NO.68 Huangjiang Donghuan Road,Huangjiang Town,Dongguan City,Guangdong Province,China
TEL :+86(0)769-38879888 Fax :+86(0)769-38879889 E-mail : yl@dgylec.com
PRODUCT SPECIFICATION SHEET
CUSTOMER
PRODUCT TYPE
: SMD TUNING FORK 7.0X1.5
NOMINAL FREQ.
: 32.768000KHz
FL P/N
: 7PSQ327002-Q
REVISION
: A0
CUSTOMER P/N
CUSTOMER'S APPROVAL&DATE
FL CORPORATION
APPROVED
CHECKED
DESIGNED
Jay Lee
Jin Qi
Chen XuanRu
MSL 1
RoHS Compliant
7PSQ327002-Q
TEL : +86(0)769-38879888 FL P/N:
FAX : 86(0)769-38879889
VER:
CONTENTS
A0
PAGE
‧ ELECTRICAL SPECIFICATIONS & ENVIRONMENTAL
2
‧ DIMENSIONS & MARKING
3
‧ REFLOW PROFILE
4
‧ PACKAGING REQUIREMENT
5/6
ATTACHMENT(optional)
‧ ELECTRICAL CHARACTERISTICS TEST
A
YES
NO
‧ TEMPERATURE CHARACTERISTICS TEST
B
YES
NO
PAGE:
1/6
TEL : +86(0)769-38879888 YL P/N:
VER:
PARAMETER
NOMINAL FREQUENCY
FREQUENCY TOLERANCE AT 25°C
TURNOVER TEMPERATURE
TEMPERATURE CONSTANT
LOAD CAPACITANCE
EQUIVALENT SERIES RESISTANCE
DRIVE LEVEL
SHUNT CAPACITANCE
AGING
OPERATING TEMPERATURE RANGE
STORAGE TEMPERATURE RANGE
ENVIRONMENTAL
PARAMETER
MOISTURE SENSITIVITY LEVEL
RoHS-2
VALUE
32.768 kHz
±20 PPM MAX
25°C ± 5°C
-0.035±0.008 PPM/°C2
12.5 pF
55 kΩ MAX
1 μW MAXIMUM
1.5 pF MAXIMUM
±5 PPM PER YEAR MAXIMUM
-40°C to +85°C EXTENDED
-55°C to +125°C
VALUE
1
5/6 COMPLIANT, EXEMPTION 7a
REACH SVHC
COMPLIANT
HALOGEN-FREE
COMPLIANT
ESD CLASSIFICATION LEVEL
N/A
TERMINATION FINISH
Sn
7PSQ327002-Q
A0
PAGE:
2/6
VER:
DIMENSIONS
(UNIT:mm)
MARKING
*1
*2
*3
*4
Frequency
Specification
Year of Production
(Last digit of year)
Week of Production
(01~52)
7PSQ327002-Q
A0
PAGE:
3/6
VER:
REFLOW PROFILE
Reflow profile
TSMIN
125°C
Temperature Max Preheat
Time (TSMIN to TSMAX)
TSMAX
150°C
tS
30-60 sec.
Temperature
TL
217°C
Peak Temperature
TP
230°C
Ramp-up rate
RUP
3°C/s max.
Ramp-down rate
RDOWN
6°C/s max.
Time within 5°C of Peak Temperature
tP
10 s
Time t[25°C] to Peak Temperature
t[25°C] to Peak
tL
120 s
Temperature Min Preheat
Time
60-150 s
7PSQ327002-Q
A0
PAGE:
4/6
VER:
PACKING :
7PSQ327002-Q
A0
PAGE:
5/6
FL P/N:
VER:
7PSQ327002-Q
A0
PAGE:
6/6
SMD PRODUCT PACKING STANDARD
Out-going packing instruction
Reel Packing
Inner Packing
standard:diameter 18cm
standard:L19.0xW19.0xH2.5cm
material:plastics
material:B corrugated paper
Carton
standard:L34.0xW22.0xH22.0cm
material:AB corrugated paper(10
boxes enter)
L1
L1
L1
The label instruction
Label Drawing
Mark Name of Article
Spec.
L1 条码标签
1.Date Code
Bar Code
2.Lot No.
Label
3.Part No.
(Chintz Paper) 4.Freq
5.Q'ty
Size
Printing
75x35mm White
Remark
Specifications on the label is for the use of templates with different product specifications may vary.
If customer specified requirements for labels packaging. please provide the operation procedure.
很抱歉,暂时无法提供与“7PSQ327002-Q”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.78210
- 100+0.73260
- 300+0.68310
- 500+0.63360
- 2000+0.60885
- 5000+0.59400
