NO.68 Huangjiang Donghuan Road,Huangjiang Town,Dongguan City,Guangdong Province,China
TEL :+86(0)769-38879888 Fax :+86(0)769-38879889 E-mail : yl@dgylec.com
PRODUCT SPECIFICATION SHEET
CUSTOMER
PRODUCT TYPE
: OSC 2.5X2.0 (4PAD)
NOMINAL FREQ.
: 24.000000 MHz
FL P/N
: 2C24000012-Q
REVISION
: S0
CUSTOMER P/N
PREPARED
CUSTOMER'S APPROVAL&DATE
PREPPR
PREP
P PR
PREP
QA
QA QA
PREP
QAQA
QAQA
QA
APPROVED
PREP
FL CORPORATION
APPROVED
Jay Lee
CHECKED
QA
DESIGNED
QA
APPRO
Jin Ji
QiPREP
VED
QA
APPROVED
QA
APPROVED
REPA
PREP
QA
QA
QA
QA
QQA
QA
Q
AA Huang HuiFang
Huang
Ning
MSL1
RoHS Compliant
TEL : (02)2894-1202
FAX : (02)2894-1206
FL P/N:
2C24000012-Q
VER:
CONTENTS
S0
PAGE
‧ SPECIFICATION REVISION RECORD SHEET
2
‧ ELECTRICAL SPECIFICATIONS
3
‧ DIMENSIONS & MARKING
4
‧ STRUCTURE ILLUSTRATION
5
‧ RELIABILITY TEST SPECIFICATIONS
6
‧ PACKAGING REQUIREMENT
7/8
‧ SPECIFICATION OF THE ENVIRONMENT-RELATED SUBSTANCES
9
ATTACHMENT(optional)
‧ ELECTRICAL CHARACTERISTICS TEST
A
YES
NO
‧ TEMPERATURE CHARACTERISTICS TEST
B
YES
NO
PAGE:
1/9
TEL : +86(0)769-38879888 FL P/N:
FAX : 86(0)769-38879889
VER:
2C24000012-Q
S0
PAGE:
2/9
Rev.
Revise page
S0
N/A
Revise Contents
Initial released
Date
Ref. No.
Reviser
16-May-22
N/A
Huang HuiFang
TEL : (02)2894-1202
FAX : (02)2894-1206
FL P/N:
VER:
2C24000012-Q
S0
PAGE:
Standard atmospheric conditions
Unless otherwise specified. The standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :25±2℃
Relative humidity :40%~70%
If there is no doubt the results, measurement shall be made within the following limits:
Relative humidity : 40%~70%
Measure equipment
Electrical characteristics measured by S&A 280A or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode)
Parameters
Symbol
Electrical Spec.
UNITS
Nominal Frequency
FL
24.000000
MHz
Operating Temperature
TOPR
-40 ~ +85
The Total Frequency Offset
+/-25
ppm
Output Load
CL
15.0
pF
Max
Supply Voltage
VDD
1.8
V
“0”Level
VOL
VDD×0.1
V
Max
“1”Level
VOH
VDD×0.9
V
Min
Enable High Voltage
ELH
VDD×0.7
V
Min.
Enable Low Voltage
ELL
VDD×0.3
V
Max.
Symmetry of Wave Form
Symmetry
45~55%
Current Consumption
IDD
10.0
mA
Max
Rise and Fall Time
Tr,Tf
10.0
nSec
Max
Start time
tosc
10.0
mSec
Max
Aging
+/-5
ppm
1st Year
Storage Temperature Range
-55~ +125
CMOS
HBM>2000V
Level 1
JESD22-A114-B
IPC/JEDEC J-STD-033C
Output waveform
ESD
MSL
Notes
3/9
FL P/N:
VER:
2C24000012-Q
S0
DIMENSIONS
Enable Control
Pad 1 Input
Pad 3 Output
Level High or Open
Normal Operation
Level Low
Stopped
MARKING
Frequency
Ex:240=24.000MHz
Y L 2 4 0
Lot (2 digits)
Year Month Code
Administrative Symbo
SUGGESTED REFLOW PROFILE
Total time : 360 sec. Max.
Solder melting point :185 oC
PAGE:
4/9
FL P/N:
VER:
2C24000012-Q
S0
PAGE:
NO
COMPONENTS
MATERIALS
QTY
FINISH/SPECIFICATIONS
1
Cap (Lid)
Metal (Fe)
1
2
Base (Package)
Ceramic (AI2O3)
1
Alumina ceramics
3
Pad (Package)
Au
4
Tungsten metalize
+Ni plating
+Au plating
4
Crystal blank
SiO2
1
5
Conductive adhesive
Ag
4
Silicone resin
6
Electrode
Noble metal
2
7
IC
Silicon (Si)
1
5/9
TEL : (02)2894-1202
FAX : (02)2894-1206
FL P/N:
VER:
2C24000012-Q
S0
PAGE:
6/9
RELIABILITY SPECIFICATIONS
1.MECHANICAL ENDURANCE
No. Test Item
1 Drop Test
2 Mechanical Shock
3 Vibration
Test Methods
150 cm height, fall freely onto stainless plate 3 times.
Device are shocked to half sine wave ( 1000 G ) three mutually
pendicular axes each 3 times. 1.0m sec. duration time
Frequency range
10 ~ 55 Hz
Amplitude
1.52 mm
Pendicular axes each test time 2 hours(x,y,z Axis)
JIS C6701
MIL-STD-202F
MIL-STD-883E
Total test time 6 hours
4 Solderability
Temperature
260oC +/- 5 oC , 5 +/-1 sec
Immersing depth
0.5 mm minimum
Immersion time
10 +/- 0.5 seconds
Flux
Rosin resin methyl alcohol
MIL-STD-883E
solvent ( 1 : 4 )
5
Resistance To
Soldering Heat
Pre-heat temperature
125 oC
Pre-heat time
60 ~ 120 sec.
Test temperature
260 +/- 5 oC
Test time
5 +/- 1 sec.
MIL-STD-202F
*Storage conditions :18 months
*Constant humidity :40~70%
2.ENVIRONMENTAL ENDURANCE
No. Test Item
Test Methods
6 High Temp. Storage
+ 125 oC +/- 3 oC for 500 +/- 12 hours
7 Low Temp. Storage
- 40 oC +/- 3 oC for 500 +/- 12 hours
MIL-STD-883E
Total 100 cycles of the following temperature cycle
1 cycle
125+/- 3 oC
8 Thermal Shock
MIL-STD-883E
25 oC
-55+/- 3
o
C
30 min.
30 min.
10 min. max.
9 High Temp. Operation + 85oC, VCC, for 1000 hours
10 Low Temp. Operation - 40oC, VCC, for 1000 hours
MIL-STD-883E
MIL-STD-883E
VER:
PACKING :
8mm-4mm,3000pcs / reel,φ 178;
2C24000012-Q
S0
PAGE:
7/9
FL P/N:
VER:
2C24000012-Q
S0
PAGE:
8/9
SMD PRODUCT PACKING STANDARD
Out-going packing instruction
Reel Packing
standard:diameter 18cm
material:plastics
name:Anti-Static Shielding Bag
standard:205×250mm
material:APET/CPP
Inner Packing
name:Anti-Static Bubble Bags
standard:430x330+20mm
material:HDPE(15 reels enter)
Carton
standard:400x400x280mm
material:AB corrugated paper (60
boxes enter)
L1
L2
L1
L1
The label instruction
Label Drawing
Mark Name of Article
Spec.
Size
Printing
L1
条码标签
Bar Code
Label
(Chintz Paper)
1.Part No.
2.Lot No.
3.Q'ty
4.Freq
70x50mm White
L2
条码标签
Bar Code
Label
(Chintz Paper)
1.Part No.
2.Date Code
3.Q'ty
4.Freq
70x50mm White
Remark
Specifications on the label is for the use of templates with different product specifications may vary.
If customer specified requirements for labels packaging. please provide the operation procedure.
FL P/N:
VER:
2C24000012-Q
S0
PAGE:
9/9
Range
Products
Packing Material
Banned Substances
Maximum concentration ppm(mg/kg)
ppm(mg/kg)
1.镉及镉化合物
Cadmium and cadmium compounds
100
100
2.铅及铅化合物
Lead and lead compounds
1000
100
3.汞及汞化合物
Mercury and mercury compounds
1000
100
4.六价铬化合物
Hexavalent-Chromium VI (Cr+6)
1000
100
5.聚溴联苯 PBB
Polybrominated biphenyls
1000
N/A
6.聚溴二苯醚 PBDE
Polybrominated diphenyl ethers
1000
N/A
7.邻苯二甲酸二(2-乙基己基)酯 DEHP
Di (2-ethylhexyl) phthalate
1000
N/A
8.邻苯二甲酸丁苄酯 BBP
Butyl Benzyl Phthalate
1000
N/A
9.邻苯二甲酸二丁酯 DBP
Dibutyl Phthalate
1000
N/A
10 邻苯二甲酸二异丁酯 DIBP
Diisobutyl Phthalate
1000
N/A
900、900、900、900
注:Br+Cl<1000
N/A
N/A
100
铅(Pb) + 镉(Cd) + 汞(Hg) + 六价铬
(Cr+6)
很抱歉,暂时无法提供与“2C24000012-Q”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.29500
- 30+2.21850
- 100+2.06550
- 500+1.91250
- 1000+1.83600
