PRD15-Q48-S5-P-D
PRD15-Q48-S5-P-D
    CUIDEVICES
    DC/DCCONVERTER5V15W
PRD15-Q48-S5-P-D 数据手册
Additional Resources: Product Page date 10/26/2020 page 1 of 14 SERIES: PRD15 Ϳ DESCRIPTION: DC-DC CONVERTER FEATURES MODEL ED U N • • • • • up to 15 W isolated output industry standard 1” x 1” package 4:1 input range low ripple & noise over voltage, over current, short circuit, and over temperature protections remote on/off control output trim -40 to 85°C temperature range efficiency up to 89% UL/cUL safety approval input voltage W\S (Vdc) 24 PRD15-Q24-S5 24 PRD15-Q24-S12 24 PRD15-Q24-S15 24 PRD15-Q48-S3 48 PRD15-Q48-S5 PRD15-Q48-S15 output power ripple & noise1 HϒFLHQF\ (Vdc) min (A) max (A) max (W) max (mVp-p) W\S (%) 9~36 3.3 0.45 4.5 14.85 90 89 9~36 5 0.3 3 15 125 87.3 9~36 12 0.13 1.3 15.6 150 84.5 9~36 15 0.11 1.1 16.5 175 85 18~75 3.3 0.5 5 16.5 90 88 48 18~75 5 0.3 3 15 95 86 48 18~75 12 0.13 1.3 15.6 120 85 48 18~75 15 0.11 1.1 16.5 120 85.3 O PRD15-Q48-S12 output current range (Vdc) N PRD15-Q24-S3 output voltage TI • • • • • 1RWHV $WIXOOORDGQRPLQDOLQSXW0+]EDQGZLGWKRVFLOORVFRSHLQSXWWHUPLQDWHGZLWKDNj)FDSDFLWRUIRU9GFLQSXWPRGHOVDQGDNj)FDSDFLWRUIRU9GFLQSXW PRGHOV2XWSXWWHUPLQDWHGZLWKNj)DQGNj)ORZ(65FDSDFLWRUV $OOVSHFL¿FDWLRQVDUHPHDVXUHGDW7D ƒ&QRPLQDOLQSXWYROWDJHDQGUDWHGRXWSXWORDGXQOHVVRWKHUZLVHVSHFL¿HG$OOPRGHOVDUHWHVWHGDQGVSHFL¿HGZLWKDNj) FDSDFLWRUIRU9GFLQSXWPRGHOVDQGDNj)FDSDFLWRUIRU9GFLQSXWPRGHOVRQWKHLQSXWDQGZLWKNj)DQGNj)ORZ(65FDSDFLWRUVRQWKHRXWSXW D IS C PART NUMBER KEY PRD15 - QXX - SXX - X - X - X Base Number ,QSXW9ROWDJH Output Voltage Packaging Style: ' ',3 0 607 5HPRWH2Q2ϑ&RQWURO 3 SRVLWLYHORJLF 1 QHJDWLYHORJLF cui.com Package Options: ³EODQN´ VWDQGDUG (through hole models only) 75 7DSH 5HHO  607PRGHOVRQO\ Additional Resources: Product Page CUI Inc Ϳ SERIES: PRD15 Ϳ DESCRIPTION: DC-DC CONVERTER date 10/26/2020 Ϳ page 2 of 14 INPUT conditions/description operating input voltage 24 Vdc input models 48 Vdc input models current 24 Vdc input models 48 Vdc input models start-up voltage 24 Vdc input models 48 Vdc input models under voltage shutdown PRD15-Q24-S3 PRD15-Q24-S5 PRD15-Q24-S12, PRD15-Q24-S15 PRD15-Q48-S15 all other models UHPRWHRQRϑ1 negative logic models ON (10~15 Vdc or open circuit) PRGHOV2)) a9GF models ON (-0.7~0.8 Vdc) Vdc Vdc 2.1 1.1 A A 16.7 Vdc Vdc 8.6 8.5 8.4 16.2 15.6 Vdc Vdc Vdc Vdc Vdc N TI recommended to add fuse: 4 A fast blow fuse for 24 Vdc input models 2 A fast blow fuse for 48 Vdc input models 1.5 A fast blow fuse for PRD15-Q48-S12 model input fuse 2Q2ϑFXUUHQWLVP$ OUTPUT conditions/description maximum capacitive load ORZ(65Ÿ PRD15-Q24-S3, S5, S12 & PRD15-Q48-S3 all other models line regulation units 1,000 470 Nj) Nj) PRD15-Q48-S3 PRD15-Q48-S12 all other models ±0.2 ±0.075 ±0.05 % % % PRD15-Q24-S3 PRD15-Q24-S5 PRD15-Q48-S3 PRD15-Q48-S5 all other models ±0.1 ±0.075 ±0.2 ±0.06 ±0.05 % % % % % 50 ms voltage accuracy min W\S O C load regulation max N parameter at 50% load ±1 IS start-up time units 36 75 PRGHOV2)) a9GFRURSHQFLUFXLW input reverse polarity protection no Notes: max 24 48 8.8 35'46LQGXFWDQFH¿OWHU DOORWKHUPRGHOVFDSDFLWDQFH¿OWHU ¿OWHU W\S 9 18 U positive logic min ED parameter % see application notes ±10 % switching frequency PRD15-Q24-S12, PRD15-Q24-S15 PRD15-Q48-S5 PRD15-Q48-S15 all other models 340 375 380 350 kHz kHz kHz kHz 50-75-50% load change to 1% Vout PRD15-Q24-S3, PRD15-Q24-S12 all other models 150 100 µs µs ±0.02 %/°C D adjustability2 dynamic load response WHPSHUDWXUHFRHϒFLHQW 1RWH )RULQSXWYROWDJH9GF35'46FDQRQO\EHWULPPHGGRZQ cui.com Additional Resources: Product Page CUI Inc Ϳ SERIES: PRD15 Ϳ DESCRIPTION: DC-DC CONVERTER date 10/26/2020 Ϳ page 3 of 14 PROTECTIONS over voltage protection auto restart PRD15-Q24-S3 PRD15-Q24-S5 PRD15-Q24-S12 PRD15-Q24-S15 PRD15-Q48-S3 PRD15-Q48-S5 PRD15-Q48-S12 PRD15-Q48-S15 over current protection current limiting, auto restart PRD15-Q24-S3 PRD15-Q24-S5 PRD15-Q24-S12 PRD15-Q24-S15 PRD15-Q48-S3 PRD15-Q48-S5 PRD15-Q48-S12 PRD15-Q48-S15 min current limiting, hiccup auto restart over temperature protection PRD15-Q48-S12 all other models TI N short circuit protection SAFETY AND COMPLIANCE parameter conditions/description isolation voltage input to output, basic insulation 24 Vdc input models 48 Vdc input models min N isolation resistance isolation capacitance PRD15-Q24-S5, PRD15-Q24-S15, PRD15-Q48-S3 all other models safety approvals 8/QG(GLWLRQ LVD (& &(PDUN O 1 DVSHU7HOFRUGLD650HWKRG&DVHJURXQG ¿[HGFRQGLWLRQV7SFERDUG ƒ&IXOOORDG natural air convection. 07%) RoHS max units 4.5 5.9 14.1 19.5 3.9 5.9 15 20 Vdc Vdc Vdc Vdc Vdc Vdc Vdc Vdc 6.0 4.6 2.0 1.6 7.2 4.5 1.8 1.7 A A A A A A A A 0.3 A 135 115 °C °C W\S max 2,000 2,250 units Vdc Vdc 10 0Ÿ 1,500 1,000 S) S) 2,000,000 hours (8 &(PDUNRQO\RQ9GFLQSXWPRGHOV C 1RWH W\S ED conditions/description U parameter ENVIRONMENTAL parameter conditions/description min max units see derating curves -40 85 °C -55 125 °C IS operating temperature D storage temperature cui.com W\S Additional Resources: Product Page CUI Inc Ϳ SERIES: PRD15 Ϳ DESCRIPTION: DC-DC CONVERTER date 10/26/2020 Ϳ page 4 of 14 SOLDERABILITY conditions/description wave soldering for Sn/Ag/Cu based solders (for through hole models): preheat temperature solder pot temperature solder dwell time UHÀRZVROGHULQJ UHÀRZVROGHUSUR¿OHEHORZLVVXLWDEOHIRU6$& type lead-free solders (for surface mount models) 260 min ramp at 1 °C/second across liquidus 160 d r 100 p 80 st ju ad 60 40 fo m ra p e ke p ak so es t ra if r de c se / 2 °C un m ra 20 1 2 3 4 5 6 260 °C 7 TI 0 °C °C s N 120 115 270 7 cooling rate 2-3 °C/second d on re ui q re units U 180 140 max TAL at 60 seconds (range 45-75 seconds) SAC305 liquidus at 219 °C 220 Temperature (°C) 245 optimal peak 245 ˚C, max peak 260 ˚C 240 W\S ED parameter Time (minutes) MECHANICAL conditions/description dimensions through hole: 1.10 x 0.96 x 0.33 [27.9 x 24.4 x 8.4 mm] surface mount: 1.10 x 0.96 x 0.33 [27.9 x 24.4 x 8.4 mm] min weight through hole mount models surface mount models D IS C O N parameter cui.com W\S max units inches inches 10 10.2 g g Additional Resources: Product Page CUI Inc Ϳ SERIES: PRD15 Ϳ DESCRIPTION: DC-DC CONVERTER date 10/26/2020 Ϳ page 5 of 14 MECHANICAL DRAWING (THROUGH HOLE) 3,1&211(&7,216 )XQFWLRQ 1 +Vin 2 -Vin 3 +Vout 4 output trim 5 -Vout 6 RQRϑFRQWURO 27.9 1.10 PIN #1 24.4 0.96 U 3,1 N TOP VIEW TI MOUNTING PLANE N 8.4 0.33 O SIDE VIEW CL 10.16 0.400 10.16 0.400 IS CL 10.16 0.400 RECOMMENDED PRI-SEC BARRIER .040±.002 .071 .002 SHOULDER 6X AT PINS 1-6 #6 .30 C #5 D ED units: inches [mm] tolerance: X.XX ±0.02 [0.5] X.XXX ±0.010 [0.25] #4 0.475 REF #2 #1 5.08 0.200 CL #3 0.41 0.15 TYP 0.58 20.32 0.800 BOTTOM VIEW cui.com 2.54 0.100 6.3 0.25 END VIEW Additional Resources: Product Page CUI Inc Ϳ SERIES: PRD15 Ϳ DESCRIPTION: DC-DC CONVERTER date 10/26/2020 Ϳ page 6 of 14 MECHANICAL DRAWING (SURFACE MOUNT) units: inches [mm] tolerance: X.XX ±0.02 [0.5] X.XXX ±0.010 [0.25] )XQFWLRQ 1 +Vin 2 -Vin 3 +Vout 4 output trim 5 -Vout 6 RQRϑFRQWURO 27.9 1.10 CL PIN #1 25.4 1.00 24.4 0.96 3 10.16 0.400 CL 2.54 0.100 1 10.16 0.400 4 2 U 3,1 ED 29.0 1.14 3,1&211(&7,216 5 TOP VIEW N 20.32 0.800 RECOMMENDED PCB LAYOUT TOP VIEW .093 TYP TI MOUNTING PLANE SIDE VIEW CL #6 N #5 10.16 0.400 0.33±.03 [8.4±0.8] #2 #4 #1 O 10.16 0.400 CL 2.54 0.100 CL #3 C 10.16 0.400 2.54 0.100 20.32 0.800 .093 0.13 REF BOTTOM VIEW D IS END VIEW cui.com 2.54 0.100 6 6X 2.60 ±0.25 .102 ±.010 Additional Resources: Product Page CUI Inc Ϳ SERIES: PRD15 Ϳ DESCRIPTION: DC-DC CONVERTER date 10/26/2020 Ϳ page 7 of 14 DERATING CURVES PRD15-Q48-S3 Derating Curves @ Sea Level 9LQ DLUÀRZIURPLQSXWWRRXWSXW 100 95 Natural Convection 0.5 m/s (100 LFM) 1.0 m/s (200 LFM) 1.5 m/s (300 LFM) 90 85 Load (%) Load (%) 100 ED PRD15-Q48-S3 Derating Curves @ Sea Level 9LQ DLUÀRZIURPLQSXWWRRXWSXW 80 Natural Convection 0.5 m/s (100 LFM) 1.0 m/s (200 LFM) 1.5 m/s (300 LFM) 2.0 m/s (400 LFM) 95 90 85 80 ~ ~ 0 -40 -20 0 20 60 70 80 85 90 -20 0 20 60 All other models, Derating Curves @ Sea Level 6HHFRQGLWLRQVLQ7DEOH TI 95 See Table 1 for conditions 90 85 N Load (%) 100 80 ~ ~ ~ ~ 0 -40 0 O -20 20 60 70 80 85 90 Ambient Temperature (°C) C Table 1 12/24 PRD15-Q24-S5 24 ,QSXWWRRXWSXW PV /)0 PRD15-Q24-S12 24 ,QSXWWRRXWSXW PV /)0 PRD15-Q24-S15 12/24 ,QSXWWRRXWSXW Natural Convection PRD15-Q48-S5 24/48 ,QSXWWRRXWSXW Natural Convection PRD15-Q48-S12 24/48 Pin 2 to Pin 1 Natural Convection PRD15-Q48-S15 24/48 ,QSXWWRRXWSXW Natural Convection Model Input (Vdc) 'LUHFWLRQRIDLUÀRZ $LUÀRZ PRD15-Q24-S3 ,QSXWWRRXWSXW Natural Convection D IS 70 Ambient Temperature (°C) N Ambient Temperature (°C) ~ ~ ~ ~ 0 -40 U ~ ~ cui.com 80 85 90 Additional Resources: Product Page CUI Inc Ϳ SERIES: PRD15 Ϳ DESCRIPTION: DC-DC CONVERTER date 10/26/2020 Ϳ page 8 of 14 EFFICIENCY CURVES 35'46(ϒFLHQF\&XUYH (I¿FLHQF\YV/LQH9ROWDJHDQG/RDG&XUUHQW#ƒ& 90 90 85 85 80 Vin = 36 V Vin = 24 V 70 Vin = 18 V Vin = 9 V 65 75 60 55 55 50 50 0.5 1 1.5 2 2.5 3 3.5 Vin = 48 V Vin = 18 V 65 60 0 Vin = 75 V 70 4 U 75 Efficiency (%) Efficiency (%) 80 ED 35'46(ϒFLHQF\&XUYH (I¿FLHQF\YV/LQH9ROWDJHDQG/RDG&XUUHQW#ƒ& 1 2 Load Current (Amps) 90 Vin = 36 V Vin = 18 V Vin = 9 V 20 10 0.25 0.5 0.75 1 O 30 N Efficiency (%) 70 40 100 90 80 70 60 50 40 30 20 10 0 1.25 1.5 1.75 Vin = 75 V Vin = 36 V Vin = 24 V Vin = 18 V N Efficiency (%) 80 50 2 5 35'46(ϒFLHQF\&XUYH (I¿FLHQF\YV/LQH9ROWDJHDQG/RDG&XUUHQW#ƒ& TI 100 Vin = 24 V 4 Load Current (Amps) 35'46(ϒFLHQF\&XUYH (I¿FLHQF\YV/LQH9ROWDJHDQG/RDG&XUUHQW#ƒ& 60 3 2.25 2.5 2.75 0 3 0.5 1 1.5 2 2.5 Load Current (Amps) D IS C Load Current (Amps) cui.com 3 Additional Resources: Product Page CUI Inc Ϳ SERIES: PRD15 Ϳ DESCRIPTION: DC-DC CONVERTER date 10/26/2020 Ϳ page 9 of 14 EFFICIENCY CURVES (CONTINUED) 35'46(ϒFLHQF\&XUYH (I¿FLHQF\YV/LQH9ROWDJHDQG/RDG&XUUHQW#ƒ& 35'46(ϒFLHQF\&XUYH (I¿FLHQF\YV/LQH9ROWDJHDQG/RDG&XUUHQW#ƒ& 90 90 80 84 Vin = 36 V Vin = 24 V Vin = 18 V Vin = 9 V 75 70 Efficiency (%) Vin = 75 V Vin = 48 V Vin = 24 V Vin = 18 V 82 80 78 76 74 60 72 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1.2 1.3 70 0.2 Load Current (Amps) 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1.2 1.3 N Load Current (Amps) 35'46(ϒFLHQF\&XUYH (I¿FLHQF\YV/LQH9ROWDJHDQG/RDG&XUUHQW#ƒ& 35'46(ϒFLHQF\&XUYH (I¿FLHQF\YV/LQH9ROWDJHDQG/RDG&XUUHQW#ƒ& TI 90 U Efficiency (%) 86 65 95 88 90 86 Efficiency (%) 85 84 80 N Efficiency (%) ED 88 85 82 Vin = 36 V Vin = 24 V Vin = 9 V 80 76 74 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 Vin = 75 V Vin = 48 V Vin = 24 V Vin = 18 V 70 O 78 75 0.9 65 60 1 1.1 0.07 0.18 0.28 0.38 0.49 0.59 0.69 Load Current (Amps) D IS C Load Current (Amps) cui.com 0.80 0.90 1.00 1.10 Additional Resources: Product Page CUI Inc Ϳ SERIES: PRD15 Ϳ DESCRIPTION: DC-DC CONVERTER date 10/26/2020 Ϳ page 10 of 14 PACKAGING (THROUGH HOLE) units: mm [inches] tolerance: +1/-0 mm [9.92] 252.0 28.4 Typ 6.4 Typ 18.0 5x 38.1 25.4 Typ 252.0 Ref 190.5 Ref A N R 6.4 Typ U 6.4 Typ [9.92] 252.0 ED 7UD\0DWHULDO'RZDQWLVWDWLFHWKDIRDP 7UD\6L]H[[PP 47
PRD15-Q48-S5-P-D 价格&库存
很抱歉,暂时无法提供与“PRD15-Q48-S5-P-D”相匹配的价格&库存,您可以联系我们找货
