Additional Resources:
Product Page
3D Model
PCB Footprint
date
01/10/2022
page
1 of 6
SERIES: PQM3-M │ DESCRIPTION: DC-DC CONVERTER
FEATURES
3 W isolated output
smaller package
single regulated output
1,500 Vdc isolation
continuous short circuit
temperature range (-40~105°C)
high efficiency at light load
high power density
high vibration tolerance
efficiency up to 81%
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
and noise1
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
max
(mVp-p)
typ
PQM3-D12-S5-M
12
9~18
5
30
600
3
60
75
PQM3-D12-S12-M
12
9~18
12
12
250
3
60
77
PQM3-D12-S15-M
12
9~18
15
10
200
3
60
79
PQM3-D24-S5-M
24
18~36
5
30
600
3
60
76
PQM3-D24-S12-M
24
18~36
12
12
250
3
60
81
PQM3-D24-S15-M
24
18~36
15
10
200
3
60
80
PQM3-D48-S5-M*
48
36~75
5
30
600
3
60
77
PQM3-D48-S12-M*
48
36~75
12
12
250
3
60
80
PQM3-D48-S15-M*
48
36~75
15
10
200
3
60
80
Notes:
1. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 µF ceramic and 10 µF electrolytic capacitors on the output.
2. * Discontinued model.
PART NUMBER KEY
PQM3 - DXX - SXX - M - X
Base Number
Input Voltage
Output Voltage
cui.com
Packaging Style
SMT
Package Options
"blank" = standard
TR = Tape & Reel
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: PQM3-M │ DESCRIPTION: DC-DC CONVERTER
date 01/10/2022 │ page 2 of 6
INPUT
parameter
conditions/description
min
typ
max
units
operating input voltage
12 V input models
24 V input models
48 V input models
9
18
36
12
24
48
18
36
75
Vdc
Vdc
Vdc
start-up voltage
12 V input models
24 V input models
48 V input models
4.5
11
24
8
16
33
9
18
36
Vdc
Vdc
Vdc
surge voltage
for maximum of 1 second
12 V input models
24 V input models
48 V input models
-0.7
-0.7
-0.7
25
50
100
Vdc
Vdc
Vdc
filter
pi filter
OUTPUT
parameter
typ
max
units
line regulation
full load, input voltage from low to high
min
±0.2
±0.4
load regulation
5% to 100% load
±0.2
±0.75
voltage accuracy
5% to 100% load
±1
±3
5V models
no-load output voltage accuracy
all other models
±1.5
±1.5
±5
±3
switching frequency
100% load, nominal input voltage (PFM mode)
350
transient recovery time
25% load step change
0.5
1
ms
transient response deviation
±2
±5
temperature coeffecient
100% load
±0.02
±0.03
%/°C
min
typ
max
units
min
typ
max
units
KHz
PROTECTIONS
parameter
short circuit protection
continuous, automatic recovery
SAFETY AND COMPLIANCE
parameter
isolation voltage
for 1 minute at 1 mA max.
1,500
Vdc
isolation resistance
at 500 Vdc
1,000
MΩ
conducted emissions
CISPR22/EN55022, class B (external circuit required, see Figure 1-b)
radiated emissions
ESD
IEC/EN61000-4-2, class B, contact ± 4kV
radiated immunity
IEC/EN61000-4-3, class A, 10V/m
EFT/burst
IEC/EN61000-4-4, class B, ± 2kV (external circuit required, see Figure 1-a)
surge
IEC/EN61000-4-5, class B, ± 2kV (external circuit required, see Figure 1-a)
conducted immunity
IEC/EN61000-4-6, class A, 3 Vr.m.s
voltage dips & interruptions
IEC/EN61000-4-29, class B, 0%-70%
MTBF
as per MIL-HDBK-217F @ 25°C
RoHS
2011/65/EU
1,000,000
cui.com
hours
Product Page
3D Model
PCB Footprint
date 01/10/2022 │ page 3 of 6
ENVIRONMENTAL
parameter
min
max
units
operating temperature
see derating curve
-40
105
°C
-55
125
°C
95
storage temperature
storage humidity
non-condensing
temperature rise
at full load, Ta=25°C
typ
25
°C
SOLDERABILITY
parameter
hand soldering
reflow soldering
min
typ
max
units
1.5 mm from case for 10 seconds
300
°C
see reflow soldering profile
240
°C
max
units
MECHANICAL
parameter
dimensions
23.86 x 13.70 x 8.00 (0.939 x 0.539 x 0.315 inch)
min
case material
epoxy resin (UL94-V0)
typ
mm
weight
5.2
g
MECHANICAL DRAWING
units: mm[inch]
tolerance: ±0.25[±0.010]
pin section tolerance: ±0.10[±0.004]
23.86±0.50[0.939±0.020]
16
2.54[0.100]
10 9
1
7
8
13.70[0.539]
15.24[0.600]
A
A
1.34
[0.053]
Side View
PIN CONNECTIONS
1.02[0.040]
0.50[0.020]
Front View
1
7
PCB Layout
Top View
8
2.50 [0.098]
10 9
19.42 [0.765]
16
Grid Size:
2.54mm x 2.54mm
1.20[0.047]
cui.com
0.25[0.010]
5 max
18.10 [0.713]
8.00
[0.315]
7.50
[0.295]
Top View
18.10±0.40[0.713±0.0016]
max 3.34[0.131]
PIN
Function
1
GND
7
NC
8
NC
9
+Vo
10
0V
16
Vin
Product Page
3D Model
PCB Footprint
date 01/10/2022 │ page 4 of 6
DERATING CURVES
EMC RECOMMENDED CIRCUIT
Figure 1
Recommended external circuit components
Vin (Vdc)
FUSE
Table 1
12
24
48
choose according to practical input current
MOV
10D560
10D101
LDM1
56μH
56μH
TVS
SMCJ28A
SMCJ48A
SMCJ90A
C0
680μF/25V
120μF/50V
120μF/100V
LDM2
12μH
12μH
12μH
C1
4.7μF/50V
4.7μF/50V
4.7μF/100V
C2
4.7μF/50V
4.7μF/50V
4.7μF/100V
TEST CONFIGURATION
Figure 2
Table 2
External components
Note: Input reflected-ripple current is measured with an inductor Lin and Capacitor Cin to simulate source impedance.
cui.com
Lin
4.7μH
Cin
220μF, ESR < 1.0Ω
at 100 KHz
Product Page
3D Model
PCB Footprint
date 01/10/2022 │ page 5 of 6
APPLICATION NOTES
1. Output load requirement
To ensure this module can operate efficiently and reliably, the minimum output load may not be less than 5% of the full load during
operation. If the actual output power is low, connect a resistor at the output end in parallel to increase the load.
2. Recommended circuit
This series has been tested according to the following recommended testing circuit before leaving the factory. This series should be
tested under load (see Figure 3 & Table 3). If you want to further decrease the input/output ripple, you can increase the capacitance
accordingly or choose capacitors with low ESR. However, the capacitance of the output filter capacitor must be appropriate. If the
capacitance is too high, a startup problem might arise. For every channel of the output, to ensure safe and reliable operation, the
maximum capacitance must be less than the maximum capacitive load (see Table 4).
Figure 3
Table 3
Vin
(Vdc)
Table 4
Cin
(µF)
Cout
(µF/mA)
Vout
(Vdc)
Max. Capacitive Load
(μF)
12
100
24
10~47
10/100
5
3300
10/100
12
1800
48
10~47 10/100
15
1000
3. Input Current
When it is used in an unregulated condition, make sure that the input fluctuations and ripple voltage do not exceed the module standard. Refer to Figure 4 & Table 5 for the startup current of this dc-dc module.
Table 5
Figure 4
Note:
Vin
(Vdc)
Ip
(mA)
12
640
24
320
48
160
1. Minimum load shouldn't be less than 5%, otherwise ripple may increase dramatically. Operation under minimum load will not damage the converter, however, they may
not meet all specifications listed.
2. Maximum capacitive load is tested at input voltage range and full load.
3. All specifications are measured at Ta=25°C, humidity
很抱歉,暂时无法提供与“PQM3-D48-S5-M-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 200+154.80704200+18.66751
