Additional Resources:
Product Page
rev.
page
page
1 of 3
date
date
04/2010
DESCRIPTION: AC-DC converter
SERIES: FSK-S5
INPUT
input current
power
max.
4.125 W
5.0 W
5.0 W
5.0 W
5.0 W
ripple & noise
max.
80 mVp-p
80 mVp-p
120 mVp-p
150 mVp-p
200 mVp-p
min
47
85
110
nom
(50~60)
max
440
264
340
150
80
0.5
0.75
units
Hz
VAC
VDC
mA
mA
A
A
mA
mA
output power derated from 85-90 VAC
min
-2%
-1%
-1%
-1%
-3%
-1%
nom
max
+2%
+1%
+1%
+1%
+3%
+1%
100
units
AC input of 110 VAC
AC input of 220 VAC
measured at 110 VAC at full load, cold start
measured at 220 VAC at full load, cold start
measured at 110 VAC
measured at 220 VAC
is
inrush current
conditions/description
co
parameter
input frequency
input voltage
output
voltage
3.3V @ 1.25A
5V @ 1.0A
12V @ 0.42A
15V @ 0.33A
24V @ 0.21A
in
AC
AC
AC
AC
AC
input
voltage
85-264V / DC 110-340V
nt
model
number
FSK-S5-3R3U
FSK-S5-5U
FSK-S5-12U
FSK-S5-15U
FSK-S5-24U
ue
• approved to UL60950, CSA C22.2 NO.60950,
CB(IEC 60950), CE(EN60950)
• universal input 85~264 Vac/ 110~340 VDC
• encapsulated, compact case
• high efficiency
• surface mounting technology
• 100kHz fixed frequency
• fixed output voltage
• thermal shutdown
• output short circuit protection
• low output ripple and noise
• isolated output
• 2 year warranty
d
features
leakage current
efficiency
71
75
77
77
77
D
OUTPUT
parameter
voltage tolerance
ripple and noise
line regulation
load regulation
dynamic load regulation
temperature drift
rise time
hold-up time
10
20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383
mS
mS
www.v-infinity.com
Product Page
rev.
page
2 of 3
date
04/2010
SERIES: FSK-S5
PROTECTION CIRCUIT
works at over 105% of the rating and recovers automatically.
150 ºC
clamp, 130~150%
GENERAL
note:
min
-20
-40
20%
20%
nom
max
70
80
90%
90%
units
ºC
ºC
RH
RH
ue
in
non-condensing
non-condensing
applied for 1 minute, 10mA
primary to secondary, 500 Vdc @ 100 MΩ
3000
VAC
at 10G 3 minute period
10
55
Hz
50G for 11mS, once on each X, Y, Z axis
4.5 x 10 5
hours
yes
approved to UL60950-1(E222889), CSA C22.2 NO.60950, CB(IEC 60950-1), CE(EN60950)
5W, 10W single output: approved; EN61204-3 class B, EN 6100-3-3 (through TUV)
standard warranty length
2
years
nt
parameter
operating temp.
storage temp.
operating humid.
storage humid.
isolation voltage
(HI-POT)
vibration
impact
MTBF
RoHS
safety
EMC 1
warranty
d
parameter
output over current
over temperature
over voltage
1. to meet the standard of EN61204-3 class B, use the external noise filter between L and N
EXTERNAL EMI FILTER
D
is
co
DERATING CURVE
www.v-infinity.com
Product Page
DESCRIPTION
NEW DRAWING
added pin diameter dimension
DATE
9/13/2007
6/27/2008
50.8 2.000
tin
ue
d
REV.
A
B
R0.30 0.012
(TYP)
15.24 0.600
25.40 1.000
B
1.00 0.039
(4 PLCS)
2
IN
20.32 0.800
5.08 0.200
(4 PLCS)
on
45.72 1.800
OUT
4
10.16 0.400
TOLERANCE:
±0.3mm UNLESS OTHERWISE
SPECIFIED
is
c
D
PC FILE NAME:
FSK-S5
RoHS
5
1
COPYRIGHT 2008 BY CUI INC.
PIN ASSIGNMENTS
Single Output
Pin Number
1
AC (N)
Notes:
1. All dimensions are in mm [inches]
2. Weight: 40g or less
3. Case material : PBT, UL94V-0
4. Construction: Encapsulated soft pot
2
3
4
5
AC (L)
NO pin
-V out
+V out
20050 SW 112th Ave.
Tualatin, OR 97062
Phone: 503-612-2300
800-275-4899
Fax: 503-612-2383
Website: www.cui.com
TITLE:
REV:
AC-DC Converter
PART NO.
FSK-S5
DRAWN BY:
JMS
B
UNITS:
MM [INCHES]
APPROVED BY:
SCALE:
1:1
很抱歉,暂时无法提供与“FSK-S5-5U”相匹配的价格&库存,您可以联系我们找货
