EPM1510SJ
EPM1510SJ
    TAMURA
    模块
    DC/DC CONVERTER 15V 1A 15W
EPM1510SJ 数据手册
EPM1510SJ ■Input-output condition Item Specification Input voltage range DC110~450V Rated input voltage DC140V, DC340V Rated output voltage 15V Rated load current   1A ■Electrical specification  Ta=25℃ Item Specification Conditions・Note Efficiency More than 80% Rated input voltage Rated output current Output voltage tolerance ±5% Line regulation Less than 100mV Input voltage DC110V~450V Load regulation Less than 250mV Output current 0~1A No-load power Less than 80mW Rated input voltage Ripple Less than 150mVp-p Ripple noise Less than 200mVp-p Rated input voltage Rated output current Measurement circuit Module N.C. 14 Drain 12 +DC IN E1 SecW 4 N.C. W1 C101 N.C. 11 Vcc V1 L201 +DC OUT 5 150mm 10 -DC IN C202 N.C. 6 N.C. N.C. 9 VccW N.C. 8 FB C201 C203 150mm P1 LM1 RL1 C204 -DC OUT 7 C102 E1 : DC power supply W1 : Wattmeter WT210 (YOKOGAWA) RL1: Electronic load V1 : Voltmeter Class 0.5 P1 : Differential probe DP-100(KG) LM1: Ripple noize meter RM-103(KG) C101 C102 C201 C202 C203 C204 L201 : : : : : : : TAMURA CORPORATION 1/6 450BXC33M (RUBYCON) CD85-E2GA102M (TDK) 25ZLG330M (RUBYCON) 25ZLG330M (RUBYCON) 25ZLG47M (RUBYCON) 50F2D104K (RUBYCON) PJ5H-2R2M (KORIN ) Rev.A Aug, 2012 EPM1510SJ ■Protection Item Specification Conditions・Note Overcurrent protection More than 1.3A Auto recovery Overvoltage protection 16.5~22V Latch off Overheat protection Latch off ■Insulation Item Specification Conditions・Note Insulation voltage (Between Pri-Sec) 3.0kV (or 3.6kV) AC 1min (or AC 2sec) Cutoff 2mA Insulation resistance (Between Pri-Sec) More than 100MΩ DC500V Specification Conditions・Note Operation temperature -20℃~80℃ Stand for ambient temperature derating Operating humidity 20~95%RH (No condensation) -25℃~85℃ ■Environmental conditions Item Storage temperature Storage humidit 5~95%RH (No condensation) ■Ambient temperature derating curve Reduce the load current according to the following temperature derating table. 100 負荷率 Load factor (%) 負荷率(%) 80 60 40 20 0 -20 -10 0 10 20 30 40 50 60 70 80 周囲温度(℃) 周囲温度 Ambient temperature (℃) TAMURA CORPORATION 2/6 Rev.A Aug, 2012 EPM1510SJ ■Typical characteristics Ta=25℃ Input power (at no load) Efficiency 100 80 90 70 70 Input Power [mW] Efficiency [%] 80 DC140V 60 DC340V 50 40 30 60 50 40 30 20 20 10 10 0 0 0 100 200 300 400 500 600 700 800 900 1000 100 150 200 Output Current [mA] 300 350 400 450 Input Voltage VDC [V] Input power (at light load) Load regulation 16.0 1.0 15.5 DC140V 0.9 DC340V 0.8 Input Power [W] Output Voltage [V] 250 15.0 14.5 0.7 0.6 0.5 0.4 DC140V 0.3 DC340V 0.2 0.1 0.0 14.0 0 100 200 300 400 500 600 700 800 900 1000 0 5 10 15 20 25 30 35 40 45 50 Output Current [mA] Output Current [mA] Line regulation 16.0 No load (0A) Rated load (1A) Output Voltage [V] 15.5 15.0 14.5 14.0 100 150 200 250 300 350 400 450 Input Voltage VDC [V] TAMURA CORPORATION 3/6 Rev.A Aug, 2012 EPM1510SJ ■Outline dimensional drawing Unit:mm TAMURA CORPORATION 4/6 Rev.A Aug, 2012 EPM1510SJ ■Recommended hole diameter and land size ※ The round pulling out figure is a pin numbering. Unit:mm Component side ■Terminal function and connection Secondaries Pin No. Name Explanation of terminals No terminal 1 No terminal 2 No terminal 3 4 SecW 5 +DC OUT 6 N.C. 7 -DC OUT Non-contact terminal ※Don't connect with other circuits. Output terminal (+) Non-contact terminal ※Don't connect with other circuits. Output terminal (-) Primaries Pin No. Name 8 FB 9 VccW 10 -DC IN 11 Vcc 12 +DC IN Non-contact terminal ※Don't connect with other circuits. Non-contact terminal ※Don't connect with other circuits. DC voltage input terminal (-) Terminal for start-up time adjustment DC voltage input terminal (+) No terminal 13 14 Explanation of terminals Drain Terminal for noise adjustment TAMURA CORPORATION 5/6 Rev.A Aug, 2012 EPM1510SJ ■Application circuit example EPM module N.C. 14 Drain AC85V~AC276V (50/60Hz) F101 D101 L101 L 12 +DC IN SecW 4 N.C. C102 C101 N.C. 11 Vcc L201 +DC OUT 5 +DC OUT 10 -DC IN N N.C. N.C. 9 6 N.C. C201 VccW -DC OUT 7 8 N.C. C202 -DC OUT FB C103 Symbol Description Part No. Manufacturer D101 Diode D2SB60 SHINDENGEN L101 L201 Inductor Inductor LF-4Z-E363H PJ5H-2R2M KORIN KORIN C101 C102 C103 C201 C202 Capacitor Capacitor Capacitor Capacitor Capacitor LE104-MX 450BXC33M CD85-E2GA102M 25ZLG330M 25ZLG330M OKAYA RUBYCON TDK RUBYCON RUBYCON F101 Fuse FCT 250V 1.6A NIPPON-SEISEN TAMURA CORPORATION 6/6 Rev.A Aug, 2012
EPM1510SJ 价格&库存
很抱歉,暂时无法提供与“EPM1510SJ”相匹配的价格&库存,您可以联系我们找货
