Additional Resources:
Product Page
3D Model
PCB Footprint
date
11/03/2022
page
1 of 9
SERIES: PCN1-M │ DESCRIPTION: DC-DC CONVERTER
FEATURES
up to 1 W isolated output
industry standard surface mount package
nominal input voltages: 5, 12 Vdc
single/dual unregulated output
1,500 Vdc isolation voltage
low ripple and noise
-40 to 100°C
efficiency up to 81%
meets EN 62368-1
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
& noise1
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
max
(mVp-p)
typ
PCN1-S5-S5-M
5
4.5~5.5
5
1
75
79
PCN1-S5-S12-M
5
4.5~5.5
12
1
75
79
PCN1-S5-S15-M
5
4.5~5.5
15
1
75
79
PCN1-S5-D5-M
5
4.5~5.5
±5
±100
1
75
74
PCN1-S5-D12-M
5
4.5~5.5
±12
±42
1
75
78
PCN1-S5-D15-M
5
4.5~5.5
±15
±33
1
75
78
PCN1-S12-S5-M
12
10.8~13.2
5
1
75
80
PCN1-S12-S12-M
12
10.8~13.2
12
1
75
81
PCN1-S12-S15-M
12
10.8~13.2
15
1
75
81
PCN1-S12-D5-M
12
10.8~13.2
±5
±100
1
75
77
PCN1-S12-D12-M
12
10.8~13.2
±12
±42
1
75
80
PCN1-S12-D15-M
12
10.8~13.2
±15
±33
1
75
81
Notes:
1. At full load, nominal input, 20 MHz bandwidth oscilloscope, with a 0.33 µF ceramic capacitor on the output.
2. Required to add a 2.2 µF ceramic capacitor to the input to reduce input voltage stress.
3. All specifications are measured at Ta=25°C, nominal input voltage, and rated output load unless otherwise specified.
PART NUMBER KEY
PCN1 - SXX - X XX - M - X
Base Number
Input Voltage
Output
S = single
D = dual
cui.com
Output Voltage
Packaging Style:
SMT
Package options
TR = Tape & Reel
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: PCN1-M │ DESCRIPTION: DC-DC CONVERTER
date 11/03/2022 │ page 2 of 9
INPUT
parameter
conditions/description
min
typ
max
units
operating input voltage
5 Vdc input models
12 Vdc input models
4.5
10.8
5
12
5.5
13.2
Vdc
Vdc
surge voltage
for maximum of 100 ms
5 Vdc input models
12 Vdc input models
9
18
Vdc
Vdc
current
5 Vdc input models
12 Vdc input models
filter
capacitive
250
110
mA
mA
input reverse polarity protection no
input fuse
Notes:
0.5 A time delay fuse for all models (recommended)
1. Required to add a 2.2 µF ceramic capacitor to the input to reduce input voltage stress.
OUTPUT
parameter
maximum capacitive load
single output models
dual output models
min
typ
voltage accuracy
max
units
220
100
μF
μF
±3.0
line regulation
1.0% change in input voltage
±1.2
load regulation
from 20% load to full load
±10
switching frequency
at nominal Vin, full load
±0.05
%/°C
max
units
1
s
max
units
100
temperature coefficient
kHz
PROTECTIONS
parameter
short circuit protection
momentary
min
typ
SAFETY AND COMPLIANCE
parameter
min
typ
isolation voltage
input to output for 1 minute
1,500
Vdc
isolation resistance
input to output
1,000
MΩ
isolation capacitance
input to output
safety approvals
meets 62368: EN
conducted emissions
EN 55022 Class B (external circuit required, see Figure 4)
MTBF
as per MIL-HDBK-217F, full load, GB, 25°C
RoHS
2011/65/EU
10
pF
1,500,000
hours
ENVIRONMENTAL
parameter
min
operating temperature
see derating curve
storage temperature
operating humidity
non-condensing
cui.com
typ
max
units
-40
100
°C
-55
125
°C
95
Product Page
3D Model
PCB Footprint
date 11/03/2022 │ page 3 of 9
SOLDERABILITY
parameter
reflow soldering
see reflow solder profile
min
typ
max
units
245
°C
300
Notes:
1.
2.
3.
4.
5.
6.
Temperature (ºC)
250
Soldering paste: SHENMAO PF610-P (Sn/Ag/Cu)
Ramp up rate during preheat: 1.79°C/second (from 30°C~155°C)
Soaking temperature: 0.33°C/second (from 155°C~185°C)
Ramp up rate during reflow: 0.71°C/second (from 220°C~245°C)
Peak temperature: 245°C (10 seconds max), above 220°C 40 to 70 seconds
Ramp up rate during cooling: -1.75°C/second (from 220°C~150)
200
150
100
50
100
150
200
250
300
Reflow Time (Seconds)
MECHANICAL
parameter
dimensions
single output models: 0.54 x 0.36 x 0.29 [13.7 x 9.2 x 7.4 mm]
dual output models: 0.64 x 0.36 x 0.29 [16.2 x 9.2 x 7.4 mm]
min
typ
case material
non-conductive black plastic
weight
dual output models
max
units
inches
inches
1.4
1.5
g
g
MECHANICAL DRAWING
Single output models
units: inches [mm]
tolerance: X.XX ±0.01 [±0.25]
X.XXX ±0.005 [±0.13]
pin section tolerance: ±0.002[±0.05]
0.300 [7.62]
Function
8
7
6
5
1
2
3
4
Single
1
-Vin
2
+Vin
3
No pin
4
-Vout
5
+Vout
6
No pin
7
No pin
8
NC
0.410 [10.41]
PIN
5-0.024(0.60)
0.090 [2.29]
PIN CONNECTIONS
0.300(7.62)
0.36(9.2)
0.12(3.0)
0.100(2.54)
0.100 [2.54]
0.050 [1.27]
Recommended PCB Layout
Top View
0.01(0.3)
0.29(7.4)
NC=no connection
0.39(9.8)
0.44(11.2)
0.54(13.7)
cui.com
Product Page
3D Model
PCB Footprint
date 11/03/2022 │ page 4 of 9
MECHANICAL DRAWING (CONTINUED)
Dual output models
units: inches [mm]
0.400 [10.16]
0.64(16.2)
PIN CONNECTIONS
2
+Vin
3
No pin
4
Common
5
-Vout
6
No pin
7
+Vout
8
No pin
9
No pin
10
NC
10 9 8 7 6
0.410 [10.41]
Dual
-Vin
1
2 3 4 5
0.090 [2.29]
1
Function
0.36(9.2)
PIN
6-0.024(0.60)
0.120(3.00)
0.300(7.60)
0.100(2.54)
0.400(10.2)
0.100 [2.54] 0.050 [1.27]
Top View
0.29(7.4)
0.01(0.3)
NC=no connection
0.39(9.8)
0.44(11.2)
DERATING CURVE
cui.com
Product Page
3D Model
PCB Footprint
date 11/03/2022 │ page 5 of 9
EFFICIENCY CURVES
cui.com
Product Page
3D Model
PCB Footprint
date 11/03/2022 │ page 6 of 9
EFFICIENCY CURVES (CONTINUED)
cui.com
Product Page
3D Model
PCB Footprint
date 11/03/2022 │ page 7 of 9
PACKAGING (TUBE)
units: mm
Tube Size: 14 x 14 x 535 mm
Single Output Models QTY: 36 pcs per tube
Dual Output Models QTY: 30 pcs per tube
PACKAGING (TAPE & REEL)
14.00
0.40
8.80
1.00
FEED DIRECTION
11.71
Dual output models
units: mm
16.00
2.00
11.50
Reel Size: Ø13”
QTY: 430 pcs per reel
1.50
1.75
4.00
11.72
FEED DIRECTION
0.40
8.60
0.80
16.50
1.50
16.00
24.00
2.00
11.50
4.00
24.00
Reel Size: Ø13”
1.75
units: mm
cui.com
Product Page
3D Model
PCB Footprint
date 11/03/2022 │ page 8 of 9
TEST CONFIGURATIONS
Input Ripple Current & Output Noise
Figure 1
Measuring Input Ripple Current
Figure 2
Measuring Output Ripple & Noise for
Table 1
L1
12 µH
C1
2.2 µF tantalum capacitor
C2
NC
Figure 3
Dual Output Models
Table 2
Input
Voltage
(Vdc)
Cin
5
12
EMC RECOMMENDED CIRCUIT
Test Condition
Input Voltage: Nominal
Output Load: Full Load
Figure 4
Conducted Emissions Test Circuit
Table 3
EN55022 Class B
Recommended External Circuit Components
Input
Voltage
(Vdc)
C11
C21
L1
5
4.7 µF / 25 V
4.7 µF / 25 V
10 µH
12
4.7 µF / 25 V
4.7 µF / 25 V
10 µH
Notes:
1. Ceramic Capacitor
cui.com
Product Page
3D Model
PCB Footprint
date 11/03/2022 │ page 9 of 9
REVISION HISTORY
rev.
description
date
1.0
initial release
07/26/2016
1.01
added tube packaging option
06/09/2017
1.02
removed tube packaging option
02/14/2020
1.03
safeties updated
05/26/2021
1.04
derating curve, efficiency curves and circuit figures updated
07/01/2021
1.05
CE certification updated
11/03/2022
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a two (2) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
很抱歉,暂时无法提供与“PCN1-S12-S12-M-TR”相匹配的价格&库存,您可以联系我们找货
