Additional Resources:
Product Page
3D Model
PCB Footprint
date
05/26/2022
page
1 of 10
SERIES: PDQ2-S │ DESCRIPTION: DC-DC CONVERTER
FEATURES
up to 2 W isolated output
industry standard SIP-8 package
nominal input voltages: 5, 12, 24, 48 Vdc
2:1 input range
single/dual regulated output
1,500 Vdc isolation voltage
remote on/off control
-40 to 100°C
efficiency up to 84%
EN 62368
designed to meet UL 62368
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
& noise1
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
max
(mVp-p)
typ
PDQ2-D5-S3-S
5
4.5~9
3.3
1.65
75
73
PDQ2-D5-S5-S
5
4.5~9
5
2
75
76
PDQ2-D5-S12-S
5
4.5~9
12
2
75
80
PDQ2-D5-S15-S
5
4.5~9
15
2
75
80
PDQ2-D5-D5-S
5
4.5~9
±5
±200
2
75
77
PDQ2-D5-D12-S
5
4.5~9
±12
±83
2
75
79
PDQ2-D5-D15-S
5
4.5~9
±15
±67
2
75
80
PDQ2-D12-S3-S
12
9~18
3.3
1.65
75
76
PDQ2-D12-S5-S
12
9~18
5
2
75
79
PDQ2-D12-S12-S
12
9~18
12
2
75
82
PDQ2-D12-S15-S
12
9~18
15
2
75
83
PDQ2-D12-D5-S
12
9~18
±5
±200
2
75
79
PDQ2-D12-D12-S
12
9~18
±12
±83
2
75
82
PDQ2-D12-D15-S
12
9~18
±15
±67
2
75
83
PDQ2-D24-S3-S
24
18~36
3.3
1.65
75
76
PDQ2-D24-S5-S
24
18~36
5
2
75
79
PDQ2-D24-S12-S
24
18~36
12
2
75
82
PDQ2-D24-S15-S
24
18~36
15
2
75
83
PDQ2-D24-D5-S
24
18~36
±5
±200
2
75
79
PDQ2-D24-D12-S
24
18~36
±12
±83
2
75
81
PDQ2-D24-D15-S
24
18~36
±15
±67
2
75
84
PDQ2-D48-S3-S
48
36~75
3.3
1.65
75
74
PDQ2-D48-S5-S
48
36~75
5
2
75
79
PDQ2-D48-S12-S
48
36~75
12
2
75
82
PDQ2-D48-S15-S
48
36~75
15
2
75
84
Notes:
1. At full load, nominal input, 20 MHz bandwidth oscilloscope.
2. All specifications are measured at Ta=25°C, nominal input voltage, and rated output load unless otherwise specified.
cui.com
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: PDQ2-S │ DESCRIPTION: DC-DC CONVERTER
MODEL
input
voltage
typ
(Vdc)
range
(Vdc)
PDQ2-D48-D5-S
48
PDQ2-D48-D12-S
48
PDQ2-D48-D15-S
48
Notes:
date 05/26/2022 │ page 2 of 10
output
voltage
output
current
output
power
ripple
& noise1
efficiency
(Vdc)
min
(mA)
max
(mA)
max
(W)
max
(mVp-p)
typ
36~75
±5
±200
2
75
78
36~75
±12
±83
2
75
82
36~75
±15
±67
2
75
84
PART NUMBER KEY
PDQ2 - DXX - X XX - S
Base Number
Input Voltage
Packaging Style:
S = SIP
Output
S = single
D = dual
Output Voltage
INPUT
parameter
conditions/description
min
typ
max
units
operating input voltage
5 Vdc input models
12 Vdc input models
24 Vdc input models
48 Vdc input models
4.5
9
18
36
5
12
24
48
9
18
36
75
Vdc
Vdc
Vdc
Vdc
surge voltage
for maximum of 100 ms
5 Vdc input models
12 Vdc input models
24 Vdc input models
48 Vdc input models
15
25
50
100
Vdc
Vdc
Vdc
Vdc
current
5 Vdc input models
12 Vdc input models
24 Vdc input models
48 Vdc input models
580
280
140
70
5 Vdc input models, power up
5 Vdc input models, power down
under voltage shutdown
3
12 Vdc input models, power up
12 Vdc input models, power down
5.8
24 Vdc input models, power up
24 Vdc input models, power down
12
48 Vdc input models, power up
48 Vdc input models, power down
24
remote on/off3
turn on (
很抱歉,暂时无法提供与“PDQ2-D48-D12-S”相匹配的价格&库存,您可以联系我们找货
