410-293-A
410-293-A
    DIGILENT(迪芝伦)
    POWERBRICK12VUSB
410-293-A 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com PowerBRICK Reference Manual Revised February 26, 2015 Overview PowerBRICKs are split-rail power supply modules that are intended to be used with a breadboard. These generate both a negative and positive voltage out of a single 5V USB voltage. There are four output voltage options: 1. 2. 3. 4. PowerBRICK 3.3: Outputs +/-3.3V PowerBRICK 5: Outputs +/-5V PowerBRICK 9: Outputs +/-9V PowerBRICK 12: Outputs +/-12V Input Voltage Input voltage can be provided either through the USB connector or the +Vin pin header. The USB connector is used only as a voltage input source, while the pin header is used either as an input or output. When a USB power source is attached, the pin header becomes an output and gives access to the USB voltage. This way the user can chain more PowerBRICKs by connecting together the +Vin pins. Note that the first PowerBRICK in the chain limits the input current. The entire chain can deliver a total output power of 2.2W, with each individual PowerBrick limited to the values specified in the tables below. For maximum output capabilities (current and capacitive load) each PowerBrick should be powered individually either through the USB connector or +Vin pin. The following tables specify output capabilities when supplied individually. Min. Typ. Max. Vin (USB or pin +Vin) 4.5V 5V 5.5V Output voltage on pin +Vin 4V 5V 5.5V DOC#: 514-008 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 3 PowerBRICK Reference Manual Output Capabilities PowerBRICK 3.3 -Vout -3.43V -3.3V Max Output Current for -Vout -320mA Max Capacitive Load for -Vout 47uF Vout 3.16V 3.3V Max Output Current for Vout 350mA Max Capacitive Load for Vout 22uF -3.16V 3.43V PowerBRICK 5 -Vout -5.2V -5V Max Output Current for -Vout -200mA Max Capacitive Load for -Vout 47uF Vout 4.8V 5V -4.8V 5.2V Max Output Current for Vout 250mA Max Capacitive Load for Vout 22uF PowerBRICK 9 -Vout -9.36V -9V Max Output Current for -Vout 130mA Max Capacitive Load for -Vout 47uF Vout 8.64V 9V 9.36V Max Output Current for Vout 130mA Max Capacitive Load for Vout 22uF Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. -8.64V Page 2 of 3 PowerBRICK Reference Manual PowerBRICK 12 -Vout -12.48V -12V Max Output Current for Vout 100mA Max Capacitive Load for Vout 47uF Vout 11.52V 12V Max Output Current for Vout 100mA Max Capacitive Load for Vout 22uF Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. -11.52V 12.48V Page 3 of 3
410-293-A 价格&库存
很抱歉,暂时无法提供与“410-293-A”相匹配的价格&库存,您可以联系我们找货
