Additional Resources:
Product Page
rev.
co
leakage current
04/2010
ue
power
max.
19.8 W
30 W
30 W
30 W
30 W
in
output
voltage
3.3V @ 6.0A
5V @ 6.0A
12V @ 2.5A
15V @ 2.0A
24V @ 1.25A
conditions/description
min
47
85
110
nom
(50~60)
min
-2%
-3%
-1%
-1%
-1%
-3%
-1%
nom
AC input of 110 VAC
AC input of 220 VAC
measured at 110 VAC at full load, cold start
measured at 220 VAC at full load, cold start
measured at 110 VAC
measured at 220 VAC
is
inrush current
input
voltage
85-264V / DC 110-340V
nt
AC
AC
AC
AC
AC
INPUT
input current
date
date
d
features
·encapsulated compact case
·high efficiency
·universal input
·board mounting technology
·built in EMI filter
·100kHz fixed frequency
·fixed output voltage
·thermal shutdown
·short circuit protection
·low output ripple and noise
·isolated output
·2 year warranty
parameter
input frequency
input voltage
1 of 3
DESCRIPTION: ac-dc converter
SERIES: FSK-S30
model
number
FSK-S30-3R3U
FSK-S30-5U
FSK-S30-12U
FSK-S30-15U
FSK-S30-24U
page
page
ripple & noise
max.
80 mVp-p
80 mVp-p
120 mVp-p
150 mVp-p
200 mVp-p
max
440
264
340
0.49
0.25
30
60
0.5
0.75
efficiency
68
78
83
83
86
units
Hz
VAC
VDC
A
A
A
A
mA
mA
OUTPUT
D
parameter
voltage tolerance
ripple and noise
line regulation
load regulation
dynamic load regulation
temperature drift
rise time
hold-up time
10
max
units
+2% (single and uncomplimentary dual)
+3% (complementary dual)
+1%
+1%
+1%
+3%
+1%
400
ms
ms
20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383
www.v-infinity.com
Additional Resources: Product Page
rev.
page
2 of 3
date
04/2010
SERIES: FSK-S30
PROTECTION CIRCUIT
works at over 105% of the rating and recovers automatically.
145 ºC
GENERAL
min
-10
-20
20%
20%
nom
max
60
70
90%
90%
units
ºC
ºC
RH
RH
ue
parameter
operating temp.
storage temp.
operating humid.
storage humid.
isolation voltage
(HI-POT)
vibration
impact
MTBF
RoHS
safety
warranty
d
parameter
output over current
over temperature
D
is
co
DERATING CURVE
nt
in
non-condensing
non-condensing
applied for 1 minute, 10mA
primary to secondary, 500 Vdc @ 100 MΩ
3000
VAC
at 10G 3 minute period
10
55
Hz
50G for 11mS, once on each X, Y, Z axis
3.0 x 10 5
hours
yes
approved to UL60950(E222889), CSA C22.2 NO.60950, CE(EN60950) - through tuv
standard warranty length
2
years
EXTERNAL EMI FILTER
L
L
C1
224MK P
+V
LOAD
S MP S
N
N
LF 1
-V
LF 2
FG
FG
jXGdGYYWmGVGY^\}SGYGjG
smXGdGYWoGjGtGsGmSG{GG ɐX[UW͑
smYGdGYWoGjGtGsGmSG{GG ɐX[UW͑
www.v-infinity.com
Product Page
53 2.087
21.5 0.846
5 0.197
84 3.307
5 0.197
11 0.433
5 0.197
16 0.630
4
2
IN
OUT
1
1 [0.039]
8 PLCS
6.3 0.248
(TYP)
on
3
16 0.630
6
8
RoHS
16 0.630
32 1.260
D
FSK-S30
COPYRIGHT
2008 BY CUI INC.
TOLERANCE:
±0.3mm UNLESS OTHERWISE
SPECIFIED
5 0.197
is
c
5 0.197
PC FILE NAME:
DATE
9/11/2006
11/24/2008
tin
ue
94 3.701
DESCRIPTION
NEW DRAWING
corrected pin 5 and 7 output assignments
d
REV.
A
B
Notes:
1. All dimensions are in mm [inches]
2. Weight: 200g or less
PIN ASSIGNMENTS
Single Output
Pin Number
1
FG
2
3
4
5
AC (N)
AC (L)
No Connect
No Pin
6
7
8
No Pin
-Vout
+Vout
20050 SW 112th Ave.
Tualatin, OR 97062
Phone: 503-612-2300
800-275-4899
Fax: 503-612-2383
Website: www.cui.com
TITLE:
REV:
AC-DC Converter
PART NO.
FSK-S30
DRAWN BY:
JMS
B
UNITS:
MM [INCHES]
APPROVED BY:
SCALE:
1:2
很抱歉,暂时无法提供与“FSK-S30-12U”相匹配的价格&库存,您可以联系我们找货
