Canada J4B 2X6 Telephone: 1 450-274-6170 info@telcodium.com www.telcodium.com High-Efficiency Power Modules AC Power Supplies DC Power Supplies Telcodium logos are trademarks and service marks of Telcodium Inc. ©2017 TELCODIUM INC. 7
TD-PFC-500 价格&库存
很抱歉,暂时无法提供与“TD-PFC-500”相匹配的价格&库存,您可以联系我们找货
