Pin
3.50
H
B
B1
2XØ0.75
B1
2.65±0.10
B12
A
Section A-A
8.66
1.80
7.62
8.02
F
8.25±0.03
0.90
1.85
B
2x 0.80
3.00
5.60
A1
A1
2.80
G
A12
B12
3x 0.50
A12
0.93
2X0.50
A
24X0.28
0.50
2x 1.40
1.30±0.05
0.80±0.05
6.83±0.025
5.50
Solder Area
1.25
0.70
2.63±0.25
B
1.30
1.85
Section B-B
USB4151
B12
GF
C
Contact Plating
GF = Gold Flash
Request Samples
and Quotation
Ø0.60±0.05
A12
GND
First
B11
SSRXp1
Second
A3
SSTXn1
Second
B10
SSRXn1
Second
A4
VBUS
First
B9
VBUS
First
A5
CC1
Second
B8
SBU2
Second
A6
Dp1
Second
B7
Dn2
Second
A7
Dn1
Second
B6
Dp2
Second
A8
SBU1
Second
B5
CC2
Second
A9
VBUS
First
B4
VBUS
First
A10
SSRXn2
Second
B3
SSTXn2
Second
A11
SSRXp2
Second
B2
SSTXp2
Second
A12
GND
First
B1
GND
Product Description
USB4151
USB3.2 Gen2 Type C Plug,Vertical, SMT
Drawing Date
A1
GND
SHELL
First
GND
14th January 2020
By
Detail
2
B12
Part Number
7.62
1
First
Second
Mechanical & Environmental
Operating Temperature: -40°C to +85°C
Mating Force: 5 to 20 N.
Unmated Force: 6 to 20 N after test
Durability: 10,000 cycles
Packing Options
C = Tape & Reel with Cap
(400 per reel)
A
GND
SSTXp1
5.00A collectively for VBUS pins
6.25A collectively for GND pins
1.25A for B5 pin
0.25A per pin for all other pins
Voltage Rating: 20V DC
Contact Resistance: 40mΩ max initial.
50mΩ max after test
Dielectric Withstanding Voltage: 100V AC
Insulation Resistance 100MΩ min
Ordering Grid
B1
A1
Electrical
Current Rating:
5.60
3.50
8.02
Mating
Sequence
Plating
Contact
Contact Area: Gold Flash over 50µ" min. Nickel
Solder Tails: 80µ" min. Matte Tin over 50µ" min. Nickel
Shell: 50µ" min. Nickel
Latch: 80µ" min. Tin
Spring: 50µ" min. Nickel
9.80
11.10
4.60+0.10
-0.00
Component Outline
0.10
2x 0.90
Signal
Material
Insulator: LCP, UL 94V-0, Black
Contact: C7025,T=0.15mm
Shell: SUS304, T=0.15mm
Latch: SUS301, T=0.30mm
Spring: SUS304, T=0.10mm
D
C
Pin
Specifications
Tolerance: ±0.05mm
E
Mating
Sequence
A2
SHELL
Recommended PCB Layout
Thickness 0.8±0.10mm
2.40±0.03
Signal
3
4
Revision
Date
5
CC
USB4151
B PCN
B1
27/04/21
Tolerances (Except as Noted)
Length
Angle
X.X ± 0.30
X.XX ± 0.25
X.XXX ± 0.10
Units:
Metric (mm)
C
3rd Angle Projection
6
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
1/3
H
The cut is random.
Cap
USB4070 (Receptacle)
PCB
4.30
5.2
G
D
6.55 min.
1.60 ref.
1.35
11.95
4.60 max.
E
11.15
15.45 ref.
2° Max.Sway
Either direction
At the top
9.5
6.20
4.60
F
Panel
C
USB4151 (Plug)
PCB
Plug and Receptacle Mating View
B
PCB Mount&Cap Information
Part Number
Product Description
USB4151
Drawing Date
14th January 2020
A
By
Detail
Revision
Date
1
2
3
4
5
CC
USB4151
B PCN
B1
27/04/21
Length
Angle
X.X ± 0.30
X.XX ± 0.25
X.XXX ± 0.10
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
2/3
H
Folder
Paper Board
Unloaded Section
(16 Pockets)
400 PCS
Unloaded Section
(16 Pockets)
Paper Board
G
Vacuum Bag
Peeling
Angle
165°~180°
F
Direction of Unreeling
Ø380
Reel and Tape
E
Carton
Ø13
Reel and Tape
W+0.5
Label
320
D
16.00
2.00
4.00
40
C
24.00
Paper Board
Pcs /
Reel
400
B
Reels /
Carton
10
Total
Quantity
4,000 pcs
Part Number
Product Description
USB4151
Drawing Date
14th January 2020
A
By
Detail
Revision
Date
1
2
3
4
5
CC
USB4151
B PCN
B1
27/04/21
Length
Angle
X.X ± 0.30
X.XX ± 0.25
X.XXX ± 0.10
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
3/3
很抱歉,暂时无法提供与“USB4151-GF-C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 400+22.51950400+2.92190
- 国内价格 香港价格
- 400+12.02201400+1.55727
- 800+11.44814800+1.48294
- 1200+11.125331200+1.44112
- 2000+10.731662000+1.39013
- 2800+10.480072800+1.35754
- 4000+10.219924000+1.32384
- 国内价格
- 1+15.70316
- 10+13.21173
- 25+12.46910
- 50+11.82229
- 80+11.35514
- 100+11.27130
- 250+10.52866
- 400+10.06152
- 800+9.51053
- 1200+9.13921
- 国内价格 香港价格
- 1+18.359631+2.37822
- 10+15.5971510+2.02038
- 25+14.6211025+1.89395
- 50+13.9238650+1.80363
- 100+13.25821100+1.71741
