Additional Resources:
Product Page
3D Model
date 12/21/2015
page
1 of 32
FEATURES
• pin and function compatible with
Architects of Modern Power™
product standards
• compact package, horizontal:
30.85 x 20.0 x 8.2 mm
• compact package, vertical:
33.0 x 7.60 x 18.1 mm
• 50 A output
• high efficiency
• auto compensation
• SMBus interface
• PMBus™ Compatible
4.5~14 V input range
0.6~3.3 V programmable output
voltage tracking
voltage margining
active current sharing
Snapshot™ parametric capture
voltage/current/temperature monitoring
synchronization and phase spreading
remote differential voltage sense
programmable soft start and soft stop
fault management
MODEL
output voltage
output current
TI
input voltage
NU
GENERAL CHARACTERISTICS
ED
SERIES: NDM2Z-50 Ϳ DESCRIPTION: AUTO COMPENSATED, DIGITAL DC-DC POL CONVERTER
(Vdc)
(Vdc)
max
(A)
max
(W)
4.5~14
0.6~3.3
50
165
DI
SC
ON
NDM2Z-50
output wattage
PART NUMBER KEY
NDM2Z-50 X - X - XXX
Base Number
Module Orientation and Pin Style:
HS = horizontal, surface mount
HT = horizontal, through hole mount
V = vertical
Firmware Conguration:
000~ZZZ
Pin Conguration:
A = 3.56 mm pin length (HT)
4.0 mm pin length (V)
B = 5.5 mm pin length (V)
* HS and HT modules are delivered on tape and reel
* V modules are delivered in trays
cui.com
Example part number: NDM2Z-50V-A-002
vertical module
4.00 mm pin length
rmware conguration 002
Product Page
3D Model
CUI Inc Ϳ SERIES: NDM2Z-50 Ϳ DESCRIPTION: AUTO COMPENSATED, DIGITAL DC-DC POL CONVERTER
date 12/21/2015 Ϳ page 2 of 32
ABSOLUTE MAXIMUM RATINGS
parameter
conditions/description
min
typ
max
units
-40
125
°C
storage temperature (TS)
-40
125
°C
-0.3
16
V
-0.3
6.5
V
input voltage (see operating information section for input and
output voltage relations)(VI)
CTRL, SA0, SA1, SALERT, SCL, SDA, VSET, SYNC,
DDC, PG
ground voltage differential
-S, PREF, GND
analog pin voltage
VO, +S, VTRK
Notes:
-0.3
0.3
V
-0.3
6.5
V
NU
logic I/O voltage
ED
operating temperature (see
thermal consideration section)
(TP1, TP2)
Stress in excess of Absolute Maximum Ratings may cause permanent damage. Absolute Maximum Ratings, sometimes referred to as no destruction limits, are
normally tested with one parameter at a time exceeding the limits in the Electrical Specication. If exposed to stress above these limits, function and performance
may degrade in an unspecied manner.
Configuration File
TI
This product is designed with a digital control circuit. The control circuit uses a conguration le which determines the
functionality and performance of the product. The Electrical Specication table shows parameter values of functionality
and performance with the default conguration le, unless otherwise specied. The default conguration le is designed
to t most application needs with focus on high efciency. If different characteristics are required it is possible to change
the conguration le to optimize certain performance characteristics. Note that current sharing operation requires changed
conguration le.
PRODUCT ELECTRICAL SPECIFICATION, HORIZONTAL
DI
SC
ON
TP1 = -30 to +95 °C, VI = 4.5 to 14 V, VI> VO + 1.0 V
Typical values given at: TP1 = +25 °C, VI = 12.0 V, max IO, unless otherwise specied under conditions.
External CIN = 470 NjF/10 mƻ, COUT = 470 NjF/10 mƻ. See Operating Information section for selection of capacitor types.
Sense pins are connected to the output pins.
parameter
input voltage rise time (VI)
monotonic
min
output voltage without
pin-strap (VO)
output voltage adjustment
range (VO)
including margining (VO)
see note 17
max
units
2.4
V/ms
1.2
V
0.60
3.3
V
0.54
3.63
V
output voltage set-point
resolution (VO)
output voltage accuracy (VO)
typ
±0.025
%FS
including line, load, temp see note 14
-1
1
current sharing operation see note 15
-2
2
internal resistance +S/-S to
VOUT/GND (VO)
47
ƻ
line regulation (VO)
VO
VO
VO
VO
0.6
1.0
1.8
3.3
V
V
V
V
2
2
2
3
mV
mV
mV
mV
load regulation (VO)
IO = 0~100%
VO
VO
VO
VO
0.6
1.0
1.8
3.3
V
V
V
V
2
2
2
2
mV
mV
mV
mV
output ripple & noise (Voac)
CO= 470 NjF (minimum external
capacitance) see note 11
VO
VO
VO
VO
0.6
1.0
1.8
3.3
V
V
V
V
30
35
mVp-p
mVp-p
mVp-p
mVp-p
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 3 of 32
PRODUCT ELECTRICAL SPECIFICATION, HORIZONTAL (CONTINUED)
parameter
output current (IO)
see note 18
static input current at max IO
(IS)
VO
VO
VO
VO
0.6
1.0
1.8
3.3
typ
V
V
V
V
max
units
50
A
3.10
4.80
8.19
14.53
current limit threshold (Ilim)
52
0.6
1.0
1.8
3.3
V
V
V
V
50% of max IO
VO
VO
VO
VO
0.6
1.0
1.8
3.3
V
V
V
V
max IO
VO
VO
VO
VO
0.6
1.0
1.8
3.3
V
V
V
V
A
A
A
A
A
85.6
90.4
93.7
95.7
80.5
86.9
91.6
94.6
7.25
7.54
8.28
9.36
W
W
W
W
0.90
0.90
1.10
1.67
W
W
W
W
170
mW
internal input capacitance (Ci)
140
F
internal output capacitance (Co)
400
F
efciency (dž)
0.6
1.0
1.8
3.3
V
V
V
V
input idling power (no load)(Pli)
default conguration:
continues conduction
mode, CCM
VO
VO
VO
VO
0.6
1.0
1.8
3.3
V
V
V
V
monitoring enabled,
precise timing enabled
DI
SC
ON
TI
power dissipation at max IO (Pd)
VO
VO
VO
VO
NU
VO
VO
VO
VO
65
11
9
7
6
short circuit current(ISC)
RMS, hiccup mode,
see note 3
A
A
A
A
ED
min
0.001
input standby power (PCTRL)
turned off with CTRL-pin
total external output
capacitance (COUT)
see note 9
470
30,000
F
ESR range of capacitors
(per single capacitor) (COUT)
see note 9
5
30
mƻ
load transient peak voltage
deviation (L to H/H to L) load
step 25-75-25% of max IO(Vtr1)
default conguration
di/dt = 2 A/Njs CO = 470
capacitance)
see note 12
VO
VO
VO
VO
0.6
1.0
1.8
3.3
V
V
V
V
79/256
127/298
144/324
210/327
mV
mV
mV
mV
load transient recovery time
note 5 (L to H/H to L) load step
25-75-25% of max IO(ttr1)
default conguration
capacitance)
see note 12
VO
VO
VO
VO
0.6
1.0
1.8
3.3
V
V
V
V
60/100
100/100
100/100
100/100
Njs
Njs
Njs
Njs
320
kHz
200-640
kHz
switching frequency (fs)
switching frequency range (fs)
PMBus congurable
switching frequency set-point
accuracy (fs)
-5
5
control circuit PWM duty cycle
5
95
minimum sync pulse width
input clock frequency drift
tolerance
150
external clock source
-13
cui.com
ns
13
Product Page
3D Model
date 12/21/2015 Ϳ page 4 of 32
parameter
min
UVLO threshold
PMBus congurable
UVLO hysteresis range
PMBus congurable
delay
see note 3
IOVP threshold
set point accuracy
IOVP hysteresis
IOVP hysteresis range
fault response
PG delay
UVP threshold
UVP threshold range
PMBus congurable
output voltage over/under
voltage protection, OVP/UVP
16
V
4.2-16
V
150
0-11.8
V
2.5
Njs
90
%Vo
5
%Vo
ms
s
85
%Vo
PMBus congurable
0-100
%Vo
PMBus congurable
UVP/OVP
response time range
PMBus congurable
fault response
see note 3
OCP threshold range
PMBus congurable
protection delay
see note 4
protection delay range
PMBus congurable
fault response
see note 3
PMBus congurable
OTP hysteresis
OTP hysteresis range
PMBus congurable
fault response
see note 3
cui.com
5
%Vo
115
%Vo
100-115
%Vo
25
Njs
5-60
Njs
automatic restart, 70 ms
62
A
0-62
A
32
TSW
1-32
TSW
OTP threshold
OTP threshold range
V
0-500
OVP threshold
OVP threshold range
mV
direct after DLC
OCP threshold
over temperature protection,
OTP at P2 see note 8
Njs
PMBus congurable
UVP/OVP response time
over current protection, OCP
2.5
see note 19
DI
SC
ON
UVP hysteresis
V
V
-150
TI
PG hysteresis
PG delay range
0.35
see note 3
PG threshold
mV
0-10.15
1
delay
power good, PG, see note 2
PMBus congurable
V
150
NU
IOVP threshold range
units
V
3.85-14
-150
UVLO hysteresis
fault response
input over voltage protection,
IOVP
max
ED
UVLO threshold range
set point accuracy
input under voltage lockout,
UVLO
typ
3.85
120
-40
°C
125
°C
25
°C
0-165
°C
automatic restart, 240 ms
Product Page
3D Model
date 12/21/2015 Ϳ page 5 of 32
logic input low threshold(VIL)
logic input high threshold (VIH)
logic input low sink current(IIL)
min
SYNC, SA0, SA1, SCL, SDA, DDC, CTRL, VSET
see note 1
hold time, SMBus(thold)
see note 1
bus free time, SMBus(tfree)
see note 1
V
mA
2
mA
ns
ns
2
ms
10
pF
40
ms
see note 16
10
ms
delay duration range
PMBus congurable
5-500,000
ms
delay accuracy turn-on
-0.25/+4
ms
delay accuracy turn-off
-0.25/+4
ms
PMBus congurable
ramp time accuracy
current sharing
operation
DI
SC
ON
ramp duration range
VVTRK = 5.5 V
10
ms
0-200
ms
100
Njs
-100
2 phases, 100% tracking
VO = 1.0 V, 10 ms ramp
200
NjA
100
mV
±100
mV
100% Tracking
-1
1
100% Tracking
-2
2
steady state operation
Max 2 x READ_IOUT monitoring
accuracy
ramp-up
4
number of products in a current
sharing group
READ_VIN vs VI
READ_VOUT vs VO
monitoring accuracy
4
see note 10
100% tracking, see note 7
current difference between
sharing group
V
delay duration
ramp duration
VTRK regulation accuracy
(VO - VVTRK)
V
250
TI
initialization time
VTRK tracking ramp accuracy
(VO - VVTRK)
mA
300
internal capacitance on logic
pins (CP)
VTRK input bias current
0.6
2.25
SYNC, SCL, SDA, SALERT, DDC, PG
setup time, SMBus(tSET)
output voltage ramp time
see note 13
V
0.4
logic output high source current
(IOH)
output voltage delay time see
note 6
units
0.8
NU
logic output low sink current
(IOL)
max
2
CTRL
logic output low signal level
(VOL)
logic output high signal level
(VOH)
typ
ED
parameter
A
7
3
1
READ_IOUT vs IO
IO = 0-50 A, TP1 = 0 to +95 °C
VI = 4.5-14 V, VO = 1.0 V
±3
A
READ_IOUT vs IO
VI = 4.5-14 V, VO = 0.6-3.3 V
±5
A
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 6 of 32
TI
NU
ED
1: See section I2C/SMBus Setup and Hold Times – Denitions.
2: Monitorable over PMBus Interface.
3: Automatic restart ~70 or 240 ms after fault if the fault is no longer present. Continuous restart attempts if the fault reappear after restart.
4: Tsw is the switching period.
5: Within +/-3% of VO
6: See section Soft-start Power Up.
7: Tracking functionality is designed to follow a VTRK signal with slew rate < 2.4 V/ms. For faster VTRK signals accuracy will depend on the regulator bandwidth.
8: See section Over Temperature Protection (OTP).
9: See section External Capacitors.
10: See section Initialization Procedure.
11: See graph Output Ripple vs External Capacitance and Operating information section Output Ripple and Noise.
12: See graph Load Transient vs. External Capacitance and Operating information section External Capacitors.
13: Time for reaching 100% of nominal Vout.
14: For Vout < 1.0 V accuracy is +/-10 mV. For further deviations see section Output Voltage Adjust using PMBus.
15: Accuracy here means deviation from ideal output voltage level given by congured droop and actual load. Includes line, load and temperature variations.
16: For current sharing the Output Voltage Delay Time must be recongured to minimum 15 ms.
17: For steady state operation above 1.05 x 3.3 V, please contact your local CUI sales representative.
18: A minimum load current is not required if Low Power mode is used (monitoring disabled).
19: See sections Dynamic Loop Compensation and Power Good.
DI
SC
ON
Notes:
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 7 of 32
TYPICAL CHARACTERISTICS, HORIZONTAL
Power Dissipation vs. Output Current, VI = 5 V
[W]
100
12
95
10
8
90
0.6 V
0.6 V
6
1.0 V
80
40
1.8 V
4
3.3 V
2
50 [A]
1.8 V
40
3.3 V
50 [A]
Dissipated power vs. load current and output voltage:
TP1 = +25 °C, VI = 5 V, fsw = 320 kHz, CO = 470 µF/10 mΩ.
Efficiency vs. load current and output voltage:
Efficiency vs. Output Current, VI = 12 V
Power Dissipation vs. Output Current, VI = 12 V
[W]
12
TI
100
10
95
8
90
DI
SC
ON
0.6 V
80
40
0.6 V
6
1.0 V
85
75
1.0 V
NU
85
75
ED
Efficiency vs. Output Current, VI = 5 V
1.0 V
1.8 V
4
1.8 V
3.3 V
2
3.3 V
50 [A]
40
50 [A]
Efficiency vs. load current and output voltage at
TP1 = +25 °C, VI = 12 V, fsw = 320 kHz, CO = 470 µF/10 mΩ.
Efficiency vs. Output Current and
Switching Frequency
Power Dissipation vs. Output Current and
Switching frequency
[W]
95
12
90
200
kHz
85
10
200
kHz
8
320
kHz
6
320
kHz
80
480
kHz
4
480
kHz
75
640
kHz
2
640
kHz
70
40
Efficiency vs. load current and switch frequency at
TP1 = +25 °C, VI = 12 V, VO = 1.0 V, CO = 470 µF/10 mΩ.
Default configuration except changed frequency
50 [A]
40
50 [A]
Dissipated power vs. load current and switch frequency at
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 8 of 32
TYPICAL CHARACTERISTICS, HORIZONTAL (CONTINUED)
[mV]
500
Load Transient vs. External Capacitance, VO = 3.3 V
Universal PID,
No NLR
[mV]
500
DLC,
No NLR
400
300
Universal PID,
Default NLR
300
200
DLC,
Default NLR
200
100
Universal PID,
Opt. NLR
100
DLC,
Opt. NLR
2
3
4
5 [mF]
Load transient peak voltage deviation vs. external capacitance.
Step (12.5-37.5-12.5 A). Parallel coupling of capacitors with 470 µF/10 mΩ,
TP1 = +25 °C, VI = 12 V, VO = 1.0 V, fsw = 320 kHz, di/dt = 2 A/µs
Load transient vs. Switch Frequency
DLC,
No NLR
400
DI
SC
ON
Universal PID,
Default NLR
300
DLC,
Default NLR
200
Universal PID,
Opt. NLR
100
DLC,
Opt. NLR
200
DLC,
Default NLR
Universal PID,
Opt. NLR
2
300
400
500
3
4
DLC,
Opt. NLR
5 [mF]
TP1 = +25 °C, VI = 12 V, VO = 3.3 V, fsw = 320 kHz, di/dt = 2 A/µs
Universal PID,
No NLR
500
Universal PID,
Default NLR
TI
[mV]
600
DLC,
No NLR
NU
400
Universal PID,
No NLR
ED
Load Transient vs. External Capacitance, VO = 1.0 V
600 [kHz]
Load transient peak voltage deviation vs. frequency.
Step-change (12.5-37.5-12.5 A).
TP1 = +25 °C. VI = 12 V, VO = 1.0 V, CO = 470 µF/10 mΩ
Note 1: For Universal PID, see section Dynamic Loop Compensation (DLC).
Note 2: In the load transient graphs, the worst-case scenario (load step 37.5-12.5 A) has been
considered.
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 9 of 32
Output Current Derating, VO = 0.6 V
Output Current Derating, VO = 1.0 V
[A]
[A]
50
3.0 m/s
40
40
2.0 m/s
30
1.0 m/s
30
0.5 m/s
Nat. Conv.
60
80
100
2.0 m/s
1.0 m/s
0.5 m/s
Nat. Conv.
10
NU
10
3.0 m/s
ED
50
120 [°C]
60
80
100
120 [°C]
Available load current vs. ambient air temperature and airflow at
VO = 1.0 V, VI = 12 V. See Thermal Consideration section.
VO = 0.6 V, VI = 12 V. See Thermal Consideration section.
Output Current Derating, VO = 1.8 V
Output Current Derating, VO = 3.3 V
[A]
[A]
50
TI
50
3.0 m/s
3.0 m/s
40
40
2.0 m/s
30
30
1.0 m/s
0.5 m/s
0.5 m/s
Nat. Conv.
10
DI
SC
ON
1.0 m/s
60
80
100
2.0 m/s
120 [°C]
VO = 1.8 V, VI = 12 V. See Thermal Consideration section.
Nat. Conv.
60
80
100
120 [°C]
VO = 3.3 V, VI = 12 V. See Thermal Consideration section.
Current Limit Characteristics, VO = 1.0 V
Current Limit Characteristics, VO = 3.3 V
[V]
[V]
1,2
4,0
VI = 4.5, 5 .0V
VI = 5.0, 12 V
0,9
3,0
4.5 V
4.5 V
5.0 V
0,6
12 V
VI = 4.5,14 V
14 V
0,3
0,0
50
55
60
65 [A]
Output voltage vs. load current at TP1 = +25 °C, VO = 1.0 V.
Note: Output enters hiccup mode at current limit.
5.0 V
2,0
12 V
VI = 12, 14 V
14 V
1,0
0,0
50
55
60
65 [A]
Output voltage vs. load current at TP1 = +25 °C, VO = 3.3 V.
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 10 of 32
Output Ripple vs. Input Voltage
Output Ripple vs. Frequency
[mVpk-pk]
70
ED
[mVpk-pk]
40
60
30
0.6 V
10
1.0 V
40
1.8 V
30
3.3 V
0.6 V
1.0 V
1.8 V
3.3 V
NU
10
7
9
11
[V]
13
Output voltage ripple Vpk-pk at: TP1 = +25 °C, CO = 470 µF/10 mΩ, IO = 50 A
300
400
500
600
[kHz]
Output voltage ripple Vpk-pk at: TP1 = +25 °C, VI = 12 V, CO = 470 µF/10 mΩ,
IO = 50 A. Default configuration except changed frequency.
Load regulation, VO = 1.0 V
TI
Output Ripple vs. External Capacitance
[mV]
[V]
40
1,010
30
DI
SC
ON
0.6 V
1.0 V
1.8 V
3.3 V
10
2
3
4
5 [mF]
Output voltage ripple Vpk-pk at: TP1 = +25 °C, VI = 12 V. IO = 50 A.
1,005
4.5 V
5.0 V
1,000
12 V
14 V
0,995
0,990
10
15
25 [A]
Load regulation at VO = 1.0 V, TP1 = +25 °C, CO = 470 µF/10 mΩ
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 11 of 32
Shut-down by input source
Start-up enabled by connecting VI at:
Top trace: output voltage (0.5 V/div.).
Bottom trace: input voltage (5 V/div.).
Time scale: (20 ms/div.).
Shut-down enabled by disconnecting
VI at:
Time scale: (2 ms/div.).
Shut-down by CTRL signal
DI
SC
ON
TI
Start-up by CTRL signal
NU
ED
Start-up by input source
Start-up by enabling CTRL signal at:
Bottom trace: CTRL signal (2 V/div.).
VI at:
cui.com
Top trace: output voltage (0.5 V/div).
Product Page
3D Model
date 12/21/2015 Ϳ page 12 of 32
PRODUCT ELECTRICAL SPECIFICATION, VERTICAL
monotonic
min
pin-strap (VO)
see note 17
2.4
V/ms
V
3.3
V
0.54
3.63
V
±0.025
%FS
-1
1
-2
2
0.6
1.0
1.8
3.3
V
V
V
V
IO = 0~100%
VO
VO
VO
VO
0.6
1.0
1.8
3.3
V
V
V
V
DI
SC
ON
VO
VO
VO
VO
TI
VOUT/GND (VO)
VO
VO
VO
VO
output current (IO)
see note 18
(IS)
VO
VO
VO
VO
0.6
1.0
1.8
3.3
0.6
1.0
1.8
3.3
V
V
V
V
47
ƻ
2
3
3
3
mV
mV
mV
mV
2
2
2
2
mV
mV
mV
mV
30
40
mVp-p
mVp-p
mVp-p
mVp-p
0.001
V
V
V
V
units
0.60
NU
resolution (VO)
max
1.2
range (VO)
typ
ED
parameter
50
3.12
4.81
8.22
14.59
52
A
A
A
A
A
65
A
RMS, hiccup mode,
see note 3
VO
VO
VO
VO
0.6
1.0
1.8
3.3
V
V
V
V
10
8
6
5
A
A
A
A
50% of max IO
VO
VO
VO
VO
0.6
1.0
1.8
3.3
V
V
V
V
85.2
90.2
93.3
95.3
max IO
VO
VO
VO
VO
0.6
1.0
1.8
3.3
V
V
V
V
80.2
86.6
91.2
94.2
7.4
7.73
8.68
10.15
W
W
W
W
0.95
0.95
1.22
1.88
W
W
W
W
efciency (dž)
0.6
1.0
1.8
3.3
V
V
V
V
VO
VO
VO
VO
mode, CCM
VO
VO
VO
VO
0.6
1.0
1.8
3.3
V
V
V
V
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 13 of 32
PRODUCT ELECTRICAL SPECIFICATION, VERTICAL (CONTINUED)
monitoring enabled,
170
mW
140
F
400
F
capacitance (COUT)
see note 9
see note 9
default conguration
capacitance)
see note 12
VO
VO
VO
VO
default conguration
capacitance)
see note 12
VO
VO
VO
VO
PMBus congurable
0.6
1.0
1.8
3.3
V
V
V
V
30,000
F
5
30
mƻ
Njs
Njs
Njs
Njs
320
kHz
200-640
kHz
5
95
fault response
PMBus congurable
see note 3
IOVP hysteresis
PMBus congurable
delay
fault response
see note 3
V
150
mV
0.35
V
0-10.15
V
2.5
Njs
PMBus congurable
set point accuracy
V
3.85-14
-150
IOVP threshold
13
3.85
UVLO hysteresis
ns
-13
delay
70/100
100/100
100/100
100/100
5
PMBus congurable
set point accuracy
IOVP
mV
mV
mV
mV
-5
UVLO threshold
UVLO
90/300
120/300
160/305
230/315
150
DI
SC
ON
tolerance
V
V
V
V
470
TI
accuracy (fs)
0.6
1.0
1.8
3.3
ED
NU
16
V
4.2-16
V
-150
150
1
mV
V
0-11.8
V
2.5
Njs
PG threshold
90
%Vo
PG hysteresis
5
%Vo
direct after DLC
ms
0-500
s
PG delay
see note 19
PG delay range
PMBus congurable
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 14 of 32
parameter
min
UVP threshold
UVP threshold range
PMBus congurable
OVP threshold
OVP threshold range
PMBus congurable
PMBus congurable
fault response
see note 3
OCP threshold
OCP threshold range
PMBus congurable
protection delay
see note 4
PMBus congurable
fault response
see note 3
OTP threshold
%Vo
5
%Vo
115
%Vo
100-115
%Vo
25
Njs
5-60
Njs
60
A
0-60
A
32
TSW
1-32
TSW
120
OTP threshold range
OTP hysteresis
PMBus congurable
PMBus congurable
fault response
see note 3
DI
SC
ON
0-100
-40
TI
(IOL)
°C
125
°C
25
°C
0-165
°C
0.8
V
0.6
mA
0.4
V
2
V
CTRL
(VOL)
(VOH)
units
%Vo
NU
UVP/OVP
response time range
max
85
ED
UVP hysteresis
typ
2.25
V
(IOH)
4
mA
2
mA
see note 1
300
see note 1
250
ns
see note 1
2
ms
pins (CP)
initialization time
note 6
10
pF
see note 10
40
ms
delay duration
see note 16
10
ms
PMBus congurable
5-500,000
ms
-0.25/+4
ms
-0.25/+4
ms
ramp duration
see note 13
ns
ramp duration range
PMBus congurable
ramp time accuracy
current sharing
operation
VVTRK = 5.5 V
10
ms
0-200
ms
100
Njs
cui.com
200
NjA
Product Page
3D Model
date 12/21/2015 Ϳ page 15 of 32
(VO - VVTRK)
sharing group
min
-100
100% Tracking
units
100
mV
mV
-1
1
-2
2
accuracy
ramp-up
4
READ_VIN vs VI
READ_VOUT vs VO
A
7
3
1
READ_IOUT vs IO
±3
A
READ_IOUT vs IO
±5
A
TI
DI
SC
ON
Notes:
max
±100
100% Tracking
sharing group
monitoring accuracy
typ
ED
(VO - VVTRK)
NU
parameter
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 16 of 32
TYPICAL CHARACTERISTICS, VERTICAL
[W]
100
12
10
95
8
90
0.6 V
0.6 V
6
1.0 V
80
40
1.8 V
4
3.3 V
2
50 [A]
40
3.3 V
50 [A]
TI
[W]
100
12
10
95
8
90
DI
SC
ON
0.6 V
80
40
0.6 V
6
1.0 V
85
75
1.8 V
1.0 V
NU
85
75
ED
1.0 V
1.8 V
4
1.8 V
3.3 V
2
3.3 V
50 [A]
40
50 [A]
TP1 = +25 °C, VI=12 V, fsw = 320 kHz, CO = 470 µF/10 mΩ.
Switching Frequency
Switching frequency
[W]
95
12
90
200
kHz
85
10
200
kHz
8
320
kHz
6
320
kHz
80
480
kHz
4
480
kHz
75
640
kHz
2
640
kHz
70
40
50 [A]
40
50 [A]
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 17 of 32
TYPICAL CHARACTERISTICS, VERTICAL (CONTINUED)
[mV]
500
Universal PID,
No NLR
DLC,
No NLR
400
300
Universal PID,
Default NLR
300
200
DLC,
Default NLR
200
100
Universal PID,
Opt. NLR
100
DLC,
Opt. NLR
2
3
4
5 [mF]
TP1 = +25 °C. VI = 12 V, VO = 1.0 V, fsw = 320 kHz, di/dt = 2 A/µs
DLC,
No NLR
400
DI
SC
ON
Universal PID,
Default NLR
300
DLC,
Default NLR
200
Universal PID,
Opt. NLR
100
DLC,
Opt. NLR
200
Universal PID,
Default NLR
DLC,
Default NLR
Universal PID,
Opt. NLR
2
300
400
500
3
4
DLC,
Opt. NLR
5 [mF]
TP1 = +25 °C. VI = 12 V, VO = 3.3 V, fsw = 320 kHz, di/dt = 2 A/µs
Universal PID,
No NLR
500
DLC,
No NLR
TI
[mV]
600
Universal PID,
No NLR
NU
400
[mV]
500
ED
600 [kHz]
Note 2: In these graphs, the worst-case scenario (load step 37.5-12.5 A) has been considered.
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 18 of 32
[A]
[A]
50
50
3.0 m/s
40
40
2.0 m/s
30
1.0 m/s
30
0.5 m/s
Nat. Conv.
60
80
100
1.0 m/s
0.5 m/s
Nat. Conv.
10
120 [°C]
60
80
100
120 [°C]
[A]
[A]
50
TI
50
3.0 m/s
40
30
1.0 m/s
0.5 m/s
0.5 m/s
Nat. Conv.
10
60
80
100
2.0 m/s
1.0 m/s
DI
SC
ON
3.0 m/s
40
2.0 m/s
30
2.0 m/s
NU
10
3.0 m/s
ED
120 [°C]
Nat. Conv.
10
60
80
100
120 [°C]
[V]
[V]
1,2
4,0
0,9
3,0
4.5 V
4.5 V
5.0 V
0,6
VI = 4.5, 5.0 V
VI = 12, 14 V
12 V
14 V
0,3
0,0
50
55
60
65 [A]
5.0 V
2,0
VI = 4.5, 14 V
12 V
VI = 5.0, 12 V
14 V
1,0
0,0
50
55
60
65 [A]
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 19 of 32
[mVpk-pk]
70
ED
[mVpk-pk]
40
60
30
0.6 V
10
1.0 V
40
1.8 V
30
3.3 V
0.6 V
1.0 V
1.8 V
3.3 V
NU
10
7
9
11
[V]
13
Output voltage ripple Vpk-pk at: TP1 = +25 °C, CO = 470 µF/10 mΩ, IO = 50 A.
[mV]
400
500
600
[kHz]
[V]
40
1,010
30
DI
SC
ON
0.6 V
1.0 V
1.8 V
3.3 V
10
TI
200
2
3
4
5 [mF]
Output voltage ripple Vpk-pk at: TP1 = +25 °C, VI = 12 V, IO = 50 A.
1,005
4.5 V
5.0 V
1,000
12 V
14 V
0,995
0,990
10
15
25 [A]
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 20 of 32
VI at:
DI
SC
ON
TI
NU
ED
VI at:
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 21 of 32
Efficiency vs. Output Current and Switching frequency
Load transient vs. Switching frequency
[mV]
600
95
200
kHz
85
300
80
480
kHz
200
75
640
kHz
100
40
50 [A]
Efficiency vs. load current and switching frequency at
DLC,
Default NLR
Universal PID,
Opt. NLR
200
300
400
500
DLC,
Opt. NLR
600 [kHz]
TP1 = +25 °C, VI = 12 V, VO =1.0 V, CO = 470 µF/10 mΩ
Power Dissipation vs. Output Current and Switching frequency
[W]
Universal PID,
Default NLR
NU
DLC,
No NLR
400
320
kHz
ED
500
90
70
Universal PID,
No NLR
Load Transient vs. Decoupling Capacitance, VO = 1.0 V
TI
[mV]
500
12
10
400
200
kHz
8
Universal PID,
No NLR
DLC,
No NLR
300
Universal PID,
Default NLR
4
480
kHz
200
DLC,
Default NLR
2
640
kHz
100
Universal PID,
Opt. NLR
DI
SC
ON
320
kHz
6
40
50 [A]
DLC,
Opt. NLR
2
3
4
5 [mF]
Dissipated power vs. load current and switching frequency at
Load transient peak voltage deviation vs. decoupling capacitance.
Output Ripple vs. Switching frequency
Load Transient vs. Decoupling Capacitance, VO = 3.3 V
[mVpk-pk]
60
50
[mV]
500
Universal PID,
No NLR
400
DLC,
No NLR
0.6 V
40
1.0 V
30
1.8 V
300
Universal PID,
Default NLR
200
DLC,
Default NLR
100
Universal PID,
Opt. NLR
3.3 V
300
400
500
600
[kHz]
IO = 50 A resistive load. Default configuration except changed frequency.
DLC,
Opt. NLR
2
3
4
5 [mF]
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 22 of 32
MECHANICAL DRAWING (HORIZONTAL, SURFACE MOUNT)
1A, 1B
VIN
2A, 2B
GND
3A, 3B
VOUT
4A
VTRK
4B
PREF
5A
+S
5B
-S
6A
SA0
6B
DDC
7A
SCL
7B
SDA
8A
VSET
8B
SYNC
SLRT
CTRL
10A
PG
10B
SA1
PLATING
Copper Alloy
Min
0.1 Njm Au
over
1~3 Njm Ni
Brass
Min
0.1 Njm Au
over
2 Njm Ni
DI
SC
ON
9A
9B
MATERIAL
NU
PIN
NAME
TI
PIN
NUMBER
ED
units: mm [inches]
tolerance unless specied:
X.X ±0.50 [0.02]
X.XX ±0.25 [0.01]
(not applied on footprint or typical values)
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 23 of 32
MECHANICAL DRAWING (HORIZONTAL, THROUGH HOLE MOUNT)
1A, 1B
VIN
2A, 2B
GND
3A, 3B
VOUT
4A
VTRK
4B
PREF
5A
+S
5B
-S
6A
SA0
6B
DDC
7A
SCL
7B
SDA
VSET
SYNC
9A
SLRT
9B
CTRL
PLATING
Copper Alloy
Min
8~13 m
matte tin
over
2.5~5 m
Ni
Brass
Min
0.2 Njm Au
over
1.27 Njm Ni
DI
SC
ON
8A
8B
MATERIAL
NU
PIN
NAME
TI
PIN
NUMBER
ED
units: mm [inches]
X.X ±0.50 [0.02]
X.XX ±0.25 [0.01]
10A
PG
10B
SA1
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 24 of 32
MECHANICAL DRAWING (VERTICAL, THROUGH HOLE MOUNT)
1A
VIN
1B
VIN
2A
GND
2B
GND
3A
VOUT
3B
VOUT
4A
+S
4B
-S
5A
VSET
5B
VTRK
6A
SALRT
6B
SDA
7A
SCL
7B
SA1
SA0
8B
SYNC
PLATING
Min
0.1 Njm Au
over
1~3 Njm Ni
Copper Alloy
Min
0.1 Njm Au
over
1 Njm Ni
DI
SC
ON
8A
MATERIAL
NU
PIN
NAME
TI
PIN
NUMBER
ED
units: mm [inches]
X.X ±0.50 [0.02]
X.XX ±0.25 [0.01]
9A
PG
9B
CTRL
10A
DDC
10B
PREF
cui.com
Product Page
3D Model
OPERATING INFORMATION
date 12/21/2015 Ϳ page 25 of 32
deviation as a result of load transients. The incorporation
of DFM enhances the performance of CUI modules over that
available from conventional analog POL offerings.
REQUIRED CONFIGURATIONS
NU
NDM2Z-50 Module Pins
Each NDM2Z-50 module should have a resistor placed
between VSET and PREF to set the output voltage of the
module. The maximum output voltage which can be
congured by PMBus commands can never exceed 110% of
the voltage set by the VSET pin. The SMBus address of each
module is set by either pin-strap conguration or resistor
value associated with the SA0 and SA1 pins. More
information regarding setting the SMBus address for a
module can be found in the section titled “SMBus”.
Power Management Overview
The NDM2Z-50 module incorporates a wide range of power
management features. All power management functions
can be configured via the SMBus interface. The NDM2Z-50
can monitor and report many characteristics of the module
including input voltage, output voltage, output current and
internal temperature. Additionally, the NDM2Z-50 includes
circuit protection features that protect the module and load
from damage due to system faults. Monitoring parameters
can also be configured to provide alerts for specific
conditions. The ability of CUI modules to digitally control,
configure and monitor OS features provides significant
benefits over traditional analog POL products.
ED
The Novum Z Products PMBus Commands application note
denes the available PMBus™ commands.
CONFIGURING THE MODULE
Pin Settings
Pins SA0 and SA1 are used to set the SMBus address
of the NDM2Z-50 module. Details of this feature are
discussed in the section titled “SMBus”. Pin SYNC is used
to synchronize the switching clock of the module to an
external clock source. More information regarding
synchronization can be found in the section titled
“SWITCHING FREQUENCY AND SYNCHRONIZATION”.
Pin VSET is used to configure the output voltage of the
module. The voltage established by the VSET pin limits the
maximum output voltage that can be configured by SMBus
commands.
The SA0, SA1, SYNC and VSET pin configurations are read
by the module when power is applied or whenever a SMBus
RESTORE command is issued.
The CTRL pin is active high and can be used to enable the
module. Internal connections on the module will drive the
CTRL pin high if it is left floating.
Pins +S and -S are used for remote voltage sensing of the
output voltage.
DI
SC
ON
TI
PCB Layout
Good performance of any point of load voltage regulator
module can only be achieved with careful PCB layout
considerations. Ground planes or very wide traces should
be used for power and ground routing. Input capacitors
should be placed close to the input voltage pins of the
module and output capacitors should be placed close to the
load. The module should also be placed as close as possible
to the load.
INPUT AND OUTPUT CAPACITORS
Input Capacitors
Input capacitors are recommended to be used with the
NDM2Z-50 module in order to minimize input voltage ripple.
A 330 NjF POSCAP or electrolytic and 3x 22 NjF ceramic
capacitors should be placed as close as possible to the input
pins of the module. Additional input capacitors may be
used if less input voltage ripple is desired.
Output Capacitors
Output capacitors are recommended to be used with the
NDM2Z-50 module in order to improve transient response
and minimize output voltage ripple. A 330 NjF POSCAP or
electrolytic and 3x 22 NjF ceramic capacitors should be
placed as close as possible to the load. Additional output
capacitors may be used to further improve the output
voltage characteristics.
POWER CONVERSION AND MANAGEMENT
Power Conversion Overview
The NDM2Z-50 module has several features to enable high
power conversion efficiency. Non-linear loop response (NLR)
improves the response time and reduces the output
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 26 of 32
Unused Pins
Table 1 describes the required or allowed connections for unused pins on the NDM2Z-50 module.
Table 1: Unused Pins
VSET
Tie to PREF with 133 kƻ resistor, see VOUT_COMMAND PMBus command
Float
DDC, SCL, SDA, SALRT
Pulled high with resistor, see "RECOMMENDED OPERATIN CONDITIONS"
ED
VTRK, SA0, SA1, SYNC, CTRL, +S, -S
Conguration of Parameters Using the SMBus
The NDM2Z-50 module is supplied with default settings. All module settings (except for module SMBus address,
congured by pins SA0 and SA1) can be re-congured via the SMBus interface. The output voltage can not be set to
greater than 110% of the voltage set by the VSET pin.
NU
START-UP PROCEDURE
Table 2: NDM2Z-50 Start-up sequence
TI
Start-up Sequence
The NDM2Z-50 module follows an internal start-up procedure after power is applied to pin VIN. Table 2 describes the
start-up sequence. If the module is to be synchronized to an external clock source, the clock frequency must be stable
prior to asserting CTRL (or applying input voltage to the module if CTRL is not used). Once this process is completed, the
module is ready to accept assertion of CTRL and commands via the SMBus interface.
STEP NAME
DESCRIPTION
1
Power applied or
RESTORE_FACTORY
Input voltage is applied to NDM2Z-50 module pin VIN or RESTORE_FACTORY
PMBus command issued
2
Factory conguration
settings
Module loads factory conguration settings. This step is also performed after
using PMBus commands to restore the factory conguration le.
3
SA0, SA1, SYNC and
VSET pin settings
Module loads values congured by the SA0, SA1, SYNC and VSET pins.
4
Default conguration
settings
Module loads default conguration settings. This data over-rides pin setting
data, except for maximum limit for VOUT_COMMAND. This step also performed
after using PMBus commands to restore the default conguration le.
5
User conguration
settings
Module loads user conguration settings. This data over-rides pin setting and
default conguration data, except for maximum limit for VOUT_COMMAND. This
step also performed after using PMBus commands to restore the user
conguration le.
6
Module ready
The module is ready to accept a CTRL signal.
7
Pre-ramp delay
The module requires approximately 5 ms following a CTRL signal and prior to
ramping its output. Additional pre-ramp delay may be congured using PMBus
commands.
Approximately
5 ms
DI
SC
ON
STEP
Soft-start Delay Ramp Times
Once CTRL is asserted the NDM2Z-50 module requires a
pre-ramp delay time before the output voltage may be
allowed to start the ramp-up process. After the delay period
has expired, the output will begin to ramp towards the
target voltage according to the pre-congured soft-start
ramp time that has been set. It is recommended to set the
soft-start ramp time to a value greater than 500 Njs in order
to prevent fault conditions due to excessive inrush current.
Soft start delay and ramp times may be set using PMBus
commands.
Output Pre-Bias
An output pre-bias condition exists when a non-zero
TIME DURATION
Depends on input
supply ramp time
Approximately 10
ms (module will
ignore a CTRL
signal and PMBus
commands during
this period)
voltage is present on the NDM2Z-50 module output before
the module output voltage is enabled. If a pre-bias voltage
exists, the output voltage of the module is set to match the
existing pre-bias voltage. The output voltage is then ramped
to the final regulation value in the specified ramp time.
The pre-bias voltage can be higher or lower than the final
output voltage. Higher pre-bias output voltages will cause
energy to be pumped into the input voltage rail powering
the module. This condition could cause the module to report
an error condition if the input voltage exceeds the input
over voltage lock out threshold. The module will report an
error condition if the pre-bias output voltage exceeds the
output over voltage protection threshold.
cui.com
Product Page
3D Model
RESISTOR (k)
VOUT (V)
RESISTOR (k)
VOUT (V)
10.0
0.60
38.3
1.30
11.0
0.65
42.2
1.40
12.1
0.70
46.4
1.50
13.3
0.75
51.1
1.60
0.80
56.2
1.70
0.85
61.9
1.80
0.90
68.1
1.90
0.95
75.0
2.00
1.00
82.5
2.10
1.05
90.9
2.20
14.7
16.2
17.8
19.6
21.5
23.7
26.1
1.10
100.0
2.30
28.7
1.15
110.0
2.50
31.6
1.20
121.0
3.00
34.8
1.25
133.0
3.30
NU
Soft-stop Delay and Ramp Times
After CTRL is de-asserted the NDM2Z-50 module utilizes
a pre-ramp delay time before the output starts the rampdown process. After the delay period has expired, the
output will begin to ramp towards ground according to the
pre-congured soft-stop ramp time that has been set. It is
recommended to set the soft-start ramp down to a value
greater than 500 Njs in order to prevent voltage spikes in
the module input supply rail due the energy stored in the
output capacitors. There will be a delay after the output
voltage has reached ground potential and then the output of
the module will be set to high impedance. Once the output
of the module is high impedance the output voltage may
oat to a non-zero value if another source or leakage path
is connected to the output. The soft-stop delay and ramp
times may be congured via PMBus commands.
PMBus commands can be used to set the output of the
NDM2Z-50 module to high impedance as soon as the output
voltage drops below a selectable threshold.
Table 4: Resistor VOUT voltage settings
ED
Power Good
The PG pin on the NDM2Z-50 module will assert if the
output of the module is within tolerance of the target
voltage and no fault conditions exist. A PG delay period
is dened as the time from when all conditions within the
module for asserting PG are met to when PG is actually
asserted. By default, PG delay is set equal to the soft-start
ramp time setting. The tolerance, polarity and delay of PG
date 12/21/2015 Ϳ page 27 of 32
TI
SMBus Setting Method
The voltage present at the VOUT pin of the NDM2Z-50
module can be reconfigured using PMBus commands. A
voltage level reconfigured by a PMBus command overrides the voltage set by the VSET pin, but cannot be set to
DI
SC
ON
Voltage Tracking
The NDM2Z-50 module includes a feature that allows the
output ramp voltage to track the ramp of a reference
voltage which is applied to the VTRK pin. The voltage ramp
tracking capability can be configured so that member
modules track at either 50% or 100% of the reference
voltage ramp rate. In addition, a member module can be
configured so that the termination voltage either tracks
or ignores perturbations on the reference voltage once it
has stabilized. Tracking at 50% and tracking final voltage
perturbations is intended for DDR memory applications. All
other applications which required voltage tracking should
use 100% tracking and ignore final voltage perturbations.
The reference voltage for tracking must have a target voltage which is equal to or greater than the target voltage of
the member modules. The turn-on delay of the reference
voltage must be at least 10 ms greater than that set for the
member modules. In voltage tracking mode, the turn-off
delay of the member modules establishes the time duration
which the member modules will track the reference voltage
after CTRL is de-asserted. The turn-off delay of the member
modules must be at least 5 ms greater than the sum of the
turn-off delay and fall time of the reference voltage.
OUTPUT VOLTAGE SETTING
Pin-Strap and Resistor Setting Methods
Using the pin-strap method, the voltage on the VOUT pin
of the NDM2Z-50 module can be set to one of three default
voltages as shown in Table 3. Table 4 lists the available
output voltage settings with a resistor connected between
VSET and PREF.
Table 3: Pin-strap VOUT voltage settings
VSET
VOUT (V)
LOW (< 0.8 V)
0.6
OPEN (N/C)
1.2
HIGH (> 2.0 V)
2.5
cui.com
Product Page
3D Model
Adaptive Diode Emulation
Please contact CUI technical support regarding the
implementation of adaptive diode emulation.
Adaptive Frequency Control
The NDM2Z-50 module includes adaptive frequency control
to improve conversion efciency. Adaptive frequency control
is not available for current sharing groups and is not
allowed when the module is placed in auto-detect mode
and a clock source is present on the SYNC pin.
Adaptive frequency control is only available while the
module is operating within adaptive diode emulation mode.
Adaptive frequency control can be enabled and disabled
with PMBus commands.
DI
SC
ON
TI
Switching Frequency
The switching frequency of the NDM2Z-50 module can
be recongured by PMBus commands or controlled by an
external clock source connected to the SYNC pin. If the
module is operated at a switching frequency of other than
the factory default setting, the compensation may need to
be adjusted and the ripple, noise, transient response and
efciency may be affected.
Non-Linear Response (NLR) Settings
The NDM2Z-50 module incorporates a non-linear response
(NLR) loop that decreases the response time and the output
voltage deviation in the event of a sudden output load
current step. This implementation results in a higher
equivalent loop bandwidth than what would be possible
using a traditional linear loop. PMBus commands can be
used to congure the NLR response of the module.
ED
Voltage Margining
The NDM2Z-50 module offers a means to vary the output
voltage higher or lower relative to the nominal voltage
setting. The rate of change of the output voltage during
voltage margining is also configurable. The margin feature
can be reconfigured through PMBus commands.
loop every time the output voltage ramps to the regulated
level. PMBus commands can be used to congure when the
module re-compensates the loop.
The user also has the option to manually congure the loop
compensation.
NU
Current sharing modules which are also configured to track
a voltage must have all of the VTRK pins tied together.
All of the CTRL pins of the member modules must also be
connected together and driven by a common source. The
rise and fall times of the member modules should be set
between 5 ms and 10 ms to ensure current sharing while
ramping. PMBus commands can be used to configure the
voltage tracking features.
date 12/21/2015 Ϳ page 28 of 32
SYNC Auto Detect
The NDM2Z-50 module will automatically check for a clock
signal on the SYNC pin after CTRL is asserted (or applying
input voltage to the module if CTRL is not used). If a clock
signal is present, the module will synchronize to the rising
edge of the external clock. The external clock signal must
be stable and conform to the “RECOMMENDED OPERATING
CONDITIONS” parameters when CTRL is asserted (or
In the event of a loss of the external clock signal, the
output voltage of the module may show transient overshoot
or undershoot and the module will automatically congure
to switch at a frequency close to the previous incoming
frequency. If no incoming clock signal is present when CTRL
is asserted (or applying input voltage to the module if CTRL
is not used), the module will switch at the frequency set by
the conguration le.
MULTI-MODULE CONFIGURATION
Output Sequencing
Multiple device sequencing of NDM2Z-50 modules may
be achieved by issuing PMBus commands to assign the
preceding device in the sequencing chain as well as the
device that will follow in the sequencing chain. The CTRL
pins of all devices in a sequencing group must be tied
together and driven high to initiate a sequenced turn-on of
the group. CTRL must be driven low to initiate a sequenced
turnoff of the group.
CONTROL LOOP
Adaptive Loop Compensation
The NDM2Z-50 module employs automatic adaptive loop
compensation to increase the performance and stability of
the module over a wide range of conditions. The default
setting congures the module to re-compensate the control
cui.com
Product Page
3D Model
POWER FAULT MANAGEMENT
NU
Active Current Sharing
Paralleling multiple NDM2Z-50 modules can be used to
increase the output current capability of a single power rail.
By connecting the DDC of each module together and
conguring the modules as a current sharing rail, the units
will share the load current.
Upon system start-up, the module with the lowest SMBus
address is dened as the reference module; the remaining
modules are members. The reference module broadcasts
the current over the DDC. The output voltages of the
member modules are controlled by the reference current
information to balance the current loading of each module
in the system.
A current sharing rail can be part of a system sequencing
group. For fault conguration, the current share rail is
congured in a quasi-redundant mode. In this mode, when
a member module fails the remaining members will
continue to operate and attempt to maintain regulation. If
fault spreading is enabled, the current share rail failure is
broadcast only after the entire current share rail fails.
Members of the current sharing rail can be disabled to
improve system power conversion efciency. If the
reference module fails or is disabled then the remaining
module with the lowest SMBus address will become the new
reference module. A change to the number of members of a
current sharing rail will cause automatic phase
re-distribution of the members of that current sharing rail.
If the members of a current sharing rail are forced to shut
down due to an observed fault, all members of the rail will
attempt to re-start simultaneously after the fault has
cleared. PMBus commands can be used to congure current
sharing. A maximum of seven modules can be congured
in a single current share group.
the phase offset of each module is controlled by the module
addresses; phase offset = device address x 45°.
For example:
• A module address of 0x00 or 0x20 would congure 0° of
phase offset
• A module address of 0x01 or 0x21 would congure 45° of
phase offset
• A module address of 0x02 or 0x22 would congure 90° of
phase offset
The phase offset of each module may also be set via the
PMBus INTERLEAVE command.
ED
Fault Spreading
NDM2Z-50 modules can be configured to broadcast a fault
event over the DDC (Digital-DC Communication bus) to the
other modules in the group. When a nondestructive fault
occurs and the module is configured to shut down on a
fault, the module will shut down and broadcast the fault
event over the DDC. The other modules on the DDC will
shut down together if configured to do so, and will attempt
to re-start in their prescribed order if configured to do so.
transmission and reception of faults.
date 12/21/2015 Ϳ page 29 of 32
DI
SC
ON
TI
Input Under and Over Voltage Lockout
Input under voltage lockout (UVLO) and input over voltage
lockout (OVLO) indicate faults for the NDM2Z-50 module
when the input voltage falls outside of preset thresholds.
The default response due to an input voltage fault is
an immediate shutdown of the module. The module will
continuously check for the presence of the fault condition.
Once the fault condition is no longer present, the module
will be re-enabled. PMBus commands can be used to
congure the thresholds and response of the module to the
fault condition.
Output Under and Over Voltage Protection
The NDM2Z-50 module employs an output voltage
protection circuit that can be used to protect load circuitry
from being subjected to voltages outside of prescribed
limits. A hardware comparator is used to compare the
voltage seen at the +S pin to voltage thresholds. If the +S
pin voltage is outside of these thresholds the PG pin will
de-assert and the module will indicate a fault condition.
The default response to an output voltage fault is to
immediately shut down. The module will continuously check
for the presence of the fault condition, when the fault
condition no longer exists the module will be re-enabled.
PMBus commands can be used to set the voltage
thresholds and congure the response of the module to the
fault condition. When operating from an external clock the
only allowed response to an output voltage fault is an
immediate shutdown.
Phase Spreading
When multiple NDM2Z-50 modules share a common DC
input supply, it may be desirable to adjust the clock phase
offset of each module. In order to enable phase spreading,
all modules must be synchronized to the same switching
clock. For modules driven by a common synchronizing clock
cui.com
Product Page
3D Model
Table 5: Pin-strap SMBus Addressing
SA0
ADDRESS
HIGH
0x22
OPEN
0x21
LOW
0x20
ED
Output Over Current Protection
Output over current protection will protect the NDM2Z-50
module and load from damage if an overload condition is
imposed on the output. The module will indicate a fault
condition when the output current limit threshold is
exceeded. The default response from an output current fault
is an immediate shutdown of the module. The module will
continuously check for the presence of the fault condition,
and if the fault condition no longer exists the module will be
re-enabled. PMBus commands can be used to congure the
current limit threshold and the response of the module to
date 12/21/2015 Ϳ page 30 of 32
Table 6: Single Resistor SMBus Addressing
RSA0 (k)
ADDRESS
RSA0 (k)
ADDRESS
10.0
0x00
34.8
0x0D
0x01
38.3
0x0E
0x02
42.2
0x0F
11.0
12.1
Thermal Overload Protection
The NDM2Z-50 module includes a thermal sensor that
measures the temperature of the module and indicates a
fault when the temperature exceeds a preset limit. The
default response from a temperature fault is an
continuously check for the fault condition and once the fault
has cleared the module will be re-enabled. PMBus
commands can be used to congure the thermal
protection threshold and the response of the module to the
fault condition. Permanent damage to the module may
result if the thermal limit is set too high.
0x03
46.4
0x10
14.7
0x04
51.1
0x11
16.2
0x05
56.2
0x12
17.8
0x06
61.9
0x13
19.6
0x07
68.1
0x14
21.5
0x08
75.0
0x15
23.7
0x09
82.5
0x16
26.1
0x0A
90.9
0x17
28.7
0x0B
100.0
0x18
31.6
0x0C
TI
NU
13.3
DI
SC
ON
When using only pin SA0 to set the SMBus address, pin SA1
should be tied to PREF.
If more than 25 unique module addresses are required or if
other SMBus address values are desired, pins SA0 and SA1
can be congured with a resistor to PREF as listed in
Table 7.
SMBUS
SMBus Communications
The NDM2Z-50 module provides a SMBus interface that
enables the user to congure the module operation as well
as monitor input and output parameters. The module can
be used with any standard 2-wire I2C host device, accepts
most standard PMBus commands, is compatible with SMBus
version 2.0 and includes an SALRT line to help mitigate
bandwidth limitations related to continuous fault
monitoring. It is recommended that CTRL be pulled low
while conguring the module with PMBus commands.
Pull-up resistors are required on the SMBus lines as
described in "RECOMMENDED OPERATING CONDITIONS".
SMBus Addresses
When communicating with multiple SMBus devices using the
SMBus interface, each device must have a unique address
so the host can distinguish between the devices. The
NDM2Z-50 module address can be set according to the
pin-strap options listed in Table 5; address values are
right-justied.
If additional module addresses are required, a resistor can
be connected to pin SA0 as shown in Table 6 to provide up
to 25 unique module addresses.
Using this method, the user can theoretically congure up
to 625 unique SMBus addresses. However, the SMBus is
inherently limited to 128 modules so attempting to
congure an address higher than 128 (0x80) will cause the
module address to repeat (i.e, attempting to congure a
module address of 129 (0x81) would result in a module
address of 1).
Therefore, the user should use index values 0-4 on pin SA1
and the full range of index values on pin SA0, which will
provide 125 module address combinations. Note that the
SMBus address 0x4B is reserved for module test and cannot
be used in the system.
cui.com
Product Page
3D Model
Table 7: Dual Resistor SMBus Addressing
SINGLE WIRE COMMUNICATIONS
13.3
14.7
10.0
0x00
0x19
0x32
0x4B
0x64
11.0
0x01
0x1A
0x33
0x4C
0x65
12.1
0x02
0x1B
0x34
0x4D
0x66
13.3
0x03
0x1C
0x35
0x4E
0x67
14.7
0x04
0x1D
0x36
0x4F
0x68
16.2
0x05
0x1E
0x37
0x50
0x69
17.8
0x06
0x1F
0x38
0x51
0x6A
19.6
0x07
0x20
0x39
0x52
0x6B
21.5
0x08
0x21
0x3A
0x53
0x6C
23.7
0x09
0x22
0x3B
0x54
0x6D
26.1
0x0A
0x23
0x3C
0x55
0x6E
28.7
0x0B
0x24
0x3D
0x56
0x6F
31.6
0x0C
0x25
0x3E
0x57
0x70
34.8
0x0D
0x26
0x3F
0x58
0x71
38.3
0x0E
0x27
0x40
0x59
0x72
42.2
0x0F
0x28
0x41
0x5A
0x73
46.4
0x10
0x29
0x42
0x5B
0x74
51.1
0x11
0x2A
0x43
0x5C
0x75
56.2
0x12
0x2B
0x44
0x5D
0x76
61.9
0x13
0x2C
0x45
0x5E
0x77
68.1
0x14
0x2D
0x46
0x5F
0x78
75.0
0x15
0x2E
0x47
0x60
0x79
82.5
0x16
0x2F
0x48
0x61
0x7A
90.9
0x17
0x30
0x49
0x62
0x7B
100.0
0x18
0x31
0x4A
0x63
0x7C
Digital-DC Bus
The DDC (Digital-DC Communication Bus) is used to
communicate between NDM2Z modules. This dedicated bus
provides the communication channel between modules for
features such as sequencing, fault spreading, and current
sharing. A pull-up resistor is required on the DDC as
dened in “RECOMMENDED OPERATING CONDITIONS”.
RSA1 (k)
ED
12.1
Snapshot™ Parameter Capture
The NDM2Z-50 module offers features that enable the user
to capture parametric data during normal operation or
following a fault. The Snapshot feature enables the user to
read status and parameter values via a block read transfer
through the SMBus. This can be done during normal
operation, although it should be noted that reading the 22
bytes will occupy the SMBus for up to 1400 Njs.
The SNAPSHOT_CONTROL command enables the user to
store the snapshot parameters to ash memory in
response to a pending fault as well as to read the stored
data from ash memory after a fault has occurred.
Automatic writes to ash memory following a fault are
triggered when any fault threshold level is exceeded,
provided that the specic response to that fault is
to shut down (writing to ash memory is not allowed if the
module is congured to re-try following the specic fault
condition). It should also be noted that the input voltage to
the module must be maintained during the time when the
module is writing the data to ash memory; a process that
requires between 700 Njs to 1400 Njs depending on whether
the data is set up for a block write. Undesirable results may
be observed if the input voltage to the module drops too
low during this process. In the event that the module
experiences a fault and power is lost, the user can extract
the last SNAPSHOT parameters stored during the fault
by using the SMBus to transfer data from ash memory to
RAM and then using the SMBus to read data from RAM.
NU
11.0
DI
SC
ON
TI
10.0
RSA0 (k)
Monitoring Via SMBus
A system controller can be used to monitor the NDM2Z-50
module system parameters through the SMBus. Fault
conditions can be detected by monitoring the SALRT pin,
which will be asserted when pre-congured fault conditions
occur. Modules can also be monitored for power conversion
parameters including but not limited to the following:
Input voltage
Output voltage
Output current
Module temperature
Switching frequency
Duty cycle
date 12/21/2015 Ϳ page 31 of 32
THERMAL CONSIDERATIONS
Mounting
Heat from the NDM2Z-50 module will be conducted through
the pins to the host board. Provisions must be made for the
host board to accommodate this additional heating.
Airow
Airow past the NDM2Z-50 module will assist in cooling
the module. Factors affecting the efciency of the cooling
include the rate, direction and temperature of the airow.
cui.com
Product Page
3D Model
date 12/21/2015 Ϳ page 32 of 32
rev.
date
1.0
09/28/2015
1.1
12/16/2015
ED
REVISION HISTORY
DI
SC
ON
TI
NU
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
Architects of Modern Power and AMP Group are trademarks of CUI.
Novum is a trademark of CUI.
PMBus is a trademark of SMIF, Inc.
Digital-DC is a trademark of Intersil Corporation.
CUI Novum products use patented technology licensed from Power-One.
All other trademarks are the property of their respective owners.
CUI offers a two (2) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
