PDQ15-Q48-S15-D
PDQ15-Q48-S15-D
    CUIDEVICES
    DC/DCCONVERTER15V15W
PDQ15-Q48-S15-D 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 03/15/2022 page 1 of 9 SERIES: PDQ15-D │ DESCRIPTION: DC-DC CONVERTER FEATURES • • • • • • • • • • • up to 15 W isolated output industry standard 1” x 1” package 4:1 input range single/dual regulated output over voltage, input under voltage lockout, and short circuit protections 1,500 Vdc isolation voltage five-sided shielded case remote on/off control output trim -40 to 105°C temperature range efficiency up to 88% MODEL input voltage output voltage output current output power ripple & noise1 efficiency typ (Vdc) range (Vdc) (Vdc) min (A) max (A) max (W) max (mVp-p) typ (%) PDQ15-Q24-S3-D 24 9~36 3.3 0 4.0 13.2 75 87 PDQ15-Q24-S5-D 24 9~36 5 0 3.0 15 75 87 PDQ15-Q24-S12-D 24 9~36 12 0 1.25 15 100 87 PDQ15-Q24-S15-D 24 9~36 15 0 1.0 15 100 88 PDQ15-Q24-D5-D 24 9~36 ±5 0 ±1.5 15 75 85 PDQ15-Q24-D12-D 24 9~36 ±12 0 ±0.625 15 100 87 PDQ15-Q24-D15-D 24 9~36 ±15 0 ±0.500 15 100 88 PDQ15-Q48-S3-D 48 18~75 3.3 0 4.0 13.2 75 88 PDQ15-Q48-S5-D 48 18~75 5 0 3.0 15 75 88 PDQ15-Q48-S12-D 48 18~75 12 0 1.25 15 100 87 PDQ15-Q48-S15-D 48 18~75 15 0 1.0 15 100 87 PDQ15-Q48-D5-D 48 18~75 ±5 0 ±1.5 15 75 85 PDQ15-Q48-D12-D 48 18~75 ±12 0 ±0.625 15 100 87 PDQ15-Q48-D15-D 48 18~75 ±15 0 ±0.500 15 100 87 Notes: 1. At full load, nominal input, 20 MHz bandwidth oscilloscope, with 10 µF tantalum and 1 µF ceramic capacitors on the output. 2. All specifications are measured at Ta=25°C, nominal input voltage, and rated output load unless otherwise specified. PART NUMBER KEY PDQ15 - QXX - X XX - D Base Number Input Voltage Packaging Style: D = DIP Output S = single D = dual cui.com Output Voltage Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PDQ15-D │ DESCRIPTION: DC-DC CONVERTER date 03/15/2022 │ page 2 of 9 INPUT parameter conditions/description operating input voltage 24 Vdc input models 48 Vdc input models min typ max units 9 18 24 48 36 75 Vdc Vdc surge voltage for maximum of 100 ms 24 Vdc input models 48 Vdc input models 50 100 Vdc Vdc current 24 Vdc input models 48 Vdc input models 2.1 1.0 A A under voltage shutdown 24 24 48 48 remote on/off1 turn on (3.5~75 Vdc or open circuit) turn off (
PDQ15-Q48-S15-D 价格&库存
很抱歉,暂时无法提供与“PDQ15-Q48-S15-D”相匹配的价格&库存,您可以联系我们找货
