PYB30-Q24-T512-H
PYB30-Q24-T512-H
    CUIDEVICES
    DC/DCCONVERTER5V+/-12V30W
PYB30-Q24-T512-H 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 03/15/2021 page 1 of 7 SERIES: PYB30 │ DESCRIPTION: DC-DC CONVERTER FEATURES • • • • • • • • • • up to 30 W isolated output industry standard pinout 4:1 input range (9~36 Vdc, 18~75 Vdc) smaller package single/dual/triple regulated outputs 1,500 Vdc isolation continuous short circuit, over current protection, over voltage protection temperature range (-40~85°C) six-sided metal shielding efficiency up to 90% MODEL input voltage output voltage output current output power ripple and noise1 efficiency typ (Vdc) range (Vdc) (Vdc) min (mA) max (mA) max (W) max (mVp-p) typ (%) PYB30-Q24-S5 24 9~36 5 300 6000 30 100 88 PYB30-Q24-S12 24 9~36 12 125 2500 30 100 88 PYB30-Q24-S15 24 9~36 15 100 2000 30 100 90 PYB30-Q24-D5 24 9~36 ±5 ±150 ±3000 30 100 86 PYB30-Q24-D12 24 9~36 ±12 ±63 ±1250 30 100 89 PYB30-Q24-D15 24 9~36 ±15 ±50 ±1000 30 100 90 175 ±31 3500 ±625 26.5 100 85 PYB30-Q24-T312 24 9~36 3.3 ±12 PYB30-Q24-T315 24 9~36 3.3 ±15 175 ±25 3500 ±500 26.5 100 86 PYB30-Q24-T512 24 9~36 5 ±12 150 ±31 3000 ±625 30 100 88 PYB30-Q24-T515 24 9~36 5 ±15 150 ±25 3000 ±500 30 100 88 PYB30-Q48-S5 48 18~75 5 300 6000 30 100 88 PYB30-Q48-S12 48 18~75 12 125 2500 30 100 88 PYB30-Q48-S15 48 18~75 15 100 2000 30 100 89 PYB30-Q48-D5 48 18~75 ±5 ±150 ±3000 30 100 86 PYB30-Q48-D12 48 18~75 ±12 ±63 ±1250 30 100 87 PYB30-Q48-D15 48 18~75 ±15 ±50 ±1000 30 100 87 175 ±31 3500 ±625 26.5 100 85 PYB30-Q48-T312 48 18~75 3.3 ±12 PYB30-Q48-T315 48 18~75 3.3 ±15 175 ±25 3500 ±500 26.5 100 85 PYB30-Q48-T512 48 18~75 5 ±12 150 ±31 3000 ±625 30 100 88 PYB30-Q48-T515 48 18~75 5 ±15 150 ±25 3000 ±500 30 100 87 Notes: 1. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 µF ceramic and 10 µF electrolytic capacitors on the output. cui.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PYB30 │ DESCRIPTION: DC-DC CONVERTER date 03/15/2021 │ page 2 of 7 PART NUMBER KEY PYB30 - QXX - XXX Base Number Output Voltage Input Voltage Output S = single D = dual T = triple INPUT parameter conditions/description operating input voltage 24 Vdc input models 48 Vdc input models min typ max units 9 18 24 48 36 75 Vdc Vdc start-up voltage 24 Vdc input models 48 Vdc input models (single/dual output models) 48 Vdc input models (triple output models) 9 18 17.8 Vdc Vdc Vdc under voltage shutdown1 24 Vdc input models 48 Vdc input models 7.8 16 surge voltage for maximum of 1 second 24 Vdc input models 48 Vdc input models -0.7 -0.7 start-up time filter Vdc Vdc 50 100 Vdc Vdc 10 ms 1 mA pi filter models ON (CTRL open or connect high level, 2.5~12 Vdc) CTRL2 models OFF (CTRL connect GND or low level, 0~1.2 Vdc) input current (models OFF) Notes: 1. Contact CUI if you are planning to use this feature in your application. 2. CTRL pin voltage is referenced to GND. OUTPUT parameter conditions/description min line regulation full load, input voltage from low to high single and dual output models triple output models (main output) triple output models (auxiliary outputs) load regulation 5% to 100% load, nominal input single and dual output models triple output models (main output) triple output models (auxiliary outputs) cross regulation dual output models: main output 50% load, secondary output from 10% to 100% load voltage accuracy single and dual output models triple output models (main output) triple output models (auxiliary outputs) 3 adjustability4 typ max units ±0.2 ±0.5 ±1 ±5 % % % ±0.5 ±1 ±2 ±5 % % % ±5 % ±3 ±3 ±5 % % % ±1 ±1 ±3 ±10 % switching frequency PWM mode 400 kHz transient recovery time 25% load step change 300 500 μs transient response deviation 25% load step change ±3 ±5 % temperature coefficient 100% load, single and dual output models 100% load, triple output models ±0.02 ±0.03 %/°C %/°C Notes: 3. For dual output models, unbalanced load can not exceed ±5%. If ±5% is exceeded, it may not meet all specifications. 4. Output trimming available on single and dual output models only. cui.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PYB30 │ DESCRIPTION: DC-DC CONVERTER date 03/15/2021 │ page 3 of 7 PROTECTIONS parameter conditions/description short circuit protection hiccup, continuous, automatic recovery min over current protection over voltage protection 3.3 Vdc output models 5 Vdc output models 12 Vdc output models 15 Vdc output models typ max units 150 % 3.9 6.2 15 18 Vdc Vdc Vdc Vdc SAFETY AND COMPLIANCE parameter conditions/description isolation voltage for 1 minute at 1 mA max. 1,500 min typ max Vdc isolation resistance at 500 Vdc 1,000 MΩ conducted emissions CISPR22/EN55022, class A, class B (external circuit required, see Figure 1-b) radiated emissions CISPR22/EN55022, class A, class B (external circuit required, see Figure 1-b) ESD IEC/EN61000-4-2, class B, contact ± 4kV radiated immunity IEC/EN61000-4-3, class A, 10V/m EFT/burst IEC/EN61000-4-4, class B, ± 2kV (external circuit required, see Figure 1-a) surge IEC/EN61000-4-5, class B, ± 2kV (external circuit required, see Figure 1-a) conducted immunity IEC/EN61000-4-6, class A, 3 Vr.m.s voltage dips & interruptions IEC/EN61000-4-29, class B, 0%-70% MTBF as per MIL-HDBK-217F @ 25°C RoHS 2011/65/EU 1,000,000 units hours ENVIRONMENTAL parameter conditions/description min operating temperature see derating curve storage temperature storage humidity non-condensing case temperature at full load, Ta=71°C typ max units -40 85 °C -55 125 °C 5 95 % 105 °C SOLDERABILITY parameter conditions/description max units hand soldering 1.5 mm from case for 10 seconds min 300 °C wave soldering see wave soldering profile 260 °C Wave Soldering Profile Peak Temp. 260°C Max. Wave Soldering Time 4 Sec. Max. 250 Temperature (°C) 200 10 Sec. Max. 150 100 50 0 Time (sec.) cui.com typ Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PYB30 │ DESCRIPTION: DC-DC CONVERTER date 03/15/2021 │ page 4 of 7 MECHANICAL parameter conditions/description dimensions 50.8 x 40.6 x 11.8 case material aluminum alloy min typ max mm weight 50 g MECHANICAL DRAWING BOARD MOUNT Grid Size: 2.54mm x 2.54mm units: mm[inch] tolerance: ±0.25[±0.010] pin diameter tolerance: ±0.10[±0.004] pin height tolerance: ±0.50[±0.020] PIN CONNECTIONS PIN Single Output Dual Output Triple Output 1 Vin Vin Vin 2 GND GND GND 3 CTRL CTRL CTRL 4 Trim Trim -Vo2 5 0V -Vo 0V 6 +Vo 0V +Vo1 7 NP +Vo +Vo2 units Bottom View PCB Layout Top View Front View cui.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PYB30 │ DESCRIPTION: DC-DC CONVERTER date 03/15/2021 │ page 5 of 7 DERATING CURVES EMC RECOMMENDED CIRCUIT Figure 1 Table 1 Single Output FU SE Vi n LDM Recommended external circuit components LCM C3 Vi n MO V TVS C1 C0 +Vo GND E FUSE EUT C2 GND D Vin (Vdc) L O AD 0V C4 FU SE Vi n LCM C3 +Vo Vi n MO V TVS C1 C0 G ND D L O AD GND E 0V 10D101K LDM 56μH 56μH TVS SMCJ48A SMCJ90A C0 120μF/50V 120μF/100V C1 4.7μF/50V 2.2μF/100V LCM 2.2mH 2.2mH C2 4.7μF/50V 2.2μF/100V C3* 1nF/2kV 1nF/2kV C4 1nF/2kV 1nF/2kV * -Vo C4 Choose according to input current 10D560K L O AD EUT C2 48 MOV Dual Output LDM 24 Note: *2nF/2kV capacitors for triple output, 48 Vdc input models. Triple Output Vi n FU SE LDM LCM +Vo 1 C3 +Vo 2 Vi n MO V TVS C1 C0 GND D E EUT C2 L O AD 0V L O AD GND C4 L O AD -Vo 2 TEST CONFIGURATION Table 2 Oscilloscope Lin Figure 2 Cin Note: External components Current Probe DC DC Load Input reflected-ripple current is measured with an inductor Lin and Capacitor Cin to simulate source impedance. cui.com Lin 4.7μH Cin 220μF, ESR < 1.0Ω at 100 kHz Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PYB30 │ DESCRIPTION: DC-DC CONVERTER date 03/15/2021 │ page 6 of 7 APPLICATION NOTES 1. Recommended circuit This series has been tested according to the following recommended testing circuit before leaving the factory. This series should be tested under load (see Figure 3). If you want to further decrease the input/output ripple, you can increase the capacitance accordingly or choose capacitors with low ESR (see Table 3). However, the capacitance of the output filter capacitor must be appropriate. If the capacitance is too high, a startup problem might arise. For every channel of the output, to ensure safe and reliable operation, the maximum capacitance must be less than the maximum capacitive load (see Table 4). Vin Figure 3 Single Output +Vo Cin DC DC Dual Output Vin DC Cin Cou t 0V GND GND Triple Output Vi n Vo 1 DC C in DC DC Cout Cout (µF) Dual Vout (Vdc) Cin (µF) -Vo 2 Table 4 Cout1 (µF) Triple Vout (Vdc) Cin (µF) Cout1 (µF) -- -- -- -- -- -- 3.3 10 10 5 10 10 ±5 10 10 5 10 10 12 10 4.7 ±12 10 4.7 ±12 10 4.7 15 10 4.7 ±15 10 4.7 ±15 10 4.7 Note: Single Vout (Vdc) Max. Capacitive Load (μF) Dual Vout (Vdc) Max. Capacitive Load1 (μF) Triple Vout (Vdc) Max. Capacitive Load1 (μF) -- -- -- -- 3.3/±12 4700/300 5 6000 5 2000 3.3/±15 4700/220 12 2500 12 1250 5/±12 4700/300 1100 15 680 5/±15 4700/220 15 1. For each output. Note: 2. -Vo 0V Cout Table 3 Cin (µF) 0V Cou t Vo 2 Cout GND Single Vout (Vdc) +Vo Cout 1. For each output. Output voltage trimming Leave open if not used. Figure 4 Application Circuit for Trim pin (part in broken line is the interior of models) Formula for Trim Resistor up : R T= aR 2 R2-a -R3 a= Vref R1 Vo’ - Vref down : R T= aR 1 R1-a -R3 a= Vo’ - Vref R2 Vref + Vo +Vo R1 V re f R2 RT R1 R3 Trim V re f RT R3 R2 0V 0V Tr im up Tr im down Trim Note: Value for R1, R2, R3, and Vref refer to Table 5 RT: Trim Resistor a: User-defined parameter, no actual meanings Vo': The trim up/down voltage Table 5 Note: Vout (Vdc) R1 (kΩ) R2 (kΩ) R3 (kΩ) Vref (V) 5 2.883 2.864 10 2.5 12 10.971 2.864 17.8 2.5 15 14.497 2.864 17.8 2.5 1. Minimum load shouldn't be less than 5%, otherwise ripple may increase dramatically. Operation under minimum load will not damage the converter, however, they may not meet all specifications listed. 2. Maximum capacitive load is tested at input voltage range and full load. 3. All specifications are measured at Ta=25°C, humidity
PYB30-Q24-T512-H 价格&库存
很抱歉,暂时无法提供与“PYB30-Q24-T512-H”相匹配的价格&库存,您可以联系我们找货
