LMC7660M/TR
LMC7660M/TR
    HGSEMI(华冠)
    SOP-8
    DC-DC电源芯片 SOP8_150MIL 3~10V 120μA
LMC7660M/TR 数据手册
LMC7660 LMC7660 Switched Capacitor Voltage Converter General Description Features The LMC7660 is a CMOS voltage converter capable of converting a positive voltage in the range of +1.5V to +10V to the corresponding negative voltage of −1.5V to −10V. The LMC7660 is a pin-for-pin replacement for the industry-standard 7660. The converter features: operation over full temperature and voltage range without need for an external diode, low quiescent current, and high power efficiency. The LMC7660 uses its built-in oscillator to switch 4 power MOS switches and charge two inexpensive electrolytic capacitors. n Operation over full temperature and voltage range without an external diode n Low supply current, 200 µA max n Pin-for-pin replacement for the 7660 n Wide operating range 1.5V to 10V n 97% Voltage Conversion Efficiency n 95% Power Conversion Efficiency n Easy to use, only 2 external components n Extended temperature range n Narrow SO-8 Package Block Diagram Pin Configuration Ordering Information Package Temperature Range Industrial NSC Drawing −40˚C to +85˚C http://www.hgsemi.com.cn 8-Lead Molded DIP LMC7660N N08E 8-Lead Molded Small Outline LMC7660M M08A 1 2018 JUN LMC7660 Absolute Maximum Ratings Power Dissipation (Note 3) Dual-In-Line Package Surface-Mount Package TJ Max (Note 3) θJA (Note 3) Dual-In-Line Package Surface-Mount Package Storage Temp. Range Lead Temperature (Soldering, 5 sec.) ESD Tolerance (Note 7) (Note 1) If Military/Aerospace specified devices are required, please contact the National Semiconductor Sales Office/ Distributors for availability and specifications. Supply Voltage Input Voltage on Pin 6, 7 (Note 2) Current into Pin 6 (Note 2) Output Short Circuit Duration (V+ ≤ 5.5V) 10.5V + −0.3V to (V + 0.3V) for V+ < 5.5V + (V − 5.5V) to (V+ + 0.3V) for V+ > 5.5V 20 µA Electrical Characteristics 1.4W 0.6W 150˚C 90˚C/W 160˚C/W −65˚C ≤ T ≤ 150˚C 260˚C ± 2000V Continuous (Note 4) LMC7660IN/ Symbol Parameter Conditions Typ LMC7660IM Limit Units Limits (Note 5) Is V+H V+L Supply Current 120 Supply Voltage RL = 10 kΩ, Pin 6 Open Range High (Note 6) Voltage Efficiency ≥ 90% RL = 10 kΩ, Pin 6 to Gnd. Supply Voltage Range Low Rout RL = ∞ Output Source Voltage Efficiency ≥ 90% IL = 20 mA 3 to 10 1.5 to 3.5 Oscillator max 3 to 10 V 1.5 to 3.5 V 1.5 to 3.5 55 110 Pin 6 Short to Gnd. Fosc µA 400 3 to 10 Resistance V = 2V, IL = 3 mA 200 100 Ω 120 max 200 Ω 300 max 10 kHz Frequency Peff Power Efficiency RL = 5 kΩ Vo eff Voltage Conversion RL = ∞ 97 95 % 90 min 99.9 97 % 95 min Efficiency Iosc Oscillator Sink or Pin 7 = Gnd. or V+ 3 µA Source Current Note 1: Absolute Maximum ratings indicate limits beyond which damage to the device may occur. DC and AC electrical specifications do not apply when operating the device beyond its rated operating conditions. See Note 4 for conditions. Note 2: Connecting any input terminal to voltages greater than V+or less than ground may cause destructive latchup. It is recommended that no inputs from sources operating from external supplies be applied prior to “power-up” of the LMC7660. Note 3: For operation at elevated temperature, these devices must be derated based on a thermal resistance of θja and Tj max, Tj = TA + θja PD. Note 4: Boldface numbers apply at temperature extremes. All other numbers apply at TA = 25˚C, V+ = 5V, Cosc = 0, and apply for the LMC7660 unless otherwise specified. Test circuit is shown in Figure 1 . Note 5: Limits at room temperature are guaranteed and 100% production tested. Limits in boldface are guaranteed over the operating temperature range (but not 100% tested), and are not used to calculate outgoing quality levels. Note 6: The LMC7660 can operate without an external diode over the full temperature and voltage range. The LMC7660 can also be used with the external diode Dx, when replacing previous 7660 designs. Note 7: The test circuit consists of the human body model of 100 pF in series with 1500Ω. http://www.hgsemi.com.cn 2 2018 JUN LMC7660 Electrical Characteristics (Note 4) (Continued) FIGURE 1. LMC7660 Test Circuit Typical Performance Characteristics OSC Freq. vs OSC Capacitance Supply Current & Power Efficiency vs Load Current (V+ = 2V) http://www.hgsemi.com.cn Vout vs Iout @ V+ = 2V Supply Current & Power Efficiency vs Load Current (V+ = 5V) 3 Vout vs Iout @ V+ = 5V Output Source Resistiance as a Function of Temperature 2018 JUN LMC7660 Typical Performance Characteristics Unloaded Oscillator Frequency as a Function of Temperature (Continued) Output R vs Supply Voltage The LMC7660 closely approaches 1 and 2 above. By using a large pump capacitor Cp, the charge removed while supplying the reservoir capacitor is small compared to Cp’s total charge. Small removed charge means small changes in the pump capacitor voltage, and thus small energy loss and high efficiency. The energy loss by Cp is: Application Information Circuit Description The LMC7660 contains four large CMOS switches which are switched in a sequence to provide supply inversion Vout = −Vin. Energy transfer and storage are provided by two inexpensive electrolytic capacitors. Figure 2 shows how the LMC7660 can be used to generate −V+ from V+. When switches S1 and S3 are closed, Cp charges to the supply voltage V+. During this time interval, switches S2 and S4 are open. After Cp charges to V+, S1 and S3 are opened, S2 and S4 are then closed. By connecting S2 to ground, Cp develops a voltage −V+/2 on Cr. After a number of cycles Cr will be pumped to exactly −V+. This transfer will be exact assuming no load on Cr, and no loss in the switches. In the circuit of Figure 2, S1 is a P-channel device and S2, S3, and S4 are N-channel devices. Because the output is biased below ground, it is important that the p− wells of S3 and S4 never become forward biased with respect to either their sources or drains. A substrate logic circuit guarantees that these p− wells are always held at the proper voltage. Under all conditions S4 p− well must be at the lowest potential in the circuit. To switch off S4, a level translator generates VGS4 = 0V, and this is accomplished by biasing the level translator from the S4 p− well. An internal RC oscillator and ÷ 2 circuit provide timing signals to the level translator. The built-in regulator biases the oscillator and divider to reduce power dissipation on high supply voltage. The regulator becomes active at about V+ = 6.5V. Low voltage operation can be improved if the LV pin is shorted to ground for V+ ≤ 3.5V. For V+ ≥ 3.5V, the LV pin must be left open to prevent damage to the part. By using a large reservoir capacitor, the output ripple can be reduced to an acceptable level. For example, if the load current is 5 mA and the accepted ripple is 200 mV, then the reservoir capacitor can omit approximately be calculated from: Precautions 1. Do not exceed the maximum supply voltage or junction temperature. 2. Do not short pin 6 (LV terminal) to ground for supply voltages greater than 3.5V. 3. Do not short circuit the output to V+. 4. External electrolytic capacitors Cr and Cp should have their polarities connected as shown in Figure 1. Replacing Previous 7660 Designs To prevent destructive latchup, previous 7660 designs require a diode in series with the output when operated at elevated temperature or supply voltage. Although this prevented the latchup problem of these designs, it lowered the available output voltage and increased the output series resistance. The National LMC7660 has been designed to solve the inherent latch problem. The LCM7660 can operate over the entire supply voltage and temperature range without the need for an output diode. When replacing existing designs, the LMC7660 can be operated with diode Dx. Power Efficiency and Ripple It is theoretically possible to approach 100% efficiency if the following conditions are met: 1. The drive circuitry consumes little power. 2. The power switches are matched and have low Ron. 3. The impedance of the reservoir and pump capacitors are negligibly small at the pumping frequency. http://www.hgsemi.com.cn Peff vs OSC Freq. @ V+ = 5V 4 2018 JUN LMC7660 Application Information (Continued) FIGURE 2. Idealized Voltage Converter current cause an increased impedance of Cr and Cp. The increased impedance, due to a lower switching rate, can be offset by raising Cr and Cp until ripple and load current requirements are met. Typical Applications Changing Oscillator Frequency It is possible to dramatically reduce the quiescent operating current of the LMC7660 by lowering the oscillator frequency. The oscillator frequency can be lowered from a nominal 10 kHz to several hundred hertz, by adding a slow-down capacitor Cosc (Figure 3). As shown in the Typical Performance Curves the supply current can be lowered to the 10 µA range. This low current drain can be extremely useful when used in µPower and battery back-up equipment. It must be understood that the lower operating frequency and supply Synchronizing to an External Clock Figure 4 shows an LMC7660 synchronized to an external clock. The CMOS gate overrides the internal oscillator when it is necessary to switch faster or reduce power supply interference. The external clock still passes through the ÷2 circuit in the 7660, so the pumping frequency will be 1⁄2 the external clock frequency. FIGURE 3. Reduce Supply Current by Lowering Oscillator Frequency FIGURE 4. Synchronizing to an External Clock Lowering Output Impedance Paralleling two or more LMC7660’s lowers output impedance. Each device must have it’s own pumping capacitor Cp, but the reservoir capacitor Cr is shared as depicted in Figure 5. The composite output resistance is: http://www.hgsemi.com.cn 5 2018 JUN LMC7660 Typical Applications (Continued) Increasing Output Voltage Stacking the LMC7660s is an easy way to produce a greater negative voltage. It should be noted that the input current required for each stage is twice the load current on that stage as shown in Figure 6. The effective output resistance is approximately the sum of the individual Rout values, and so only a few levels of multiplication can be used. It is possible to generate −15V from +5V by connecting the second 7660’s pin 8 to +5V instead of ground as shown in Figure 7. Note that the second 7660 sees a full 20V and the input supply should not be increased beyond +5V. FIGURE 5. Lowering Output Resistance by Paralleling Devices FIGURE 6. Higher Voltage by Cascade FIGURE 7. Getting −15V from +5V Split V+ In Half Figure 8 is one of the more interesting applications for the LMC7660. The circuit can be used as a precision voltage divider (for very light loads), alternately it is used to generate a 1⁄2 supply point in battery applications. In the 1⁄2 cycle when S1 and S3 are closed, the supply voltage divides across the capacitors in a conventional way proportional to their value. http://www.hgsemi.com.cn 6 In the 1⁄2 cycle when S2 and S4 are closed, the capacitors switch from a series connection to a parallel connection. This forces the capacitors to have the same voltage; the charge redistributes to maintain precisely V+/2, across Cp and Cr. In this application all devices are only V+/2, and the supply voltage can be raised to 20V giving exactly 10V at Vout. 2018 JUN LMC7660 Typical Applications at V+ + (V+ −VD1). D1 is reverse biased in this interval. This application uses only two of the four switches in the 7660. The other two switches can be put to use in performing a negative conversion at the same time as shown in Figure 10. In the 1⁄2 cycle that D1 is charging Cp1, Cp2 is connected from ground to −Vout via S2 and S4, and Cr2 is storing Cp2’s charge. In the interval that S1 and S3 are closed, Cp1 pumps the junction of D1 and D2 above V+, while Cp2 is refreshed from V+. (Continued) Getting Up … and Down The LMC7660 can also be used as a positive voltage multiplier. This application, shown in Figure 9, requires 2 additional diodes. During the first 1⁄2 cycle S2 charges Cp1 through D1; D2 is reverse biased. In the next 1⁄2 cycle S2 is open and S1 is closed. Since Cp1 is charged to V+ − VD1 and is referenced to V+through S1, the junction of D1 and D2 is FIGURE 8. Split V+ in Half FIGURE 9. Positive Voltage Multiplier FIGURE 10. Combined Negative Converter and Positive Multiplier Regulating −Vout Thermometer Spans 180˚C Using the combined negative and positive multiplier of Figure 11 with an LM35 it is possible to make a µPower thermometer that spans a 180˚C temperature range. The LM35 temperature sensor has an output sensitivity of 10 mV/˚C, while drawing only 50 µA of quiescent current. In order for the LM35 to measure negative temperatures, a pull down to a negative voltage is required. Figure 11 shows a thermometer circuit for measuring temperatures from −55˚C to +125˚C and requiring only two 1.5V cells. End of battery life can be extended by replacing the up converter diodes with Schottky’s. http://www.hgsemi.com.cn It is possible to regulate the output of the LMC7660 and still maintain µPower performance. This is done by enclosing the LMC7660 in a loop with a LP2951. The circuit of Figure 12 will regulate Vout to −5V for IL = 10 mA, and Vin = 6V. For Vin > 7V, the output stays in regulation up to IL = 25 mA. The error flag on pin 5 of the LP2951 sets low when the regulated output at pin 4 drops by about 5%. The LP2951 can be shutdown by taking pin 3 high; the LMC7660 can be shutdown by shorting pin 7 and pin 8. 7 2018 JUN LMC7660 Typical Applications (Continued) The LP2951 can be reconfigured to an adjustable type regulator, which means the LMC7660 can give a regulated output from −2.0V to −10V dependent on the resistor ratios R1 and R2, as shown in Figure 13, Vref = 1.235V: *For lower voltage operation, use Schottky rectifiers FIGURE 11. µPower Thermometer Spans 180˚C, and Pulls Only 150 µA FIGURE 12. Regulated −5V with 200 µA Standby Current http://www.hgsemi.com.cn 8 2018 JUN LMC7660 Typical Applications (Continued) Vref = 1.235V *Low voltage operation FIGURE 13. LMC7660 and LP2951 Make a Negative Adjustable Regulator http://www.hgsemi.com.cn 9 2018 JUN LMC7660 Important statement: Huaguan Semiconductor Co,Ltd. reserves the right to change the products and services provided without notice. Customers should obtain the latest relevant information before ordering, and verify the timeliness and accuracy of this information. Customers are responsible for complying with safety standards and taking safety measures when using our products for system design and machine manufacturing to avoid potential risks that may result in personal injury or property damage. Our products are not licensed for applications in life support, military, aerospace, etc., so we do not bear the consequences of the application of these products in these fields. Our documentation is only permitted to be copied without any tampering with the content, so we do not accept any responsibility or liability for the altered documents. http://www.hgsemi.com.cn 10 2018 JUN
LMC7660M/TR 价格&库存
很抱歉,暂时无法提供与“LMC7660M/TR”相匹配的价格&库存,您可以联系我们找货
LMC7660M/TR
  • 5+2.45819
  • 50+1.94109
  • 150+1.71947
  • 500+1.44299
  • 2500+1.27980
  • 5000+1.20582
库存:2296
LMC7660M/TR
  • 1+2.25334
  • 2+2.21954
库存:2
