Additional Resources:
Product Page
3D Model
PCB Footprint
date
07/01/2021
page
1 of 9
SERIES: PCN1-S │ DESCRIPTION: DC-DC CONVERTER
FEATURES
up to 1 W isolated output
industry standard SIP package
nominal input voltages: 5, 12, 24 Vdc
single/dual unregulated output
1,500 Vdc isolation voltage
low ripple and noise
-40 to 100°C
efficiency up to 83%
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
& noise1
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
max
(mVp-p)
typ
PCN1-S5-S5-S
5
4.5~5.5
5
1
75
79
PCN1-S5-S12-S
5
4.5~5.5
12
1
75
79
PCN1-S5-S15-S
5
4.5~5.5
15
1
75
79
PCN1-S5-D5-S
5
4.5~5.5
±5
±100
1
75
74
PCN1-S5-D12-S
5
4.5~5.5
±12
±42
1
75
78
PCN1-S5-D15-S
5
4.5~5.5
±15
±33
1
75
78
PCN1-S12-S5-S
12
10.8~13.2
5
1
75
80
PCN1-S12-S12-S
12
10.8~13.2
12
1
75
81
PCN1-S12-S15-S
12
10.8~13.2
15
1
75
81
PCN1-S12-D5-S
12
10.8~13.2
±5
±100
1
75
77
PCN1-S12-D12-S
12
10.8~13.2
±12
±42
1
75
80
PCN1-S12-D15-S
12
10.8~13.2
±15
±33
1
75
81
PCN1-S24-S5-S
24
21.6~26.4
5
1
75
80
PCN1-S24-S12-S
24
21.6~26.4
12
1
75
83
PCN1-S24-S15-S
24
21.6~26.4
15
1
75
81
PCN1-S24-D5-S
24
21.6~26.4
±5
±100
1
75
79
PCN1-S24-D12-S
24
21.6~26.4
±12
±42
1
75
81
PCN1-S24-D15-S
24
21.6~26.4
±15
±33
1
75
82
Notes:
1. At full load, nominal input, 20 MHz bandwidth oscilloscope, with a 0.33 µF ceramic capacitor on the output.
2. Required to add a 2.2 µF (5 & 12 Vdc input models) or 4.7 µF (24 Vdc input models) ceramic capacitor to the input to reduce input voltage stress.
3. All specifications are measured at Ta=25°C, nominal input voltage, and rated output load unless otherwise specified.
PART NUMBER KEY
PCN1 - SXX - X XX - S
Base Number
Input Voltage
Output
S = single
D = dual
cui.com
Output Voltage
Packaging Style:
S = SIP
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: PCN1-S │ DESCRIPTION: DC-DC CONVERTER
date 07/01/2021 │ page 2 of 9
INPUT
parameter
conditions/description
min
typ
max
units
operating input voltage
5 Vdc input models
12 Vdc input models
24 Vdc input models
4.5
10.8
21.6
5
12
24
5.5
13.2
26.4
Vdc
Vdc
Vdc
surge voltage
for maximum of 100 ms
5 Vdc input models
12 Vdc input models
24 Vdc input models
9
18
30
Vdc
Vdc
Vdc
current
5 Vdc input models
12 Vdc input models
24 Vdc input models
filter
capacitive
250
110
50
mA
mA
mA
input reverse polarity protection no
input fuse
Notes:
0.5 A time delay fuse for all models (recommended)
1. Required to add a 2.2 µF (5 & 12 Vdc input models) or 4.7 µF (24 Vdc input models) ceramic capacitor to the input to reduce input voltage stress.
OUTPUT
parameter
maximum capacitive load
single output models
dual output models
min
typ
voltage accuracy
max
units
220
100
μF
μF
±3.0
line regulation
1.0% change in input voltage
±1.2
load regulation
from 20% load to full load
±10
switching frequency
at nominal Vin, full load
24 Vdc input models
all other models
75
100
temperature coefficient
kHz
kHz
±0.05
%/°C
max
units
1
s
max
units
PROTECTIONS
parameter
short circuit protection
momentary
min
typ
SAFETY AND COMPLIANCE
parameter
min
typ
isolation voltage
input to output for 1 minute
1,500
Vdc
isolation resistance
input to output
1,000
MΩ
isolation capacitance
input to output
conducted emissions
EN 55022 Class B (external circuit required, see Figure 4)
MTBF
as per MIL-HDBK-217F, full load, GB, 25°C
RoHS
2011/65/EU
10
pF
1,500,000
hours
ENVIRONMENTAL
parameter
min
max
units
operating temperature
see derating curve
-40
100
°C
-55
125
°C
95
storage temperature
operating humidity
non-condensing
cui.com
typ
Product Page
3D Model
PCB Footprint
date 07/01/2021 │ page 3 of 9
SOLDERABILITY
wave soldering
see wave soldering profile
Notes:
1.
2.
3.
4.
5.
min
typ
max
units
260
°C
max
units
Temperature (°C)
parameter
Soldering materials: Sn/Cu/Ni
Ramp up rate during preheat: 1.4°C/s (from 50°C to 100°C)
Soaking temperature: 0.5°C/s (from 100°C to 130°C), 60±20 seconds
Peak temperature: 260°C, above 250°C for 3~6 seconds
Ramp down rate during cooling: -10°C/s (from 260°C to 150°C)
Time (Seconds)
MECHANICAL
parameter
min
typ
dimensions
5, 12 Vdc input models: 0.77 x 0.24 x 0.40 [19.5 x 6.1 x 10.2 mm]
24 Vdc input models: 0.77 x 0.28 x 0.40 [19.5 x 7.2 x 10.2 mm]
case material
non-conductive black plastic
weight
24 Vdc input models
all other models
inches
inches
2.7
1.8
g
g
MECHANICAL DRAWING
24 Vdc input models
0.02 [0.5]
0.02 [0.5]
0.40 [10.2]
0.77 [19.5]
0.77 [19.5]
0.40 [10.2]
units: inches [mm]
tolerance: X.XX ±0.01 [±0.25]
X.XXX ±0.005 [±0.13]
pin section tolerance: ±0.002[±0.05]
PIN CONNECTIONS
5
No pin
Common
6
+Vout
+Vout
0.73 [18.5]
0.73 [18.5]
1 2
4 5 6
0.020[0.50]
0.093 [2.35] 0.300 [7.62]
0.100 [2.54]
1 2
0.28[7.2]
-Vout
0.13 [3.2]
-Vin
-Vout
4 5 6
1 2
0.010 [0.25]
0.07 [1.8]
-Vin
4
0.100 [2.54]
0.020[0.50]
0.8mm PLATED THROUGH HOLE
1.5mm PAD SIZE
4 5 6
1.5mm PAD SIZE
0.100 [2.54]
1 2
4
5 6
0.28[7.2]
2
0.08 [2.1]
0.066[1.68]
+Vin
0.100 [2.54]
0.24 [6.1]
+Vin
0.08 [2.1]
0.13 [3.2]
Dual
0.010 [0.25]
0.06 [1.6]
Single
0.24[6.1]
1
Function
0.058 [1.48]
PIN
0.77[19.5]
0.77[19.5]
Recommended PCB Layout
Top View
cui.com
Top View
Product Page
3D Model
PCB Footprint
date 07/01/2021 │ page 4 of 9
DERATING CURVE
EFFICIENCY CURVES
cui.com
Product Page
3D Model
PCB Footprint
date 07/01/2021 │ page 5 of 9
EFFICIENCY CURVES (CONTINUED)
cui.com
Product Page
3D Model
PCB Footprint
date 07/01/2021 │ page 6 of 9
cui.com
Product Page
3D Model
PCB Footprint
date 07/01/2021 │ page 7 of 9
PACKAGING
units: mm
Tube size: 17.2 x 9 x 340 mm
QTY: 16 pcs
24 Vdc input models
units: mm
Tube size: 20 x 11 x 340 mm
QTY: 14 pcs
cui.com
Product Page
3D Model
PCB Footprint
date 07/01/2021 │ page 8 of 9
TEST CONFIGURATIONS
Input Ripple Current & Output Noise
Figure 1
Measuring Input Ripple Current
Figure 2
Measuring Output Ripple & Noise for
Single Output Models
Table 1
L1
12 µH
C1
2.2 µF or 4.7 µF tantalum capacitor
C2
NC
Figure 3
Dual Output Models
Table 2
Input
Voltage
(Vdc)
Cin
5
2.2 µF ceramic capacitor
12
24
4.7 µF ceramic capacitor
EMC RECOMMENDED CIRCUIT
Test Condition
Input Voltage: Nominal
Output Load: Full Load
Figure 4
Conducted Emissions Test Circuit
Table 3
EN55022 Class B
Recommended External Circuit Components
Input
Voltage
(Vdc)
C11
C21
L1
5
4.7 µF / 25 V
4.7 µF / 25 V
10 µH
12
4.7 µF / 25 V
4.7 µF / 25 V
10 µH
24
10 µF / 50 V
10 µF / 50 V
7.5 µH
Notes:
1. Ceramic Capacitor
cui.com
Product Page
3D Model
PCB Footprint
date 07/01/2021 │ page 9 of 9
REVISION HISTORY
rev.
description
date
1.0
initial release
07/26/2016
1.01
company logo updated
04/12/2021
1.02
derating curve, efficiency curves and circuit figures updated
07/01/2021
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a two (2) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
很抱歉,暂时无法提供与“PCN1-S5-S15-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+37.70790
- 16+33.40093
