Additional Resources:
Product Page
3D Model
PCB Footprint
date
11/15/2021
page
1 of 6
SERIES: PQMC3-S │ DESCRIPTION: DC-DC CONVERTER
FEATURES
3 W isolated output
smaller package
single/dual regulated output
1,500 Vdc isolation
continuous short circuit
temperature range (-40~105°C)
high efficiency at light load
efficiency up to 84%
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
and noise1
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
max
(mVp-p)
typ
PQMC3-D5-S5-S
5
4.5~9
5
25
500
2.5
75
73
PQMC3-D5-S9-S
5
4.5~9
9
14
278
2.5
75
74
PQMC3-D5-S12-S
5
4.5~9
12
10
208
2.5
75
77
PQMC3-D5-S15-S
5
4.5~9
15
8
167
2.5
75
74
PQMC3-D5-D5-S
5
4.5~9
±5
±13
±250
2.5
75
74
PQMC3-D5-D12-S
5
4.5~9
±12
±5
±104
2.5
75
77
PQMC3-D5-D15-S
5
4.5~9
±15
±4
±83
2.5
75
77
PQMC3-D12-S3-S
12
9~18
3.3
38
758
2.5
75
75
PQMC3-D12-S5-S
12
9~18
5
30
600
3
75
76
PQMC3-D12-S9-S
12
9~18
9
17
333
3
75
79
PQMC3-D12-S12-S
12
9~18
12
13
250
3
75
82
PQMC3-D12-S15-S
12
9~18
15
10
200
3
75
83
PQMC3-D12-S24-S
12
9~18
24
6
125
3
75
81
PQMC3-D12-D5-S
12
9~18
±5
±15
±300
3
75
78
PQMC3-D12-D12-S
12
9~18
±12
±6
±125
3
75
79
PQMC3-D12-D15-S
12
9~18
±15
±5
±100
3
75
80
PQMC3-D24-S3-S
24
18~36
3.3
38
758
2.5
75
74
PQMC3-D24-S5-S
24
18~36
5
30
600
3
75
81
PQMC3-D24-S9-S
24
18~36
9
17
333
3
75
83
PQMC3-D24-S12-S
24
18~36
12
13
250
3
75
83
PQMC3-D24-S15-S
24
18~36
15
10
200
3
75
83
PQMC3-D24-S24-S
24
18~36
24
6
125
3
75
83
PQMC3-D24-D5-S
24
18~36
±5
±15
±300
3
75
79
PQMC3-D24-D9-S
24
18~36
±9
±8
±167
3
75
81
PQMC3-D24-D12-S
24
18~36
±12
±6
±125
3
75
83
PQMC3-D24-D15-S
24
18~36
±15
±5
±100
3
75
83
PQMC3-D48-S3-S
48
36~75
3.3
38
758
2.5
75
75
PQMC3-D48-S5-S
48
36~75
5
30
600
3
75
76
cui.com
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: PQMC3-S │ DESCRIPTION: DC-DC CONVERTER
MODEL
(CONTINUED)
input
voltage
date 11/15/2021 │ page 2 of 6
output
voltage
output
current
output
power
ripple
and noise1
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
typ
(mVp-p)
typ
PQMC3-D48-S12-S
48
36~75
12
13
250
3
75
80
PQMC3-D48-S15-S
48
36~75
15
10
200
3
75
84
PQMC3-D48-S24-S
48
36~75
24
6
125
3
75
82
PQMC3-D48-D5-S
48
36~75
±5
±15
±300
3
75
79
PQMC3-D48-D12-S
48
36~75
±12
±6
±125
3
75
82
PQMC3-D48-D15-S
48
36~75
±15
±5
±100
3
75
82
Notes:
1. ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 μF ceramic and 10 μF electrolytic capacitors on the output.
PART NUMBER KEY
PQMC3 - DXX - XXX -S
Base Number
Output
S = single
D = dual
Input Voltage
Packaging Style
SIP
Output Voltage
INPUT
parameter
conditions/description
min
typ
max
units
operating input voltage
5 Vdc input models
12 Vdc input models
24 Vdc input models
48 Vdc input models
4.5
9
18
36
5
12
24
48
9
18
36
75
Vdc
Vdc
Vdc
Vdc
start-up voltage
5 Vdc input models
12 Vdc input models
24 Vdc input models
48 Vdc input models
3.5
4.5
11
24
4
8
16
33
4.5
9
18
36
Vdc
Vdc
Vdc
Vdc
surge voltage
for maximum of 1 second
5 Vdc input models
12 Vdc input models
24 Vdc input models
48 Vdc input models
-0.7
-0.7
-0.7
-0.7
12
25
50
100
Vdc
Vdc
Vdc
Vdc
filter
capacitance filter
models ON (CTRL open or insulated)
CTRL2
Notes:
models OFF (connect voltage, current into CTRL is
5~10mA)
2. See application notes on page 6.
OUTPUT
parameter
typ
max
units
line regulation
full load, input voltage from low to high
±0.2
±0.5
load regulation
5% to 100% load
±0.6
±1
voltage accuracy
5% to 100% load
±1
±3
no-load voltage accuracy
PQMC3-D12-S3-S & PQMC3-D48-S3-S
all other models
±1.5
±8
±5
voltage balance3
dual output, balanced loads
±0.5
±1
switching frequency
100% load, nominal input voltage, PFM mode
250
transient recovery time
25% load step change
0.5
3
ms
transient response deviation
±2.5
±5
temperature coeffecient
100% load
±0.02
±0.03
%/°C
Notes:
min
3. For dual output models, unbalanced loads should not exceed ±5%. If ±5% is exceeded, it may not meet all specifications.
cui.com
kHz
Product Page
3D Model
PCB Footprint
date 11/15/2021 │ page 3 of 6
PROTECTIONS
parameter
short circuit protection
continuous, automatic recovery
min
typ
max
units
min
typ
max
units
SAFETY AND COMPLIANCE
parameter
isolation voltage
input to output for 1 minute at 1 mA max.
1,500
Vdc
isolation resistance
input to output at 500 Vdc
1,000
MΩ
conducted emissions
CISPR22/EN55022, class B (external circuit required, see Figure 1-b)
radiated emissions
ESD
IEC/EN61000-4-2, class B, contact ± 4kV
radiated immunity
IEC/EN61000-4-3, class A, 10V/m
EFT/burst
IEC/EN61000-4-4, class B, ± 2kV (external circuit required, see Figure 1-a)
surge
IEC/EN61000-4-5, class B, ± 2kV (external circuit required, see Figure 1-a)
conducted immunity
IEC/EN61000-4-6, class A, 3 Vr.m.s
voltage dips & interruptions
IEC/EN61000-4-29, class B, 0%-70%
MTBF
as per MIL-HDBK-217F @ 25°C
RoHS
2011/65/EU
1,000,000
hours
ENVIRONMENTAL
parameter
min
max
units
operating temperature
see derating curve
-40
105
°C
-55
125
°C
95
storage temperature
storage humidity
non-condensing
temperature rise
at full load, Ta=25°C
typ
25
°C
SOLDERABILITY
parameter
hand soldering
wave soldering
min
typ
max
units
1.5 mm from case for 10 seconds
300
°C
see wave soldering profile
260
°C
max
units
MECHANICAL
parameter
dimensions
22.00 x 9.50 x 12.00 (0.866 x 0.374 x 0.472 inch)
min
case material
plastic (UL94-V0)
weight
typ
mm
4.9
DERATING CURVES
cui.com
g
Product Page
3D Model
PCB Footprint
date 11/15/2021 │ page 4 of 6
MECHANICAL DRAWING
PIN CONNECTIONS
Ø1.00 [0.039]
0.50[0.020]
12.00
[0.472]
units: mm[inch]
tolerance: ±0.25[±0.010]
pin section tolerance: ±0.10[±0.004]
PIN
Single Output
Dual Output
1
GND
GND
2
Vin
Vin
Front View
3
Ctrl
Ctrl
22.00 [0.866]
5
NC
NC
6
+Vo
+Vo
7
0V
0V
8
CS
-Vo
1
2
3
5
6
7
8
2.50
[0.098]
1
NC: No Connection
2
3
5
PCB Layout
Top View
2.54[0.100]
0.30 [0.012]
9.50
[0.374]
4.10 [0.161]
6
7
8
0.50[0.020]
17.78 [0.700]
Bottom View
EMC RECOMMENDED CIRCUIT
Figure 1
Recommended external circuit components
Vin (Vdc)
5
FUSE
MOV
12
24
48
choose according to practical input current
S14K35
S14K60
LDM1
56μH
56μH
TVS
SMCJ13A
SMCJ28A
SMCJ48A
SMCJ90A
C0
680μF/16V
680μF/25V
330μF/50V
330μF/100V
C1
4.7μF/50V
4.7μF/50V
4.7μF/50V
4.7μF/100V
Table 1
LDM2
12μH
12μH
12μH
12μH
C2
4.7μF/50V
4.7μF/50V
4.7μF/50V
4.7μF/100V
CY
1nF/2kV
1nF/2kV
1nF/2kV
1nF/2kV
D1
RB160M-60/1A
RB160M-60/1A
RB160M-60/1A
RB160M-60/1A
VC − VD − 1.0
−300
aaaaaaaaaaaa
IC
R=
Follows:aaaaa
aaaaa
R
Cd
47nF/100V
47nF/100V
47nF/100V
47nF/100V
Note: Figure 1-c is on/off control circuit. See page 6 for details.
TEST CONFIGURATION
External components
Figure 2
Table 2
Note: Input reflected-ripple current is measured with an inductor Lin and Capacitor Cin to simulate source impedance.
cui.com
Lin
4.7μH
Cin
220μF, ESR < 1.0Ω
at 100 KHz
Grid Size:
2.54mm x 2.54mm
Product Page
3D Model
PCB Footprint
date 11/15/2021 │ page 5 of 6
APPLICATION NOTES
1. Output load requirement
To ensure this module can operate efficiently and reliably, the minimum output load may not be less than 5% of the full load during
operation. If the actual output power is low, connect a resistor at the output end in parallel to increase the load.
2. Recommended circuit
This series has been tested according to the following recommended testing circuit before leaving the factory. This series should
be tested under load (see Figure 3 and Table 3). If you want to further decrease the input/output ripple, you can increase the
capacitance accordingly or choose capacitors with low ESR. However, the capacitance of the output filter capacitor must be
appropriate. If the capacitance is too high, a startup problem might arise. For every channel of the output, to ensure safe and reliable
operation, the maximum capacitance must be less than the maximum capacitive load (see Table 4).
Single output
Dual output
Figure 3
Table 3
Table 4
Vin
(Vdc)
Cin1
(µF)
Cin2
(µF)
Lin
(µH)
Cs1
(µF)
Cout
(µF)
Lout2
(µH)
Cd
(nF/V)
5
100
47
4.7~12
10~22
100
2.2~10
47/100
12
100
47
4.7~12
10~22
100
2.2~10
47/100
24
10
1
4.7~12
10~22
100
2.2~10
47/100
48
10
1
4.7~12
10~22
100
2.2~10
47/100
Note:
1. For single output only
2. For dual output only
Single
Vout
(Vdc)
Max. Capacitive
Load
(μF)
Dual
Vout
(Vdc)
Max. Capacitive
Load1
(μF)
3.3
2700
5
2200
5
1000
9
1000
9
680
12
680
12
470
15
470
15
330
24
Note:
330
1. For each output.
3. CTRL Terminal
When open or applied high impedance, the converter will turn on. When it’s pulled high, the converter will shutdown. The input
current should between 5~10mA. Exceeding the maximum 20mA will cause permanent damage to the converter. The value for R can
be derived as follows:
V − VD − 1.0
−300
R= C
IC
Vc: Control pin input voltage
VD: Forward voltage drop of diode D1
IC: Input current to control pin
R: Resistor of control circuit
Figure 4
4. Input Current
When it is used in an unregulated condition, make sure that the input fluctuations and ripple voltage do not exceed the module
standard. Refer to Figure 5 and Table 5 for the startup current of this dc-dc module.
Figure 5
Note:
Table 5
Vin
(Vdc)
Ip
(mA)
5
1110
12
640
24
325
48
160
1. Minimum load shouldn't be less than 5%, otherwise ripple may increase dramatically. Operation under minimum load will not damage the converter, however, they may
not meet all specifications listed.
2. Maximum capacitive load is tested at input voltage range and full load.
3. All specifications are measured at Ta=25°C, humidity
