Additional Resources:
Product Page
3D Model
date 04/22/2022
page
1 of 13
MODEL: NDM2Z-12V Ϳ DESCRIPTION: AUTO COMPENSATED, DIGITAL DC-DC POL CONVERTER
MODEL
FEATURES
FRPSDFWSDFNDJH
vertical:
20.8 x 7.23 x 15.6 mm
(0.820 x 0.285 x 0.614 x in)
• 12 A output
KLJKHIILFLHQF\
• auto compensation
60%XVLQWHUIDFH
• PMBus™ Compatible
(ULFVVRQIRRWSULQWFRPSDWLEOH
(Vdc)
NDM2Z-12V
4.5~14
output current
output wattage
(Vdc)
max
(A)
max
(W)
0.6~5.0
12
60
SC
ON
PART NUMBER KEY
output voltage
TI
input voltage
ED
a9LQSXWUDQJH
a9SURJUDPPDEOHRXWSXW
YROWDJHWUDFNLQJ
YROWDJHPDUJLQLQJ
• Snapshot™ parametric capture
YROWDJHFXUUHQWWHPSHUDWXUHPRQLWRULQJ
V\QFKURQL]DWLRQDQGSKDVHVSUHDGLQJ
UHPRWHGLIIHUHQWLDOYROWDJHVHQVH
SURJUDPPDEOHVRIWVWDUWDQGVRIWVWRS
IDXOWPDQDJHPHQW
NU
GENERAL CHARACTERISTICS
NDM2Z-12V - X X - XXX
Base Number
DI
3LQ&RQ¿JXUDWLRQ
A = standard
FRQ¿JXUDWLRQ
3DFNDJH2SWLRQ
A = loose parts
B = tape and reel
& WUD\
)LUPZDUH&RQ¿JXUDWLRQ
000~ZZZ
Example part number: NDM2Z-12V-AA-002
vertical module
VWDQGDUGSLQFRQ¿JXUDWLRQ
ORRVHSDUWVSDFNDJHRSWLRQ
¿UPZDUHFRQ¿JXUDWLRQ
CONTENTS
$EVROXWH0D[LPXP5DWLQJV
5HFRPPHQGHG2SHUDWLQJ&RQGLWLRQV
Pin Descriptions................................................3
7\SLFDO&KDUDFWHULVWLFVa
0HFKDQLFDO'UDZLQJ
2SHUDWLQJ,QIRUPDWLRQa
cui.com
Product Page
3D Model
CUI Inc Ϳ MODEL: NDM2Z-12V Ϳ DESCRIPTION: AUTO COMPENSATED, DIGITAL DC-DC POL CONVERTER
date 04/22/2022 Ϳ page 2 of 13
ABSOLUTE MAXIMUM RATINGS
conditions/description
min
typ
max
units
Vin
LQSXWYROWDJH
GLJLWDOSLQYROWDJH
CTRL, DDC, SA0, SALRT, SDA, SCL, SYNC, VSET
-0.3
15
V
6.5
V
DQDORJSLQYROWDJH
+S, -S, VTRK
-0.3
6.5
V
JURXQGYROWDJHGLϑHUHQWLDO
(GND - PREF)
-0.3
0.3
V
RSHUDWLQJWHPSHUDWXUH
TP1
-40
120
°C
-55
125
°C
ED
parameter
VWRUDJHWHPSHUDWXUH
RECOMMENDED OPERATING CONDITIONS
NU
-30°C < TP1 < +95°C, 4.5 V < Vin9W\SLFDOPHDVXUHPHQWVPDGHDW9in = 12 V, Vout 9,out ,max, TP1 = 25°C,
=Cin Nj)Pƻ&out Nj)Pƻ
INPUT / OUTPUT
parameter
Vin
LQSXWVXSSO\YROWDJH
,out
output current
min
max
units
4.5
typ
14
V
A
adjustable via resistor or PMBus™ commands
5.0
V
adjustable via PMBus commands
YROWDJHDFFXUDF\
over line, load and temperature
measured at +S and -S
-1
1
V Vin 14 V
= 0.6 V
= 1.0 V
= 1.8 V
= 3.3 V
0.6
TI
Vout
Vout PDUJLQ
ORDGUHJXODWLRQ
0 A ,out ,max
Vout = 0.6 V
Vout = 1.0 V
Vout = 1.8 V
Vout = 3.3 V
YROWDJHVHWSRLQWUHVROXWLRQ
ZKHQ9out set via PMBus commands
YROWDJHULSSOHDQGQRLVH
Vout
Vout
Vout
Vout
ramp-up time
ms
RQWLPHGHOD\
5
500,000
ms
SC
ON
OLQHUHJXODWLRQ
4.5
Vout
Vout
Vout
Vout
0.6
1.0
1.8
3.3
0.3
0.6
0.4
2.2
2.8
2.3
2.0
3.1
-0.025
0.025
31
38
52
85
ORDGWUDQVLHQWUHFRYHU\WLPH1
,outRI,maxG,GW $NjV
Vout = 0.6 V
Vout = 1.0 V
Vout = 1.8 V
Vout = 3.3 V
TBD
DI
ORDGWUDQVLHQWYROWDJHGHYLDWLRQ
VHWWOLQJWRZLWKLQRI9out
cui.com
mV
9
14
17
16
V
V
V
V
,outRI,maxG,GW $NjV
Vout = 0.6 V
Vout = 1.0 V
Vout = 1.8 V
Vout = 3.3 V
1RWHV
mV
% FS
mVp-p
mV
µs
Product Page
3D Model
date 04/22/2022 Ϳ page 3 of 13
POWER / EFFICIENCY
min
RXWSXWSRZHU
Vout 9PDUJLQ
,out RIPD[
Vout
Vout
Vout
Vout
0.6
1.0
1.8
3.3
V
V
V
V
,out = max
Vout
Vout
Vout
Vout
0.6
1.0
1.8
3.3
V
V
V
V
HϒFLHQF\
VZLWFKLQJIUHTXHQF\
FAULT PROTECTION
min
RXWSXWRYHUYROWDJHSURWHFWLRQ
293DGMXVWDEOHYLD30%XVFRPPDQGV
output over current protection
2&3DGMXVWDEOHYLD30%XVFRPPDQGV
LQSXWXQGHUYROWDJHSURWHFWLRQ
LQSXWRYHUYROWDJHSURWHFWLRQ
over temperature protection
273PHDVXUHGRQWKHPRGXOH
WKHUPDOSURWHFWLRQK\VWHUHVLV
GLϑHUHQFHEHWZHHQWHPSHUDWXUHIDXOWDQGZDUQLQJ
TI
parameter
SC
ON
max
units
66
W
83.6
87.9
90.4
90.8
81.1
86.5
89.8
91.2
0.45
0.58
0.94
1.78
0.13
W
320
N+]
NU
Vout = 0.6 V
Vout = 1.0 V
Vout = 1.8 V
Vout = 3.3 V
CTRL deasserted
LGOHSRZHU
typ
ED
parameter
typ
max
units
5.6
V
TBD
A
4.5
14
V
125
°C
15
°C
POWER CONNECTIONS
symbol
9,1
GND
9287
pin
IO type
description
1A
3RZHU
,QSXWYROWDJH
2A
Ground
3RZHUJURXQG
3A
3RZHU
2XWSXWYROWDJH
COMMUNICATION CONNECTIONS
symbol
pin
IO type
description
+S
4A
$QDORJ
2XWSXWYROWDJHSRVLWLYHVHQVHLQSXW
4B
$QDORJ
2XWSXWYROWDJHQHJDWLYHVHQVHLQSXW
5A
'LJLWDO
2XWSXWYROWDJHSLQVWUDS
VTRK
5B
$QDORJ
9ROWDJHWUDFNLQJLQSXW
SALRT
6A
'LJLWDO
SMBus alert
SDA
6B
'LJLWDO
SMBus data
SCL
7A
'LJLWDO
SBMBus clock
SYNC
7B
'LJLWDO
6\QFKURQL]DWLRQ,2
SA0
8A
'LJLWDO
SMBus Address pinstrap
CTRL
8B
'LJLWDO
Remote control or enable pin
DDC
9A
'LJLWDO
'LJLWDO'&&RPPXQLFDWLRQVEXVHTXLYDOHQWWR(ULFVVRQ3RZHU*&%
PREF
9B
Ground
3LQVWUDSJURXQG
-S
DI
VSET
cui.com
V
Product Page
3D Model
date 04/22/2022 Ϳ page 4 of 13
LOGIC INPUT/OUTPUT CHARACTERISTICS
parameter
min
LQSXWKLJKYROWDJH9,+)
CTRL, DDC, SA0, SCL, SDA, SYNC, VSET
LQSXWORZYROWDJH9,/)
RXWSXWKLJKYROWDJH92+)
DDC, SALRT, SDA, SYNC
RXWSXWORZYROWDJH92/)
max
units
0.8
V
2
V
V
ED
2.25
OUTPUT DECOUPLING CAPACITOR RECOMMENDATION
min
total output capacitance located on host board
300
typ
NU
parameter
C287
DDC CONFIGURATION REQUIREMENTS
typ
0.4
V
max
units
15,000
µF
$SXOOXSUHVLVWRULVUHTXLUHGRQWKH''&LQRUGHUWRJXDUDQWHHWKHULVHWLPHDVIROORZV
Rise TimeDDC = RDDC * CDDC < 1 µs
RDDC is the DDC pull-up resistor and CDDCLVWKH''&FDSDFLWLYHORDGLQJ7KHSXOOXSUHVLVWRUVKRXOGEHWLHGWRDQH[WHUQDO9RU9
VXSSO\7KHGHVLJQHUQHHGVWRHQVXUHWKDWWKHUHVLVWRUSXOOXSYROWDJHLVSUHVHQWGXULQJPRGXOHSRZHUXS(DFKPRGXOHFRQQHFWHGWR
WKH''&SUHVHQWVaS)HDFKLQFKRI)53&%WUDFHLQWURGXFHVaS)RIFDSDFLWLYHORDGLQJ
TI
SMBUS CONFIGURATION REQUIREMENTS
SC
ON
7KHFRPSOHWHVSHFL¿FDWLRQVIRUWKH60%XVFDQEHIRXQGRQWKHIROORZLQJZHESDJHVZZZSPEXVLQIRVPEXVRUJ
TYPICAL CHARACTERISTICS
TP1 = 25°C, Vin = 12 V, Cin = 470 µF/10 mCout = 470 µF/8 m, Iout = Imax
DI
Conditions (applies to all graphs unless stated otherwise):
cui.com
Product Page
3D Model
date 04/22/2022 Ϳ page 5 of 13
TYPICAL CHARACTERISTICS (CONTINUED)
Start-up
Shut-down
(Vout = 1.0 V)
9.0
3.0 A, 2 A/µs)
Output Ripple and Noise
(Vout = 1.0 V)
DI
SC
ON
(Vout = 1.0 V, Iout = 3.0
TI
Output Load Transient Response
NU
ED
(Vout = 1.0 V)
cui.com
Product Page
3D Model
date 04/22/2022 Ϳ page 6 of 13
MECHANICAL DRAWING
DI
SC
ON
TI
NU
ED
units: mm [inches]
WROHUDQFHXQOHVVVSHFL¿HG
X.X ±0.50 [0.02]
X.XX ±0.25 [0.01]
QRWDSSOLHGRQIRRWSULQWRUW\SLFDOYDOXHV
cui.com
PIN
NUMBER
PIN
NAME
1A
9,1
2A
GND
3A
9287
4A
+S
4B
-S
5A
VSET
5B
VTRK
6A
SALRT
6B
SDA
7A
SCL
7B
SYNC
8A
SA0
8B
CTRL
9A
DDC
9B
PREF
MATERIAL
PLATING
$XNjP
over Ni 1~3
NjP
&RSSHU$OOR\
$XNjP
Product Page
3D Model
OPERATING INFORMATION
date 04/22/2022 Ϳ page 7 of 13
POWER CONVERSION AND MANAGEMENT
REQUIRED CONFIGURATIONS
Power Management Overview
The NDM2Z-12PRGXOHLQFRUSRUDWHVDZLGHUDQJHRISRZHU
PDQDJHPHQWIHDWXUHV$OOSRZHUPDQDJHPHQWIXQFWLRQV
FDQEHFRQILJXUHGYLDWKH60%XVLQWHUIDFH7KH1'0=12
FDQPRQLWRUDQGUHSRUWPDQ\FKDUDFWHULVWLFVRIWKHPRGXOH
LQFOXGLQJLQSXWYROWDJHRXWSXWYROWDJHRXWSXWFXUUHQWDQG
LQWHUQDOWHPSHUDWXUH$GGLWLRQDOO\WKH1'0=12 includes
FLUFXLWSURWHFWLRQIHDWXUHVWKDWSURWHFWWKHPRGXOHDQGORDG
IURPGDPDJHGXHWRV\VWHPIDXOWV0RQLWRULQJSDUDPHWHUV
FDQDOVREHFRQILJXUHGWRSURYLGHDOHUWVIRUVSHFLILF
FRQGLWLRQV7KHDELOLW\RI&8,PRGXOHVWRGLJLWDOO\FRQWURO
FRQILJXUHDQGPRQLWRU26IHDWXUHVSURYLGHVVLJQLILFDQW
EHQHILWVRYHUWUDGLWLRQDODQDORJ32/SURGXFWV
TI
NU
NDM2Z-12 Module Pins
Each NDM2Z-12 module should have a resistor placed
EHWZHHQ96(7DQG35()WRVHWWKHRXWSXWYROWDJHRIWKH
PRGXOH7KHPD[LPXPRXWSXWYROWDJHZKLFKFDQEH
FRQ¿JXUHGE\30%XVFRPPDQGVFDQQHYHUH[FHHGRI
WKHYROWDJHVHWE\WKH96(7SLQ7KH60%XVDGGUHVVRIHDFK
PRGXOHLVVHWE\HLWKHUSLQVWUDSFRQ¿JXUDWLRQRUUHVLVWRUYDOXHDVVRFLDWHGZLWKWKH6$SLQ0RUHLQIRUPDWLRQ
UHJDUGLQJVHWWLQJWKH60%XVDGGUHVVIRUDPRGXOHFDQEH
IRXQGLQWKHVHFWLRQWLWOHG³60%XV´
ED
Power Conversion Overview
The NDM2Z-12PRGXOHKDVVHYHUDOIHDWXUHVWRHQDEOHKLJK
SRZHUFRQYHUVLRQHIILFLHQF\1RQOLQHDUORRSUHVSRQVH1/5
improves the response time and reduces the output
GHYLDWLRQDVDUHVXOWRIORDGWUDQVLHQWV7KHLQFRUSRUDWLRQ
RI')0HQKDQFHVWKHSHUIRUPDQFHRI&8,PRGXOHVRYHUWKDW
DYDLODEOHIURPFRQYHQWLRQDODQDORJ32/RIIHULQJV
7KH1'0=PRGXOHVDUHDYDLODEOHLQGLϑHUHQW
FRQ¿JXUDWLRQVQRWDOOSLQVDQGIXQFWLRQVDUHVXSSRUWHGE\
HDFKFRQ¿JXUDWLRQ7KLVGRFXPHQWGHVFULEHVDOOSLQVDQG
IXQFWLRQV
The Novum Z Products PMBus Commands application note
GH¿QHVWKHDYDLODEOH30%XVFRPPDQGV
CONFIGURING THE MODULE
SC
ON
PCB Layout
*RRGSHUIRUPDQFHRIDQ\SRLQWRIORDGYROWDJHUHJXODWRU
PRGXOHFDQRQO\EHDFKLHYHGZLWKFDUHIXO3&%OD\RXW
FRQVLGHUDWLRQV*URXQGSODQHVRUYHU\ZLGHWUDFHVVKRXOG
EHXVHGIRUSRZHUDQGJURXQGURXWLQJ,QSXWFDSDFLWRUV
VKRXOGEHSODFHGFORVHWRWKHLQSXWYROWDJHSLQVRIWKH
module and output capacitors should be placed close to the
load. The module should also be placed as close as possible
to the load.
INPUT AND OUTPUT CAPACITORS
DI
Input Capacitors
,QSXWFDSDFLWRUVDUHUHFRPPHQGHGWREHXVHGZLWKWKH
NDM2Z-12PRGXOHLQRUGHUWRPLQLPL]HLQSXWYROWDJHULSSOH
$Nj)326&$3RUHOHFWURO\WLFDQG[Nj)FHUDPLF
capacitors should be placed as close as possible to the input
SLQVRIWKHPRGXOH$GGLWLRQDOLQSXWFDSDFLWRUVPD\EH
XVHGLIOHVVLQSXWYROWDJHULSSOHLVGHVLUHG
Output Capacitors
2XWSXWFDSDFLWRUVDUHUHFRPPHQGHGWREHXVHGZLWKWKH
NDM2Z-12 module in order to improve transient response
DQGPLQLPL]HRXWSXWYROWDJHULSSOH$Nj)326&$3RU
HOHFWURO\WLFDQG[Nj)FHUDPLFFDSDFLWRUVVKRXOGEH
placed as close as possible to the load. Additional output
FDSDFLWRUVPD\EHXVHGWRIXUWKHULPSURYHWKHRXWSXW
YROWDJHFKDUDFWHULVWLFV
Pin Settings
3LQ6$LVXVHGWRVHWWKH60%XVDGGUHVVRIWKH1'0=12
PRGXOH'HWDLOVRIWKLVIHDWXUHDUHGLVFXVVHGLQWKHVHFWLRQ
WLWOHG³60%XV´3LQ6
