Additional Resources:
Product Page
3D Model
PCB Footprint
date
07/13/2021
page
1 of 5
SERIES: VAT2-SMT │ DESCRIPTION: DC-DC CONVERTER
FEATURES
2 W isolated output
industry standard 14 pin SMT package
dual unregulated outputs
1,000 Vdc isolation
short circuit protection
wide temperature (-40~105°C)
efficiency up to 85%
RoHS
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
and noise1
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
max
(mVp-p)
typ
VAT2-S5-D5-SMT*
5
4.5~5.5
±5
±20
±200
2
150
82
VAT2-S5-D9-SMT*
5
4.5~5.5
±9
±12
±111
2
150
83
VAT2-S5-D12-SMT
5
4.5~5.5
±12
±9
±83
2
150
84
VAT2-S5-D15-SMT*
5
4.5~5.5
±15
±7
±67
2
150
82
VAT2-S12-D5-SMT*
12
10.8~13.2
±5
±20
±200
2
150
83
VAT2-S12-D9-SMT*
12
10.8~13.2
±9
±12
±111
2
150
84
VAT2-S12-D12-SMT*
12
10.8~13.2
±12
±9
±83
2
150
84
VAT2-S12-D15-SMT*
12
10.8~13.2
±15
±7
±67
2
150
85
Notes:
1. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 μF ceramic and 10 μF electrolytic capacitors on the output.
*. Discontinued
PART NUMBER KEY
VAT2 - SXX - DXX -SMT - X
Output Voltage
Base Number
Input Voltage
Package Options
"blank" = standard
TR = Tape & Reel
Packaging Style
cui.com
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: VAT2-SMT │ DESCRIPTION: DC-DC CONVERTER
date 07/13/2021 │ page 2 of 5
INPUT
parameter
conditions/description
min
typ
max
units
operating input voltage
5 Vdc model
12 Vdc model
4.5
10.8
5
12
5.5
13.2
Vdc
Vdc
parameter
min
typ
line regulation
for Vin change of 1%
load regulation
measured from 10%
load to full load
voltage accuracy
see derating curves
switching frequency
100% load
temperature coefficient
100% load
OUTPUT
5 Vdc models
9 Vdc models
12 Vdc models
15 Vdc models
12.8
8.3
6.8
6.3
max
units
±1.2
15
10
10
10
70
kHz
±0.03
%/°C
max
units
1
s
max
units
PROTECTIONS
parameter
min
typ
SAFETY AND COMPLIANCE
parameter
min
typ
isolation voltage
input to output for 1 minute at 1 mA max.
1,000
Vdc
isolation resistance
input to output at 500 Vdc
1,000
MΩ
conducted emissions
CISPR22/EN55022, class A (external circuit required, see Figure 1)
ESD
IEC/EN 61000-4-2, class B, contact ±6kV
MTBF
as per MIL-HDFK-217 at 25 °C
RoHS
2011/65/EU
3,500,000
hours
ENVIRONMENTAL
parameter
min
max
units
operating temperature
see derating curve
-40
105
°C
-55
125
°C
95
storage temperature
storage humidity
non-condensing
temperature rise
at full load
reflow soldering
see reflow soldering profile
typ
25
°C
245
cui.com
°C
Product Page
3D Model
PCB Footprint
date 07/13/2021 │ page 3 of 5
MECHANICAL
parameter
dimensions
17.78 x 12.70 x 6.00 (0.700 x 0.500 x 0.236 inch)
min
case material
plastic (UL94-V0)
typ
max
mm
weight
2.1
g
MECHANICAL DRAWING
units: mm [inches]
tolerance: ±0.25 [±0.010]
pin section tolerance: ±0.10 [±0.004]
PIN CONNECTIONS
PIN
FUNCTION
1
GND
2
+Vin
5
-Vo
6
0V
7
+Vo
10
-Vo
others
NC
DERATING CURVES
EMC RECOMMENDED CIRCUIT
Figure 1
Table 1
Recommended external circuit
components
cui.com
units
Vout
(Vdc)
C1
C2
5
2.2μF/50V
4.7μF
9
2.2μF/50V
2.2μF
12
2.2μF/50V
1μF
15
2.2μF/50V
0.47μF
Product Page
3D Model
PCB Footprint
date 07/13/2021 │ page 4 of 5
APPLICATION NOTES
1. Output load requirement
To ensure this module can operate efficiently and reliably, the minimum output load may not be less than 10% of the full load during
operation. If the actual output power is low, connect a resistor at the output end in parallel to increase the load.
2. Overload Protection
Under normal operating conditions, the output circuit of this product has no protection against overload. The simplest method to add
this is to add a circuit breaker to the circuit.
3. Recommended circuit
If you want to further decrease the input/output ripple, you can increase the capacitance accordingly or choose capacitors with low
ESR (see Figure 2 & Table 2). However, the capacitance of the output filter capacitor must be appropriate. If the capacitance is too
high, a startup problem might arise. For every channel of the output, to ensure safe and reliable operation, the maximum capacitance
must be less than the maximum capacitive load (see Table 3).
Figure 2
Table 2
Note:
Table 3
Vin
(Vdc)
Cin
(µF)
Dual Vo
(Vdc)
Cout
(µF)
Dual Vout
(Vdc)
Max. Capacitive Load1
(μF)
5
4.7
±5
4.7
5
100
12
2.2
±9
2.2
9
100
±12
1
12
100
±15
0.47
15
Note:
It’s not recommended to connect any external capacitors in
applications with less than 0.5 watt output.
100
1. For each output.
4. Output Voltage Regulation and Over-voltage Protection Circuit
The device for output voltage regulation, over-voltage and over-current protection is a linear regulator and a capacitor filtering network with overheat protection which can be connected to the input or output end in series (see Figure 3). The recommended capacitance of its filter capacitor (see Table 3), and the linear regulator is based on the actual voltage and current required.
Figure 3
Note:
1.
2.
3.
4.
Operation under minimum load will not damage the converter; however, they may not meet all specifications listed.
Max. capacitive load tested at input voltage range and full load.
It is recommended to use either ceramic capacitors or electrolytic capacitors on the input and the output. Using tantalum capacitors may increase the risk of failure.
All specifications measured at: Ta=25°C, humidity
很抱歉,暂时无法提供与“VAT2-S12-D9-SMT-TR”相匹配的价格&库存,您可以联系我们找货
