NO.68 Huangjiang Donghuan Road,Huangjiang Town,Dongguan City,Guangdong Province,China
TEL :+86(0)769-38879888 Fax :+86(0)769-38879889 E-mail : yl@dgylec.com
PRODUCT SPECIFICATION SHEET
CUSTOMER
PRODUCT TYPE
: SMD TUNING FORK 7.0X1.5
NOMINAL FREQ.
: 32.768000 KHz
FL P/N
: 7PSQ327008-Q
REVISION
: S0
CUSTOMER P/N
CUSTOMER'S APPROVAL&DATE
FL CORPORATION
APPROVED
CHECKED
DESIGNED
Xing Yue
Jin Qi
Li Xiang
MSL1
RoHS Compliant
7PSQ327008-Q
TEL : +86(0)769-38879888 FL P/N:
FAX : 86(0)769-38879889
VER:
CONTENTS
S0
PAGE
‧ SPECIFICATION REVISION RECORD SHEET
2
‧ ELECTRICAL SPECIFICATIONS
3
‧ DIMENSIONS
4
‧ RELIABILITY TEST SPECIFICATIONS
5
‧ PARKING
6
‧ SPECIFICATION OF THE ENVIRONMENT-RELATED SUBSTANCES
7
ATTACHMENT(optional)
‧ ELECTRICAL CHARACTERISTICS TEST
A
YES
NO
‧ TEMPERATURE CHARACTERISTICS TEST
B
YES
NO
PAGE:
1/7
VER:
7PSQ327008-Q
S0
PAGE:
Rev.
Revise page
S0
N/A
Revise Contents
Initial released
Date
Ref. No.
Reviser
11-Jul-22
N/A
Li Xiang
2/7
FL P/N:
7PSQ327008-Q
S0
VER:
PAGE:
PRODUCT DESCRIPION
Standard atmospheric conditions
Unless otherwise specified. The standard range of atmospheric conditions for making measurement
and tests are as follow:
25±2℃
Ambient temperature :
40%~70%
Relative humidity :
If there is no doubt the results, measurement shall be made within the following limits:
25±2℃
40%~70%
Relative humidity :
Measure equipment
Electrical characteristics measured by S&A250B or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode)
Electrical Spec.
No.
Items
Remarks
Symbol
Min
Typ
Max
Units
1 Nominal Frequency
FL
32.768000
KHz
2 Load Capacitance
CL
7.0
pF
3 Frequency Tolerance
±20
ppm
at 25±3℃
4 Quality Factor
Q
40000
5 Turnover Temperature
30
6 Freq. vs Temp. Coefficient
-0.035±0.01
at 25±5℃
ppm/℃2
7 Shunt Capacitance
C0
0.8
pF
8 Motional Capacitance
C1
1.9
fF
ppm/year
at 25±2℃
9 Aging (/1 year)
10 Operating Temperature
-40
85
11 Storage Temperature
Equivalent series
12
resistance
-55
125
ESR
65
kΩ
IR
500
M-ohms
at DC 100V
13 Insulation Resistance
±3
14 ESD
15 MSL
16 Drive Level
DL
HBM>2000V
JESD22-A114-B
Level 1
IPC/JEDEC J-STD033C
0.1
1.0
uW
3/7
VER:
DIMENSIONS unit:mm
MARKING
*1
*2
*3
*4
Frequency
Specification
Year of Production
(Last digit of year)
Week of Production
(01~52)
7PSQ327008-Q
S0
PAGE:
4/7
VER:
7PSQ327008-Q
S0
PAGE:
5/7
RELIABILITY SPECIFICATIONS
1.MECHANICAL ENDURANCE
Test Item
No.
1 Drop Test
2 Mechanical Shock
3 Vibration
Test Methods
150 cm height, fall freely onto stainless plate 3 times.
Device are shocked to half sine wave ( 1000 G ) three mutually
pendicular axes each 3 times. 1.0m sec. duration time
Frequency range
10 ~ 55 Hz
Amplitude
1.52 mm
Pendicular axes each test time 2 hours(x,y,z Axis)
Total test time 6 hours
Immersing depth
260 oC ±5 oC
0.5 mm minimum
Immersion time
5 ± 1 seconds
Flux
Rosin resin methyl alcohol
Temperature
4 Solderability
solvent ( 1 : 4 )
Pre-heat temperature
5
Resistance To
Soldering Heat
Pre-heat time
125 oC
60 ~ 120 sec.
260 +/- 5 oC
5 +/- 1 sec.
Test temperature
Test time
JIS C6701
MIL-STD-202F
MIL-STD-883E
GB/T 2424.172008 / IEC
60068-244:1995;
GB/T 2423.282005 / IEC
60068-220:1979
MIL-STD-202F
*Storage conditions :18 months
*Constant humidity :40~70%
2.ENVIRONMENTAL ENDURANCE
Test Item
No.
6 High Temp. Storage
7 Low Temp. Storage
o
Test Methods
o
+ 125 C +/- 3 C for 500 +/- 12 hours
- 40 oC +/- 3 oC for 500 +/- 12 hours
Total 100 cycles of the following temperature cycle
MIL-STD-883E
1 cycle
125+/- 3 oC
8 Thermal Shock
MIL-STD-883E
25 oC
-55+/- 3
o
C
30 min.
30 min.
10 min. max.
9 High Temp&Homidity
85℃±3℃, RH 85%,500Hrs
JIS C5023
FL P/N:
VER:
7PSQ327008-Q
S0
PAGE:
PACKING :
Taping specification
Subject to EIA-481 & IEC-60286
1、 Tape dimensions TE1604L
Material of the Carrier Tape : PS
Material of the Top Tape : PET+PE
Unit: mm
2、Reel dimensions
Material of the Reel : PS
Unit: mm
6/7
FL P/N:
VER:
7PSQ327008-Q
S0
PAGE:
7/7
Range
Products
Packing Material
Banned Substances
Maximum concentration
ppm(mg/kg)
ppm(mg/kg)
1.镉及镉化合物
Cadmium and cadmium compounds
100
100
2.铅及铅化合物
Lead and lead compounds
1000
100
3.汞及汞化合物
Mercury and mercury compounds
1000
100
4.六价铬化合物
Hexavalent-Chromium VI (Cr+6)
1000
100
5.聚溴联苯 PBB
Polybrominated biphenyls
1000
N/A
6.聚溴二苯醚 PBDE
Polybrominated diphenyl ethers
1000
N/A
7.邻苯二甲酸二(2-乙基己基)酯 DEHP
Di (2-ethylhexyl) phthalate
1000
N/A
8.邻苯二甲酸丁苄酯 BBP
Butyl Benzyl Phthalate
1000
N/A
9.邻苯二甲酸二丁酯 DBP
Dibutyl Phthalate
1000
N/A
10 邻苯二甲酸二异丁酯 DIBP
Diisobutyl Phthalate
1000
N/A
11. 氟(F)、氯(Cl)、溴(Br)、碘
(I)
Fluorine、Chlorine、 Bromine、Iodine
900、900、900、900
注:Br+Cl<1000
N/A
12.包装材料中重金属(汞、镉、六价铬、
铅、PBB、PBDE)之总量
Heavy metals (mercury, cadmium, lead,
Cr+6,PBB and PBDE) in packing
materials
N/A
100
铅(Pb) + 镉(Cd) + 汞(Hg) + 六价铬
(Cr+6)
很抱歉,暂时无法提供与“7PSQ327008-Q”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.78210
- 100+0.73260
- 300+0.68310
- 500+0.63360
- 2000+0.60885
- 5000+0.59400
