MF0207F10R0BLU040
MF0207F10R0BLU040
    HECHENGOHM(代禾铖)
    插件,D2.3xL6.5mm
    金属膜电阻 AXIAL_D2.3X6.5MM_TM 10Ω ±1% 1/4W
MF0207F10R0BLU040 数据手册
深圳市代禾铖电子有限公司 精密金属膜电阻器 METAL FILM RESISTORS 编号 DHC-R-01 版本 A 页次 第 1 页 共 7 页 承 认 书 客户名称: 精密金属膜电阻器 产品品名: 规格描述: MF1/8W-5W ±1% 客户料号: 30K,2W,1%,100PPM/℃ 备 注: 100Ω,1/4W,1%,100ppm/℃ 2022-09-30 送样日期: 制造厂商: 核准 Approval 林学东 全系列承认 客户承认: 确认 Check By 邢兰兵 审核 Prepared By 核准 Approval 确认 Check By 审核 Prepared By 闵小江 公 公 司 司 章 章 联系方式:闵先生 15976878116 网址:http://www.gddaihec.com ISO9001:2015 ROHS&REACH 1 深圳市代禾铖电子有限公司 精密金属膜电阻器 METAL FILM RESISTORS 编号 DHC-R-01 版本 A 页次 第 2 页 共 7 页 1. General Instruction General Specifications Normal Type Rated Power MF-0204 1/8W MF-0207 1/4W MF-0410 1/2W MF-0414 1W MF-0617 2W MF-0718 3W MF-0207S 1/4WS MF-0410S 1/2WS MF-0414S 1WS MF-0617S 2WS MF-0718S 3WS MF-0925S 5WS 3.5 ± 1.0 1.7 ± 1.0 27±2.0 0.40±0.05 6.5 ± 1.0 2.3 ± 1.0 26±2.0 0.40±0.05 9.0 ± 1.0 3.2 ± 1.0 25±2.0 0.50±0.05 11 ± 1.0 4.5 ± 1.0 30±2.0 0.60±0.05 15 ± 1 5.0 ± 0.5 28±2.0 0.60±0.05 17 ± 1 6 ± 0.5 32±2.0 0.70±0.05 0204 0207 0410 0414 200 250 350 500 400 500 700 1000 0.1Ω-1MΩ 0.1Ω-1MΩ 0.1Ω-1MΩ 0.1Ω-1MΩ 100Ω-511KΩ 100Ω-511KΩ 100Ω-511KΩ 100Ω-51KΩ 0617 500 1000 0.1Ω-1MΩ 100Ω-51KΩ 0718 500 1000 0.1Ω-1MΩ 100Ω-51KΩ Mini Type Rated Power Standard Dimensions (mm) Body Length (L) Body Diameter (D) Lead Length (H) ± 2 Lead Diameter (d) ± 0.05 Electrical Specification Din Size Maximum Working Voltage (V) Maximum Overload Voltage (V) Resistance Range ( ±1%(F)) ( ±0.5%(D)) *L esser of P R o r m a x im u m w o r k i n g v o lta g e . Operating Temperature. Range: -55℃~ +155℃. S=Miniature Type. For Example:0207S the body size of 1/8W but with rated power of 1/4W.  The taping dimension other than the standard is also available as per our taping specifications.  The resistance range of lower than 10Ω and higher than 1MΩ and / or the tolerance is lower than 0.5% are available on special request.  Color of Body: Normal type is Blue.  Packaging: Taped / Box and Bulk.  Forming: P / M / MB / MK / F / FK1 / FK2 & FKK .  Standard: JIS-C-5202 Power Derating Curve ISO9001:2015 ROHS&REACH 2 深圳市代禾铖电子有限公司 精密金属膜电阻器 METAL FILM RESISTORS Power Load (%) -55℃ 100 编号 DHC-R-01 版本 A 页次 第 3 页 共 7 页 70℃ 80 60 40 20 0 -60 -40 155℃ -20 0 20 40 60 80 100 120 140 160 180 Ambient Temperature(℃) 2. Performance Specifications Characteristics Standard 1. Resistance Temperature Coefficient (PPM/℃) 2. Dielectric Withstanding Voltage ±100 PPM/℃ ±50 PPM/℃ ±25 PPM/℃ Test Methods Natural resistance centigrade. change per temperature degree R 2  R1  10 6 (PPM/℃) R1(T 2  T 1) R1: Resistance value at reference temperature. (T1) R2: Resistance value at reference temperature. (T2) T1: Room Temperature T2 : T1±100℃ Resistors shall be subjected to an approximately sinusoidal test potential (as below) 60Hz applied between both No evidence of flashover, terminals connected together and a 90° V-Block extending mechanical damage or arcing beyond the end of the resistor. or, insulation break down. Resistor Wattage DC Volts 1/8W (1/4WSi) 150 1/4W (1/2WS) 350 1/2W 1W,2W Above 600 3. Solderability 90% Covered min. The terminal lead shall be dipped into molten solder s at 3.2 to 4.8mm from the body of resistor. The temp. and time as below: a. 235±5℃ for 2±0.5 seconds b. 270±10℃ for 2±0.5 seconds No evidence of mechanical damage ΔR/R at ±0.5% Max The terminal of the resistor is dipped into the molten solder of 350±10℃ for 3±0.5 seconds. Then put the resistor in the room temperature. For min.3 hours. 4. Resistance to Soldering ISO9001:2015 ROHS&REACH 3 深圳市代禾铖电子有限公司 精密金属膜电阻器 METAL FILM RESISTORS 5. Humidity Load Life ±1% Max/1000Hours 6. Load Life ±1% Max /1000Hours 7. 编号 DHC-R-01 版本 A 页次 第 4 页 共 7 页 Resistance change after 1000 hours ( 1.5 hours on 0.5 hours off)at rated continuous working voltage in a humidity chamber controlled at 40 ± 2 ℃ and 90~95% relative humidity . Permanent resistance change after 1000 hours operating at rated continuous working voltage with a duly cycle of 1.5 hours on 0.5 hours off at 70 ± 2℃ ambient . Resistance change after continuous five cycles for duty cycle Temperature Cycling ±1% Max with no evidence as specified below. of mechanical damage Step Temperature Characteristics Standard Time 1 -30℃ 30 Minutes 2 +25℃ 10~15 Minutes 3 +85℃ 30 Minutes 4 +25℃ 10~15 Minutes Test Methods 8. Short Time Overload Δ R/R at ±0.5% Max. with no evidence of arcing burning, or charring Permanent resistance change after the application of a potential of 2.5 times rated continuous working voltage for 5 seconds at room temperature. No evidence of mechanical damage or loosening terminals Direct load resistance to 2.5kg direct load 30±5 seconds twist test, for axial leads unit only. Terminal lead shall be bent through at a right angle at a point of 6.35mm from the body edge of resistor and shall be rotated through at a right angle about the original axis of the bent terminal in alternating direction for a total 3 rotations. 9. Terminal Strength 3. Marking ISO9001:2015 ROHS&REACH 4 深圳市代禾铖电子有限公司 精密金属膜电阻器 METAL FILM RESISTORS 编号 DHC-R-01 版本 A 页次 第 5 页 共 7 页 4.Taping Dimension Type W±1.0 P±0.5 T±0.5 L1-L2 S t Z T52 52 5 6 1.0 Max 3.2 Min 0.8 Max 1.2 Max ISO9001:2015 ROHS&REACH 5 深圳市代禾铖电子有限公司 精密金属膜电阻器 METAL FILM RESISTORS 编号 DHC-R-01 版本 A 页次 第 6 页 共 7 页 F Type: 5.Packing Taping Type: Unit:mm/pcs Type T52 Watts 1/6W / 1/8W 1/4WS 1/4W/ 1/2WS 1/2W/ 1WS 1/16W A B C Q’ty 76 70 255 5000 76 100 255 5000 76 57 255 1000 ISO9001:2015 ROHS&REACH 6 深圳市代禾铖电子有限公司 精密金属膜电阻器 METAL FILM RESISTORS 编号 DHC-R-01 版本 A 页次 第 7 页 共 7 页 Bulk Type: Unit:mm Watts A B C 1/8W,1/4W,1/2W 125 75 243 1W,2W,3W,5W 50 100 255 6.Part Number MF - 0207 - F - 1000 - F 1 3 - 5 - 2 1. Type 2. Power/Size 3. Tolerance 4. Value 5. Shape - 4 - MF = Metal Film Resistor MFC = Metal Film Resistor and Lead Wire used Tinned copper Wire Type Power 0204 1/8W Code % R15 Value 0.15Ω Type 0207 1/4W 1/4W F ±1% E96 Code 0207s 1R54 1.54Ω T Taping P P Type 0410S 1/2W 0410 …… 1/2W …… D ±0.5% 1540 0925 5W B ±0.1% 1541 1542 1543 154Ω 1.54KΩ 15.4KΩ 154KΩ M MB MK F M forming MB forming MK forming F forming 1544 1.54MΩ 1545 1546 15.4MΩ 154MΩ FK1 FK2 FKK FK1 forming FK2 forming FKK forming ISO9001:2015 ROHS&REACH 7
MF0207F10R0BLU040 价格&库存
很抱歉,暂时无法提供与“MF0207F10R0BLU040”相匹配的价格&库存,您可以联系我们找货
