Additional Resources:
Product Page
3D Model
PCB Footprint
date
07/28/2021
page
1 of 5
SERIES: VAWQ12 │ DESCRIPTION: DC-DC CONVERTER
FEATURES
up to 12 W isolated output
wide input (4:1)
industry standard 24 pin DIP package
single regulated outputs
1,500 V isolation
short circuit and over voltage protection
wide temperature (-40~85°C)
efficiency up to 88%
RoHS
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
and noise1
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
max
(mA)
max
(W)
max
(mVp-p)
typ
VAWQ12-Q24-S3R3
24
9.0~36.0
3.3
3,500
11.55
85
85
VAWQ12-Q24-S5
24
9.0~36.0
5
2,400
12
85
86
VAWQ12-Q24-S12
24
9.0~36.0
12
1,000
12
85
86
VAWQ12-Q24-S15
24
9.0~36.0
15
800
12
85
86
VAWQ12-Q48-S3R3
48
18.0~75.0
3.3
3,500
11.55
85
85
VAWQ12-Q48-S5
48
18.0~75.0
5
2,400
12
85
87
VAWQ12-Q48-S12
48
18.0~75.0
12
1,000
12
85
87
VAWQ12-Q48-S15
48
18.0~75.0
15
800
12
85
88
Notes:
1. ripple and noise are measured at 20 MHz BW
PART NUMBER KEY
VAWQ12 - QXX - SXX
Base Number
Input Voltage
cui.com
Output Voltage
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: VAWQ12 │ DESCRIPTION: DC-DC CONVERTER
date 07/28/2021 │ page 2 of 5
INPUT
parameter
conditions/description
operating input voltage
CTRL
max
units
24
48
36.0
75.0
Vdc
Vdc
40
Vdc
1.2
Vdc
max
units
12
W
or open circuit
module off
Note:
typ
9.0
18.0
3
module on
1
min
1. Control pin voltage referenced to GND
OUTPUT
parameter
min
output power
typ
1.2
line regulation
input voltage from low to high
±0.2
±0.5
load regulation
measured from 10% load to full load
±0.5
±1.5
±1
±3
400
450
voltage accuracy
switching frequency
350
temperature coefficient
±0.02
kHz
%/°C
PROTECTIONS
parameter
3.3 V model
5 V model
12 V model
15 V model
24 V input
under voltage protection
48 V input
short circuit protection
min
typ
max
4.3
6
13
16
units
Vdc
Vdc
Vdc
Vdc
module on
8.8
9
Vdc
module off
8.3
8.5
Vdc
module on
17
17.5
Vdc
module off
16.5
17
Vdc
typ
max
units
continuous, automatic recovery
SAFETY AND COMPLIANCE
parameter
min
isolation voltage
for 1 minute at 1 mA max.
1,500
Vdc
isolation resistance
at 500 Vdc
1,000
MΩ
MTBF
MIL-HDBK-217F, at 25°C
1,000,000
hours
RoHS compliant
yes
ENVIRONMENTAL
parameter
min
operating temperature
see derating curves
-40
storage temperature
typ
-55
case temperature
95
storage humidity
non-condensing
lead temperature
1.5 mm from case for 10 seconds
cui.com
max
units
85
°C
125
°C
105
°C
95
300
°C
Product Page
3D Model
PCB Footprint
date 07/28/2021 │ page 3 of 5
DERATING CURVES
MECHANICAL
parameter
dimensions
32.00 x 20.00 x 10.80 (1.260 x 0.787 x 0.425 inch)
min
case material
aluminum alloy
typ
units
mm
weight
14
MECHANICAL DRAWING
units: mm [inches]
tolerance: ±0.25 [±0.010]
pin section tolerance: ±0.10 mm [±0.004]
PIN CONNECTIONS
cui.com
max
PIN
FUNCTION
1
CTRL
2,3
GND
11
NC
14
+Vo
16
0V
22,23
Vin
g
Product Page
3D Model
PCB Footprint
date 07/28/2021 │ page 4 of 5
EFFICIENCY CURVES
APPLICATION NOTES
1. Recommended Circuit
All of the VAWQ12 models have been tested according to the following recommended testing circuit before leaving factory. If you want
to further decrease the input ripple, Cin is recommended to use 100 µF. If ripple and noise are required, you can increase capacitance
of Cout properly. However, the capacitance should not be higher than Max capacitance. (see Figure 1).
Figure 1
Vin
Vout
C in
DC
DC
GND
0V
2. Recommended Capacitance
Table 1
Note:
Vout
(Vdc)
Cin
(µF)
Cout
(µF)
3.3/5
100
220
12/15
100
100
1. All specifications measured at Ta: 25°C, humidity
很抱歉,暂时无法提供与“VAWQ12-Q24-S12”相匹配的价格&库存,您可以联系我们找货
