PQMC3-D48-S12-S
PQMC3-D48-S12-S
    CUIDEVICES
    DC/DCCONVERTER12V3W
PQMC3-D48-S12-S 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 11/15/2021 page 1 of 6 SERIES: PQMC3-S │ DESCRIPTION: DC-DC CONVERTER FEATURES • • • • • • • • 3 W isolated output smaller package single/dual regulated output 1,500 Vdc isolation continuous short circuit temperature range (-40~105°C) high efficiency at light load efficiency up to 84% MODEL input voltage output voltage output current output power ripple and noise1 efficiency typ (Vdc) range (Vdc) (Vdc) min (mA) max (mA) max (W) max (mVp-p) typ (%) PQMC3-D5-S5-S 5 4.5~9 5 25 500 2.5 75 73 PQMC3-D5-S9-S 5 4.5~9 9 14 278 2.5 75 74 PQMC3-D5-S12-S 5 4.5~9 12 10 208 2.5 75 77 PQMC3-D5-S15-S 5 4.5~9 15 8 167 2.5 75 74 PQMC3-D5-D5-S 5 4.5~9 ±5 ±13 ±250 2.5 75 74 PQMC3-D5-D12-S 5 4.5~9 ±12 ±5 ±104 2.5 75 77 PQMC3-D5-D15-S 5 4.5~9 ±15 ±4 ±83 2.5 75 77 PQMC3-D12-S3-S 12 9~18 3.3 38 758 2.5 75 75 PQMC3-D12-S5-S 12 9~18 5 30 600 3 75 76 PQMC3-D12-S9-S 12 9~18 9 17 333 3 75 79 PQMC3-D12-S12-S 12 9~18 12 13 250 3 75 82 PQMC3-D12-S15-S 12 9~18 15 10 200 3 75 83 PQMC3-D12-S24-S 12 9~18 24 6 125 3 75 81 PQMC3-D12-D5-S 12 9~18 ±5 ±15 ±300 3 75 78 PQMC3-D12-D12-S 12 9~18 ±12 ±6 ±125 3 75 79 PQMC3-D12-D15-S 12 9~18 ±15 ±5 ±100 3 75 80 PQMC3-D24-S3-S 24 18~36 3.3 38 758 2.5 75 74 PQMC3-D24-S5-S 24 18~36 5 30 600 3 75 81 PQMC3-D24-S9-S 24 18~36 9 17 333 3 75 83 PQMC3-D24-S12-S 24 18~36 12 13 250 3 75 83 PQMC3-D24-S15-S 24 18~36 15 10 200 3 75 83 PQMC3-D24-S24-S 24 18~36 24 6 125 3 75 83 PQMC3-D24-D5-S 24 18~36 ±5 ±15 ±300 3 75 79 PQMC3-D24-D9-S 24 18~36 ±9 ±8 ±167 3 75 81 PQMC3-D24-D12-S 24 18~36 ±12 ±6 ±125 3 75 83 PQMC3-D24-D15-S 24 18~36 ±15 ±5 ±100 3 75 83 PQMC3-D48-S3-S 48 36~75 3.3 38 758 2.5 75 75 PQMC3-D48-S5-S 48 36~75 5 30 600 3 75 76 cui.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PQMC3-S │ DESCRIPTION: DC-DC CONVERTER MODEL (CONTINUED) input voltage date 11/15/2021 │ page 2 of 6 output voltage output current output power ripple and noise1 efficiency typ (Vdc) range (Vdc) (Vdc) min (mA) max (mA) max (W) typ (mVp-p) typ (%) PQMC3-D48-S12-S 48 36~75 12 13 250 3 75 80 PQMC3-D48-S15-S 48 36~75 15 10 200 3 75 84 PQMC3-D48-S24-S 48 36~75 24 6 125 3 75 82 PQMC3-D48-D5-S 48 36~75 ±5 ±15 ±300 3 75 79 PQMC3-D48-D12-S 48 36~75 ±12 ±6 ±125 3 75 82 PQMC3-D48-D15-S 48 36~75 ±15 ±5 ±100 3 75 82 Notes: 1. ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 μF ceramic and 10 μF electrolytic capacitors on the output. PART NUMBER KEY PQMC3 - DXX - XXX -S Base Number Output S = single D = dual Input Voltage Packaging Style SIP Output Voltage INPUT parameter conditions/description min typ max units operating input voltage 5 Vdc input models 12 Vdc input models 24 Vdc input models 48 Vdc input models 4.5 9 18 36 5 12 24 48 9 18 36 75 Vdc Vdc Vdc Vdc start-up voltage 5 Vdc input models 12 Vdc input models 24 Vdc input models 48 Vdc input models 3.5 4.5 11 24 4 8 16 33 4.5 9 18 36 Vdc Vdc Vdc Vdc surge voltage for maximum of 1 second 5 Vdc input models 12 Vdc input models 24 Vdc input models 48 Vdc input models -0.7 -0.7 -0.7 -0.7 12 25 50 100 Vdc Vdc Vdc Vdc filter capacitance filter models ON (CTRL open or insulated) CTRL2 Notes: models OFF (connect voltage, current into CTRL is 5~10mA) 2. See application notes on page 6. OUTPUT parameter conditions/description typ max units line regulation full load, input voltage from low to high ±0.2 ±0.5 % load regulation 5% to 100% load ±0.6 ±1 % voltage accuracy 5% to 100% load ±1 ±3 % no-load voltage accuracy PQMC3-D12-S3-S & PQMC3-D48-S3-S all other models ±1.5 ±8 ±5 % % voltage balance3 dual output, balanced loads ±0.5 ±1 switching frequency 100% load, nominal input voltage, PFM mode 250 transient recovery time 25% load step change 0.5 3 ms transient response deviation 25% load step change ±2.5 ±5 % temperature coeffecient 100% load ±0.02 ±0.03 %/°C Notes: min 3. For dual output models, unbalanced loads should not exceed ±5%. If ±5% is exceeded, it may not meet all specifications. cui.com % kHz Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PQMC3-S │ DESCRIPTION: DC-DC CONVERTER date 11/15/2021 │ page 3 of 6 PROTECTIONS parameter conditions/description short circuit protection continuous, automatic recovery min typ max units min typ max units SAFETY AND COMPLIANCE parameter conditions/description isolation voltage input to output for 1 minute at 1 mA max. 1,500 Vdc isolation resistance input to output at 500 Vdc 1,000 MΩ conducted emissions CISPR22/EN55022, class B (external circuit required, see Figure 1-b) radiated emissions CISPR22/EN55022, class B (external circuit required, see Figure 1-b) ESD IEC/EN61000-4-2, class B, contact ± 4kV radiated immunity IEC/EN61000-4-3, class A, 10V/m EFT/burst IEC/EN61000-4-4, class B, ± 2kV (external circuit required, see Figure 1-a) surge IEC/EN61000-4-5, class B, ± 2kV (external circuit required, see Figure 1-a) conducted immunity IEC/EN61000-4-6, class A, 3 Vr.m.s voltage dips & interruptions IEC/EN61000-4-29, class B, 0%-70% MTBF as per MIL-HDBK-217F @ 25°C RoHS 2011/65/EU 1,000,000 hours ENVIRONMENTAL parameter conditions/description min max units operating temperature see derating curve -40 105 °C -55 125 °C 95 % storage temperature storage humidity non-condensing temperature rise at full load, Ta=25°C typ 25 °C SOLDERABILITY parameter conditions/description hand soldering wave soldering min typ max units 1.5 mm from case for 10 seconds 300 °C see wave soldering profile 260 °C max units MECHANICAL parameter conditions/description dimensions 22.00 x 9.50 x 12.00 (0.866 x 0.374 x 0.472 inch) min case material plastic (UL94-V0) weight typ mm 4.9 DERATING CURVES cui.com g Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PQMC3-S │ DESCRIPTION: DC-DC CONVERTER date 11/15/2021 │ page 4 of 6 MECHANICAL DRAWING PIN CONNECTIONS Ø1.00 [0.039] 0.50[0.020] 12.00 [0.472] units: mm[inch] tolerance: ±0.25[±0.010] pin section tolerance: ±0.10[±0.004] PIN Single Output Dual Output 1 GND GND 2 Vin Vin Front View 3 Ctrl Ctrl 22.00 [0.866] 5 NC NC 6 +Vo +Vo 7 0V 0V 8 CS -Vo 1 2 3 5 6 7 8 2.50 [0.098] 1 NC: No Connection 2 3 5 PCB Layout Top View 2.54[0.100] 0.30 [0.012] 9.50 [0.374] 4.10 [0.161] 6 7 8 0.50[0.020] 17.78 [0.700] Bottom View EMC RECOMMENDED CIRCUIT Figure 1 Recommended external circuit components Vin (Vdc) 5 FUSE MOV 12 24 48 choose according to practical input current -- -- S14K35 S14K60 LDM1 -- -- 56μH 56μH TVS SMCJ13A SMCJ28A SMCJ48A SMCJ90A C0 680μF/16V 680μF/25V 330μF/50V 330μF/100V C1 4.7μF/50V 4.7μF/50V 4.7μF/50V 4.7μF/100V Table 1 LDM2 12μH 12μH 12μH 12μH C2 4.7μF/50V 4.7μF/50V 4.7μF/50V 4.7μF/100V CY 1nF/2kV 1nF/2kV 1nF/2kV 1nF/2kV D1 RB160M-60/1A RB160M-60/1A RB160M-60/1A RB160M-60/1A VC − VD − 1.0 −300 aaaaaaaaaaaa IC R= Follows:aaaaa aaaaa R Cd 47nF/100V 47nF/100V 47nF/100V 47nF/100V Note: Figure 1-c is on/off control circuit. See page 6 for details. TEST CONFIGURATION External components Figure 2 Table 2 Note: Input reflected-ripple current is measured with an inductor Lin and Capacitor Cin to simulate source impedance. cui.com Lin 4.7μH Cin 220μF, ESR < 1.0Ω at 100 KHz Grid Size: 2.54mm x 2.54mm Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PQMC3-S │ DESCRIPTION: DC-DC CONVERTER date 11/15/2021 │ page 5 of 6 APPLICATION NOTES 1. Output load requirement To ensure this module can operate efficiently and reliably, the minimum output load may not be less than 5% of the full load during operation. If the actual output power is low, connect a resistor at the output end in parallel to increase the load. 2. Recommended circuit This series has been tested according to the following recommended testing circuit before leaving the factory. This series should be tested under load (see Figure 3 and Table 3). If you want to further decrease the input/output ripple, you can increase the capacitance accordingly or choose capacitors with low ESR. However, the capacitance of the output filter capacitor must be appropriate. If the capacitance is too high, a startup problem might arise. For every channel of the output, to ensure safe and reliable operation, the maximum capacitance must be less than the maximum capacitive load (see Table 4). Single output Dual output Figure 3 Table 3 Table 4 Vin (Vdc) Cin1 (µF) Cin2 (µF) Lin (µH) Cs1 (µF) Cout (µF) Lout2 (µH) Cd (nF/V) 5 100 47 4.7~12 10~22 100 2.2~10 47/100 12 100 47 4.7~12 10~22 100 2.2~10 47/100 24 10 1 4.7~12 10~22 100 2.2~10 47/100 48 10 1 4.7~12 10~22 100 2.2~10 47/100 Note: 1. For single output only 2. For dual output only Single Vout (Vdc) Max. Capacitive Load (μF) Dual Vout (Vdc) Max. Capacitive Load1 (μF) 3.3 2700 -- -- 5 2200 5 1000 9 1000 9 680 12 680 12 470        15 470 15 330 24 Note: 330 -- -- 1. For each output. 3. CTRL Terminal When open or applied high impedance, the converter will turn on. When it’s pulled high, the converter will shutdown. The input current should between 5~10mA. Exceeding the maximum 20mA will cause permanent damage to the converter. The value for R can be derived as follows: V − VD − 1.0 −300 R= C IC Vc: Control pin input voltage VD: Forward voltage drop of diode D1 IC: Input current to control pin R: Resistor of control circuit Figure 4 4. Input Current When it is used in an unregulated condition, make sure that the input fluctuations and ripple voltage do not exceed the module standard. Refer to Figure 5 and Table 5 for the startup current of this dc-dc module. Figure 5 Note: Table 5 Vin (Vdc) Ip (mA) 5 1110 12 640 24 325 48 160 1. Minimum load shouldn't be less than 5%, otherwise ripple may increase dramatically. Operation under minimum load will not damage the converter, however, they may not meet all specifications listed. 2. Maximum capacitive load is tested at input voltage range and full load. 3. All specifications are measured at Ta=25°C, humidity
PQMC3-D48-S12-S 价格&库存
很抱歉,暂时无法提供与“PQMC3-D48-S12-S”相匹配的价格&库存,您可以联系我们找货
