CD288H1V221T
CD288H1V221T
    CH(创慧电子)
    插件,D8xL12mm
    直插铝电解电容 AEC_D8X12MM_TM 220µF -10~+20% Ф8.00 x 12.00mm 35V
CD288H1V221T 数据手册
物料承认书 RoHS APPROVAL SHEET 档案编号: 客户名称: Customer Name: 华秋电子 供应商 东莞市创慧电子有限公司 公司地址 东莞市谢岗镇金川工业区 物料名称 铝电解电容器 物料名称 铝电解电容器 物料编码 CD288H1V221T 物料品牌 CH 物料规格 35V220uF 供方电话 0769-87633398 物料尺寸 D8X12L 供方传真 0769-87633399 物料规格书 : N Y ROHS检测报告: N Y 样品测试报告: N Y IQC样品: N Y 附件 新机型物料 物料变更 增加/变更供应商 其它: 备注 客户确认栏 批准 Approver 审核 Checker 制作 Engineer 盖章 日期: 供应商确认栏 批准 Approver 审核 Checker 制作 Engineer 刘劲松 魏小容 邓瑶玲 日期: 1 of 5 盖章 2022/11/28 CH-QC-JL-019 B/0 CD288H Series Aluminum Electrolytic Capacitors Item Name Rating CD288H1V221T 35V220uF Case size D8X12L 1. Operating Temp. Range -40+105℃ 2. Electrical Characteristics See Table 1. 【Table 1】 Rated Voltage VDC Surge Voltage VDC 35 44 Nominal Dissipation Tolerance on Static Factor (tanδ) Capacitance Capacitance max 20℃ (%) 20℃ 120Hz (μF) 120Hz 220 -10%~+20% 0.12 Leakage Current 2min. 20 ℃(μA) Permissible Ripple Current (mArms) 105℃ 100KHz Impedance (Ω) 100KHz 20℃ 77 725 0.27 3. Dimensions Insulating Sleeve P±0.5 ΦD+α max. φd±0.05 Tinned copper-ply wire L+β L±max. β 15min. 4min. Safety vent (Φ8up) Rubber Bung Φ6.3 is available by Request Unit(mm) ΦD 8 α 0.5 L 12.0 β 1.0 Φd 0.5 P 3.5 4. Marking Following items are printed with golden colour on green colour sleeve Example of Marking 220μF ① 35V ① Rated Voltage & Nominal Capacitance ② Polarity (negative) ③ Trade Mark of CH ④ Product Series ⑤ Operating Temp. Range ② VENT LOWESR ③ PET ④⑤ -40+105℃ 5. MULTIPLIER FOR RIPPLE CURRENT ①. Frequency Coefficient Freq.(Hz) Cap(μF) 60(50)Hz 220 0.75 ②. Temperature Coefficient 120Hz 1KHz 10KHz 100KHz 0.9 0.95 0.98 1 Ambient Temperature(℃) 40 60 70 85 105 Coefficient 2.4 2.1 1.78 1.65 1 2 of 5 CH-QC-JL-019 B/0 6. Characteristics No. Item Performance Test Method 1 Leakage Current 2 Static Capacitance 3 Dissipation Factor (tanδ) 4 Load Life Leakage Current Cap. Change Dissipation Factor Appearance ≤the value specified in Table 1 ≤±20% of initial value ≤200% of value specified in Table 1 No remarkable abnormality Test condition: 105±2℃ 120Hz Applied voltage: Rated voltage Applied Ripple Current: 725mArms Test Time: 3000 +72, -0 hours 5 Shelf Life Leakage Current Cap. Change Dissipation Factor Appearance ≤the value specified in Table 1 ≤±20% of initial value ≤200% of value specified in Table 1 No remarkable abnormality Test Temp. : 105±2℃ No voltage applied Test Time 1000 hours +24, -0 hours 6 Terminal Strength Tensile Strength Bending Strength 7 Impedance Ratio 8 Temperature Characteristics I≤ 77μA Protection Resistor: 1000±10Ω Applied Volt: Rated Voltage Measuring time: 2 minutes -10%~+20% Measured Frequency: 120Hz±20% Measured Voltage: ≤ 0.5Vrms, 1.5 ~ 2.0VDC 0.12 and Under Same as condition of Capacitors 45N {4.5kg} 25N {2.5kg} Z(-25℃)/Z(+20℃) Z(-40℃)/Z(+20℃) Stage Item 2,3 Impedance Ratio 5 Cap. Change 2 3 Performance less than the value mentioned in 6-7 ≤±25% against value in stage 4 After the capacitor is held at temperature of each stage and reaches temperature stability, measure performance. 9 Surge Voltage 10 Vibration Resistance Keeping time Tensile: 1~5 sec Bending: 30±5 sec Item Leakage Current Cap, Change Dissipation Factor Appearance Performance ≤ the initial specified value ≤ ±15% against value before test ≤ the initial specified value No remarkable abnormality Capacitance Cap. Change Appearance Stability required ≤±5% of the initial specified value No remarkable abnormality Stage Test Temp(℃) 1 20±2 2 -25±3; 3 -40±3; 4 20±2 5 105±2 6 20±2 Test Temp.: 15~35℃ Test volt.: Surge Volt. Specified in 2 Voltage apply 1,000 times of charge for 30±5 sec, under frequency of 6±0.5 sec, and discharge for 5min 30sec. Frequency: 10~55Hz Width of vibration: 1.5mm Direction and duration: X,Y and Z directions, each for 2 hours 11 Solderbility 3/4 area of surrounding directions of surface should be covered with new solder. Solder: Sn-Ag, Sn-Cu Type Soldering Temp: 240±5℃ Dipping degree: 2~2.5mm Flux: Ethanol solution (JIS K8101) or Isopropylalchol (JIS K8839) solution of Rosin (JIS K5902) 12 Resistance to Soldering Leakage Current Cap, Change Dissipation Factor Appearance ≤ the initial specified value ≤ ±15% against value before test ≤ the initial specified value No remarkable abnormality 3 of 5 Soldering Temp. 280±5℃ Soldering Time . 10±1sec. CH-QC-JL-019 B/0 6-2. Characteristics No. Item Performance 13 Resistance to Humidity Leakage Current Cap. Change Dissipation Factor Appearance 14 Pressure valve moment characteristics 7. Test Method ≤ Initial specified value ≤±15% of initial value ≤ Initial specified value No remarkable abnormality Pressure valve open safely. There must be nothing ignition or scattering from product. Test Temp. : 40±2℃ Humidity 90~95% Test Time : 500 ± 8 hours After the above condition, restored to normal temp, and then measured. DC method: Apply an reverse current of 1A to impress the reverse voltage until pressure valve open. Packing method Packaging shape, size, quantity H W 8 9 Component size Quantity per case Symbol of box L H W D8X12L PCS Y-2 480 320 320 L Related Standards: JIS C 5141 Marking on packing box ① Item name ② Series name ③ Rated Voltage ④ Nominal Static Capacitance ⑤ Case size ⑥ Lot No. ⑦ Quantity 10 Soldering 10-1 Soldering by soldering iron Temperature of iron top : 270~350℃ Operating time : within 3 sec. 10-2 Flow soldering. Preheat : PCB surface temperature 120℃±5℃ Solder temp.: 260℃±5℃ Solder dipping time: 2~4sec. 11 Cleaning of PC board after soldering Some solvents is acceptable but make sure following condition: Solvent: IPA or Alcoholic agent like Pinealpha ST-100S, Cleanthrough 750H, 750L, 710M, 750K, or Technocare FRW-14~17 ① Cleaning should be made by ultrasonic within 5min, at the temperature less then 60℃. ② Control of pollution is necessary. ③ Keep away from cleaning agent. Please do not store in air-tight container. Dry it by hot air, keep the temperature of air less than maximum operating temp. 4 of 5 CH-QC-JL-019 B/0 东莞市创慧电子有限公司 DongGuan ChuangHui electronics Co.,Ltd. TEST DATA SHEET OF ELECTROLYTIC CAPACITORS (检测数据表) DATE (日期): 2022/11/28 CUSTOMER (客户): RATINGS 华秋电子 (规格): LEAD PITCH (脚距): Item QUANTITY (数 量): BRAND/SERIES (商标 / 系列): 35V220uF CASE SIZE (尺 寸): 3.5 ±0.5mm LEAD DIA. (引 线 直 径): 15 PCS CH CD288H D8X12L 0.5 ±0.05mm Max. Ripple Capacitance Max. Tanδ Max. Leakage Max. Current (mArms) Working Tolerance at at 120Hz Current (μA) Impedance (Ω) at 100KHz 105 Temp. (℃) after 2 min. at 100KHz 20℃ 120Hz 20℃ 20℃ ℃ Spec -10%~+20% 12% 77.0 0.27 No. Capcitance (μF) Tanδ (%) Leakage Current(μA) Impedance (Ω) 1 217.6 3.9 7.6 0.0912 2 213.7 3.7 8.4 0.0856 3 218.4 3.7 6.8 0.0928 4 218.3 3.9 8.5 0.0904 5 215.9 3.8 5.8 0.089 6 218.3 3.8 6.1 0.0906 7 215.4 3.9 5.7 0.0877 8 216.8 3.9 6.3 0.0935 9 214.8 3.9 6.7 0.0844 10 219.4 3.8 5.7 0.0879 MIN. 213.7 3.7 5.7 0.044 MAX. 219.4 3.9 8.5 0.0935 AVE. 216.9 3.8 6.8 0.069 核准 刘劲松 审核 魏小容 5 of 5 725 Surge Volt. (V) -40+105℃ 44 Remarks 制作 邓瑶玲 CH-QC-JL-019 B/0
CD288H1V221T 价格&库存
很抱歉,暂时无法提供与“CD288H1V221T”相匹配的价格&库存,您可以联系我们找货
