NQB-420NWA-AN
NQB-420NWA-AN
    CUIDEVICES
    DIP5
    CONV BUS 12V OUT 420W
NQB-420NWA-AN 数据手册
Additional Resources: Product Page date 11/07/2014 page 1 of 30 GENERAL CHARACTERISTICS FEATURES • • • • • • • pin and function compatible with Architects of Modern Power™ product standards • industry standard quarter-brick 57.9 x 36.8 x 11.3 mm (2.28 x 1.45 x 0.445 in) • industry-leading power density for telecom and datacom 127~141W / sq. in • high efficiency, typ. 96.4% at half load, 12 Vout • fully regulated advanced bus converter from 36~75Vin • 2,250 Vdc input to output isolation • fast feed forward regulation to manage line transients • optional baseplate for high temperature applications • droop load sharing with 10% current share accuracy • 2.9 million hours MTBF • ISO 9001/14001 certified supplier SC ON TI NU industry standard footprint isolated topology high power density fast transient response high conversion efficiency wide range of input and output characteristics available ED SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS MODEL output voltage output current output wattage (Vdc) (Vdc) max (A) max (W) NQB-420NWA-AN 36~75 12 35 420 NQB-468NMA-AN 40~60 12 39 468 NQB-415NWB-AN 36~75 12.45 35 415 NQB-462NMB-AN 40~60 12.45 39 462 DI input voltage cui.com Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 2 of 30 PART NUMBER KEY NQB- XXX N X X - X X X X - XXX -ES X Base Number ED Engineering Phase: A~Z Design Output Power: 1~999 Engineering Sample: ES Input Voltage Range: W = wide (36~75 V) M = medium (40~60 V) )LUPZDUH&RQ¿JXUDWLRQ 000~ZZZ Heatsink Option: "blank" = open frame + KHDWVLQNÀDW G = heatsink with GND pin TI Nominal Output Voltage: A = 12.0 V B = 12.45 V C = 9.6 V Load Sharing Function: D = 9.0 V D = Vout droop E = 5.0 V NU No Digital Interface Enable Logic Sense: N = negative logic P = positive logic SC ON Pin Description: A = 5.33 mm (0.210 in.) B = 4.57 mm (0.180 in.) C = 3.69 mm (0.145 in.) D = 2.79 mm (0.110 in.) S = SMT Packaging: 20 converters(through hole pin)/tray, PE foam dissipative 20 converters(surface mount pin)/tray, Antistatic PPE Example part number: NQB-420NWA-AN-001 420 W output power, no digital pins wide input voltage range, 12.0 V output 5.33 mm pins, negative enable logic ¿UPZDUHUHYLVLRQ CONTENTS DI Part Number Key........................................................2 General Information...................................................3 6DIHW\6SHFL¿FDWLRQ Absolute Maximum Ratings..........................................4 (OHFWULFDO6SHFL¿FDWLRQ 12V, 35A, 420W, 36~75Vin; NQB-420NWA-AN....................5 12 V, 39 A, 468 W, 40~60 Vin; NQB-468NMA-AN..................9 12.45 V, 35 A, 415 W, 36~75 Vin; NQB-415NWB-AN............13 12.45 V, 39 A, 462 W, 40~60 Vin; NQB-420NMB-AN............16 cui.com (0& 6SHFL¿FDWLRQ Operating Information...................................19 Thermal Consideration..................................21 Connections............................................22 Mechanical Information.................................23 Soldering Information...................................26 Delivery Package Information.........................27 3URGXFW4XDOL¿FDWLRQ6SHFL¿FDWLRQ Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 3 of 30 General Information Telcordia SR-332 Issue 2 also provides techniques to HVWLPDWHWKHXSSHUFRQ¿GHQFHOHYHOVRIIDLOXUHUDWHVEDVHG on the mean and standard deviation. Component power supplies for general use should comply with the requirements in IEC/EN/UL 60950 1 Safety of Information Technology Equipment. Product related standards, e.g. IEEE 802.3af Power over Ethernet, and ETS 300132 2 Power interface at the input to telecom equipment, operated by direct current (dc) are based on IEC/EN/UL 60950 1 with regards to safety. CUI Power Modules DC/DC converters and DC/DC UHJXODWRUVDUH8/UHFRJQL]HGDQGFHUWL¿HGLQ DFFRUGDQFHZLWK(17KHÀDPPDELOLW\UDWLQJIRU all construction parts of the products meet requirements for V 0 class material according to IEC 60695 11 10, Fire KD]DUGWHVWLQJWHVWÀDPHV – 50 W horizontal and vertical ÀDPHWHVWPHWKRGV Mean steady-state failure rate, λ Std. deviation, σ 60.9 nF ailures/h NU 421 n F ailures/h the requirements of all applicable safety standards and UHJXODWLRQVIRUWKH¿QDOSURGXFW ED Reliability 7KHIDLOXUHUDWH NJ DQGPHDQWLPHEHWZHHQIDLOXUHV 07%) NJ LVFDOFXODWHGDWPD[RXWSXWSRZHUDQG an operating ambient temperature (TA) of +40°C. CUI Power Modules uses Telcordia SR-332 Issue 2 Method 1 to calculate the mean steady-state failure rate and standard GHYLDWLRQ ı  MTBF (mean value) for the NQB series = 2.9 Mh. 07%)DWFRQ¿GHQFHOHYHO 0K Compatibility with RoHS requirements Isolated DC/DC converters The products are compatible with the relevant clauses and requirements of the RoHS directive 2011/65/EU and have a maximum concentration value of 0.1% by weight in homogeneous materials for lead, mercury, hexavalent chromium, PBB and PBDE and of 0.01% by weight in homogeneous materials for cadmium. TI *DOYDQLFLVRODWLRQEHWZHHQLQSXWDQGRXWSXWLVYHUL¿HG in an electric strength test and the isolation voltage (Viso) meets the voltage strength requirement for basic insulation according to IEC/EN/UL 60950-1. It is recommended to use a slow blow fuse at the input RIHDFK'&'&FRQYHUWHU,IDQLQSXW¿OWHULVXVHGLQWKH FLUFXLWWKHIXVHVKRXOGEHSODFHGLQIURQWRIWKHLQSXW¿OWHU In the rare event of a component problem that imposes a short circuit on the input source, this fuse will provide the following functions: • Isolate the fault from the input power source so as not to affect the operation of other parts of the system • Protect the distribution wiring from excessive current and power loss thus preventing hazardous overheating DI SC ON Exemptions in the RoHS directive utilized in CUI Power Modules products are found in the Statement of Compliance document. Safety Specification Reliability CUI Power Modules DC/DC converters and DC/DC regulators are designed in accordance with the safety standards IEC 60950 1, EN 60950 1 and UL 60950 1 Safety of Information Technology Equipment. IEC/EN/UL 60950 1 contains requirements to prevent injury or damage due to the following hazards: • Electrical shock • Energy hazards • Fire • Mechanical and heat hazards • Radiation hazards • Chemical hazards On-board DC/DC converters and DC/DC regulators are GH¿QHGDVFRPSRQHQWSRZHUVXSSOLHV$VFRPSRQHQWV they cannot fully comply with the provisions of any safety requirements without “conditions of acceptability”. Clearance between conductors and between conductive parts of the component power supply and conductors on WKHERDUGLQWKH¿QDOSURGXFWPXVWPHHWWKHDSSOLFDEOH safety requirements. Certain conditions of acceptability apply for component power supplies with limited stand-off (see Mechanical Information for further information). It is WKHUHVSRQVLELOLW\RIWKHLQVWDOOHUWRHQVXUHWKDWWKH¿QDO product housing these components complies with The DC/DC converter output is considered as safety extra low voltage (SELV) if one of the following conditions is met: • The input source has double or reinforced insulation from the AC mains according to IEC/EN/ UL 60950-1 • The input source has basic or supplementary insulation from the AC mains and the input of the DC/DC converter is maximum 60 Vdc and connected to protective earth according to IEC/EN/UL 60950-1 • The input source has basic or supplementary insulation from the AC mains and the DC/DC converter output is connected to protective earth according to IEC/EN/UL 60950-1 Non - isolated DC/DC regulators The DC/DC regulator output is SELV if the input source meets the requirements for SELV circuits according to IEC/ EN/UL 60950-1. cui.com Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 4 of 30 Absolute Maximum Ratings parameter conditions/description min operating temperature (TP1) see thermal consideration section typ max units -40 +125 °C storage temperature (TS) -55 +125 °C input voltage (VI) -0.5 +80 +65* V input to output test voltage, see note 1 2250 Vdc input voltage transient (Vtr) according to ETSI EN 300 132-2 and Telcordia GR1089-CORE +100 +80* V remote control pin voltage (VRC) see operating information section 18 V ED isolation voltage (Viso) -0.3 Stress in excess of Absolute Maximum Ratings may cause permanent damage. Absolute Maximum Ratings, sometimes referred to as no destruction limits, are normally tested with one SDUDPHWHUDWDWLPHH[FHHGLQJWKHOLPLWVRI2XWSXWGDWDRU(OHFWULFDO&KDUDFWHULVWLFV,IH[SRVHGWRVWUHVVDERYHWKHVHOLPLWVIXQFWLRQDQGSHUIRUPDQFHPD\GHJUDGHLQDQXQVSHFL¿HG manner. Note 1: Isolation voltage (input/output to base-plate) max 750 Vdc. * Applies for the narrow input version VI= 40-60 V Driver +IN NU Fundamental Circuit Diagram +OUT -IN Driver SC ON Auxillary Supply TI -OUT RC Control RC isolation Functional Description TP1, TP3 = -40 to +90ºC, VI = 36 to 75 V. Typical values given at: TP1, TP3 = +25°C, VI= 53 V, max IOXQOHVVRWKHUZLVHVSHFL¿HGXQGHU&RQGLWLRQV &RQ¿JXUDWLRQ)LOH&'$ parameter conditions/description min typ max units fault protection characteristics fault limit setpoint accuracy hysteresis delay DI input under voltage lockout (UVLO) -2 33 2 300 2 V % V NjV output voltage - under voltage protection fault limit fault response time 0 200 V NjV output voltage - over voltage protection fault limit fault response time 15.6 200 V NjV over current protection (OCP) setpoint accuracy (IO) fault limit fault response time over temperature protection (OTP) fault limit hysteresis fault response time -6 41 200 125 10 300 cui.com 6 % A NjV ºC ºC NjV Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 5 of 30 Electrical Specification 12.0 V, 35 A, 420 W TP1, TP3 = -40 to +90ºC, VI = 36 to 75 V. Typical values given at: TP1, TP3 = +25°C, VI = 53 V, max IOXQOHVVRWKHUZLVHVSHFL¿HGXQGHU&RQGLWLRQV Additional Cout P)&RQ¿JXUDWLRQ)LOH&'$ parameter conditions/description min input voltage range (VI) typ 36 max units 75 V decreasing input voltage 32 33 34 V turn-on input voltage (VIon) increasing input voltage 34 35 36 V ED turn-off input voltage (VIoff) internal input capacitance (CI) 18 output power (PO) 0 HI¿FLHQF\ dž 50% of max IO max IO 50% of max IO, VI = 48 V max IO, VI = 48 V power dissipation (Pd) max IO Nj) 420 96.2 95.5 96.4 95.5 NU 19.8 IO = 0 A, VI = 53 V VI = 53 V (turned off with RC) switching frequency (fs) 0-100% of max IO output voltage setting and accuracy (VOi) TP1 = +25°C, VI = 53 V, IO = 35 A 11.88 output voltage tolerance band (VO) 0-100% of max IO 11.76 line regulation (VO) max IO TI input idling power (Pli) input standby power (PRC) W % % % % 29.5 W 3.3 W 0.4 W 140 kHz 12.0 12.12 V 12.24 V 21 55 mV 6 40 mV VI = 53 V, 0-100% of max IO VI = 53 V, load step 25-75-25% of max IO, di/dt = $NjV ±0.4 V load transient recovery time (ttr) VI = 53 V, load step 25-75-25% of max IO, di/dt = $NjV 150 µs ramp-up time (tr) - (from íRI9Oi) 10-100% of max IO, TP1, TP3 = 25ºC, VI = 53 V 8 ms start-up time (ts) - (from VI connection to 90% of VOi) 10-100% of max IO, TP1, TP3 = 25ºC, VI = 53 V 24 ms VI shut-down fall time (tf) (from VI off to 10% of VO) max IO IO = 0 A, CO = 0 mF 3.6 7 ms s RC start-up time (tRC) max IO 12 ms RC shut-down fall time (tRC) (from RC off to 10% of VO) max IO IO = 0 A, CO = 0 mF 5.1 7 ms s SC ON load regulation (VO) load transient voltage deviation (Vtr) output current (IO) current limit threshold (Ilim) VO = 10.8 V, TP1, TP3 < max TP1, TP3 short circuit current (Isc) TP1, TP3 = 25ºC, see Note 1 recommended capacitive load (Cout) TP1, TP3 = 25ºC, see Note 2 0 37 41 35 A 44 A 12 6 mF See ripple & noise section, max IO , see Note 3 60 150 mVp-p over voltage protection (OVP) TP1, TP3 = 25°C, VI = 53 V, 10-100% of max IO 15.6 remote control (RC) sink current (note 4), see operating information trigger level, decreasing RC-voltage trigger level, increasing RC-voltage 0.7 mA V V DI 3.5 output ripple & noise (VOac) Note 1: 2: 3: 4: 0.1 A 2.6 2.9 OCP in hic-up mode Low ESR-value Cout = 100 µF, external capacitance Sink current drawn by external device connected to the RC pin. Minimum sink current required guaranteeing activated RC function. cui.com V Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 6 of 30 Typical Characteristics 12.0 V, 35 A / 420 W Efficiency Power Dissipation 100 ED [W] 24 [%] 20 95 53 V 53 V 8 75 V 75 V 4 NU 80 48 V 12 48 V 85 36 V 16 36 V 90 75 0 0 5 10 15 20 25 30 0 35 [A] 5 10 15 20 25 30 35 [A] Dissipated power vs. load current and input voltage at TP1, TP3 = +25°C Efficiency vs. load current and input voltage at TP1, TP3 = +25 C Output Characteristics Current Limit Characteristics [V] [V] 13.0 TI 12.2 11.0 12.1 36 V 48 V 12.0 DI SC ON 53 V 75 V 11.9 11.8 0 5 10 15 20 25 30 35 [A] Output voltage vs. load current at TP1, TP3 = +25°C cui.com 36 V 9.0 48 V 53 V 7.0 75 V 5.0 3.0 35 37 39 41 43 45 [A] Output voltage vs. load current at IO > max IO , TP1, TP3 = +25°C Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 7 of 30 Typical Characteristics 12.0 V, 35 A / 420 W Shut-down Start-up enabled by connecting VI at: TP1, TP3 = +25°C, VI = 53 V, IO = 35 A resistive load. Top trace: output voltage (5 V/div.). Bottom trace: input voltage (50 V/div.). Time scale: (10 ms/div.). Shut-down enabled by disconnecting VI at: TP1, TP3 = +25°C, VI = 53 V, IO =35 A resistive load. Top trace: output voltage (5 V/div.). Bottom trace: input voltage (50 V/div.). Time scale: (2 ms/div.). Output Load Transient Response DI SC ON TI Output Ripple & Noise NU ED Start-up Output voltage ripple at: TP1, TP3 = +25°C, VI = 53 V, IO = 35 A resistive load. Trace: output voltage (50 mV/div.). Time scale: (2 µs/div.). Output voltage response to load current step-change (8.75-26.25-8.75 A) at: TP1, TP3 =+25°C, VI = 53 V, CO = 3.5 mF. Input Voltage Transient Response Output voltage response to input voltage transient at: TP1, TP3 = +25°C, VI = 36-75 V, IO = 17 A resistive load, CO = 3.5 mF Top trace: output voltage (2 V/div.). Bottom trace: input voltage (20 V/div.). Time scale: (0.5 ms/div.). cui.com Top trace: output voltage (0.5 V/div.). Bottom trace: output current (20 A/div.). Time scale: (0.5 ms/div.). Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 8 of 30 Typical Characteristics 12.0 V, 35 A / 420 W [A] 35 ED Output Current Derating – Open frame 3.0 m/s 30 2.0 m/s 25 15 1.0 m/s 10 0.5 m/s 5 Na t. Co nv. 0 0 20 40 60 80 100 [°C] Available load current vs. ambient air temperature and airflow at VI = 53 V. See Thermal Consideration section. Output Current Derating – Base plate [A] 35 NU 1.5 m/s 20 Thermal Resistance – Base plate TI [°C/W] 6 3.0 m/s 30 5 2.0 m/s 25 4 1.5 m/s 3 DI SC ON 20 15 1.0 m/s 10 0.5 m/s 5 2 1 Na t. Con v. 0 0 0 20 40 60 80 100 [°C] Available load current vs. ambient air temperature and airflow at VI = 53 V. See Thermal Consideration section. Output Current Derating – Base plate + Heat sink 25 20 15 10 20 40 60 80 1.5 2.0 2.5 3.0 [m/s] A 40 35 2.0 m/s 30 1.5 m/s 25 1.0 m/s 20 15 0.5 m/s 10 0 0 1.0 Thermal resistance vs. airspeed measured at the converter. Tested in wind tunnel with airflow and test conditions as per the Thermal consideration section. VI = 53 V. 3.0 m/s Na t. Con v. 5 0.5 Output Current Derating – Cold wall sealed box [A] 35 30 0.0 100 [°C] Ta mb 85 °C 5 0 0 20 40 60 80 100 [°C] Available load current vs. base plate temperature at 85ºC ambient. VI = 53 V. See Thermal Consideration section. Available load current vs. ambient air temperature and airflow at VI = 53 V. See Thermal Consideration section. Tested with Plate Fin Transverse heatsink, height 0.23 In, P0114 Thermal Pad. cui.com Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 9 of 30 Electrical Specification 12.0 V, 39 A / 468 W TP1, TP3 = -40 to +90ºC, VI = 40 to 60 V. Typical values given at: TP1, TP3 = +25°C, VI = 53 V, max IOXQOHVVRWKHUZLVHVSHFL¿HGXQGHU&RQGLWLRQV Additional Cout P)&RQ¿JXUDWLRQ)LOH&'$ parameter conditions/description min input voltage range (VI) max units 60 V decreasing input voltage 36 37 38 V turn-on input voltage (VIon) increasing input voltage 38 39 40 ED turn-off input voltage (VIoff) internal input capacitance (CI) 18 output power (PO) 0 50% of max IO max IO 50% of max IO, VI = 48 V max IO, VI = 48 V power dissipation (Pd) max IO input idling power (Pli) IO = 0 A, VI = 53 V 468 21.2 V Nj) 96.7 95.7 96.8 95.6 NU HI¿FLHQF\ dž typ 40 W % % % % 30.5 2.8 W W VI = 53 V (turned off with RC) 0-100% of max IO output voltage setting and accuracy (VOi) TP1 = +25°C, VI = 53 V, IO = 39 A 11.88 output voltage tolerance band (VO) 0-100% of max IO 11.76 line regulation (VO) max IO load regulation (VO) VI = 53 V, 1-100% of max IO load transient voltage deviation (Vtr) VI = 53 V, load step 25-75-25% of max IO, di/dt = $NjV ±0.4 V load transient recovery time (ttr) VI = 53 V, load step 25-75-25% of max IO, di/dt = $NjV 150 µs ramp-up time (tr) - (from íRI9Oi) 10-100% of max IO, TP1 = 25ºC, VI = 53 V 8 ms start-up time (ts) - (from VI connection to 90% of VOi) 10-100% of max IO, TP1 = 25ºC, VI = 53 V 24 ms VI shut-down fall time (tf) (from VI off to 10% of VO) max IO IO = 0 A, CO = 0 mF 3 7 ms s RC start-up time (tRC) max IO 12 ms RC shut-down fall time (tRC) (from RC off to 10% of VO) max IO IO = 0 A, CO = 0 mF 4.5 7 ms s SC ON TI input standby power (PRC) switching frequency (fs) output current (IO) current limit threshold (Ilim) VO = 10.8 V, TP1, TP3 < max TP1, TP3 short circuit current (Isc) TP1 = 25ºC, see Note 1 recommended capacitive load (Cout) TP1 = 25ºC, see Note 2 output ripple & noise (VOac) 0.4 W 140 kHz 12.0 V 12.24 V 31 60 mV 5 25 mV 0 41 12.12 44 39 A 47 A 14 6 mF See ripple & noise section, max IO , see Note 3 50 110 mVp-p over voltage protection (OVP) TP1, TP3 = 25°C, VI = 53 V, 10-100% of max IO 15.6 remote control (RC) sink current (note 4), see operating information trigger level, decreasing RC-voltage trigger level, increasing RC-voltage DI 3.9 Note 1: 2: 3: 4: 0.1 A 2.6 2.9 OCP in hic-up mode Low ESR-value Cout = 100 µF, external capacitance Sink current drawn by external device connected to the RC pin. Minimum sink current required guaranteeing activated RC function. cui.com V 0.7 mA V V Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 10 of 30 Typical Characteristics 12.0 V, 39 A / 468 W Efficiency Power Dissipation [%] 20 95 40 V 90 60 V 80 48 V 53 V 10 53 V 85 40 V 15 48 V 60 V 5 0 75 5 10 15 20 25 30 35 40 [A] 0 5 10 15 20 25 30 35 NU 0 ED [W] 25 100 40 [A] Dissipated power vs. load current and input voltage at TP1, TP3 = +25°C Efficiency vs. load current and input voltage at TP1, TP3 = +25 C Output Characteristics Current Limit Characteristics [V] [V] 13.0 12.2 TI 11.0 12.1 40 V 48 V 12.0 53 V 60 V DI SC ON 11.9 11.8 0 5 10 15 20 25 30 35 40 [A] Output voltage vs. load current at TP1, TP3 = +25°C cui.com 40 V 9.0 48 V 7.0 53 V 60 V 5.0 3.0 39 41 43 45 47 [A] Output voltage vs. load current at IO > max IO , TP1, TP3 = +25°C Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 11 of 30 Typical Characteristics 12.0 V, 39 A / 468 W Top trace: output voltage (5 V/div.). Bottom trace: input voltage (50 V/div.). Time scale: (10 ms/div.). Shut-down enabled by disconnecting VI at: TP1, TP3 = +25°C, VI = 53 V, IO =39 A resistive load. Top trace: output voltage (5 V/div.). Bottom trace: input voltage (50 V/div.). Time scale: (2 ms/div.). Output Load Transient Response DI SC ON TI Output Ripple & Noise ED Start-up enabled by connecting VI at: TP1, TP3 = +25°C, VI = 53 V, IO = 39 A resistive load. Shut-down NU Start-up Output voltage ripple at: TP1, TP3 = +25°C, VI = 53 V, IO = 39 A resistive load. Trace: output voltage (50 mV/div.). Time scale: (2 µs/div.). Output voltage response to load current step-change (9.75-29.25-9.75 A) at: TP1, TP3 =+25°C, VI = 53 V, CO = 3.9 mF. Input Voltage Transient Response Output voltage response to input voltage transient at: TP1, TP3 = +25°C, VI = 40-60 V, IO = 19,5 A resistive load, CO = 3.9 mF Top trace: output voltage (2 V/div.). Bottom trace: input voltage (20 V/div.). Time scale: (0.5 ms/div.). cui.com Top trace: output voltage (0.5 V/div.). Bottom trace: output current (20 A/div.). Time scale: (0.5 ms/div.). Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 12 of 30 Typical Characteristics 12.0 V, 39 A / 468 W Output Current Derating – Open frame 35 3.0 m/s 30 2.0 m/s 25 1.5 m/s 20 1.0 m/s 15 ED [A] 40 0.5 m/s 10 Na t. Con v. 5 0 20 40 60 80 100 [°C] Available load current vs. ambient air temperature and airflow at VI = 53 V. See Thermal Consideration section. Output Current Derating – Base plate NU 0 Thermal Resistance – Base plate [A] 40 [°C/W] 3.0 m/s 35 2.0 m/s 25 1.5 m/s 5 4 TI 30 6 20 3 1.0 m/s 15 2 0.5 m/s 10 5 1 Na t. Con v. DI SC ON 0 0 20 40 60 80 100 [°C] Available load current vs. ambient air temperature and airflow at VI = 53 V. See Thermal Consideration section. Output Current Derating – Base Plate + Heat sink [A] 40 3.0 m/s 35 0 0.0 25 20 Na t. Con v. 0 0 20 40 60 80 100 [°C] Available load current vs. ambient air temperature and airflow at VI = 53 V. See Thermal Consideration section. Tested with Plate Fin Transverse heatsink, height 0.23 In, P0114 Thermal Pad. cui.com 3.0[m/s] 35 1.0 m/s 5 2.5 40 1.5 m/s 0.5 m/s 2.0 A 25 10 1.5 Output Current Derating – Cold wall sealed box 2.0 m/s 15 1.0 Thermal resistance vs. airspeed measured at the converter. Tested in wind tunnel with airflow and test conditions as per the Thermal consideration section. VI = 53 V. 30 20 0.5 30 Ta mb 85 °C 15 10 5 0 0 20 40 60 80 100 [°C] Available load current vs. base plate temperature at 85ºC ambient. VI = 53 V. See Thermal Consideration section. Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 13 of 30 Electrical Specification 12.45 V, 35 A / 415 W TP1, TP3 = -40 to +90ºC, VI = 36 to 75 V. Typical values given at: TP1, TP3 = +25°C, VI = 53 V, max IOXQOHVVRWKHUZLVHVSHFL¿HGXQGHU&RQGLWLRQV Additional Cout P)&RQ¿JXUDWLRQ)LOH&'$ parameter conditions/description min input voltage range (VI) max units 75 V decreasing input voltage 32 33 34 V turn-on input voltage (VIon) increasing input voltage 34 35 36 ED turn-off input voltage (VIoff) internal input capacitance (CI) 18 output power (PO) 0 50% of max IO max IO 50% of max IO, VI = 48 V max IO, VI = 48 V power dissipation (Pd) max IO input idling power (Pli) IO = 0 A, VI = 53 V 415 19.5 V Nj) 96.2 95.5 96.4 95.5 NU HI¿FLHQF\ dž typ 36 W % % % % 29.5 3.2 W W input standby power (PRC) VI = 53 V (turned off with RC) switching frequency (fs) 0-100% of max IO output voltage setting and accuracy (VOi) TP1 = 25°C, VI = 53 V, IO = 0 A output voltage tolerance band (VO) 0-100% of max IO line regulation (VO) max IO load regulation (VO) VI = 53 V, 0-100% of max IO load transient voltage deviation (Vtr) VI = 53 V, load step 25-75-25% of max IO, di/dt = $NjV ±0.4 V load transient recovery time (ttr) VI = 53 V, load step 25-75-25% of max IO, di/dt = $NjV 150 µs ramp-up time (tr) - (from íRI9Oi) 10-100% of max IO, TP1, TP3 = 25ºC, VI = 53 V 23 ms start-up time (ts) - (from VI connection to 90% of VOi) 10-100% of max IO, TP1, TP3 = 25ºC, VI = 53 V 39 ms VI shut-down fall time (tf) (from VI off to 10% of VO) max IO IO = 0 A, CO = 0 mF 3.6 7 ms s RC start-up time (tRC) max IO 27 ms RC shut-down fall time (tRC) (from RC off to 10% of VO) max IO IO = 0 A, CO = 0 mF 5.1 7 ms s 12.415 0.4 W 140 kHz 12.45 12.485 V 12.7 V 20 55 mV 600 700 mV TI 11.5 SC ON 500 output current (IO) current limit threshold (Ilim) VO = 10.8 V, TP1, TP3 < max TP1, TP3 short circuit current (Isc) TP1, TP3 = 25ºC, see Note 1 recommended capacitive load (Cout) TP1, TP3 = 25ºC, see Note 2 output ripple & noise (VOac) 0 37 41 35 A 44 A 12 6 mF See ripple & noise section, max IO , see Note 3 60 150 mVp-p over voltage protection (OVP) TP1, TP3 = 25°C, VI = 53 V, 10-100% of max IO 15.6 remote control (RC) sink current (note 4), see operating information trigger level, decreasing RC-voltage trigger level, increasing RC-voltage DI 3.5 Note 1: 2: 3: 4: 0.1 A 2.6 2.9 OCP in hic-up mode Low ESR-value Cout = 100 µF, external capacitance Sink current drawn by external device connected to the RC pin. Minimum sink current required guaranteeing activated RC function. cui.com V 0.7 mA V V Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 14 of 30 Typical Characteristics 12.45 V, 63 A / 747 W, two products in parallel Efficiency Power Dissipation 100 ED [W] 45 [%] 40 35 95 53 V 20 53 V 15 75 V 75 V 10 NU 80 48 V 25 48 V 85 36 V 30 36 V 90 5 75 0 0 10 20 30 40 50 60 0 [A] 10 20 30 40 50 60 [A] Dissipated power vs. load current and input voltage at TP1, TP3 = +25°C Efficiency vs. load current and input voltage at TP1, TP3 = +25 C Output Characteristics Current Limit Characteristics [V] [V] 13.0 TI 12.5 12.4 11.0 12.3 12.2 48 V SC ON 75 V 12.0 48 V 53 V 7.0 53 V 12.1 36 V 9.0 36 V 75 V 5.0 11.9 3.0 11.8 0 10 20 30 40 50 60 Start-up DI 65 67 69 71 73 75 77 79 81 83 [A] [A ] Output voltage vs. load current at TP1, TP3 = +25°C Start-up enabled by connecting VI at: TP1, TP3 = +25°C, VI = 53 V, IO = 63 A resistive load. 63 Output voltage vs. load current at IO > max IO , TP1, TP3 = +25°C Output Load Transient Response Output voltage response to load current Top trace: output voltage (0.5 V/div.). step-change (15.8-47.3-15.8 A) at: Bottom trace: output current (20 A/div.). TP1, TP3 =+25°C, VI = 53 V, CO = 3.5 mF. Time scale: (0.5 ms/div.). Top trace: output voltage (5 V/div.). Bottom trace: input voltage (50 V/div.). Time scale: (10 ms/div.). cui.com Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 15 of 30 Typical Characteristics 12.45 V, 35 A / 415 W [A] 35 ED Output Current Derating – Open frame 3.0 m/s 30 2.0 m/s 25 15 1.0 m/s 10 0.5 m/s 5 Na t. Co nv. 0 0 20 40 60 80 100 [°C] Available load current vs. ambient air temperature and airflow at VI = 53 V. See Thermal Consideration section. Output Current Derating – Base plate NU 1.5 m/s 20 Thermal Resistance – Base plate [°C/W] TI [A] 35 6 3.0 m/s 30 5 2.0 m/s 25 4 1.5 m/s 3 DI SC ON 20 15 1.0 m/s 10 0.5 m/s 5 2 1 Na t. Con v. 0 0 0 20 40 60 80 100 [°C] 0.0 Available load current vs. ambient air temperature and airflow at VI = 53 V. See Thermal Consideration section. Output Current Derating – Base plate + Heat sink 25 20 15 10 20 40 60 80 2.0 2.5 3.0 [m/s] A 40 35 2.0 m/s 30 1.5 m/s 25 1.0 m/s 20 15 0.5 m/s 10 0 0 1.5 Thermal resistance vs. airspeed measured at the converter. Tested in wind tunnel with airflow and test conditions as per the Thermal consideration section. VI = 53 V. 3.0 m/s Na t. Con v. 5 1.0 Output Current Derating – Cold wall sealed box [A] 35 30 0.5 Ta mb 85 °C 5 0 100 [°C] 0 20 40 60 80 100 [°C] Available load current vs. base plate temperature at 85ºC ambient. VI = 53 V. See Thermal Consideration section. Available load current vs. ambient air temperature and airflow at VI = 53 V. See Thermal Consideration section. Tested with Plate Fin Transverse heatsink, height 0.23 In, P0114 Thermal Pad. cui.com Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 16 of 30 Electrical Specification 12.45 V, 39 A / 462 W TP1, TP3 = -40 to +90ºC, VI = 40 to 60 V. Typical values given at: TP1, TP3 = +25°C, VI = 53 V, max IOXQOHVVRWKHUZLVHVSHFL¿HGXQGHU&RQGLWLRQV Additional Cout P)&RQ¿JXUDWLRQ)LOH&'$ parameter conditions/description min input voltage range (VI) decreasing input voltage turn-on input voltage (VIon) increasing input voltage 36 37 max units 60 V 38 38 internal input capacitance (CI) 39 40 18 output power (PO) 0 power dissipation (Pd) max IO IO = 0 A, VI = 53 V 21.0 V Nj) 462 96.7 95.7 96.8 95.6 50% of max IO max IO 50% of max IO, VI = 48 V max IO, VI = 48 V input idling power (Pli) V UE D turn-off input voltage (VIoff) HI¿FLHQF\ dž typ 40 W % % % % 30.5 2.8 W W VI = 53 V (turned off with RC) 0-100% of max IO output voltage setting and accuracy (VOi) TP1 = 25°C, VI = 53 V, IO = 0 A output voltage tolerance band (VO) 0-100% of max IO line regulation (VO) max IO load regulation (VO) VI = 53 V, 0-100% of max IO load transient voltage deviation (Vtr) VI = 53 V, load step 25-75-25% of max IO, di/dt = $NjV ±0.4 V load transient recovery time (ttr) VI = 53 V, load step 25-75-25% of max IO, di/dt = $NjV 150 µs ramp-up time (tr) - (from íRI9Oi) 10-100% of max IO, TP1 = 25ºC, VI = 53 V 23 ms start-up time (ts) - (from VI connection to 90% of VOi) 10-100% of max IO, TP1 = 25ºC, VI = 53 V 39 ms VI shut-down fall time (tf) (from VI off to 10% of VO) max IO IO = 0 A, CO = 0 mF 3 7 ms s RC start-up time (tRC) max IO 27 ms RC shut-down fall time (tRC) (from RC off to 10% of VO) max IO IO = 0 A, CO = 0 mF 4.5 7 ms s IN input standby power (PRC) switching frequency (fs) 12.415 SC ON T current limit threshold (Ilim) VO = 10.8 V, TP1, TP3 < max TP1, TP3 short circuit current (Isc) TP1 = 25ºC, see Note 1 TP1 = 25ºC, see Note 2 output ripple & noise (VOac) W kHz 12.45 12.485 V 12.7 V 31 60 mV 600 700 mV 11.5 output current (IO) recommended capacitive load (Cout) 0.4 140 500 0 41 44 39 A 47 A 14 6 mF See ripple & noise section, max IO , see Note 3 50 110 mVp-p over voltage protection (OVP) TP1, TP3 = 25°C, VI = 53 V, 10-100% of max IO 15.6 remote control (RC) sink current (note 4), see operating information trigger level, decreasing RC-voltage trigger level, increasing RC-voltage 0.7 mA V V DI 3.9 Note 1: 2: 3: 4: 0.1 A 2.6 2.9 OCP in hic-up mode Low ESR-value Cout = 100 µF, external capacitance Sink current drawn by external device connected to the RC pin. Minimum sink current required guaranteeing activated RC function. cui.com V Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 17 of 30 Typical Characteristics 12.45 V, 70 A / 830 W, two products in parallel Efficiency Power Dissipation [%] ED [W] 45 100 40 35 95 53 V 20 53 V 60 V 15 60 V 80 48 V 25 48 V 85 40 V 30 40 V 90 10 NU 5 75 0 0 10 20 30 40 50 60 0 70 [A] 10 20 30 40 50 60 70 [A] Dissipated power vs. load current and input voltage at TP1, TP3 = +25°C Efficiency vs. load current and input voltage at TP1, TP3 = +25 C Output Characteristics Current Limit Characteristics [V] 13.0 [V] TI 12.5 12.4 11.0 12.3 40 V 12.2 48 V 60 V SC ON 12.0 11.9 11.8 0 10 20 30 40 50 60 70 [A] Output voltage vs. load current at TP1, TP3 = +25°C DI Start-up Start-up enabled by connecting VI at: TP1, TP3 = +25°C, VI = 53 V, IO = 70 A resistive load. 48 V 53 V 7.0 53 V 12.1 40 V 9.0 60 V 5.0 3.0 70 75 80 85 90 [A] Output voltage vs. load current at IO > max IO , TP1, TP3 = +25°C Output Load Transient Response Top trace: output voltage (5 V/div.). Bottom trace: input voltage (50 V/div.). Time scale: (10 ms/div.). Output voltage response to load current Top trace: output voltage (0.5 V/div.). step-change (17.5-52.5-17.5 A) at: Bottom trace: output current (20 A/div.). TP1, TP3 =+25°C, VI = 53 V, CO = 3.9 mF Time scale: (0.5 ms/div.). cui.com Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 18 of 30 Typical Characteristics 12.45 V, 39 A / 462 W Output Current Derating – Open frame 35 3.0 m/s 30 2.0 m/s 25 1.5 m/s 20 1.0 m/s 15 ED [A] 40 0.5 m/s 10 Na t. Con v. 5 0 20 40 60 80 100 [°C] Available load current vs. ambient air temperature and airflow at VI = 53 V. See Thermal Consideration section. Output Current Derating – Base plate NU 0 Thermal Resistance – Base plate [A] 40 [°C/W] 3.0 m/s 35 2.0 m/s 25 1.5 m/s 5 4 TI 30 6 20 3 1.0 m/s 15 2 0.5 m/s 10 5 1 Na t. Con v. 0 SC ON 0 0 20 40 60 80 100 [°C] Available load current vs. ambient air temperature and airflow at VI = 53 V. See Thermal Consideration section. Output Current Derating – Base Plate + Heat sink [A] 40 3.0 m/s 35 0.0 1.0 m/s 20 DI Na t. Con v. 0 0 20 40 60 3.0[m/s] 35 25 5 2.5 A 1.5 m/s 0.5 m/s 2.0 40 25 10 1.5 Output Current Derating – Cold wall sealed box 2.0 m/s 15 1.0 Thermal resistance vs. airspeed measured at the converter. Tested in wind tunnel with airflow and test conditions as per the Thermal consideration section. VI = 53 V. 30 20 0.5 30 Ta mb 85 °C 15 10 5 0 80 100 [°C] 0 20 40 60 80 100 [°C] Available load current vs. base plate temperature at 85ºC ambient. VI = 53 V. See Thermal Consideration section. Available load current vs. ambient air temperature and airflow at VI = 53 V. See Thermal Consideration section. Tested with Plate Fin Transverse heatsink, height 0.23 In, P0114 Thermal Pad. cui.com Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 19 of 30 EMC Specification Conducted EMI measured according to EN55022, CISPR 22 and FCC part 15J (see test set-up). The fundamental switching frequency is 140 kHz for NQB at VI = 53 V, max IO. Test set-up ED Conducted EMI Input terminal value (typ) NU Layout recommendations The radiated EMI performance of the product will depend on the PWB layout and ground layer design. It is also important to consider the stand-off of the product. If a ground layer is used, it should be connected to the output of the product and the equipment ground or chassis. A ground layer will increase the stray capacitance in the PWB and improve the high frequency EMC performance. Output ripple and noise 2XWSXWULSSOHDQGQRLVHPHDVXUHGDFFRUGLQJWR¿JXUH below. TI EMI without filter SC ON 2SWLRQDOH[WHUQDO¿OWHUIRUFODVV% 6XJJHVWHGH[WHUQDOLQSXW¿OWHULQRUGHUWRPHHWFODVV%LQ EN 55022, CISPR 22 and FCC part 15J. 0 C4 L1 C1 L2 C2 + C3 + Module - - R Filter components: C1 = 1 μF C2 = 1 μF+220 μF C3 = 1 μF+220 μF C4,C5 = 2.2 nF L1 = 810 μH L2 = 810 μH C5 0 Output ripple and noise test setup DI Operating information EMI with filter Power Management Overview This product includes protection features that continuously safeguard the load from damage due to unexpected system faults. Input Voltage The NQB consists of two different product families designed for two different input voltage ranges, 36 to 75 Vdc and 40 to 60 Vdc, see ordering information. The input voltage range 36 to 75 Vdc meets the requirements of the European Telecom Standard ETS 300 132-2 for normal input voltage range in –48 and cui.com Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS The input voltage range 40 to 60 Vdc meets the requirements for normal input voltage range in -48 V systems, -40.5 to -57.0 V. At input voltages exceeding 60 V, the power loss will be higher than at normal input voltage and TP1 must be limited to absolute max +125°C. The absolute maximum continuous input voltage is 65 Vdc. Parallel Operation (Droop Load Share, DLS) The NQB, DLS products are variants that can be connected LQSDUDOOHO7KHSURGXFWVKDYHDSUHFRQ¿JXUHGYROWDJH droop: The stated output voltage set point is at no load. The output voltage will decrease when the load current is increased. The voltage will droop 0.6 V while load reaches max load. This feature allows the products to be connected in parallel and share the current with 10% accuracy. Up to 90% of max output current can be used from each product. NU Turn-off Input Voltage The product monitors the input voltage and will turn on and turn off at predetermined levels. The minimum hysteresis between turn on and turn off input voltage is 2 V. capacitors are used to handle low frequency dynamic load changes. Ceramic capacitors will also reduce any high frequency noise at the load. It is equally important to use low resistance and low inductance PWB layouts and cabling. External decoupling capacitors will become part of the product’s control loop. The control loop is optimized for a wide range of external capacitance and the maximum recommended value that could be used without any DGGLWLRQDODQDO\VLVLVIRXQGLQWKHHOHFWULFDOVSHFL¿FDWLRQ The ESR of the capacitors is a very important parameter. 6WDEOHRSHUDWLRQLVJXDUDQWHHGZLWKDYHUL¿HG(65YDOXH RI!PŸDFURVVWKHRXWSXWFRQQHFWLRQV)RUIXUWKHU information please contact your local CUI Power Modules representative. ED –60 Vdc systems, -40.5 to -57.0 V and –50.0 to -72 V respectively. At input voltages exceeding 75 V, the power loss will be higher than at normal input voltage and TP1 must be limited to absolute max +125°C. The absolute maximum continuous input voltage is 80 Vdc. date 11/07/2014 Ϳ page 20 of 30 Voltage regulation DLS products 12.8 DI Input and Output Impedance The impedance of both the input source and the load will interact with the impedance of the product. It is important that the input source has low characteristic impedance. Minimum recommended external input capacitance is 100 µF. The performance in some applications can be enhanced by addition of external capacitance as described under External Decoupling Capacitors. External Decoupling Capacitors :KHQSRZHULQJORDGVZLWKVLJQL¿FDQWG\QDPLFFXUUHQW requirements, the voltage regulation at the point of load can be improved by addition of decoupling capacitors at the load. The most effective technique is to locate low ESR ceramic and electrolytic capacitors as close to the load as possible, using several parallel capacitors to lower the effective ESR. The ceramic capacitors will handle highfrequency dynamic load changes while the electrolytic Output Voltage [V] SC ON TI Remote Control (RC) 7KHSURGXFWVDUH¿WWHGZLWKDUHPRWHFRQWUROIXQFWLRQ The remote control is referenced to the primary negative input connection (-In). The RC function allows the converter to be turned on/off by an external device like a semiconductor or mechanical switch. The RC pin has an internal pull up resistor. The device should be capable of sinking 0.7 mA. When the RC pin is left open, the voltage generated on the RC pin is max 6 V. The product is provided with “negative logic” remote control and will be off until the RC pin is connected to the -In. To turn on the product the voltage between RC pin and -In should be less than 1 V. To turn off the product the RC pin should be left open for a minimum of time 150 µs, the same time requirement applies when the product shall turn on. In situations where it is desired to have the product to power up automatically without the need for control signals or a switch, the RC pin can be wired directly to –In Module 1 12.6 Module 2 Module 1+2 12.4 12.2 12.0 11.8 11.6 0 10 20 30 40 50 60 70 Output Current [A] Feed Forward Capability The NQB products have a feed forward function implemented that can handle sudden input voltage changes. The output voltage will be regulated during an input transient and will typically stay within 10% when an input transient is applied. Soft-start Power Up The rise time of the ramp up is 10 ms. When starting by applying input voltage the control circuit boot-up time adds an additional 15 ms delay. The DLS variants have a SUHFRQ¿JXUHGUDPSXSWLPHRI 25 ms. Temperature Protection (OTP, UTP) The products are protected from thermal overload by an internal temperature shutdown protection. When TP1 as GH¿QHGLQWKHUPDOFRQVLGHUDWLRQVHFWLRQLVH[FHHGHGWKH product will shut down. The product will make continuous attempts to start up and resume normal operation cui.com Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS Over Current Protection (OCP) The product includes current limiting circuitry for protection at continuous overload. The setting for the product is hic-up mode if the maximum output current is exceeded and the output voltage is below 0.3×Vout. Above the trip voltage the product will continue operate while maintaining the output current at the maximum output current. The load distribution should be designed for the PD[LPXPRXWSXWVKRUWFLUFXLWFXUUHQWVSHFL¿HG Droop Load Share variants (DLS) will enter hic-up mode, with a trip voltage, 0.04×Vout. Above the trip voltage the product will continue to operate while maintaining the output current at the maximum output current The product is tested on a 254 x 254 mm, 35 µm (1 oz), 16-layer test board mounted vertically in a wind tunnel with a cross-section of 608 x 203 mm. TI Input Over/Under voltage protection The input of the product is protected from high input voltage and low input voltage. General The product is designed to operate in different thermal HQYLURQPHQWVDQGVXI¿FLHQWFRROLQJPXVWEHSURYLGHG to ensure reliable operation. For products mounted on a PWB without a heat sink attached, cooling is achieved mainly by conduction, from the pins to the host board, DQGFRQYHFWLRQZKLFKLVGHSHQGDQWRQWKHDLUÀRZDFURVV WKHSURGXFW,QFUHDVHGDLUÀRZHQKDQFHVWKHFRROLQJRI the product. The Output Current Derating graph found in the output section for each model provides the available output current vs. ambient air temperature and air velocity at VI =53 V. ED Over Voltage Protection (OVP) The product includes over voltage limiting circuitry for protection of the load. The OVP limit is 30% above the nominal output voltage. The response from an over voltage fault is to immediately shut down. The device will continuously check for the presence of the fault condition, and when the fault condition no longer exists the device will be re-enabled. Thermal Consideration NU automatically when the temperature has dropped below WKHWHPSHUDWXUHWKUHVKROGWKHK\VWHUHVLVLVGH¿QHGLQ JHQHUDOHOHFWULFDOVSHFL¿FDWLRQ7KHSURGXFWKDVDOVRDQ under temperature protection. date 11/07/2014 Ϳ page 21 of 30 SC ON Pre-bias Start-up Capability The product has a Pre-bias start up functionality and will not sink current during start up if a Pre-bias source is present at the output terminals. If the Pre-bias voltage is lower than the target value, the product will ramp up to the target value. If the Pre-bias voltage is higher than the target value, the product will ramp down to the target value and in this case sink current for a limited time. 13.4 13.2 13.2 13.0 13.0 12.8 12.8 Vout [V] 13.4 12.6 DI Vout [V] Output Voltage Regulation The NQB products are designed to be fully regulated within the plotted area. Operating outside this area is not recommended. 12.4 12.2 12.0 35 45 55 65 75 Vin [V] Vin range: 36-75Vdc For products with base plate used in a sealed box/cold wall application, cooling is achieved mainly by conduction through the cold wall. The Output Current Derating graphs are found in the output section for each model. The product is tested in a sealed box test set up with ambient temperatures 85, 55 and 25°C. 12.6 12.4 12.2 12.0 35 40 45 50 55 60 65 Vin [V] Vin range:40-60Vdc cui.com Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS &DOFXODWHWKHWHPSHUDWXUHLQFUHDVH Ʃ7  Ʃ7 5th x Pd 3. Max allowed ambient temperature is: Max TP1Ʃ7 E.g. NQB-468 at 2m/s: Position Description P1 PWB (reference point, open TP1=125º C frame) 1. ((1/0.95) - 1) × 468 W = 24.6 W P2 Opto-coupler TP2=105º C 2. 19.5 W × 2.8°C/W = 69.0°C} P3 PWB (reference point for base-plate version) TP3=125º C P4 Primary MOSFET TP4=125º C 3. 125 °C - 69.0°C = max ambient temperature is 56°C The actual temperature will be dependent on several factors such as the PWB size, number of layers and GLUHFWLRQRIDLUÀRZ NU Max temperature Resistance graph found in the Output section for each model. Note that the thermal resistance can be VLJQL¿FDQWO\UHGXFHGLIDKHDWVLQNLVPRXQWHGRQWKHWRS of the base plate. ED 'H¿QLWLRQRISURGXFWRSHUDWLQJWHPSHUDWXUH The product operating temperature is used to monitor the temperature of the product, and proper thermal conditions FDQEHYHUL¿HGE\PHDVXULQJWKHWHPSHUDWXUHDWSRVLWLRQV P1, P2, P3 and P4. The temperature at these positions (TP1, TP2, TP3, TP4) should not exceed the maximum temperatures in the table below. The number of measurement points may vary with different thermal design and topology. Temperatures above maximum TP1, measured at the reference point P1 (TP3 / P3 for base plate versions) are not allowed and may cause permanent damage. date 11/07/2014 Ϳ page 22 of 30 SC ON TI Connections (Top view) Top view Pin Designation Function 1 +In Positive Input 2 RC Remote Control 3 Case Case to GND (optional) 4 -In Negative Input 5 -Out Negative Output 16 +Out Positive Output DI Bottom view %HVWDLUÀRZGLUHFWLRQLVIURPSRVLWLYHWRQHJDWLYHSLQV Ambient Temperature Calculation For products with base plate the maximum allowed ambient temperature can be calculated by using the thermal resistance. 1. The power loss is calculated by using the formula dž  îRXWSXWSRZHU SRZHUORVVHV 3d). dž HI¿FLHQF\RISURGXFW(J  2. Find the thermal resistance (Rth) in the Thermal cui.com Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 23 of 30 UE D Mechanical Information - Hole Mount, Open Frame Version Top View Pin Positions According To Recommended Footprint DI SC ON T IN Table 1. X1 = Ordering information PIN SPECIFICATIONS Pin 1, 2, 4, 5 & 16 Material: Copper alloy Plating: Min Au 0.1 µm over 1-3 µm Ni. Pin position 3 is only used for base plate GND connection which is not available on this module. Recommended Footprint - Top View Recommended keep away area for user components. The stand-off in combination with insulating material ensures that requirements as per IEC/EN/UL60950 are met and 2250 V isolation maintained even if open vias or traces are present under the DC/DC converter. cui.com Weight: Typical 48 g All dimensions: mm [inch] Tolerances: x.x ±0.50 [0.02] x.xx ±0.25 [0.01] (not applied on footprint or typical values) Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 24 of 30 UE D Mechanical Information - Hole Mount, Base Plate Version IN Top View Pin Positions According To Recommended Footprint DI SC ON T Table 1. X1 = Ordering information Recommended Footprint - Top View Recommended keep away area for user components. The stand-off in combination with insulating material ensures that requirements as per IEC/EN/UL60950 are met and 2250 V isolation maintained even if open vias or traces are present under the DC/DC converter. cui.com CASE Material: Aluminum For screw attachment apply mounting torque of max 0.44 Nm [3.9 lbf in]. M3 screws must not protrude more than 2.7mm [0.106] into the base plate. PIN SPECIFICATIONS Pin 1, 2, 3, 4, 5 & 16 Material: Copper alloy Plating: Min Au 0.1 µm over 1-3 µm Ni. Pin position 3 is only used for base plate GND connection. Weight: Typical 68 g All dimensions: mm [inch] Tolerances: x.x ±0.50 [0.02] x.xx ±0.25 [0.01] (not applied on footprint or typical values) Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 25 of 30 ED Mechanical Information - Surface Mount Version SC ON TI NU Top View Pin Positions According To Recommended Footprint Recommended Footprint - Top View DI PIN SPECIFICATIONS Pin 1, 2, 4, 5 & 16 Material: Copper alloy Plating: Min Au 0.1 µm over 1-3 µm Ni. Weight: Typical 46 g All dimensions: mm [inch] Tolerances: x.x ±0.50 [0.02] x.xx ±0.25 [0.01] (not applied on footprint or typical values) Recommended keep away area for user components. The stand-off in combination with insulating material ensures that requirements as per IEC/EN/UL60950 are met and 2250 V isolation maintained even if open vias or traces are present under the DC/DC converter. cui.com Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 26 of 30 Soldering Information - Surface Mounting Lead-free (Pb-free) solder processes The surface mount product is intended for forced FRQYHFWLRQRUYDSRUSKDVHUHÀRZVROGHULQJLQ6Q3EDQG Pb-free processes. For Pb-free solder processes, a pin temperature (TPIN) in excess of the solder melting temperature (TL, 217 to 221°C for SnAgCu solder alloys) for more than 60 seconds and a peak temperature of 245°C on all solder joints is recommended to ensure a reliable solder joint. 7KHUHÀRZSUR¿OHVKRXOGEHRSWLPLVHGWRDYRLGH[FHVVLYH heating of the product. It is recommended to have DVXI¿FLHQWO\H[WHQGHGSUHKHDWWLPHWRHQVXUHDQ even temperature across the host PWB and it is also UHFRPPHQGHGWRPLQLPL]HWKHWLPHLQUHÀRZ Maximum Product Temperature Requirements ED Top of the product PWB near pin 2 is chosen as reference location for the maximum (peak) allowed product temperature (TPRODUCT) since this will likely be the warmest SDUWRIWKHSURGXFWGXULQJWKHUHÀRZSURFHVV $QRFOHDQÀX[LVUHFRPPHQGHGWRDYRLGHQWUDSPHQWRI FOHDQLQJÀXLGVLQFDYLWLHVLQVLGHWKHSURGXFWRUEHWZHHQ the product and the host board, since cleaning residues may affect long time reliability and isolation voltage. SnPb solder processes )RU6Q3EVROGHUSURFHVVHVWKHSURGXFWLVTXDOL¿HGIRU06/ 1 according to IPC/JEDEC standard J STD 020C. 'XULQJUHÀRZ7PRODUCT must not exceed 225 °C at any time. Average ramp-up (T PRODUCT ) Typical solder melting (liquidus) temperature TL Minimum reflow time above T L 3°C/s max 3°C/s max 183°C 221°C 60 s 60 s T PIN 210°C 235°C Peak product temperature T PRODUCT 225°C 260°C Average ramp-down (T PRODUCT ) 6°C/s max 6°C/s max Maximum time 25°C to peak 6 minutes 8 minutes Pb-free solder processes )RU3EIUHHVROGHUSURFHVVHVWKHSURGXFWLVTXDOL¿HGIRU MSL 3 according to IPC/JEDEC standard J-STD-020C. 'XULQJUHÀRZ7PRODUCT must not exceed 260 °C at any time. Dry Pack Information TI Minimum pin temperature NU General reflow process specifications SnPb eutectic Pb-free Temperature TPRODUCT maximum TPIN minimum 3URGXFWVLQWHQGHGIRU3EIUHHUHÀRZVROGHULQJSURFHVVHV are delivered in standard moisture barrier bags according to IPC/JEDEC standard J STD 033 (Handling, packing, VKLSSLQJDQGXVHRIPRLVWXUHUHÀRZVHQVLWLYLW\VXUIDFH mount devices). Pin profile SC ON TL Time in preheat / soak zone Time 25°C to peak Time in reflow Product profile Using products in high temperature Pb-free soldering processes requires dry pack storage and handling. In case the products have been stored in an uncontrolled environment and no longer can be considered dry, the modules must be baked according to J STD 033. Time Thermocoupler Attachment Minimum Pin Temperature Recommendations Pin number 5 chosen as reference location for the minimum pin temperature recommendation since this will OLNHO\EHWKHFRROHVWVROGHUMRLQWGXULQJWKHUHÀRZSURFHVV Top of PWB near pin 2 for measurement of maximum product temperature, TPRODUCT SnPb solder processes DI For SnPb solder processes, a pin temperature (TPIN) in excess of the solder melting temperature, (TL, 183°C for Sn63Pb37) for more than 60 seconds and a peak temperature of 220°C is recommended to ensure a reliable solder joint. For dry packed products only: depending on the type of VROGHUSDVWHDQGÀX[V\VWHPXVHGRQWKHKRVWERDUGXSWR a recommended maximum temperature of 245°C could be used, if the products are kept in a controlled environment (dry pack handling and storage) prior to assembly. Pin 5 for measurement of minimum pin (solder joint ) temperature, TPIN cui.com Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 27 of 30 Soldering Information - Hole Mounting The hole mounted product is intended for plated through hole mounting by wave or manual soldering. The pin WHPSHUDWXUHLVVSHFL¿HGWRPD[LPXPWRƒ&IRU maximum 10 seconds. ED A maximum preheat rate of 4°C/s and maximum preheat temperature of 150°C is suggested. When soldering by hand, care should be taken to avoid direct contact between the hot soldering iron tip and the pins for more than a few seconds in order to prevent overheating. Delivery Package Information The products are delivered in antistatic injection molded trays (Jedec design guide 4.10D standard) and in antistatic trays. Tray Specifications – SMD Antistatic PPE Surface resistance Tray thickness 105 < Ohm/square < 1012 The trays can be baked at maximum 125°C for 48 hours 14.50 mm 0.571 [ inch] Box capacity 20 products (2 full trays/box) Tray weight 125 g empty, 574 g full tray DI SC ON Bakability TI Material NU $QRFOHDQÀX[LVUHFRPPHQGHGWRDYRLGHQWUDSPHQWRI FOHDQLQJÀXLGVLQFDYLWLHVLQVLGHWKHSURGXFWRUEHWZHHQ the product and the host board. The cleaning residues may affect long time reliability and isolation voltage. JEDEC standard tray for 2x5 = 10 products. All dimensions in mm [inch] Tolerances: X.x ±0.26 [0.01], X.xx ±0.13 [0.005] Note: pick up positions refer to center of pocket. See mechanical drawing for exact location on product. cui.com Additional Resources: Product Page DI SC ON TI NU Tray Specifications - TH Material PE Foam Surface 105 < Ohm/square < 1012 resistance Bakability The trays are not bakeable Tray capacity 20 converters/tray Box capacity 20 products (1 full tray/box) Product – Open frame 1100 g full tray, 140g empty tray Weight Product – Base plate option 1480 g full tray, 140 g empty tray date 11/07/2014 Ϳ page 28 of 30 ED CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS cui.com Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 29 of 30 Product Qualification Specification Characteristics IPC-A-610 Change of temperature (Temperature cycling) IEC 60068-2-14 Na Temperature range Number of cycles Dwell/transfer time -40 to 100°C 500 15 min/0-1 min Cold (in operation) IEC 60068-2-1 Ad Temperature T A Duration -45°C 72 h Damp heat IEC 60068-2-67 Cy Temperature Humidity Duration Dry heat IEC 60068-2-2 Bd Temperature Duration Electrostatic discharge susceptibility IEC 61340-3-1, JESD 22-A114 IEC 61340-3-2, JESD 22-A115 Human body model (HBM) Machine Model (MM) Class 2, 2000 V Class 3, 200 V Immersion in cleaning solvents IEC 60068-2-45 XA, method 2 Water Glycol ether Isopropyl alcohol 55°C 35°C 35°C Mechanical shock IEC 60068-2-27 Ea Peak acceleration Duration 100 g 6 ms Moisture reflow sensitivity 1 J-STD-020C Level 1 (SnPb-eutectic) Level 3 (Pb Free) 225°C 260°C Duration 1000 h IEC 60068-2-20 Tb, method 1A Solder temperature Duration 270°C 10-13 s IEC 60068-2-21 Test Ua1 IEC 60068-2-21 Test Ue1 Through hole mount products Surface mount products All leads All leads Preconditioning Temperature, SnPb Eutectic Temperature, Pb-free 150°C dry bake 16 h 215°C 235°C Preconditioning Temperature, SnPb Eutectic Temperature, Pb-free Steam ageing 235°C 245°C Frequency Spectral density Duration 10 to 500 Hz 0.07 g2/Hz 10 min in each direction Resistance to soldering heat SC ON Robustness of terminations IEC 60068-2-58 test Td 1 Solderability IEC 60068-2-20 test Ta 2 Vibration, broad band random IEC 60068-2-64 Fh, method 1 2QO\IRUSURGXFWVLQWHQGHGIRUUHÀRZVROGHULQJ VXUIDFHPRXQWSURGXFWV 2. Only for products intended for wave soldering (plated through hole products) DI 1RWHV 85°C 85 % RH 1000 hours 125°C 1000 h NU MIL-STD-202G, method 108A 2 TI Operational life test ED External visual inspection cui.com Additional Resources: Product Page CUI Inc Ϳ SERIES: NQB-N Ϳ DESCRIPTION: FULLY REGULATED ADVANCED BUS CONVERTERS date 11/07/2014 Ϳ page 30 of 30 REVISION HISTORY rev. date 1.01 11/07/2014 DI SC ON TI NU ED The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com Novum and Architects of Modern Power are trademarks of CUI. All other trademarks are the property of their respective owners. CUI offers a two (2) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
NQB-420NWA-AN 价格&库存
很抱歉,暂时无法提供与“NQB-420NWA-AN”相匹配的价格&库存,您可以联系我们找货
