Additional Resources:
Product Page
3D Model
PCB Footprint
date
07/07/2021
page
1 of 7
SERIES: PEM1-S │ DESCRIPTION: DC-DC CONVERTER
FEATURES
1 W isolated output
smaller package
single/dual unregulated output
3,000 Vdc isolation
short circuit protection
extended temperature range (-40~105°C)
antistatic protection up to 8kV
high efficiency at light load
efficiency up to 81%
EN 62368-1
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
and noise2
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
typ
(mVp-p)
typ
PEM1-S3-S3-S
3.3
2.97~3.63
3.3
30
303
1
60
73
PEM1-S3-S5-S
3.3
2.97~3.63
5
1
60
78
PEM1-S5-S3-S
5
4.5~5.5
3.3
30
303
1
60
73
PEM1-S5-S5-S
5
4.5~5.5
5
1
60
80
PEM1-S5-S12-S1
5
4.5~5.5
12
9
83
1
60
80
1
PEM1-S5-S15-S
5
4.5~5.5
15
7
67
1
60
81
PEM1-S5-S24-S1
5
4.5~5.5
24
5
42
1
60
81
PEM1-S5-D3-S
5
4.5~5.5
±3.3
±15
±152
1
60
73
PEM1-S5-D5-S1
5
4.5~5.5
±5
±10
±100
1
60
80
1
PEM1-S5-D12-S
5
4.5~5.5
±12
±5
±42
1
60
80
PEM1-S5-D15-S1
5
4.5~5.5
±15
±4
±33
1
60
81
1
PEM1-S5-D24-S
5
4.5~5.5
±24
±2
±21
1
60
81
PEM1-S12-S3-S
12
10.8~13.2
3.3
30
303
1
60
75
PEM1-S12-S5-S
12
10.8~13.2
5
1
60
80
PEM1-S12-S12-S1
12
10.8~13.2
12
9
83
1
60
80
PEM1-S12-S15-S
12
10.8~13.2
15
7
67
1
60
81
PEM1-S12-D3-S
12
10.8~13.2
±3.3
±15
±152
1
60
74
PEM1-S12-D5-S1
12
10.8~13.2
±5
±10
±100
1
60
80
1
PEM1-S12-D12-S
12
10.8~13.2
±12
±5
±42
1
60
81
PEM1-S12-D15-S1
12
10.8~13.2
±15
±4
±33
1
60
81
PEM1-S15-S5-S
15
13.5~16.5
5
1
60
80
PEM1-S15-S12-S
15
13.5~16.5
12
9
83
1
60
80
PEM1-S15-S15-S
15
13.5~16.5
15
7
67
1
60
81
PEM1-S15-D5-S
15
13.5~16.5
±5
±10
±100
1
60
80
PEM1-S15-D15-S
15
13.5~16.5
±15
±4
±33
1
60
81
PEM1-S24-S3-S
24
21.6~26.4
3.3
30
303
1
60
75
PEM1-S24-S5-S
24
21.6~26.4
5
1
60
79
1
1
1
1
Notes:
1. UL approved
2. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 μF ceramic and 10 μF electrolytic capacitors on the output.
cui.com
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: PEM1-S │ DESCRIPTION: DC-DC CONVERTER
MODEL
(CONTINUED)
input
voltage
date 07/07/2021 │ page 2 of 7
output
voltage
output
current
output
power
ripple
and noise2
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
typ
(mVp-p)
typ
PEM1-S24-S12-S1
24
21.6~26.4
12
9
83
1
60
81
PEM1-S24-S15-S1
24
21.6~26.4
15
7
67
1
60
81
PEM1-S24-S24-S
24
21.6~26.4
24
5
42
1
60
81
PEM1-S24-D3-S
24
21.6~26.4
±3.3
±15
±152
1
60
73
PEM1-S24-D5-S
24
21.6~26.4
±5
±10
±100
1
60
80
PEM1-S24-D12-S1
24
21.6~26.4
±12
±5
±42
1
60
81
1
PEM1-S24-D15-S
24
21.6~26.4
±15
±4
±33
1
60
79
PEM1-S24-D24-S1
24
21.6~26.4
±24
±2
±21
1
60
80
1
1
Notes:
1. UL approved
PART NUMBER KEY
PEM1 - SXX - XXX -S
Base Number
Output
S = single
D = dual
Input Voltage
Output Voltage
Packaging Style
SIP
INPUT
parameter
conditions/description
min
typ
max
units
operating input voltage
3.3 Vdc input models
5 Vdc input models
12 Vdc input models
15 Vdc input models
24 Vdc input models
2.97
4.5
10.8
13.5
21.6
3.3
5
12
15
24
3.63
5.5
13.2
16.5
26.4
Vdc
Vdc
Vdc
Vdc
Vdc
surge voltage
for maximum of 1 second
5 Vdc input models
12 Vdc input models
15 Vdc input models
24 Vdc input models
-0.7
-0.7
-0.7
-0.7
-0.7
5
9
18
21
30
Vdc
Vdc
Vdc
Vdc
Vdc
filter
capacitance filter
max
units
±1.5
±1.2
OUTPUT
parameter
min
typ
line regulation
for Vin change of 1%
3.3 Vdc output models
all other models
load regulation
measure from 10% load to full load
5 Vdc input models
12 Vdc input models
15 Vdc input models
24 Vdc input models
voltage accuracy
see tolerance envelope curve
voltage balance
dual output, balanced loads
±0.5
switching frequency
at full load, nominal input voltage
100
temperature coefficient
at full load
18
12
8
7
6
±1
±0.03
cui.com
kHz
%/°C
Product Page
3D Model
PCB Footprint
date 07/07/2021 │ page 3 of 7
PROTECTIONS
parameter
min
typ
short circuit protection1
Note:
max
units
1
s
max
units
1. The supply voltage must be discontinued at the end of the short circuit duration.
SAFETY AND COMPLIANCE
parameter
isolation voltage
input to output for 1 minute, 1 mA max. leakage
current
3,000
Vdc
isolation resistance
input to output at 500 Vdc
1,000
MΩ
isolation capacitance
input to output, 100KHz, 0.1V
safety approvals2
certified to 62368-1: EN
certified to 60950-1: UL
conducted emissions
CISPR22/EN55022, class B (external circuit required, see Figure 1)
radiated emissions
ESD
IEC/EN61000-4-2, class B, contact ± 8kV for single outputs
IEC/EN61000-4-2, class B, contact ± 6kV for dual outputs
MTBF
as per MIL-HDBK-217F @ 25°C
RoHS
min
typ
pF
3,500,000
hours
2011/65/EU
Note:
2. See specific models noted on pages 1 & 2.
ENVIRONMENTAL
parameter
min
max
units
operating temperature
see derating curve
-40
105
°C
-55
125
°C
95
storage temperature
storage humidity
non-condensing
temperature rise
at Ta = 25°C
typ
25
°C
SOLDERABILITY
parameter
hand soldering
wave soldering3
Notes:
min
typ
max
units
1.5 mm from case for 10 seconds
300
°C
see wave soldering profile
260
°C
3. Preheat conditions: At 120°C for over 1 minute.
Peak Temp. 260°C Max.
250
Wave Soldering Time
4 Sec. Max.
250
200
Temperature (°C)
Temperature (°C)
200
150
120
>60 seconds
100
50
10 Sec. Max.
150
100
50
Time (sec.)
Preheat Profile
Time (sec.)
Wave Soldering Profile
cui.com
Product Page
3D Model
PCB Footprint
date 07/07/2021 │ page 4 of 7
MECHANICAL
parameter
dimensions
19.50 x 6.00 x 9.30 (0.768 x 0.236 x 0.366 inch)
min
case material
epoxy resin (UL94-V0)
weight
units: mm[inch]
tolerance: ±0.25[±0.010]
pin section tolerance: ±0.10[±0.004]
PIN CONNECTIONS
Single Output
Dual Output
1
Vin
Vin
2
GND
GND
5
0V
-Vo
6
No Pin
0V
7
+Vo
+Vo
cui.com
max
units
mm
2.4
MECHANICAL DRAWING
PIN
typ
g
Product Page
3D Model
PCB Footprint
date 07/07/2021 │ page 5 of 7
DERATING CURVES
EMC RECOMMENDED CIRCUIT
Figure 1
Table 1
Recommended external circuit components
Vin
(Vdc)
C1
LDM
3.3
4.7μF/50V
6.8μH
5
4.7μF/50V
6.8μH
12
4.7μF/50V
6.8μH
15
4.7μF/50V
6.8μH
4.7μF/50V
6.8μH
24
Note:
1. See Table 3 for Cout values.
TEST CONFIGURATION
Figure 2
Table 2
External components
Note: Input reflected-ripple current is measured with an inductor Lin and Capacitor Cin to simulate source impedance.
cui.com
Lin
4.7μH
Cin
220μF, ESR < 1.0Ω
at 100 kHz
Product Page
3D Model
PCB Footprint
date 07/07/2021 │ page 6 of 7
APPLICATION NOTES
1. Output load requirement
To ensure this module can operate efficiently and reliably, the minimum output load may not be less than 10% of the full load during
operation. If the actual output power is low, connect a resistor at the output end in parallel to increase the load.
2. Overload Protection
Under normal operating conditions, the output circuit of this product has no protection against overload. The simplest method to add
this is to add a circuit breaker to the circuit.
3. Recommended circuit
If you want to further decrease the input/output ripple, you can increase the capacitance accordingly or choose capacitors with low
ESR (see Figure 3 & Table 3). However, the capacitance of the output filter capacitor must be appropriate. If the capacitance is too
high, a startup problem might arise. For every channel of the output, to ensure safe and reliable operation, the maximum capacitance
must be less than the maximum capacitive load (see Table 4).
Figure 3
Single output
Dual output
Table 3
Table 4
Vin
(Vdc)
Cin
(µF)
Single Vo
(Vdc)
Cout
(µF)
Dual Vo
(Vdc)
Cout
(µF)
Single Vout
(Vdc)
Max. Capacitive Load
(μF)
Dual Vout
(Vdc)
Max. Capacitive Load1
(μF)
3.3
4.7
3.3
10
±3.3
4.7
3.3
220
3.3
100
5
4.7
5
10
±5
4.7
5
220
5
100
12
2.2
12
2.2
±12
1
12
220
12
100
15
2.2
15
1
±15
0.47
15
220
15
100
24
1
24
1
±24
0.47
220
24
100
Note:
Note:
It’s not recommended to connect any external capacitors in
applications with less than 0.5 watt output.
1.
2.
3.
4.
24
Note:
1. For each output.
Operation under minimum load will not damage the converter; however, they may not meet all specifications listed.
Max. capacitive load tested at input voltage range and full load.
It is recommended to use either ceramic capacitors or electrolytic capacitors on the input and the output. Using tantalum capacitors may increase the risk of failure.
All specifications measured at: Ta=25°C, humidity
很抱歉,暂时无法提供与“PEM1-S24-S24-S”相匹配的价格&库存,您可以联系我们找货
