74LVC4245A-Q100
Octal dual supply translating transceiver; 3-state
Rev. 1 — 20 October 2014
Product data sheet
1. General description
The 74LVC4245A-Q100 is an octal dual supply translating transceiver featuring
non-inverting 3-state bus compatible outputs in both send and receive directions. It is
designed to interface between a 3 V and 5 V bus in a mixed 3 V and 5 V supply
environment.
The device features an output enable input (pin OE) for easy cascading and a
send/receive input (pin DIR) for direction control. Pin OE controls the outputs so that the
buses are effectively isolated.
In suspend mode, when VCC(A) is zero, there is no current flow from one supply to the
other supply. The A-outputs must be set 3-state and the voltage on the A-bus must be
smaller than Vdiode (typical 0.7 V).
VCC(A) VCC(B), except in suspend mode.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
5 V tolerant inputs/outputs, for interfacing with 5 V logic
Wide supply voltage range:
3 V bus (VCC(B)): 1.5 V to 3.6 V
5 V bus (VCC(A)): 1.5 V to 5.5 V
CMOS low-power consumption
Direct interface with TTL levels
Inputs accept voltages up to 5.5 V
High-impedance when VCC(A) = 0 V
Complies with JEDEC standard no. JESD8B/JESD36
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Multiple package options
74LVC4245A-Q100
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
40 C to +125 C
SO24
plastic small outline package; 24 leads;
body width 7.5 mm
SOT137-1
74LVC4245APW-Q100 40 C to +125 C
TSSOP24
plastic thin shrink small outline package; 24 leads; SOT355-1
body width 4.4 mm
74LVC4245ABQ-Q100 40 C to +125 C
DHVQFN24 plastic dual in-line compatible thermal enhanced
very thin quad flat package; no leads;
24 terminals; body 3.5 5.5 0.85 mm
74LVC4245AD-Q100
SOT815-1
4. Functional diagram
2
DIR
OE
3
B0
4
22
2
B1
5
6
2
4
19
6
18
B3
7
17
8
16
9
15
10
14
IEC Logic symbol
74LVC4245A_Q100
Product data sheet
15
A7
B7
mna452
Fig 1.
16
A6
B6
10
17
A5
B5
9
18
A4
B4
8
19
A3
21
7
A2
B2
1
3
21
A1
G3
3EN1
3EN2
22
A0
14
mna453
Fig 2.
Logic diagram
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 17
74LVC4245A-Q100
Nexperia
5. Pinning information
5.1 Pinning
WHUPLQDO
LQGH[DUHD
/9&$4
9&&%
9&&$
/9&$4
',5
9&&%
9&&%
2(
*1'
*1'
*1'
',5
9&&%
2(
*1'
*1'
*1'
*1'
9&&$
DDD
7UDQVSDUHQWWRSYLHZ
DDD
(1) This is not a supply pin. The substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to GND.
Fig 3.
Pin configuration SO24 and TSSOP24
Fig 4.
Pin configuration DHVQFN24
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
VCC(A)
1
supply voltage (5 V bus)
VCC(B)
23, 24
supply voltage (3 V bus)
GND
11, 12, 13
ground (0 V)
DIR
2
direction control
A[0:7]
3, 4, 5, 6, 7, 8, 9, 10
data input or output
B[0:7]
21, 20, 19, 18, 17, 16, 15, 14
OE
22
output enable input (active LOW)
74LVC4245A_Q100
Product data sheet
3 of 17
74LVC4245A-Q100
Nexperia
6. Functional description
Table 3.
Functional table[1]
Input
Input/output
OE
DIR
An
Bn
L
L
A=B
input
L
H
input
B=A
H
X
Z
Z
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC(A)
supply voltage A
VCC(B)
supply voltage B
IIK
input clamping current
VI
IOK
Min
Max
Unit
0.5
+6.5
V
0.5
+4.6
V
50
mA
input voltage
[1]
0.5
+6.5
V
output clamping current
VO > VCCO or VO < 0 V
[3]
50
mA
output HIGH or LOW state
[1]
0.5
VCC + 0.5
V
output 3-state
[1]
0.5
+6.5
V
VO = 0 V to VCCO
[3]
50
mA
100
mA
output voltage
VO
Conditions
VI < 0 V
IO
output current
ICC
supply current
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
500
mW
Tamb = 40 C to +125 C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO24 packages: above 70 C the value of Ptot derates linearly with 8 mW/K.
For TSSOP24 packages: above 60 C the value of Ptot derates linearly with 5.5 mW/K.
For DHVQFN24 packages: above 60 C the value of Ptot derates linearly with 4.5 mW/K.
[3]
VCCO is the supply voltage associated with the output.
8. Recommended operating conditions
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCC(A)
supply voltage A
VCC(A) VCC(B);
see Figure 5 for maximum
speed performance
1.5
5.5
V
VCC(B)
supply voltage B
VCC(A) VCC(B);
see Figure 5 for low-voltage
applications
1.5
3.6
V
VI
input voltage
for control inputs
V
74LVC4245A_Q100
Product data sheet
4 of 17
74LVC4245A-Q100
Nexperia
Table 5.
Recommended operating conditions …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VO
output voltage
VCC
V
output 3-state
V
40
+125
C
VCC(B) = 2.7 V to 3.0 V
ns/V
VCC(B) = 3.0 V to 3.6 V
10
ns/V
VCC(A) = 3.0 V to 4.5 V
ns/V
VCC(A) = 4.5 V to 5.5 V
10
ns/V
Tamb
ambient temperature
t/V
input transition rise and fall rate
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Typ[1]
Max
VCC(B) = 2.7 V to 3.6 V
2.0
V
2.0
V
0.8
V
0.8
V
VCC(B) = 2.7 V to 3.6 V; IO = 100 A
VCC(B) 0.2
VCC(B)
V
VCC(B) = 2.7 V; IO = 12 mA
VCC(B) 0.5
V
VCC(B) = 3.0 V; IO = 24 mA
VCC(B) 0.8
V
VCC(A) = 4.5 V to 5.5 V; IO = 100 A
VCC(A) 0.2
VCC(A)
V
VCC(A) = 4.5 V; IO = 12 mA
VCC(A) 0.5
V
VCC(A) = 4.5 V; IO = 24 mA
VCC(A) 0.8
V
0.20
V
0.40
V
0.55
V
0.20
V
0.40
V
0.55
V
0.1
5
A
VCC(B) = 3.6 V; VO = VCC(B) or GND
0.1
5
A
VCC(A) = 5.5 V; VO = VCC(A) or GND
0.1
5
A
VCC(B) = 3.6 V;
other inputs at VCC(B) or GND
0.1
10
A
VCC(A) = 5.5 V;
other inputs at VCC(A) or GND
0.1
10
A
Unit
Tamb = 40 C to +85 C
VIH
VIL
VOH
VOL
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage VI = VIH or VIL
LOW-level output voltage VI = VIH or VIL
II
input leakage current
VI = 5.5 V or GND
IOZ
OFF-state output current
VI = VIH or VIL
ICC
supply current
74LVC4245A_Q100
Product data sheet
[2]
IO = 0 A
5 of 17
74LVC4245A-Q100
Nexperia
Table 6.
Static characteristics …continued
Symbol
ICC
Parameter
additional supply current
CI
input capacitance
CI/O
input/output capacitance
Min
Typ[1]
Max
Unit
VI = VCC(B) 0.6 V;
5
500
A
VI = VCC(A) 0.6 V;
5
500
A
4.0
pF
5.0
pF
2.0
V
2.0
V
0.8
V
0.8
V
VCC(B) 0.3
V
VCC(B) 0.65
V
VCC(B) 1.0
V
Conditions
per control pin; IO = 0 A
[3]
An and Bn
VIH
VIL
VOH
VOL
II
IOZ
ICC
VCC(A) 0.3
V
VCC(A) 0.65
V
VCC(A) 1.0
V
0.30
V
0.60
V
0.80
V
0.30
V
supply current
74LVC4245A_Q100
Product data sheet
0.60
V
0.80
V
A
A
A
VCC(B) = 3.6 V;
40
A
VCC(A) = 5.5 V;
40
A
VI = 5.5 V or GND
VI = VIH or VIL
[2]
IO = 0 A
6 of 17
74LVC4245A-Q100
Nexperia
Table 6.
Symbol
Parameter
ICC
Min
Typ[1]
Max
Unit
VI = VCC(B) 0.6 V;
5000
A
VI = VCC(A) 0.6 V;
5000
A
Conditions
[3]
[1]
All typical values are measured at VCC(A) = 5.0 V, VCC(B) = 3.3 V and Tamb = 25 C.
[2]
For transceivers, the parameter IOZ includes the input leakage current.
[3]
VCC(B) = 2.7 V to 3.6 V: other inputs at VCC(B) or GND.
VCC(A) = 4.5 V to 5.5 V: other inputs at VCC(A) or GND.
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V). VCC(A) = 4.5 V to 5.5 V; tr = tf 2.5 ns. For test circuit, see Figure 8.
Symbol Parameter
tPHL
tPLH
tPZL
tPZH
tPLZ
tPHZ
HIGH to LOW
propagation
delay
LOW to HIGH
propagation
delay
OFF-state to
LOW
propagation
delay
OFF-state to
HIGH
propagation
delay
LOW to
OFF-state
propagation
delay
HIGH to
OFF-state
propagation
delay
74LVC4245A_Q100
Product data sheet
Conditions
VCC(B)
40 C to +85 C
40 C to +125 C Unit
Min
Typ[1]
Max
Min
Max
1.0
3.6
6.3
1.0
8.0
ns
An to Bn;
see Figure 6
2.7 V
3.0 V to 3.6 V
1.0
3.3
6.3
1.0
8.0
ns
Bn to An;
see Figure 6
2.7 V
1.0
3.4
6.1
1.0
8.0
ns
3.0 V to 3.6 V
1.0
3.4
6.1
1.0
8.0
ns
An to Bn;
see Figure 6
2.7 V
1.0
3.3
6.7
1.0
8.5
ns
3.0 V to 3.6 V
1.0
2.8
6.5
1.0
8.5
ns
Bn to An;
see Figure 6
2.7 V
1.0
3.0
5.0
1.0
6.5
ns
3.0 V to 3.6 V
1.0
3.0
5.0
1.0
6.5
ns
OE to An;
see Figure 7
2.7 V
1.0
4.5
9.0
1.0
11.5
ns
3.0 V to 3.6 V
1.0
4.5
9.0
1.0
11.5
ns
OE to Bn;
see Figure 7
2.7 V
1.0
4.4
8.7
1.0
11.0
ns
3.0 V to 3.6 V
1.0
3.8
8.1
1.0
10.5
ns
OE to An;
see Figure 7
2.7 V
1.0
4.5
8.1
1.0
10.5
ns
3.0 V to 3.6 V
1.0
4.5
8.1
1.0
10.5
ns
OE to Bn;
see Figure 7
2.7 V
1.0
4.3
8.7
1.0
11.0
ns
3.0 V to 3.6 V
1.0
3.2
8.1
1.0
10.5
ns
OE to An;
see Figure 7
2.7 V
1.0
2.9
7.0
1.0
9.0
ns
3.0 V to 3.6 V
1.0
2.9
7.0
1.0
9.0
ns
OE to Bn;
see Figure 7
2.7 V
1.0
3.9
7.7
1.0
10.0
ns
3.0 V to 3.6 V
1.0
3.5
7.7
1.0
10.0
ns
OE to An;
see Figure 7
2.7 V
1.0
2.8
5.8
1.0
7.5
ns
3.0 V to 3.6 V
1.0
2.8
5.8
1.0
7.5
ns
OE to Bn;
see Figure 7
2.7 V
1.0
3.3
7.8
1.0
10.0
ns
3.0 V to 3.6 V
1.0
2.9
7.8
1.0
10.0
ns
7 of 17
74LVC4245A-Q100
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
tsk(o)
output skew
time
CPD
power
dissipation
capacitance
Conditions
40 C to +85 C
VCC(B)
[2]
40 C to +125 C Unit
Min
Typ[1]
Max
Min
Max
1.0
1.5
ns
[3]
5 V bus: Bn to An;
VI = GND to VCC(A);
VCC(A) = 5.0 V
outputs enabled
17
pF
outputs disabled
5
pF
[3]
3 V bus: An to Bn;
VI = GND to VCC(B);
VCC(B) = 3.3 V
outputs enabled
17
pF
outputs disabled
5
pF
[1]
Typical values are measured at Tamb = 25 C, VCC(A) = 5.0 V, and VCC(B) = 2.7 V and 3.3 V respectively.
[2]
Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz; fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
(CL VCC2 fo) = sum of the outputs
11. AC waveforms
mna454
3.9
VCC(B)
VCC(A) ³ VCC(B)
(V) 3.6
3.3
3.0
2.7
2.4
2.1
1.8
1.5
1.2
0.9
1.5
2.1
2.7
Full operation
Fig 5.
3.3
3.9
4.5
5.1
5.7
VCC(A) (V)
Complies with TTL levels
Supply operation area
74LVC4245A_Q100
Product data sheet
8 of 17
74LVC4245A-Q100
Nexperia
VI
An, Bn
input
VM
GND
t PHL
t PLH
VOH
Bn, An
output
VM
VOL
mna366
VM = 1.5 V at 2.7 V VCC(B) 3.6 V.
VM = 0.5 VCC(A) at VCC(A) 4.5 V.
VOL and VOH are typical output voltage drops that occur with the output load.
Fig 6.
Input (An, Bn) to output (Bn, An) propagation delays
9,
2(LQSXW
90
*1'
W 3/=
W 3=/
9&&
RXWSXW
/2:WR2))
2))WR/2:
92/
90
9;
W 3+=
92+
W 3=+
9<
RXWSXW
+,*+WR2))
2))WR+,*+
90
*1'
RXWSXWV
HQDEOHG
RXWSXWV
GLVDEOHG
RXWSXWV
HQDEOHG
PQD
VX = VOL + 0.3 V at VCC(B) 2.7 V.
VY = VOH 0.3 V at VCC(B) 2.7 V.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 7.
3-state enable and disable times
74LVC4245A_Q100
Product data sheet
9 of 17
74LVC4245A-Q100
Nexperia
9(;7
9&&
9,
5/
92
'87
57
5/
PQD
Test data is given in Table 8. Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
Fig 8.
Test circuit for measuring switching times
Table 8.
Test data
Supply voltage
Input
Load
VCC(A)
VCC(B)
VI [1]
CL
RL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ [2]
< 2.7 V
< 2.7 V
VCCI
50 pF
500
open
GND
2 VCCO
2.7 V to 3.6 V
2.7 V
50 pF
500
open
GND
2 VCCO
4.5 V to 5.5 V
3.0 V
50 pF
500
open
GND
2 VCCO
[1]
VCCI is the supply voltage associated with the data input port.
[2]
VCCO is the supply voltage associated with the output port.
74LVC4245A_Q100
Product data sheet
VEXT
10 of 17
74LVC4245A-Q100
Nexperia
12. Package outline
62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
ES
GHWDLO;
Z 0
PP
VFDOH
',0(16,216LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
PP
LQFKHV
ș
R
R
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPLQFKPD[LPXPSHUVLGHDUHQRWLQFOXGHG
Fig 9.
5()(5(1&(6
287/,1(
9(56,21
627
06
-(,7$
(8523($1
352-(&7,21
,668('$7(
Package outline SOT137-1 (SO24)
74LVC4245A_Q100
Product data sheet
11 of 17
74LVC4245A-Q100
Nexperia
76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
ES
H
GHWDLO;
Z 0
PP
VFDOH
',0(16,216PPDUHWKHRULJLQDOGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
ș
PP
R
R
1RWHV
3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
5()(5(1&(6
-(,7$
(8523($1
352-(&7,21
,668('$7(
02
Fig 10. Package outline SOT355-1 (TSSOP24)
74LVC4245A_Q100
Product data sheet
12 of 17
74LVC4245A-Q100
Nexperia
'+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJH
QROHDGVWHUPLQDOVERG\[[PP
627
F
GHWDLO;
WHUPLQDO
LQGH[DUHD
H
WHUPLQDO
LQGH[DUHD
H
Y 0 & $ %
Z 0 &
E
H
(K
'K
PP
VFDOH
81,7
PD[
E
F
' K
( K
H
H
H
Y
Z
PP
1RWH
5()(5(1&(6
287/,1(
9(56,21
-(,7$
627
(8523($1
352-(&7,21
,668('$7(
Fig 11. Package outline SOT815-1 (DHVQFN24)
74LVC4245A_Q100
Product data sheet
13 of 17
74LVC4245A-Q100
Nexperia
13. Abbreviations
Table 9.
Abbreviations
Acronym
Description
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVC4245A_Q100 v.1
20141020
Product data sheet
74LVC4245A_Q100
Product data sheet
14 of 17
74LVC4245A-Q100
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74LVC4245A_Q100
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
15 of 17
74LVC4245A-Q100
Nexperia
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74LVC4245A_Q100
Product data sheet
16 of 17
Nexperia
74LVC4245A-Q100
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
AC waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14
Legal information. . . . . . . . . . . . . . . . . . . . . . . 15
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Contact information. . . . . . . . . . . . . . . . . . . . . 16
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Date of release: 20 October 2014
