PRD15-Q24-S12-N-M-TR 数据手册
Additional Resources:
Product Page
date
10/26/2020
page
1 of 14
SERIES: PRD15 Ϳ DESCRIPTION: DC-DC CONVERTER
FEATURES
MODEL
ED
U
N
up to 15 W isolated output
industry standard 1” x 1” package
4:1 input range
low ripple & noise
over voltage, over current, short circuit, and over
temperature protections
remote on/off control
output trim
-40 to 85°C temperature range
efficiency up to 89%
UL/cUL safety approval
input
voltage
W\S
(Vdc)
24
PRD15-Q24-S5
24
PRD15-Q24-S12
24
PRD15-Q24-S15
24
PRD15-Q48-S3
48
PRD15-Q48-S5
PRD15-Q48-S15
output
power
ripple
& noise1
HϒFLHQF\
(Vdc)
min
(A)
max
(A)
max
(W)
max
(mVp-p)
W\S
9~36
3.3
0.45
4.5
14.85
90
89
9~36
5
0.3
3
15
125
87.3
9~36
12
0.13
1.3
15.6
150
84.5
9~36
15
0.11
1.1
16.5
175
85
18~75
3.3
0.5
5
16.5
90
88
48
18~75
5
0.3
3
15
95
86
48
18~75
12
0.13
1.3
15.6
120
85
48
18~75
15
0.11
1.1
16.5
120
85.3
O
PRD15-Q48-S12
output
current
range
(Vdc)
N
PRD15-Q24-S3
output
voltage
TI
1RWHV
$WIXOOORDGQRPLQDOLQSXW0+]EDQGZLGWKRVFLOORVFRSHLQSXWWHUPLQDWHGZLWKDNj)FDSDFLWRUIRU9GFLQSXWPRGHOVDQGDNj)FDSDFLWRUIRU9GFLQSXW
PRGHOV2XWSXWWHUPLQDWHGZLWKNj)DQGNj)ORZ(65FDSDFLWRUV
$OOVSHFL¿FDWLRQVDUHPHDVXUHGDW7D &QRPLQDOLQSXWYROWDJHDQGUDWHGRXWSXWORDGXQOHVVRWKHUZLVHVSHFL¿HG$OOPRGHOVDUHWHVWHGDQGVSHFL¿HGZLWKDNj)
FDSDFLWRUIRU9GFLQSXWPRGHOVDQGDNj)FDSDFLWRUIRU9GFLQSXWPRGHOVRQWKHLQSXWDQGZLWKNj)DQGNj)ORZ(65FDSDFLWRUVRQWKHRXWSXW
D
IS
C
PART NUMBER KEY
PRD15 - QXX - SXX - X - X - X
Base Number
,QSXW9ROWDJH
Output Voltage
Packaging Style:
' ',3
0 607
5HPRWH2Q2ϑ&RQWURO
3 SRVLWLYHORJLF
1 QHJDWLYHORJLF
cui.com
Package Options:
³EODQN´ VWDQGDUG
(through hole
models only)
75 7DSH 5HHO
607PRGHOVRQO\
Product Page
CUI Inc Ϳ SERIES: PRD15 Ϳ DESCRIPTION: DC-DC CONVERTER
date 10/26/2020 Ϳ page 2 of 14
INPUT
conditions/description
operating input voltage
24 Vdc input models
48 Vdc input models
current
24 Vdc input models
48 Vdc input models
start-up voltage
24 Vdc input models
48 Vdc input models
under voltage shutdown
PRD15-Q24-S3
PRD15-Q24-S5
PRD15-Q24-S12, PRD15-Q24-S15
PRD15-Q48-S15
all other models
UHPRWHRQRϑ1
negative logic
models ON (10~15 Vdc or open circuit)
PRGHOV2))a9GF
models ON (-0.7~0.8 Vdc)
Vdc
Vdc
2.1
1.1
A
A
16.7
Vdc
Vdc
8.6
8.5
8.4
16.2
15.6
Vdc
Vdc
Vdc
Vdc
Vdc
N
TI
recommended to add fuse:
4 A fast blow fuse for 24 Vdc input models
2 A fast blow fuse for 48 Vdc input models
1.5 A fast blow fuse for PRD15-Q48-S12 model
input fuse
2Q2ϑFXUUHQWLVP$
OUTPUT
maximum capacitive load
ORZ(65
PRD15-Q24-S3, S5, S12 & PRD15-Q48-S3
all other models
line regulation
units
1,000
470
Nj)
Nj)
PRD15-Q48-S3
PRD15-Q48-S12
all other models
±0.2
±0.075
±0.05
PRD15-Q24-S3
PRD15-Q24-S5
PRD15-Q48-S3
PRD15-Q48-S5
all other models
±0.1
±0.075
±0.2
±0.06
±0.05
50
ms
voltage accuracy
min
W\S
O
C
load regulation
max
N
parameter
at 50% load
±1
IS
start-up time
units
36
75
PRGHOV2))a9GFRURSHQFLUFXLW
input reverse polarity protection no
Notes:
max
24
48
8.8
35'46LQGXFWDQFH¿OWHU
DOORWKHUPRGHOVFDSDFLWDQFH¿OWHU
¿OWHU
W\S
9
18
U
positive logic
min
ED
parameter
see application notes
±10
switching frequency
PRD15-Q48-S5
PRD15-Q48-S15
all other models
340
375
380
350
kHz
kHz
kHz
kHz
50-75-50% load change to 1% Vout
PRD15-Q24-S3, PRD15-Q24-S12
all other models
150
100
µs
µs
±0.02
%/°C
D
adjustability2
dynamic load response
WHPSHUDWXUHFRHϒFLHQW
1RWH
)RULQSXWYROWDJH9GF35'46FDQRQO\EHWULPPHGGRZQ
cui.com
Product Page
date 10/26/2020 Ϳ page 3 of 14
PROTECTIONS
over voltage protection
auto restart
PRD15-Q24-S3
PRD15-Q24-S5
PRD15-Q24-S12
PRD15-Q24-S15
PRD15-Q48-S3
PRD15-Q48-S5
PRD15-Q48-S12
PRD15-Q48-S15
over current protection
current limiting, auto restart
PRD15-Q24-S3
PRD15-Q24-S5
PRD15-Q24-S12
PRD15-Q24-S15
PRD15-Q48-S3
PRD15-Q48-S5
PRD15-Q48-S12
PRD15-Q48-S15
min
current limiting, hiccup auto restart
over temperature protection
PRD15-Q48-S12
all other models
TI
N
short circuit protection
SAFETY AND COMPLIANCE
parameter
isolation voltage
input to output, basic insulation
24 Vdc input models
48 Vdc input models
min
N
isolation resistance
isolation capacitance
PRD15-Q24-S5, PRD15-Q24-S15, PRD15-Q48-S3
all other models
safety approvals
8/QG(GLWLRQ
LVD
(&&(PDUN
O
1
DVSHU7HOFRUGLD650HWKRG&DVHJURXQG
¿[HGFRQGLWLRQV7SFERDUG &IXOOORDG
natural air convection.
07%)
RoHS
max
units
4.5
5.9
14.1
19.5
3.9
5.9
15
Vdc
Vdc
Vdc
Vdc
Vdc
Vdc
Vdc
Vdc
6.0
4.6
2.0
1.6
7.2
4.5
1.8
1.7
A
A
A
A
A
A
A
A
0.3
A
135
115
°C
°C
W\S
max
2,000
2,250
units
Vdc
Vdc
10
1,000
S)
S)
2,000,000
hours
(8
&(PDUNRQO\RQ9GFLQSXWPRGHOV
C
1RWH
W\S
ED
U
parameter
ENVIRONMENTAL
parameter
min
max
units
see derating curves
-40
85
°C
-55
125
°C
IS
operating temperature
D
storage temperature
cui.com
W\S
Product Page
date 10/26/2020 Ϳ page 4 of 14
SOLDERABILITY
wave soldering
for Sn/Ag/Cu based solders (for through hole
models):
preheat temperature
solder pot temperature
solder dwell time
UHÀRZVROGHULQJ
UHÀRZVROGHUSUR¿OHEHORZLVVXLWDEOHIRU6$&
type lead-free solders (for surface mount models)
260
min
ramp at 1 °C/second across liquidus
160
d
r
100
p
80
st
ju
ad
60
40
fo
m
ra
p
e
ke
p
ak
so
es
t
ra
if
r
de
c
se
2
°C
un
m
ra
2
3
4
5
6
260
°C
7
TI
°C
°C
s
N
120
115
270
7
cooling rate 2-3 °C/second
d
on
re
ui
q
re
units
U
180
140
max
TAL at 60 seconds (range 45-75 seconds)
SAC305 liquidus at 219 °C
220
Temperature (°C)
245
optimal peak 245 ˚C, max peak 260 ˚C
240
W\S
ED
parameter
Time (minutes)
MECHANICAL
dimensions
through hole: 1.10 x 0.96 x 0.33 [27.9 x 24.4 x 8.4 mm]
surface mount: 1.10 x 0.96 x 0.33 [27.9 x 24.4 x 8.4 mm]
min
weight
through hole mount models
D
IS
C
O
N
parameter
cui.com
W\S
max
units
inches
inches
10
10.2
g
g
Product Page
date 10/26/2020 Ϳ page 5 of 14
MECHANICAL DRAWING (THROUGH HOLE)
3,1&211(&7,216
)XQFWLRQ
1
+Vin
2
-Vin
3
+Vout
4
output trim
5
-Vout
6
RQRϑFRQWURO
27.9
1.10
PIN #1
24.4
0.96
U
3,1
N
TOP VIEW
TI
MOUNTING
PLANE
N
8.4
0.33
O
SIDE VIEW
CL
10.16
0.400
10.16
0.400
IS
CL
10.16
0.400
RECOMMENDED
PRI-SEC BARRIER
.040±.002
.071 .002 SHOULDER
6X AT PINS 1-6
#6
.30
C
#5
D
ED
units: inches [mm]
tolerance: X.XX ±0.02 [0.5]
X.XXX ±0.010 [0.25]
#4
0.475
REF
#2
#1
5.08
0.200
CL
#3
0.41
0.15 TYP
0.58
20.32
0.800
BOTTOM VIEW
cui.com
2.54
0.100
6.3
0.25
END VIEW
Product Page
date 10/26/2020 Ϳ page 6 of 14
MECHANICAL DRAWING (SURFACE MOUNT)
units: inches [mm]
X.XXX ±0.010 [0.25]
)XQFWLRQ
1
+Vin
2
-Vin
3
+Vout
4
output trim
5
-Vout
6
RQRϑFRQWURO
27.9
1.10
CL
PIN #1
25.4
1.00
24.4
0.96
3
10.16
0.400
CL
2.54
0.100
1
10.16
0.400
4
2
U
3,1
ED
29.0
1.14
3,1&211(&7,216
5
TOP VIEW
N
20.32
0.800
RECOMMENDED PCB LAYOUT
TOP VIEW
.093 TYP
TI
MOUNTING
PLANE
SIDE VIEW
CL
#6
N
#5
10.16
0.400
0.33±.03
[8.4±0.8]
#2
#4
#1
O
10.16
0.400
CL
2.54
0.100
CL
#3
C
10.16
0.400
2.54
0.100
20.32
0.800
.093
0.13
REF
BOTTOM VIEW
D
IS
END VIEW
cui.com
2.54
0.100
6
6X
2.60 ±0.25
.102 ±.010
Product Page
date 10/26/2020 Ϳ page 7 of 14
DERATING CURVES
PRD15-Q48-S3 Derating Curves @ Sea Level
9LQ DLUÀRZIURPLQSXWWRRXWSXW
100
95
Natural Convection
0.5 m/s (100 LFM)
1.0 m/s (200 LFM)
1.5 m/s (300 LFM)
90
85
Load (%)
Load (%)
100
ED
80
Natural Convection
0.5 m/s (100 LFM)
1.0 m/s (200 LFM)
1.5 m/s (300 LFM)
2.0 m/s (400 LFM)
95
90
85
80
-20
70
80 85 90
-20
All other models, Derating Curves @ Sea Level
6HHFRQGLWLRQVLQ7DEOH
TI
95
See Table 1 for conditions
90
85
N
Load (%)
100
80
O
-20
70
80 85 90
Ambient Temperature (°C)
C
Table 1
12/24
PRD15-Q24-S5
24
,QSXWWRRXWSXW
PV/)0
PRD15-Q24-S12
24
,QSXWWRRXWSXW
PV/)0
PRD15-Q24-S15
12/24
,QSXWWRRXWSXW
Natural Convection
PRD15-Q48-S5
24/48
,QSXWWRRXWSXW
Natural Convection
PRD15-Q48-S12
24/48
Pin 2 to Pin 1
Natural Convection
PRD15-Q48-S15
24/48
,QSXWWRRXWSXW
Natural Convection
Model
Input (Vdc)
'LUHFWLRQRIDLUÀRZ
$LUÀRZ
PRD15-Q24-S3
,QSXWWRRXWSXW
Natural Convection
D
IS
70
N
U
cui.com
80 85 90
Product Page
date 10/26/2020 Ϳ page 8 of 14
EFFICIENCY CURVES
35'46(ϒFLHQF\&XUYH
(I¿FLHQF\YV/LQH9ROWDJHDQG/RDG&XUUHQW#&
90
90
85
85
80
Vin = 36 V
Vin = 24 V
70
Vin = 18 V
Vin = 9 V
65
75
60
55
55
50
50
0.5
1
1.5
2
2.5
3
3.5
Vin = 48 V
Vin = 18 V
65
60
Vin = 75 V
70
4
U
75
Efficiency (%)
Efficiency (%)
80
ED
35'46(ϒFLHQF\&XUYH
1
2
Load Current (Amps)
90
Vin = 36 V
Vin = 18 V
Vin = 9 V
0.25
0.5
0.75
1
O
30
N
Efficiency (%)
70
40
100
90
80
70
60
50
40
30
1.5
1.75
Vin = 75 V
Vin = 36 V
Vin = 24 V
Vin = 18 V
N
Efficiency (%)
80
50
2
5
35'46(ϒFLHQF\&XUYH
TI
100
Vin = 24 V
4
Load Current (Amps)
35'46(ϒFLHQF\&XUYH
60
3
2.25
2.5
2.75
0.5
1
1.5
2
2.5
Load Current (Amps)
D
IS
C
Load Current (Amps)
cui.com
3
Product Page
date 10/26/2020 Ϳ page 9 of 14
EFFICIENCY CURVES (CONTINUED)
35'46(ϒFLHQF\&XUYH
35'46(ϒFLHQF\&XUYH
90
90
80
84
Vin = 36 V
Vin = 24 V
Vin = 18 V
Vin = 9 V
75
70
Efficiency (%)
Vin = 75 V
Vin = 48 V
Vin = 24 V
Vin = 18 V
82
80
78
76
74
60
72
0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9
1 1.1 1.2 1.3
70
0.2
Load Current (Amps)
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
1.1
1.2
1.3
N
Load Current (Amps)
35'46(ϒFLHQF\&XUYH
35'46(ϒFLHQF\&XUYH
TI
90
U
Efficiency (%)
86
65
95
88
90
86
Efficiency (%)
85
84
80
N
Efficiency (%)
ED
88
85
82
Vin = 36 V
Vin = 24 V
Vin = 9 V
80
76
74
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
Vin = 75 V
Vin = 48 V
Vin = 24 V
Vin = 18 V
70
O
78
75
0.9
65
60
1
1.1
0.07
0.18
0.28
0.38
0.49
0.59
0.69
Load Current (Amps)
D
IS
C
Load Current (Amps)
cui.com
0.80
0.90
1.00
1.10
Product Page
date 10/26/2020 Ϳ page 10 of 14
PACKAGING (THROUGH HOLE)
units: mm [inches]
tolerance: +1/-0 mm
[9.92]
252.0
28.4
Typ
6.4
Typ
18.0
5x 38.1
25.4
Typ
252.0
Ref
190.5
Ref
A
N
R 6.4
Typ
U
6.4
Typ
[9.92]
252.0
ED
7UD\0DWHULDO'RZDQWLVWDWLFHWKDIRDP
7UD\6L]H[[PP
47
PRD15-Q24-S12-N-M-TR 价格&库存
很抱歉,暂时无法提供与“PRD15-Q24-S12-N-M-TR”相匹配的价格&库存,您可以联系我们找货
