SD103AWS
SD103AWS
    HOTTECH(合科泰)
    SOD-323
    肖特基二极管 VR=40V IF=350mA 50pF P=200mW SOD-323
SD103AWS 数据手册
SD103AWS-SD103CWS SCHOTTKY BARRIER DIODE FEATURES  Low Forward Voltage  Fast Switching  Low Capacitance  PN Junction Guard Ring for Transient and ESD Protection MECHANICAL DATA  Case: SOD-323  Case Material: Molded Plastic. UL flammability  Classification Rating: 94V-0  Weight: 0.005 grams (approximate) SOD-323 MARKING: SD103AWS:S4 SD103BWS:S5 SD103CWS:S6 MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Parameter Symbol Peak Repetitive Peak Reverse Voltage VRRM Working Peak Reverse Voltage VRWM DC Blocking Voltage VR RMS Reverse Voltage VR(RMS) SD103AWS SD103BWS SD103CWS Unit 40 30 20 V 28 21 14 V Forward Continuous Current IFM 350 mA Non-repetitive Peak Forward Surge Current @t=8.3ms IFSM 2.0 A Power Dissipation Pd 200 mW Thermal Resistance Junction to Ambient Junction Temperature RθJA 500 125 ℃/W Storage Temperature TSTG Tj ℃ ℃ -55~+150 ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified) Parameter Symbol Min Typ Max Unit Conditions Reverse breakdown voltage SD103AWS SD103BWS SD103CWS V(BR) 40 V 30 20 IR=100μA IR=100μA 0.37 VF Forward voltage IR=100μA 0.60 V IF=20mA IF=200mA Reverse current SD103AWS SD103BWS SD103CWS Capacitance between terminals Reverse recovery time ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD IRM 5.0 μA VR=30V VR=20V VR=10V CT trr 50 10 pF ns E-mail:hkt@heketai.com VR=0V,f=1.0MHz IF=IR=200mA Irr=0.1XIR ,RL=100Ω 1/ 4 SD103AWS-SD103CWS SCHOTTKY BARRIER DIODE Forward Characteristics Reverse Characteristics 1000 350 REVERSE CURRENT IR F (mA) (uA) 100 I T =100℃ FORWARD CURRENT a 10 Ta=25℃ 1 100 T =100℃ a 10 1 T =25℃ a 0.1 0 100 200 300 400 500 0.1 600 0 10 Capacitance Characteristics 50 20 30 REVERSE VOLTAGE FORWARD VOLTAGE V (mV) F VR 40 (V) Power Derating Curve 250 Ta=25℃ (mW) 200 P D 40 POWER DISSIPATION CAPACITANCE BETWEEN TERMINALS CT (pF) f=1MHz 30 20 150 100 50 10 0 5 10 15 REVERSE VOLTAGE 20 VR 25 (V) ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD 30 0 0 25 50 75 100 125 AMBIENT TEMPERATURE T (℃) a E-mail:hkt@heketai.com 2/ 4 SD103AWS-SD103CWS SCHOTTKY BARRIER DIODE SOD-323 Package Outline Dimensions Symbol Dimensions In Millimeters Min. Dimensions In Inches Max. A Min. Max. 1.000 0.039 A1 0.000 0.100 0.000 0.004 A2 0.800 0.900 0.031 0.035 b 0.250 0.350 0.010 0.014 c 0.080 0.150 0.003 0.006 D 1.200 1.400 0.047 0.055 E 1.600 1.800 0.063 0.071 E1 2.250 2.750 0.100 0.108 L 0.475 RE F 0.019 REF L1 0.250 0.400 0.010 0.016 θ 0° 8° 0° 8° SOD-323 Suggested Pad Layout Note: 1.Controlling dimension: in millimeters 2.General tolerance: ±0.05mm 3.The pad layout is for reference purposes only ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 3/ 4 SD103AWS-SD103CWS SCHOTTKY BARRIER DIODE SOD-323 Tape and Reel SOD-323 Embossed Carrier Tape DIMENSIONS ARE IN MILLIMETER TYPE A B C d E F P0 P P1 W SOD-323 1.48 3.3 1.25 Ø1.50 1.75 3.50 4.00 4.00 2.00 8.00 TOLERANCE ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 SOD-323 Tape Leader and Trailer SOD-323 Reel DIMENSIONS ARE IN MILLIMETER REEL OPTION 7’’ DIA TOLERANCE D D1 D2 G H I W1 W2 Ø178 54.40 13.00 R78 R25.60 R6.50 9.50 12.30 ±2 ±1 ±1 ±1 ±1 ±1 ±1 ±1 ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 4/ 4
SD103AWS 价格&库存
很抱歉,暂时无法提供与“SD103AWS”相匹配的价格&库存,您可以联系我们找货
SD103AWS
  • 50+0.06280
  • 500+0.04990
  • 3000+0.03790
  • 6000+0.03370
  • 24000+0.03010
  • 51000+0.02810
库存:84159
SD103AWS
  • 1+0.04250
  • 100+0.03380
库存:9000
SD103AWS
  • 20+0.14980
  • 100+0.09660
  • 800+0.06770
  • 3000+0.04830
  • 6000+0.04590
  • 30000+0.04250
库存:3383
SD103AWS
  • 50+0.05784
  • 600+0.04617
  • 1200+0.04548
  • 3000+0.03509
库存:3383
SD103AWS
  • 1+0.03070
  • 3000+0.02440
库存:15110
SD103AWS
    • 50+0.06310
    • 500+0.05038
    • 3000+0.03828
    • 6000+0.03407
    • 24000+0.03037
    • 51000+0.02832
    库存:422079
