Additional Resources:
Product Page
3D Model
PCB Footprint
date
11/11/2022
page
1 of 8
SERIES: PES1-M │ DESCRIPTION: DC-DC CONVERTER
FEATURES
1 W isolated output
smaller package
single/dual unregulated outputs
3,000 Vdc isolation
short circuit protection
extended temperature range (-40~105°C)
antistatic protection up to 8kV
high efficiency at light load
efficiency up to 82%
designed to meet EN/BS EN 62368-1
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
and noise2
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
typ
(mVp-p)
typ
PES1-S3-S3-M
3.3
2.97~3.63
3.3
30
303
1
60
69
PES1-S3-S5-M
3.3
2.97~3.63
5
1
60
74
PES1-S5-S3-M1
5
4.5~5.5
3.3
30
303
1
60
72
1
PES1-S5-S5-M
5
4.5~5.5
5
1
60
80
PES1-S5-S9-M1
5
4.5~5.5
9
12
111
1
60
80
1
PES1-S5-S12-M
5
4.5~5.5
12
9
84
1
60
80
PES1-S5-S15-M1
5
4.5~5.5
15
7
67
1
60
80
PES1-S5-S24-M
5
4.5~5.5
24
4
42
1
60
80
PES1-S5-D5-M
5
4.5~5.5
±5
±10
±100
1
60
80
PES1-S5-D9-M
5
4.5~5.5
±9
±6
±56
1
60
80
PES1-S5-D12-M
5
4.5~5.5
±12
±5
±42
1
60
79
PES1-S5-D15-M
5
4.5~5.5
±15
±3
±33
1
60
81
PES1-S5-D24-M
5
4.5~5.5
±24
±2
±21
1
60
81
1
PES1-S12-S3-M
12
10.8~13.2
3.3
30
303
1
60
72
PES1-S12-S5-M1
12
10.8~13.2
5
1
60
71
1
1
PES1-S12-S9-M
12
10.8~13.2
9
12
111
1
60
80
1
PES1-S12-S12-M
12
10.8~13.2
12
9
84
1
60
80
PES1-S12-S15-M1
12
10.8~13.2
15
7
67
1
60
80
PES1-S12-D5-M
12
10.8~13.2
±5
±10
±100
1
60
80
PES1-S12-D9-M
12
10.8~13.2
±9
±6
±56
1
60
80
PES1-S12-D12-M
12
10.8~13.2
±12
±5
±42
1
60
73
PES1-S12-D15-M
12
10.8~13.2
±15
±3
±33
1
60
81
PES1-S12-D24-M
12
10.8~13.2
±24
±2
±21
1
60
81
PES1-S15-S15-M
15
13.5~16.5
15
7
67
1
60
80
1
PES1-S24-S5-M
24
21.6~26.4
5
1
60
73
PES1-S24-S9-M1
24
21.6~26.4
9
12
111
1
60
80
24
21.6~26.4
15
7
67
1
60
72
1
PES1-S24-S15-M
1
Notes:
1. UL approved
2. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 μF ceramic and 10 μF electrolytic capacitors on the output.
cui.com
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: PES1-M │ DESCRIPTION: DC-DC CONVERTER
MODEL
(CONTINUED)
input
voltage
date 11/11/2022 │ page 2 of 8
output
voltage
output
current
ripple
and noise2
efficiency
max
(mA)
max
(W)
typ
(mVp-p)
typ
typ
(Vdc)
range
(Vdc)
PES1-S24-S24-M1
24
21.6~26.4
24
4
42
1
60
80
PES1-S24-D5-M
24
21.6~26.4
±5
±10
±100
1
60
70
PES1-S24-D9-M
24
21.6~26.4
±9
±6
±56
1
60
80
PES1-S24-D12-M
24
21.6~26.4
±12
±5
±42
1
60
72
PES1-S24-D15-M
24
21.6~26.4
±15
±3
±33
1
60
71
PES1-S24-D24-M
24
21.6~26.4
±24
±2
±21
1
60
76
Notes:
min
(mA)
output
power
(Vdc)
1. UL approved
PART NUMBER KEY
PES1 - SXX - XXX - M - X
Base Number
Input Voltage
Output
S = single
D = dual
Output Voltage
Packaging Style
"blank" = tube
TR = tape & reel
INPUT
parameter
conditions/description
min
typ
max
units
operating input voltage
3.3 Vdc input models
5 Vdc input models
12 Vdc input models
15 Vdc input models
24 Vdc input models
2.97
4.5
10.8
13.5
21.6
3.3
5
12
15
24
3.63
5.5
13.2
16.5
26.4
Vdc
Vdc
Vdc
Vdc
Vdc
surge voltage
for maximum of 1 second
5 Vdc input models
12 Vdc input models
15 Vdc input models
24 Vdc input models
-0.7
-0.7
-0.7
-0.7
-0.7
5
9
18
21
30
Vdc
Vdc
Vdc
Vdc
Vdc
filter
capacitance filter
max
units
±1.5
±1.2
OUTPUT
parameter
line regulation
for Vin change of 1%
3.3 Vdc output models
all other models
min
load regulation
measured from 10% load to full load
5 Vdc output models
9 Vdc output models
12 Vdc output models
15 Vdc output models
24 Vdc output models
voltage accuracy
see tolerance envelope curve
switching frequency
100% load, nominal input voltage
temperature coefficient
100% load
typ
18
12
9
8
7
6
100
kHz
±0.03
cui.com
%/°C
Product Page
3D Model
PCB Footprint
date 11/11/2022 │ page 3 of 8
PROTECTIONS
parameter
PES1-S5-S24-M, PES1-S5-D24-M and all 24 V
input models1
all other models: continuous, automatic recovery
Note:
min
typ
max
units
1
s
max
units
1. If maximum protection time is exceeded input power must me cycled to restart device.
SAFETY AND COMPLIANCE
parameter
isolation voltage
input to output for 1 minute at 1 mA max.
3,000
Vdc
isolation resistance
input to output at 500 Vdc
1,000
MΩ
safety approvals2
certified to 60950-1: UL
designed to meet 62368: EN/BS EN
conducted emissions
CISPR22/EN55022 class B (external circuit required, see Figure 1)
radiated emissions
ESD
IEC/EN61000-4-2, class B, contact ± 8kV for single outputs
IEC/EN61000-4-2, class B, contact ± 6kV for dual outputs
MTBF
as per MIL-HDBK-217F @ 25°C
RoHS
2011/65/EU
Note:
min
typ
3,500,000
hours
2. See specific models noted on page 1 & 2.
ENVIRONMENTAL
parameter
min
operating temperature
see derating curve
storage temperature
storage humidity
non-condensing
temperature rise
at full load, Ta = 25°C
typ
max
units
-40
105
°C
-55
125
°C
95
25
°C
SOLDERABILITY
parameter
max
units
hand soldering
1.5 mm from case for 10 seconds
min
300
°C
reflow soldering
see reflow soldering profile
245
°C
cui.com
typ
Product Page
3D Model
PCB Footprint
date 11/11/2022 │ page 4 of 8
MECHANICAL
parameter
dimensions
single output models: 12.70 x 8.30 x 7.25
dual output models: 15.24 x 8.30 x 7.25
min
case material
epoxy resin (UL94-V0)
weight
dual output models
typ
max
units
mm
mm
1.6
2.0
g
g
MECHANICAL DRAWING
SINGLE OUTPUT MODELS
rArC
units: mm[inch]
tolerance: ±0.25[±0.010]
pin section tolerance: ±0.10[±0.004]
2
Vin
4
0V
5
+Vo
8
NC
AC
GND
d
q
1
AC
Function
AC
AC
:UV
很抱歉,暂时无法提供与“PES1-S12-S12-M-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+44.41213500+5.37472
- 国内价格 香港价格
- 1+55.492381+6.71564
- 5+54.714745+6.62153
- 10+53.9308810+6.52667
- 25+52.3411725+6.33428
- 50+50.7564550+6.14250
