Additional Resources:
Product Page
3D Model
PCB Footprint
date
09/13/2022
page
1 of 6
SERIES: PEM2-S │ DESCRIPTION: DC-DC CONVERTER
FEATURES
2 W isolated output
smaller package
single/dual unregulated output
3,000 Vdc isolation
short circuit protection
extended temperature range (-40~105°C)
antistatic protection up to 8kV
high efficiency at light load
efficiency up to 86%
EN 62368-1
MODEL
input
voltage
PEM2-S5-S5-S1
output
voltage
output
current
output
power
ripple
and noise2
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
typ
(mVp-p)
typ
5
4.5~5.5
5
40
400
2
75
82
1
PEM2-S5-S12-S
5
4.5~5.5
12
17
167
2
75
82
PEM2-S5-S15-S1
5
4.5~5.5
15
13
133
2
75
83
PEM2-S5-S24-S
5
4.5~5.5
24
8
83
2
75
84
PEM2-S5-D5-S1
5
4.5~5.5
±5
±20
±200
2
75
80
1
PEM2-S5-D12-S
5
4.5~5.5
±12
±8
±83
2
75
83
PEM2-S5-D15-S1
5
4.5~5.5
±15
±7
±67
2
75
82
1
PEM2-S5-D24-S
5
4.5~5.5
±24
±4
±42
2
75
84
PEM2-S12-S5-S1
12
10.8~13.2
5
40
400
2
75
82
PEM2-S12-S12-S
12
10.8~13.2
12
17
167
2
75
84
PEM2-S12-S15-S1, *
12
10.8~13.2
15
13
133
2
75
85
PEM2-S12-D5-S
12
10.8~13.2
±5
±20
±200
2
75
80
PEM2-S12-D12-S1
12
10.8~13.2
±12
±8
±83
2
75
84
PEM2-S12-D15-S *
12
10.8~13.2
±15
±7
±67
2
75
84
PEM2-S15-S5-S
15
13.5~16.5
5
40
400
2
75
80
PEM2-S15-D15-S
15
13.5~16.5
±15
±7
±67
2
75
84
PEM2-S24-S5-S
24
21.6~26.4
5
40
400
2
75
80
PEM2-S24-S12-S1
24
21.6~26.4
12
17
167
2
75
84
1
PEM2-S24-S15-S
24
21.6~26.4
15
13
133
2
75
86
PEM2-S24-S24-S1
24
21.6~26.4
24
8
83
2
75
86
PEM2-S24-D5-S
24
21.6~26.4
±5
±20
±200
2
75
80
PEM2-S24-D12-S1
24
21.6~26.4
±12
±8
±83
2
75
84
PEM2-S24-D15-S
24
21.6~26.4
±15
±7
±67
2
75
84
1
1
1
1,
1
1
1
Notes:
1. UL approved
2. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 μF ceramic and 10 μF electrolytic capacitors on the output.
3. * Discontinued model.
cui.com
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: PEM2-S │ DESCRIPTION: DC-DC CONVERTER
date 09/13/2022 │ page 2 of 6
PART NUMBER KEY
PEM2 - SXX - XXX -S
Base Number
Output
S = single
D = dual
Input Voltage
Output Voltage
Packaging Style
SIP
INPUT
parameter
conditions/description
min
typ
max
units
operating input voltage
5 Vdc input models
12 Vdc input models
15 Vdc input models
24 Vdc input models
4.5
10.8
13.5
21.6
5
12
15
24
5.5
13.2
16.5
26.4
Vdc
Vdc
Vdc
Vdc
surge voltage
for maximum of 1 second
5 Vdc input models
12 Vdc input models
15 Vdc input models
24 Vdc input models
-0.7
-0.7
-0.7
-0.7
9
18
21
30
Vdc
Vdc
Vdc
Vdc
filter
capacitance filter
max
units
±1.2
OUTPUT
parameter
min
typ
line regulation
for Vin change of 1%
load regulation
measured from 10% load to full load
5 Vdc output models
12 Vdc output models
15 Vdc output models
24 Vdc output models
voltage accuracy
see tolerance envelope curves
voltage balance
dual output, balanced loads
±0.5
switching frequency
100% load, nominal input voltage
100
temperature coefficient
100% load
12
8
7
6
±1
kHz
±0.03
%/°C
max
units
1
s
max
units
PROTECTIONS
parameter
short circuit protection1
12, 15, & 24 Vdc input models; PEM2-S5-S24-S, PEM2-S5-D24-S
all other models: continuous, automatic recovery
Notes:
min
typ
1. The supply voltage must be discontinued at the end of the short circuit duration
SAFETY AND COMPLIANCE
parameter
isolation voltage
input to output, for 1 minute at 1 mA max.
3,000
Vdc
isolation resistance
input to output, at 500 Vdc
1,000
MΩ
safety approvals2
certified to 62368-1: EN
certified to 60950-1: UL
conducted/radiated emissions
CISPR32/EN55032 class B (external circuit required, see Figure 1)
ESD
IEC/EN61000-4-2, class B, contact ± 8kV for single outputs
IEC/EN61000-4-2, class B, contact ± 6kV for dual outputs
MTBF
as per MIL-HDBK-217F @ 25°C
RoHS
2011/65/EU
Notes:
min
3,500,000
2. See specific models noted on page 1
cui.com
typ
hours
Product Page
3D Model
PCB Footprint
date 09/13/2022 │ page 3 of 6
ENVIRONMENTAL
parameter
min
max
units
operating temperature
see derating curve
-40
105
°C
-55
125
°C
95
storage temperature
storage humidity
non-condensing
temperature rise
at full load, Ta = 25°C
typ
25
°C
SOLDERABILITY
parameter
hand soldering
wave soldering1
Notes:
min
typ
max
units
1.5 mm from case for 10 seconds
300
°C
see wave soldering profile
260
°C
max
units
1. Preheat conditions: At 120°C for over 1 minute.
MECHANICAL
parameter
dimensions
19.65 x 7.05 x 10.16 (0.774 x 0.278 x 0.400 inch)
min
case material
plastic (UL94-V0)
weight
typ
mm
2.4
g
MECHANICAL DRAWING
PIN CONNECTIONS
PIN
Single Output
Dual Output
1
Vin
Vin
2
GND
GND
5
0V
-Vo
6
No Pin
0V
7
+Vo
+Vo
Front View
Grid Size: 2.54mm x 2.54mm
19.65 [0.774]
PCB Layout
Top View
Bottom View
cui.com
7.05 [0.278]
10.16 [0.400]
units: mm[inch]
tolerance: ±0.25[±0.010]
pin section tolerance: ±0.10[±0.004]
Product Page
3D Model
PCB Footprint
date 09/13/2022 │ page 4 of 6
DERATING CURVES
EMC RECOMMENDED CIRCUIT
Figure 1
Table 1
Recommended external circuit components
Vin
(Vdc)
C1, C2
CY
LDM
5
4.7μF/50V
6.8μH
12
4.7μF/50V
6.8μH
15
4.7μF/50V
6.8μH
24
4.7μF/50V
1nF/3kV
6.8μH
Note: 1. See Table 3 for Cout values.
TEST CONFIGURATION
Figure 2
Table 2
External components
Lin
4.7μH
Cin
220μF, ESR < 1.0Ω
at 100 kHz
Note: Input reflected-ripple current is measured with an inductor Lin and Capacitor Cin to simulate source impedance.
cui.com
Product Page
3D Model
PCB Footprint
date 09/13/2022 │ page 5 of 6
APPLICATION NOTES
1. Output load requirement
To ensure this module can operate efficiently and reliably, the minimum output load may not be less than 10% of the full load during
operation. If the actual output power is low, connect a resistor at the output end in parallel to increase the load.
2. Overload Protection
Under normal operating conditions, the output circuit of this product has no protection against overload. The simplest method to add
this is to add a circuit breaker to the circuit.
3. Recommended circuit
If you want to further decrease the input/output ripple, you can increase the capacitance accordingly or choose capacitors with low
ESR (see Figure 3 & Table 3). However, the capacitance of the output filter capacitor must be appropriate. If the capacitance is too
high, a startup problem might arise. For every channel of the output, to ensure safe and reliable operation, the maximum capacitance
must be less than the maximum capacitive load (see Table 4).
Figure 3
Single Output
Dual Output
Table 3
Vin
(Vdc)
Cin
(µF)
Single Vo
(Vdc)
Cout
(µF)
Table 4
Dual Vo
(Vdc)
Cout
(µF)
Single Vout
(Vdc)
Max. Capacitive Load
(μF)
Dual Vout
(Vdc)
Max. Capacitive Load1
(μF)
5
4.7
5
10
±5
4.7
5
220
5
100
12
2.2
12
2.2
±12
1
12
220
12
100
15
2.2
15
1
±15
0.47
15
220
15
100
24
1
24
1
±24
0.47
24
220
24
100
Note:
1. For each output.
4. Output Voltage Regulation and Over-voltage Protection Circuit
The device for output voltage regulation, over-voltage and over-current protection is a linear regulator and a capacitor filtering
network with overheat protection, which can be connected to the input or output end in series (see Figure 4). The recommended
capacitance of its filter capacitor (see Table 1), and the linear regulator is based on the actual voltage and current required.
Single Output
Figure 4
Dual Output
Note:
1. Operation under minimum load will not damage the converter; however, they may not meet all specifications listed.
2. Max. capacitive load tested at input voltage range and full load.
3. All specifications measured at: Ta=25°C, humidity
很抱歉,暂时无法提供与“PEM2-S12-D12-S”相匹配的价格&库存,您可以联系我们找货
