No. 68 Huangjiang Donghuan Road, Huangjiang Town, Dongguan City, Guangdong Province, China
TEL :+86(0)769-38879888 Fax :+86(0)769-38879889 E-mail : yl@dgylec.com
PRODUCT SPECIFICATION SHEET
CUSTOMER
PRODUCT TYPE
SMD TSX 2.52.0
NOMINAL FREQ.
26.000000 MHz
FL P/N
2Z26000007-Q
REVISION
A5
CUSTOMER P/N
CUSTOMER'S APPROVAL & DATE
FL CORPORATION
APPROVED
CHECKED
DESIGNED
Jay Lee
Kuro Peng
Han Shuang
MSL 1
RoHS Compliant
FL P/N
REV.
CONTENTS
2Z26000007-Q
A5
PAGE
PAGE
‧ SPECIFICATION REVISION RECORD SHEET
2
‧ ELECTRICAL SPECIFICATIONS
3 to 4
‧ CONNECTION DIAGRAM, DIMENSIONS & MARKING
5
‧ MARKING
6
‧ SUGGESTED REFLOW PROFILE
6
‧ STRUCTURE ILLUSTRATION
7
‧ RELIABILITY TEST SPECIFICATIONS
8
‧ PACKING
9 to 10
‧ SPECIFICATION OF THE ENVIRONMENT-RELATED SUBSTANCES
11
ATTACHMENT (optional)
‧ ELECTRICAL CHARACTERISTICS TEST
A
YES
NO
‧ TEMPERATURE CHARACTERISTICS TEST
B
YES
NO
1/11
FL P/N
REV.
2Z26000007-Q
A5
PAGE
2/11
Rev.
Revise Page
A0
N/A
A1
P.8, P.9
Revise Contents
Date
Ref. No.
Reviser
Initial released.
28-Nov-18
N/A
K. Yasuda
Revise packing information
2-Nov-19
N/A
Kuro
P.8 Delete Pressure Cooker Storage; P.10
Change packaging requirement; P.11
Change Specification of the
environment-related substances.
19-Dec-19
N/A
Chen XuanRu
A2
P.8, P.10, P.11
A3
P.10
Change SMD PRODUCT PACKING
STANDARD
11-Aug-20
N/A
Chen XuanRu
A4
P.6
Change Marking
3-Nov-21
N/A
Chen XuanRu
A5
P.5,P.8
Add ESD and MSL;
Add Storage conditions and constant
humidity
14-Feb-22
N/A
Han Shuang
FL P/N
REV.
2Z26000007-Q
A5
PAGE
3/11
PRODUCT DESCRIPION
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as
follow:
25±10°C
Ambient temperature :
40% to 70%
Relative humidity :
If there is no doubt the results, measurement shall be made within the following limits:
25±3℃
40% to 70%
Relative humidity :
Measure equipment
Electrical characteristics are measured by S&A250B or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Parameters
Nominal frequency
Oscillation mode
Load capacitance
Frequency tolerance
Frequency Temperature
5
Characteristics
Electrical Spec.
26.000000
AT-cut Fundamental
7
-10
+10
Units
MHz
NA
pF
ppm
At 25±2°C
dFr
-12
+10
ppm
At -30~+85°C (reference 25℃)
-2
+2
ppm
After two reflows (0.5Hr freq.
drift substruct 168Hr freq. drift
ESR
Q
-0.7
-1.4
-2.5
-5
-30
-40
75,000
+0.7
+1.4
+2.5
+5
+105
+105
50
500
W
S
13.5
15
16.5
ppm/pF
17 Inflection point
Ti
29
30.5
32
°C
18 Room temperature
19 Insulation resistance
20 Drive level
First-order curve fitting
21
parameter
T0
IR
DL
500
10
30.5
50
100
°C
MW
mW
C1
-0.4
-0.25
-0.1
ppm/°C
1
2
3
4
6 Frequency drift after reflow
Aging (/1 year)
Aging (/2 year)
Aging (/5 year)
Aging (/10 year)
Operating temperature
Storage temperature
Equivalent series resistance
Quality factor
Spurious mode series
15
resistance
16 Pullability
7
8
9
10
11
12
13
14
Symbol
FL
CL
dF
Fa
22
Second-order curve fitting
parameter
C2
-4.5
23
Third-order curve fitting
parameter
C3
8.7
9.85
11
Notes
ppm/year
ppm/2year
at 25±2℃
ppm/5year
ppm/10year
°C
°C
W
NA
10-4
ppm/°C2
10-5
ppm/°C3
±500KHz
At DC 100V
Ta=-40 to +85℃ per 1℃ (Note
1)
FL P/N
REV.
2Z26000007-Q
A5
PAGE
4/11
ELECTRICAL SPECIFICATIONS (CONT.)
Parameters
Full Cycle Temperature
24
Hysteresis
Symbol
Electrical Spec.
Units
-0.5
+0.5
ppm
Notes
at -30~+85℃
(Note 2)
25
5℃ Small Cycle Temperature
Hysteresis
-0.05
+0.05
ppm
(Note 3)
26
Full Cycle Frequency stability
slope
-50
+50
ppb/℃
(Note 4)
-50
+50
ppb/℃
(Note 4)
FDLD
FDLDH
DLD2
DLDH2
3.5
0.7
2.5
1.5
ppm
ppm
Ω
Ω
Drive Level
10nW~100uW
Step Ratio is sqrt10
27
28
29
30
31
5℃ Small Cycle
Frequency stability slope 1
DLD Freq. (Max-Min)
DLD Freq. (Hysteresis)
DLD ESR (Max-Min)
DLD ESR (Hysteresis)
Note 1
Note 2
Note 3
Note 4
Measure FT points every 1℃, heating up from -40 to 85℃, substrut a third-order polynomial best fit.
F(T) = C3(T-To)3 + C2(T-To)2 + C1(T-To); To = 30.5℃
Temp. range:-30 to 85℃ for each 1℃, Temp. rate: ~1.0°C/min
Test flow: 25℃(1)->-30℃->85℃->25℃(2), (25℃(1) freq. drift subtract 25℃(2) freq. drift)
Temp. range:-30 to 85℃ for each 0.5℃, Temp. rate: ~1.0℃/min, Test flow: any 5℃ cycle (ex.25℃(1)->-30℃->25
℃(2), 25℃(1) freq. drift subtract 25℃(2) freq. drift)
Test condition: Continuous temperature rate change of~ 1.0°C/min
Measure FT points every 1℃, heating up from -30 to 85℃, subtract a fifth-order polynomial best fit, and
then calculate the slope of the residual.
NTC THERMISTOR SPECIFICATIONS TABLE
1
2
3
4
5
6
7
Parameters
Operating Temperature
Storage Temperature
Resistance
B-constant
Tolerance
ESD
MSL
Symbol
Electrical Spec.
-30
+105
-40
+105
100
4250
-1
+1
HBM>4000V
Level 1
Units
°C
°C
kW
K
Notes
At 25°C
At 25°C - 50°C
JESD22-A114-B
IPC/JEDEC J-STD-033C
FL P/N
REV.
2Z26000007-Q
A5
CONNECTION DIAGRAM
DIMENSIONS (Unit : mm)
Unit : mm
Pad
#1
#2
#3
#4
Function
Xtal terminal (Input)
Thermistor + GND terminal
Xtal terminal (Output)
Thermistor terminal
SUGGESTED LAYOUT
PAGE
5/11
FL P/N
REV.
2Z26000007-Q
A5
MARKING
Frequency
EX: 26.000MHz = 260
YL
lot (2 digits)
year month
Administrative Symbo
Total time : 360 sec. Max.
Solder melting point :225 oC
Temp. (℃)
10 sec. Max.
260 5
220
60 sec. Max.
180
150
120 sec. Max.
Time (sec.)
PAGE
6/11
FL P/N
REV.
2Z26000007-Q
A5
PAGE
7/11
COMPONENTS
MATERIALS
QTY
1
Cap (Lid)
Kovar (Fe+Co+Ni)
1
2
Base (Package)
Alumina Ceramics (Al2O3)
+ Kovar (Fe+Co+Ni)
1
3
Pad (Package)
Ni + Au
4
4
Crystal Blank
SiO2
1
5
Electrode
Cr + Nobel material
2
6
Conductive Adhesive
Ag
2
7
Thermistor
Alumina Ceramics (Al2O3),
Ni + Ag+ Sn
1
8
Solder
Sn + Ag + Cu
2
FINISH/SPECIFICATIONS
Ni plating
Silicone resin
FL P/N
REV.
2Z26000007-Q
A5
PAGE
8/11
RELIABILITY SPECIFICATIONS
1. MECHANICAL ENDURANCE
Test Item
No.
1 Drop test
2 Shock test
3 Mechanical shock
4 Vibration
5 Gross leak
6 Fine leak
7 Solderability
Resistance to soldering
8
heat
Test Methods
150 cm height, fall freely onto stainless plate 3 times.
150g/150cm height, 3times in the direction of ±x, ±y, ±z on concrete
floor.
Device are shocked to half sine wave (1000 G) three mutually
perpendicular axes each 3 times. 1.0ms duration time.
Frequency range
Amplitude
Perpendicular axes each test time
10 to 55 Hz
1.52 mm
2 hours (x, y, z axis)
Total test time 6 hours
Standard sample for automatic gross leak detector. Test pressure
2kg/cm2.
Helium bombing 4.5kgf/cm2 for 2 hours.
Temperature
260 oC ±5 oC
Immersing depth
0.5 mm minimum
Immersion time
5 ± 1 seconds
Flux
Rosin resin methyl alcohol
solvent ( 1 : 4 )
Pre-heat temperature
Pre-heat time
Test temperature
Test time
125°C
60 to 120 sec.
260 ± 5°C
5 ± 1 sec.
JIS C6701
IEC-68-02-27
MIL-STD-202F
MIL-STD-883E
MIL-STD-883E
MIL-STD-883E
GB/T 2424.172008 / IEC 600682-44:1995;
GB/T 2423.282005 / IEC 600682-20:1979
MIL-STD-202F
*Storage conditions :18 months
*Constant humidity :40~70%
2. ENVIRONMENTAL ENDURANCE
Test Item
No.
High
Temp.
storage
9
10 Low Temp. storage
Test Methods
+ 125°C ± 3°C for 500 ± 12 hours
- 40°C ± 3°C for 500 ± 12 hours
Total 100 cycles of the following temperature cycle
MIL-STD-883E
1 cycle
11 Thermal shock
125+/- 3 oC
MIL-STD-883E
25 oC
-55+/- 3
o
C
30 min.
30 min.
10 min. max.
12 High Temp. & humidity
85°C±3℃, RH 85%, 500 hours
JIS C5023
FL P/N
REV.
2Z26000007-Q
A5
PAGE
9/11
PACKING : (EIA-481-2)
Direction of feed
Index Mark
Direction of products
Dimension
PKG Type
A0
B0
2.25±0.1
2.70±0.1
2520 TSX (8mm)
P1
P2
4±0.1
2±0.1
Standard Reel Quantity is 3,000 pcs per reel.
K0
1.45±0.10
D1
1±0.1
Unit : mm
T
0.25±0.05
D0
1.55±0.05
W
8±0.3
P0
4±0.1
E
1.75±0.1
THE INSPECTION FOR TAPE TENSION
Appearance
ITEM
ALL
Tape Tension
REMARK : NA
8045、7050
6035-12mm
5032-12mm
3225-12mm
3225-8mm
2520-8mm
2016-8mm
1612-8mm
6035-16mm
5032-16mm
Defect
1.The tape is not coincidence
2.The bubble
overstep 61±6g (55~67g)
overstep 40±5g (35~45g)
overstep 55±6g (49~61g)
overstep 34±6g (28~40g)
overstep 60±6g (54~66g)
Method
Visual inspection
Pull test
F
3.50±0.1
FL P/N
REV.
2Z26000007-Q
A5
PAGE
10/11
SMD PRODUCT PACKING STANDARD
Out-going packing instruction
Reel Packing
Standard:Diameter 18cm
Material:Plastics
Name:Anti-Static Shielding Bag
Standard:205×250mm
Material:APET/CPP
Inner Packing
Standard:430×330+20mm
Material:HDPE (15 reels enter)
Carton
Standard:400×400×280mm
Material:AB corrugated paper (4 bags
enter)
L1
L2
The label instruction
Label Drawing
Mark Name of Article
Spec.
1.Part No.
L1
条码标签
Bar Code Label 2.Lot No.
(Chintz Paper)
3.Q'ty
4.Freq
L2
条码标签
Bar Code Label
(Chintz Paper)
1.Part No.
2.Date Code
3.Q'ty
4.Freq
Size
70x50mm
Printing
White
70x50mm
White
Remark
Specifications on the label is for the use of templates with different product specifications may vary.
If customer specified requirements for labels packaging, please provide the operation procedure.
FL P/N
REV.
2Z26000007-Q
A5
PAGE
11/11
Range
Banned Substances
Products
Maximum concentration
ppm (mg/kg)
Packing Material
ppm (mg/kg)
1
镉及镉化合物
Cadmium and cadmium compounds
100
100
2
铅及铅化合物
Lead and lead compounds
1000
100
3
汞及汞化合物
Mercury and mercury compounds
1000
100
4
六价铬化合物
Hexavalent-Chromium VI (Cr+6)
1000
100
5
聚溴联苯 PBB
Polybrominated biphenyls
1000
N/A
6
聚溴二苯醚 PBDE
Polybrominated diphenyl ethers
1000
N/A
7
邻苯二甲酸二(2-乙基己基)酯
DEHP
Di (2-ethylhexyl) phthalate
1000
N/A
8
邻苯二甲酸丁苄酯 BBP
Butyl Benzyl Phthalate
1000
N/A
9
邻苯二甲酸二丁酯 DBP
Dibutyl Phthalate
1000
N/A
10
邻苯二甲酸二异丁酯 DIBP
Diisobutyl Phthalate
1000
N/A
11
氟(F)、氯(Cl)、溴(Br)、碘(I)
Fluorine、Chlorine、 Bromine、
Iodine
900、900、900、900
注:Br+Cl<1000
N/A
12
包装材料中重金属(汞、镉、六价
铬、铅、PBB、PBDE)之总量
Heavy metals (mercury, cadmium,
lead, Cr+6,PBB and PBDE) in packing
materials
N/A
100
铅(Pb) + 镉(Cd) + 汞(Hg) + 六价铬
(Cr+6)
很抱歉,暂时无法提供与“2Z26000007-Q”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.76788
- 100+0.71928
- 300+0.67068
- 500+0.62208
- 2000+0.59778
- 5000+0.58320
