2C19200001-Q
2C19200001-Q
    YL(惠伦晶体)
    SMD2520_4P
    有源晶振 19.2MHz 1.8V ±30ppm SMD2520_4P
2C19200001-Q 数据手册
NO.68 Huangjiang Donghuan Road,Huangjiang Town,Dongguan City,Guangdong Province,China TEL :+86(0)769-38879888 Fax :+86(0)769-38879889 E-mail : yl@dgylec.com PRODUCT SPECIFICATION SHEET CUSTOMER : PRODUCT TYPE : OSC 2.5X2.0 (4PAD) NOMINAL FREQ. : 19.200000 MHz FL P/N : 2C19200001-Q REVISION : S1 CUSTOMER P/N : PREPARED CUSTOMER'S APPROVAL&DATE PREP P PR PREP QA QA QA PREP QAQA QAQA QA APPROVED PREP FL CORPORATION APPROVED Xing Yue CHECKED QA DESIGNED QA APPRO Jin Ji QiPREP VED QA APPROVED QA APPROVED REPA PREP QAQA QA QA QA QAQA QA QQA QA Q AA Chen XuanRu Huang Ning MSL1 RoHS Compliant TEL : (02)2894-1202 FAX : (02)2894-1206 FL P/N: 2C19200001-Q VER: CONTENTS S1 PAGE ‧ SPECIFICATION REVISION RECORD SHEET 2 ‧ ELECTRICAL SPECIFICATIONS 3 ‧ DIMENSIONS & MARKING 4 ‧ STRUCTURE ILLUSTRATION 5 ‧ RELIABILITY TEST SPECIFICATIONS 6 ‧ PACKAGING REQUIREMENT 7/8 ‧ SPECIFICATION OF THE ENVIRONMENT-RELATED SUBSTANCES 9 ATTACHMENT(optional) ‧ ELECTRICAL CHARACTERISTICS TEST A YES NO ‧ TEMPERATURE CHARACTERISTICS TEST B YES NO PAGE: 1/9 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: 2C19200001-Q S1 PAGE: 2/9 SPECIFICATION REVISION RECORD SHEET Rev. Revise page S0 N/A S1 P.3、P.4 Revise Contents Date Ref. No. Reviser Initial released 24-Aug-21 N/A Han Shuang P.3 Add ESD & MSL; P.4 change marking. 25-Mar-22 N/A Chen XuanRu TEL : (02)2894-1202 FAX : (02)2894-1206 FL P/N: VER: 2C19200001-Q S1 PAGE: ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified. The standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature :25±2℃ Relative humidity :40%~70% If there is no doubt the results, measurement shall be made within the following limits: Ambient temperature :25±2℃ Relative humidity : 40%~70% Measure equipment Electrical characteristics measured by S&A 280A or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode) ELECTRICAL SPECIFICATIONS Parameters Symbol Electrical Spec. UNITS Nominal Frequency FL 19.200000 MHz - Operating Temperature TOPR -40 ~ +85 ℃ - Temperature Frequency Offset - +/-30 ppm - Output Load CL 15.0 pF Max Supply Voltage VDD 1.8 V - “0”Level VOL VDD×0.1 V Max “1”Level VOH VDD×0.9 V Min Enable High Voltage ELH VDD×0.7 V Min. Enable Low Voltage ELL VDD×0.3 V Max. Symmetry of Wave Form Symmetry 45~55% Current Consumption IDD 10.0 mA Max Rise and Fall Time Tr,Tf 10.0 nSec Max Start time tosc 10.0 mSec Max Aging - +/-5 ppm 1st Year Storage Temperature Range - -55 ~ +125 ℃ - - CMOS HBM>2000V 1级 - JESD22-A114-B IPC/JEDEC J-STD-033C Output waveform ESD MSL Notes - 3/9 TEL : +86(0)769-38879888 FAX : 86(0)769-38879889 FL P/N: VER: 2C19200001-Q S1 DIMENSIONS Enable Control Pad 1 Input Pad 3 Output Level High or Open Normal Operation Level Low Stopped MARKING Frequency Ex:192=19.200MHz Y L 1 9 2 ● Lot (2 digits) Year Month Code Administrative Symbo SUGGESTED REFLOW PROFILE Total time : 360 sec. Max. Solder melting point :185 oC PAGE: 4/9 TEL : +86(0)769-38879888 FAX : 86(0)769-38879889 FL P/N: VER: 2C19200001-Q S1 PAGE: STRUCTURE ILLUSTRATION NO COMPONENTS MATERIALS QTY FINISH/SPECIFICATIONS 1 Cap (Lid) Metal (Fe) 1 - 2 Base (Package) Ceramic (AI2O3) 1 Alumina ceramics 3 Pad (Package) Au 4 Tungsten metalize +Ni plating +Au plating 4 Crystal blank SiO2 1 - 5 Conductive adhesive Ag 4 Silicone resin 6 Electrode Noble metal 2 - 7 IC Silicon (Si) 1 - 5/9 TEL : (02)2894-1202 FAX : (02)2894-1206 FL P/N: VER: 2C19200001-Q S1 PAGE: 6/9 RELIABILITY SPECIFICATIONS 1.MECHANICAL ENDURANCE No. Test Item 1 Drop Test 2 Mechanical Shock 3 Vibration Test Methods 150 cm height, fall freely onto stainless plate 3 times. Device are shocked to half sine wave ( 1000 G ) three mutually pendicular axes each 3 times. 1.0m sec. duration time Frequency range 10 ~ 55 Hz Amplitude 1.52 mm Pendicular axes each test time 2 hours(x,y,z Axis) JIS C6701 MIL-STD-202F MIL-STD-883E Total test time 6 hours 4 Solderability Temperature 260oC +/- 5 oC , 5 +/-1 sec Immersing depth 0.5 mm minimum Immersion time 10 +/- 0.5 seconds Flux Rosin resin methyl alcohol MIL-STD-883E solvent ( 1 : 4 ) 5 Resistance To Soldering Heat Pre-heat temperature 125 oC Pre-heat time 60 ~ 120 sec. Test temperature 260 +/- 5 oC Test time 5 +/- 1 sec. MIL-STD-202F 2.ENVIRONMENTAL ENDURANCE No. Test Item Test Methods 6 High Temp. Storage + 125 oC +/- 3 oC for 500 +/- 12 hours 7 Low Temp. Storage - 40 oC +/- 3 oC for 500 +/- 12 hours MIL-STD-883E Total 100 cycles of the following temperature cycle 1 cycle 125+/- 3 oC 8 Thermal Shock MIL-STD-883E 25 oC -55+/- 3 o C 30 min. 30 min. 10 min. max. 9 High Temp. Operation + 85oC, VCC, for 1000 hours 10 Low Temp. Operation - 40oC, VCC, for 1000 hours MIL-STD-883E MIL-STD-883E TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: PACKING : 8mm-4mm,3000pcs / reel,φ 178; 2C19200001-Q S1 PAGE: 7/9 TEL : +86(0)769-38879888 FAX : 86(0)769-38879889 FL P/N: VER: 2C19200001-Q S1 PAGE: 8/9 SMD PRODUCT PACKING STANDARD Out-going packing instruction Reel Packing name:reel standard:diameter 18cm material:plastics name:Anti-Static Shielding Bag standard:205×250mm material:APET/CPP Inner Packing name:Anti-Static Bubble Bags standard:430x330+20mm material:HDPE(15 reels enter) Carton name:carton standard:400x400x280mm material:AB corrugated paper (60 boxes enter) L1 L2 L1 L1 The label instruction Label Drawing Mark Name of Article Spec. Size Printing L1 条码标签 Bar Code Label (Chintz Paper) 1.Part No. 2.Lot No. 3.Q'ty 4.Freq 70x50mm White L2 条码标签 Bar Code Label (Chintz Paper) 1.Part No. 2.Date Code 3.Q'ty 4.Freq 70x50mm White Remark Specifications on the label is for the use of templates with different product specifications may vary. If customer specified requirements for labels packaging. please provide the operation procedure. TEL : +86(0)769-38879888 FAX : 86(0)769-38879889 FL P/N: VER: 2C19200001-Q S1 PAGE: 9/9 Range Products Packing Material Banned Substances Maximum concentration ppm(mg/kg) Maximum concentration ppm(mg/kg) 1.镉及镉化合物 Cadmium and cadmium compounds 100 100 2.铅及铅化合物 Lead and lead compounds 1000 100 3.汞及汞化合物 Mercury and mercury compounds 1000 100 4.六价铬化合物 Hexavalent-Chromium VI (Cr+6) 1000 100 5.聚溴联苯 PBB Polybrominated biphenyls 1000 N/A 6.聚溴二苯醚 PBDE Polybrominated diphenyl ethers 1000 N/A 7.邻苯二甲酸二(2-乙基己基)酯 DEHP Di (2-ethylhexyl) phthalate 1000 N/A 8.邻苯二甲酸丁苄酯 BBP Butyl Benzyl Phthalate 1000 N/A 9.邻苯二甲酸二丁酯 DBP Dibutyl Phthalate 1000 N/A 10 邻苯二甲酸二异丁酯 DIBP Diisobutyl Phthalate 1000 N/A 900、900、900、900 注:Br+Cl<1000 N/A N/A 100 铅(Pb) + 镉(Cd) + 汞(Hg) + 六价铬 (Cr+6)
2C19200001-Q 价格&库存
很抱歉,暂时无法提供与“2C19200001-Q”相匹配的价格&库存,您可以联系我们找货
2C19200001-Q
  • 1+2.29500
  • 30+2.21850
  • 100+2.06550
  • 500+1.91250
  • 1000+1.83600
