NO.68 Huangjiang Donghuan Road,Huangjiang Town,Dongguan City,Guangdong Province,China
TEL :+86(0)769-38879888 Fax :+86(0)769-38879889 E-mail : yl@dgylec.com
PRODUCT SPECIFICATION SHEET
CUSTOMER
PRODUCT TYPE
: SMD X'TAL 3.2*2.5(4PAD)
NOMINAL FREQ.
: 24.000000 MHz
FL P/N
: 3S24000332-Q
PREPARE
REVISION
: S1
CUSTOMER P/N
CUSTOMER'S APPROVAL&DATE
PREPPR
P PREP
QA
QA QA
PREP
QAQA
QA
APPROVED
PREP
FL CORPORATION
APPROVED
Xing Yue
CHECKED
QA
DESIGNED
QA
QA
APPROVED
QA
APPROVED
PREP
PREP
QA
QA
QA
QA
QA
QA
Jin QA
Qi
Li Xiang
MSL1
RoHS Compliant
3S24000332-Q
TEL : +86(0)769-38879888 FL P/N:
FAX : 86(0)769-38879889
VER:
CONTENTS
S1
PAGE
‧ SPECIFICATION REVISION RECORD SHEET
2
‧ ELECTRICAL SPECIFICATIONS
3
‧ DIMENSIONS & MARKING
4
‧ STRUCTURE ILLUSTRATION
5
‧ RELIABILITY TEST SPECIFICATIONS
6
‧ PACKAGING REQUIREMENT
7/8
‧ SPECIFICATION OF THE ENVIRONMENT-RELATED SUBSTANCES
9
ATTACHMENT(optional)
‧ ELECTRICAL CHARACTERISTICS TEST
A
YES
NO
‧ TEMPERATURE CHARACTERISTICS TEST
B
YES
NO
PAGE:
1/9
VER:
3S24000332-Q
S1
PAGE:
Rev.
Revise page
S0
N/A
S1
P.3
Revise Contents
Date
Ref. No.
Reviser
Initial released
25-Oct-21
N/A
May Zhang
Add ESD&MSL
25-Jul-22
N/A
Li Xiang
2/9
FL P/N:
3S24000332-Q
S1
VER:
PAGE:
PRODUCT DESCRIPION
Standard atmospheric conditions
Unless otherwise specified. The standard range of atmospheric conditions for making measurement
and tests are as follow:
25±2℃
Ambient temperature :
40%~70%
Relative humidity :
If there is no doubt the results, measurement shall be made within the following limits:
25±2℃
40%~70%
Relative humidity :
Measure equipment
Electrical characteristics measured by S&A250B or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode)
Electrical Spec.
No.
Items
Remarks
Symbol
1 Nominal Frequency
Min
Typ
Max
Units
FL
24.000000
MHz
Fundamental
CL
12.0
pF
4 Frequency Tolerance
±10
ppm
at 25±2℃
5 Frequency Stability
±20
ppm
at -40~+85℃
(reference 25℃)
6 Shunt Capacitance
C0
2 Oscillation Mode
3 Load Capacitance
3
at 25±2℃
7 Aging (/1 year)
8 Operating Temperature
-40
85
9 Storage Temperature
-40
105
ESR
50
ohms
IR
500
M-ohms
at DC 100V
JESD22-A114-B
IPC/JEDEC J-STD033C
10 Equivalent series resistance
11 Insulation Resistance
±3
pF
ppm/year
12 ESD
HBM>4000V
13 MSL
Level 1
14 Drive Level
DL
10
100
uW
3/9
VER:
DIMENSIONS unit:mm
3S24000332-Q
S1
PAGE:
CONNECTION DIAGRAM (TOP VIEW)
#3
#4
#3
#4
#1
#2
#2
#1
Pin
#1
#2
#3
#4
Function
Xtal terminal (Input)
GND terminal
Xtal terminal (Output)
GND terminal
0.7
LAND PATTERN unit:mm
MARKING
Frequency
EX: 24.000MHz = 240
YL
lot (2 digits)
year month
Administrative Symbo
SUGGESTED REFLOW PROFILE
Total time : 360 sec. Max.
Temp.
Solder melting point : 225 oC
10 sec. Max.
260 5
220
60 sec. Max.
180
150
120 sec. Max.
Time
4/9
VER:
3S24000332-Q
S1
PAGE:
NO
COMPONENTS
MATERIALS
QTY
FINISH/SPECIFICATIONS
1
Cap(Lid)
Kovar(Fe+Co+Ni)
1
Ni plating
2
Base(Package)
Almina Ceramics (AI2O3)
1
3
Pad(Package)
Ni + Au
4
Ni+Au plating
4
Crystal blank
SiO2
1
5
Conductive adhesive
Ag
2
Silicone resin
6
Electrode
Noble metal
2
5/9
VER:
3S24000332-Q
S1
PAGE:
6/9
RELIABILITY SPECIFICATIONS
1.MECHANICAL ENDURANCE
Test Item
Test Methods
No.
1 Drop Test
150 cm height, fall freely onto stainless plate 3 times.
2 Shock Test
3 Mechanical Shock
4 Vibration
5 Gross Leak
6 Fine Leak
7 Solderability
8
Resistance To
Soldering Heat
150g/150cm Height,3times in the direction of ±x, ±y, ±z on
concrete floor
JIS C6701
IEC-68-02-27
Device are shocked to half sine wave ( 1000 G ) three mutually
MIL-STD-202F
pendicular axes each 3 times. 1.0m sec. duration time
Frequency range
10 ~ 55 Hz
Amplitude
1.52 mm
MIL-STD-883E
Pendicular axes each test time 2 hours(x,y,z Axis)
Total test time 6 hours
Standard Sample For Automatic Gross Leak Detector Test
Pressure 2kg/cm2
Helium Bombing 4.5kgf/cm2 for 2 hr
MIL-STD-883E
MIL-STD-883E
o
o
Temperature
Immersing depth
Immersion time
Flux
260 C ±5 C
0.5 mm minimum
5 ± 1 seconds
Rosin resin methyl alcohol
solvent ( 1 : 4 )
Pre-heat temperature
Pre-heat time
Test temperature
Test time
125 oC
60 ~ 120 sec.
260 +/- 5 oC
5 +/- 1 sec.
GB/T 2424.172008 / IEC
60068-244:1995;
GB/T 2423.282005 / IEC
60068-220:1979
MIL-STD-202F
*Storage conditions :18 months
*Constant humidity :40~70%
2.ENVIRONMENTAL ENDURANCE
Test Item
Test Methods
No.
o
o
9 High Temp. Storage
+ 125 C +/- 3 C for 500 +/- 12 hours
10 Low Temp. Storage
- 40 oC +/- 3 oC for 500 +/- 12 hours
MIL-STD-883E
Total 100 cycles of the following temperature cycle
1 cycle
o
125+/- 3 C
25 oC
11 Thermal Shock
-55+/- 3
o
MIL-STD-883E
C
30 min.
30 min.
10 min. max.
12 High Temp&Homidity
85℃±3℃, RH 85%,500Hrs
JIS C5023
FL P/N:
VER:
3S24000332-Q
S1
PACKING :
8mm-4mm,3000pcs / reel,φ 178;
Dimension
A
1.40
±0.1
B
3.40
±0.1
C
2.70
±0.1
Dimension
L
178
L1
13
W
11.5
D
E
F
G
4.00
8.00
4.00
1.50
W1
8
Unit:mm
3000pcs / reel
H
Unit:
1.75 mm
PAGE:
7/9
FL P/N:
VER:
3S24000332-Q
S1
PAGE:
SMD PRODUCT PACKING STANDARD
Out-going packing instruction
Reel Packing
Inner Packing
standard:diameter 18cm
standard:430×330+20mm
material:plastics
material:HDPE(15 reels enter)
Carton
standard:400×400×280mm
material:AB corrugated paper(4
bags enter)
L1
L2
The label instruction
Label Drawing
Mark Name of Article
Spec.
1.Part No.
L1 条码标签
Bar Code
2.Lot No.
Label
3.Q'ty
(Chintz Paper) 4.Freq
L2
条码标签
Bar Code
Label
(Chintz Paper)
1.Part No.
2.Date Code
3.Q'ty
4.Freq
Size
Printing
70x50mm White
70x50mm White
Remark
Specifications on the label is for the use of templates with different product specifications may vary.
If customer specified requirements for labels packaging. please provide the operation procedure.
8/9
FL P/N:
VER:
3S24000332-Q
S1
PAGE:
9/9
Range
Products
Packing Material
Banned Substances
Maximum concentration
ppm(mg/kg)
ppm(mg/kg)
1.镉及镉化合物
Cadmium and cadmium compounds
100
100
2.铅及铅化合物
Lead and lead compounds
1000
100
3.汞及汞化合物
Mercury and mercury compounds
1000
100
4.六价铬化合物
Hexavalent-Chromium VI (Cr+6)
1000
100
5.聚溴联苯 PBB
Polybrominated biphenyls
1000
N/A
6.聚溴二苯醚 PBDE
Polybrominated diphenyl ethers
1000
N/A
7.邻苯二甲酸二(2-乙基己基)酯 DEHP
Di (2-ethylhexyl) phthalate
1000
N/A
8.邻苯二甲酸丁苄酯 BBP
Butyl Benzyl Phthalate
1000
N/A
9.邻苯二甲酸二丁酯 DBP
Dibutyl Phthalate
1000
N/A
10 邻苯二甲酸二异丁酯 DIBP
Diisobutyl Phthalate
1000
N/A
11. 氟(F)、氯(Cl)、溴(Br)、碘
(I)
Fluorine、Chlorine、 Bromine、Iodine
900、900、900、900
注:Br+Cl<1000
N/A
12.包装材料中重金属(汞、镉、六价铬、
铅、PBB、PBDE)之总量
Heavy metals (mercury, cadmium, lead,
Cr+6,PBB and PBDE) in packing
materials
N/A
100
铅(Pb) + 镉(Cd) + 汞(Hg) + 六价铬
(Cr+6)
很抱歉,暂时无法提供与“3S24000332-Q”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.29862
- 100+0.27972
- 300+0.26082
- 500+0.24192
- 2000+0.23247
- 5000+0.22680
