Additional Resources:
Product Page
3D Model
PCB Footprint
date
07/20/2021
page
1 of 6
SERIES: PVB3-D │ DESCRIPTION: DC-DC CONVERTER
FEATURES
3 W isolated output
smaller package
single/dual regulated output
3,000 Vdc isolation
short circuit protection
temperature range (-40~105°C)
high efficiency at light load
efficiency up to 86%
EN 62368-1
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
and noise2
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
max
(mVp-p)
typ
PVB3-D5-S5-D
5
4.5~9
5
30
600
3
80
74
PVB3-D5-S12-D
5
4.5~9
12
12
250
3
80
77
PVB3-D5-S15-D
5
4.5~9
15
10
200
3
80
77
PVB3-D5-D5-D
5
4.5~9
±5
±15
±300
3
80
76
PVB3-D5-D12-D
5
4.5~9
±12
±6
±125
3
80
78
PVB3-D5-D15-D
5
4.5~9
±15
±5
±100
3
80
78
PVB3-D12-S3-D
12
9~18
3.3
46
909
3
80
74
PVB3-D12-S5-D
12
9~18
5
30
600
3
80
81
PVB3-D12-S12-D
12
9~18
12
12
250
3
80
83
PVB3-D12-S15-D
12
9~18
15
10
200
3
80
82
PVB3-D12-S24-D
12
9~18
24
6
125
3
80
83
PVB3-D12-D5-D
12
9~18
±5
±15
±300
3
80
81
PVB3-D12-D9-D
12
9~18
±9
±8
±166
3
80
84
PVB3-D12-D12-D
12
9~18
±12
±6
±125
3
80
84
PVB3-D12-D15-D
12
9~18
±15
±5
±100
3
80
85
PVB3-D24-S3-D
24
18~36
3.3
46
909
3
80
78
PVB3-D24-S5-D
24
18~36
5
30
600
3
80
81
PVB3-D24-S12-D
24
18~36
12
12
250
3
80
86
PVB3-D24-S15-D
24
18~36
15
10
200
3
80
86
PVB3-D24-S24-D
24
18~36
24
6
125
3
80
85
PVB3-D24-D5-D
24
18~36
±5
±15
±300
3
80
82
PVB3-D24-D12-D
24
18~36
±12
±6
±125
3
80
84
PVB3-D24-D15-D
24
18~36
±15
±5
±100
3
80
84
PVB3-D48-S5-D
48
36~75
5
30
600
3
80
82
PVB3-D48-S12-D
48
36~75
12
12
250
3
80
86
PVB3-D48-S15-D
48
36~75
15
10
200
3
80
86
PVB3-D48-D3-D
48
36~75
±3.3
±22
±455
3
80
76
1
Notes:
1. UL approved
2. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 μF ceramic and 10 μF electrolytic capacitors on the output.
cui.com
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: PVB3-D │ DESCRIPTION: DC-DC CONVERTER
MODEL
(CONTINUED)
input
voltage
output
voltage
typ
(Vdc)
range
(Vdc)
PVB3-D48-D5-D
48
PVB3-D48-D12-D
48
PVB3-D48-D15-D
48
Notes:
date 07/20/2021 │ page 2 of 6
output
current
output
power
ripple
and noise2
efficiency
(Vdc)
min
(mA)
max
(mA)
max
(W)
typ
(mVp-p)
typ
36~75
±5
±15
±300
3
80
82
36~75
±12
±6
±125
3
80
84
36~75
±15
±5
±100
3
80
85
1. UL approved
PART NUMBER KEY
PVB3 - DXX - XXX - D
Base Number
Input Voltage
Output
S = single
D = dual
Packaging Style
DIP
Output Voltage
INPUT
parameter
conditions/description
min
typ
max
units
operating input voltage
5 Vdc input models
12 Vdc input models
24 Vdc input models
48 Vdc input models
4.5
9
18
36
5
12
24
48
9
18
36
75
Vdc
Vdc
Vdc
Vdc
start-up voltage
5 Vdc input models
12 Vdc input models
24 Vdc input models
48 Vdc input models
4.5
9
18
36
Vdc
Vdc
Vdc
Vdc
surge voltage
for maximum of 1 second
5 Vdc input models
12 Vdc input models
24 Vdc input models
48 Vdc input models
12
25
50
100
Vdc
Vdc
Vdc
Vdc
filter
pi filter
typ
max
units
-0.7
-0.7
-0.7
-0.7
OUTPUT
parameter
min
line regulation
full load, input voltage from low to high
±0.2
±0.5
load regulation
5% to 100% load
±0.2
±0.5
voltage accuracy
no-load voltage accuracy
±1
±3
±1.5
±5
±1
voltage balance
dual output, balanced loads
±0.5
switching frequency
100% load, nominal input voltage, PFM mode
200
transient recovery time
25% load step change
0.5
2
ms
transient response deviation
±2
±5
temperature coeffecient
100% load
±0.02
±0.03
%/°C
max
units
1
s
3
Notes:
kHz
3. For dual output models, unbalanced loads should not exceed ±5%. If ±5% is exceeded, it may not meet all specifications.
PROTECTIONS
parameter
min
4
Notes:
4. The supply voltage must be discontinued at the end of the short circuit duration
cui.com
typ
Product Page
3D Model
PCB Footprint
date 07/20/2021 │ page 3 of 6
SAFETY AND COMPLIANCE
parameter
isolation voltage
input to output for 1 minute at 1 mA max.
3,000
min
typ
max
isolation resistance
input to output at 500 Vdc
1,000
isolation capacitance
input to output at 100 kHz/0.1 V
safety approvals
certified to 62368-1: EN
certified to 60950-1: UL
conducted emissions
CISPR22/EN55022, class B (external circuit required, see Figure 1-b)
radiated emissions
ESD
IEC/EN61000-4-2, class B, contact ± 4kV/air ± 8kV
radiated immunity
IEC/EN61000-4-3, class A, 10V/m
EFT/burst
IEC/EN61000-4-4, class B, ± 2kV (external circuit required, see Figure 1-a)
surge
IEC/EN61000-4-5, class B, ± 2kV (external circuit required, see Figure 1-a)
conducted immunity
IEC/EN61000-4-6, class A, 3 Vr.m.s
voltage dips & interruptions
IEC/EN61000-4-29, class B, 0%-70%
MTBF
as per MIL-HDBK-217F @ 25°C
RoHS
2011/65/EU
units
Vdc
MΩ
30
50
1,000,000
pF
hours
ENVIRONMENTAL
parameter
min
max
units
operating temperature
see derating curve
-40
105
°C
-55
125
°C
5
95
storage temperature
storage humidity
non-condensing
temperature rise
at full load, Ta=25°C
typ
25
°C
SOLDERABILITY
parameter
hand soldering
wave soldering
min
typ
max
units
1.5 mm from case for 10 seconds
300
°C
see wave soldering profile
260
°C
max
units
MECHANICAL
parameter
min
dimensions
31.60 x 20.30 x 10.20 (1.244 x 0.799 x 0.402 inch)
case material
plastic (UL94-V0)
weight
typ
mm
14
g
MECHANICAL DRAWING
units: mm[inch]
tolerance: ±0.50[±0.020]
pin section tolerance: ±0.10[±0.004]
PIN CONNECTIONS
PIN
Single Output
Dual Output
2, 3
GND
GND
9
NC
0V
10,15
NC
NC
11
NC
-Vo
14
+Vo
+Vo
16
0V
0V
22, 23
Vin
Vin
Front View
Bottom View
PCB Layout
Top View
NC: No Connection
cui.com
Product Page
3D Model
PCB Footprint
date 07/20/2021 │ page 4 of 6
DERATING CURVES
EMC RECOMMENDED CIRCUIT
Figure 1
Recommended external circuit components
Vin (Vdc)
5
FUSE
Table 1
12
24
48
choose according to practical input current
MOV
S14K25
S14K35
S14K60
C0
1000μF
1000μF
330μF/50V
330μF/100V
C1
4.7μF/50V
4.7μF/50V
4.7μF/50V
4.7μF/100V
LDM1
12μH
12μH
12μH
12μH
C2
4.7μF/50V
4.7μF/50V
4.7μF/50V
4.7μF/100V
C3
10μF
10μF
10μF
10μF
CY1
1nF/3kV
1nF/3kV
1nF/3kV
1nF/3kV
cui.com
Product Page
3D Model
PCB Footprint
date 07/20/2021 │ page 5 of 6
APPLICATION NOTES
1. Output load requirement
To ensure this module can operate efficiently and reliably, the minimum output load may not be less than 5% of the full load during
operation. If the actual output power is low, connect a resistor at the output end in parallel to increase the load.
2. Recommended circuit
This series has been tested according to the following recommended testing circuit before leaving the factory. This series should be
tested under load (see Figure 2 & Table 2). If you want to further decrease the input/output ripple, you can increase the capacitance
accordingly or choose capacitors with low ESR. However, the capacitance of the output filter capacitor must be appropriate. If the
capacitance is too high, a startup problem might arise. For every channel of the output, to ensure safe and reliable operation, the
maximum capacitance must be less than the maximum capacitive load (see Table 3).
Figure 2
Single output
Dual output
Table 2
Table 3
Vin
(Vdc)
Cin
(µF)
Cout
(µF)
5
100
10
12
100
10
24
10~47
10
48
10~47
10
Single
Vout
(Vdc)
Max. Capacitive
Load
(μF)
Dual
Vout
(Vdc)
Max. Capacitive
Load1
(μF)
3.3
4700
3.3
4700
5
4700
5
2200
12
2700
9
2000
15
2200
12
1800
24
1800
15
1000
Note:
1. For each output.
3. Input Current
When it is used in an unregulated condition, make sure that the input fluctuations and ripple voltage do not exceed the module
standard. Refer to Figure 3 and Table 4 for the startup current of this dc-dc module.
Figure 3
Note:
Table 4
Vin
(Vdc)
Ip
(mA)
5
1400
12
620
24
310
48
150
1. Minimum load shouldn't be less than 5%, otherwise ripple may increase dramatically. Operation under minimum load will not damage the converter, however, they may
not meet all specifications listed.
2. Maximum capacitive load is tested at input voltage range and full load.
3. All specifications are measured at Ta=25°C, humidity
很抱歉,暂时无法提供与“PVB3-D12-D15-D”相匹配的价格&库存,您可以联系我们找货
