Additional Resources:
Product Page
3D Model
date
06/24/2019
page
1 of 7
SERIES: V78-500 │ DESCRIPTION: NON-ISOLATED SWITCHING REGULATOR
FEATURES
0.5 A current output
extremely high efficiency up to 97%
no heat sink required
pin compatible to LM78XX linear regulators
available in straight and right angle SIP packages
low ripple and noise
short circuit protection, thermal shutdown
wide temperature (-40~85°C)
RoHS
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
and noise1
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
max
(mA)
max
(W)
max
(mVp-p)
Vin min
Vin max
V7801-500
12
4.75~26
1.5
500
0.75
35
76
66
V78X2-500*
12
4.75~28
1.8
500
0.9
35
79
67
V7802-500
12
4.75~28
2.5
500
1.25
35
85
73
V7803-500
24
4.75~28
3.3
500
1.65
35
90
80
V7805-500
24
6.5~32
5.0
500
2.5
35
93
84
V78X6-500
24
8~32
6.5
500
3.25
35
94
87
V7809-500
24
11~32
9.0
500
4.5
35
95
91
V7812-500
24
15~32
12
500
6
35
95
92
V7815-500
24
18~32
15
500
7.5
35
96
93
Notes:
1. ripple and noise are measured at 20 MHz BW
*. Discontinued model
PART NUMBER KEY
V78 XX - 500
Base Number
Output Voltage
cui.com
Output Current
Product Page
3D Model
CUI Inc │ SERIES: V78-500 │ DESCRIPTION: NON-ISOLATED SWITCHING REGULATOR
date 06/24/2019 │ page 2 of 7
INPUT
parameter
conditions/description
min
typ
max
units
operating input voltage
1.5 V output
1.8 V output
2.5 V output
3.3 V output
5 V output
6 V output
9 V output
12 V output
15 V output
4.75
4.75
4.75
4.75
6.5
8
11
15
18
12
12
12
24
24
24
24
24
24
26
28
28
28
32
32
32
32
32
Vdc
Vdc
Vdc
Vdc
Vdc
Vdc
Vdc
Vdc
Vdc
OUTPUT
parameter
typ
max
units
line regulation
Vin = min ~ max,
at full load
1.5~2.5 V models
3.3~15 V models
min
±0.5
±0.2
±1.0
±0.4
load regulation
measured from
10% load to full load
1.5~2.5 V models
3.3~15 V models
±0.4
±0.4
±0.75
±0.6
voltage accuracy
100% load
±2
±3
switching frequency
100% load, input voltage range
280
330
temperature coefficient
450
kHz
±0.02
%/°C
max
units
PROTECTIONS
parameter
continuous, automatic recovery
min
thermal shutdown
internal IC junction
typ
150
°C
SAFETY AND COMPLIANCE
parameter
min
MTBF
RoHS compliant
typ
max
2,000,000
units
hours
yes
ENVIRONMENTAL
parameter
max
units
operating temperature
min
-40
typ
85
°C
storage temperature
-55
125
°C
100
°C
case temperature
storage humidity
non-condensing
temperature rise
at full load
95
lead temperature
1.5 mm from case for 10 seconds
25
cui.com
°C
300
°C
Product Page
3D Model
date 06/24/2019 │ page 3 of 7
DERATING CURVES
1. output power vs. ambient temperature
100
Load (%)
80
60
40
-20
60
71
85
100
120
Ambient Temperature (°C)
MECHANICAL
parameter
dimensions
0.689 x 0.354 x 0.453 (11.50 x 9.00 x 17.50 mm)
min
case material
plastic (UL94-V0)
typ
max
inch
weight
2.0
g
MECHANICAL DRAWING
units: mm [inches]
tolerance: ±0.25 [±0.010]
pin section tolerance: ±0.10 mm [±0.004]
Front View
Side View
Bottom View
PIN CONNECTIONS
cui.com
units
PIN
FUNCTION
1
+Vin
2
GND
3
+Vo
Product Page
3D Model
date 06/24/2019 │ page 4 of 7
TYPICAL APPLICATION CIRCUIT
1. C1 and C2 are required and should be fitted close to the converter pins
2. For the capatance of C1 and C2, see the external capacitor table. Low ESR types should be chosen
3. C3: a low ESR capacitor is required to keep the noise at the converter to a minimum. Ceramic capacitors are preffered, but tantalum of
low ESR electrolytic capacitors may also suffice; General use 10μF/50V ceramic capacitor. C4 Optional, General use 100μF/25V
electrolytic capacitor.
4. No parallel connection or plug and play
TEST CIRCUIT
DC Power
Source
+Vin
Voltage
Meter
Electronic
Load
Current
Meter
Current
Meter
Cin
+Vout
DC/DC
Converter
GND
Cout
30cm, 18AWG A
Twisted
Voltage
Meter
B
20MHz
Oscilloscope
0V
A
1. Cin = 10µF / 50V for 500mA and 22µF / 50V for 1A, Cout = 100µF / 16V.
2. C01 = 10µF / 50V Electrolytic, C02 = 0.1µF / 50V Ceramic.
3. All points labeled A refer to one junction.
4. All points labeled B refer to one junction.
5. Use a short ground loop for probing. Do not use a wired ground clip.
cui.com
+ A
C01 +
C02
B
B
A
B
Product Page
3D Model
date 06/24/2019 │ page 5 of 7
EFFICIENCY AND RIPPLE
Output
Ripple
Efficiency
50
100
95
Efficiency (%)
V7803-500
V7805-500
85
80
V7806-500
V7809-500
75
70
V7812-500
65
Ripple (mVpp)
40
90
V7815-500
60
V7803-500
V7805-500
30
V7806-500
V7809-500
V7812-500
V7815-500
10
55
10
Vin(V)
Vin(V)
50
10
30 32
Efficiency vs. Vin (Full Load)
Ripple vs. Vin ( Full Load)
100
50
95
Efficiency (%)
85
V7803-500
V7805-500
80
V7806-500
V7809-500
75
V7812-500
V7815-500
Ripple (mVpp)
40
90
30
V7803-500
V7805-500
V7812-500
V7806-500
V7809-500
V7815-500
70
10
65
100
200
300
400
500
Output Current(mA)
Efficiency vs. Load (Vin=Vin_min)
100
600
200
300
400
500
600
Output Current (mA)
Ripple vs. Load (Vin=Vin_min)
100
50
90
Efficiency (%)
70
V7806-500
V7809-500
60
V7812-500
50
V7815-500
40
Ripple (mVpp)
V7803-500
V7805-500
80
40
V7803-500
V7805-500
30
V7806-500
V7809-500
V7812-500
V7815-500
10
30
200
300
400
500
Output Current (mA)
Efficiency vs. Load (Vin=Vin_max)
100
600
200
300
400
Output Current (mA)
Ripple vs. Load (Vin=24V)
cui.com
500
600
Product Page
3D Model
date 06/24/2019 │ page 6 of 7
EXTERNAL CAPACITOR TABLE
Part
C1,C3
C2,C4
Number
(Ceramic Capacitor)
(Ceramic Capacitor)
V7801-500
10 µF/50V
22 µF/6.3V
V78X2-500
10 µF/50V
22 µF/6.3V
V7802-500
10 µF/50V
22 µF/6.3V
V7803-500
10 µF/50V
22 µF/6.3V
V7805-500
10 µF/50V
22 µF/10V
V78X6-500
10 µF/50V
10 µF/10V
V7809-500
10 µF/50V
10 µF/16V
V7812-500
10 µF/50V
10 µF/25V
V7815-500
10 µF/50V
10 µF/25V
cui.com
Product Page
3D Model
date 06/24/2019 │ page 7 of 7
REVISION HISTORY
rev.
description
date
1.0
initial release
07/13/2010
1.01
new template applied
04/18/2012
1.02
V-Infinity branding removed
09/04/2012
1.03
updated typical application circuits
09/25/2012
1.04
updated external capacitor values
11/08/2012
1.05
discontinued V78X2-500 model
06/24/2019
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a two (2) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical
component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to
affect its safety or effectiveness.
很抱歉,暂时无法提供与“V7812-500”相匹配的价格&库存,您可以联系我们找货
