2SQ3270013-Q
2SQ3270013-Q
    YL(惠伦晶体)
    SMD2012_2P
    无源晶振 7pF 55KΩ ±20ppm SMD2012_2P 32.768KHz
2SQ3270013-Q 数据手册
36 Donghuan Road,Jitigang Village,Huangjiang,Dongguan,Guangdong Province,P.R.China TEL :+86(0)769-38879888 Fax :+86(0)769-38879889 E-mail : yl@dgylec.com PRODUCT SPECIFICATION SHEET CUSTOMER : PRODUCT TYPE : SMD X`TAL 2.0*1.2 NOMINAL FREQ. : 32.768kHz FL P/N : 2SQ3270013-Q REVISION : S0 CUSTOMER P/N : CUSTOMER'S APPROVAL&DATE FL CORPORATION APPROVED CHECKED DESIGNED Jay Lee Jin Qi Chen XuanRu RoHS Compliant 2SQ3270013-Q TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: CONTENTS S0 PAGE ‧ ELECTRICAL SPECIFICATIONS & ENVIRONMENTAL 3 ‧ DIMENSIONS AND MAKING LAYOUT 4 ‧ REFLOW PROFILE 5 ‧ PACKAGING REQUIREMENT 6 ATTACHMENT(optional) ‧ ELECTRICAL CHARACTERISTICS TEST A YES NO ‧ TEMPERATURE CHARACTERISTICS TEST B YES NO PAGE: 1/6 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: 2SQ3270013-Q S0 PAGE: 2/6 SPECIFICATION REVISION RECORD SHEET Rev. Revise page S0 N/A Revise Contents Initial released Date Ref. No. Reviser 20-Sep-19 N/A Chen XuanRu TEL : +86(0)769-38879888 YL P/N: FAX : 86(0)769-38879889 VER: 2SQ3270013-Q S0 PAGE: ELECTRICAL SPECIFICATIONS PARAMETER VALUE NOMINAL FREQUENCY 32.768 kHz FREQUENCY TOLERANCE AT 25°C ±20 PPM MAX TURNOVER TEMPERATURE 25°C ± 5°C -6 TEMPERATURE CHARACTERISTICS(25℃±5℃ ) (-0.03±0.01)×10 /℃2 LOAD CAPACITANCE 7 pF EQUIVALENT SERIES RESISTANCE 55 kΩ MAX DRIVE LEVEL 0.1±0.01μW MAXIMUM DRIVE LEVEL 1μW max. SHUNT CAPACITANCE 1.9pF typ. (at 1MHz) MOTIONAL CAPACITANCE 9.9fF typ. ±3 PPM AGING (FIRST YEAR,AT 25℃) INSULATION RESISTANCE 500 MΩ MINIMUM OPERATING TEMPERATURE RANGE -40°C to +85°C STORAGE TEMPERATURE RANGE -40°C to +85°C ±5ppm max 75 cm drop test in 3 axes onto a SHOCK RESISTANCE hard surface or 3000gx0.3msx1/2 sinewave in 3 axes 3/6 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: DIMENSIONS AND MAKING LAYOUT 1.Out Line Drawing 2.MARKING *1 *2 *3 *4,5 Specification CL ( 7pF:B、9pF:J、12.5pF:F ) Year of Production( Last digit of year ) Week of Production(01~ 52) 3.Lead Connection 2SQ3270013-Q S0 PAGE: 4/6 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: REFLOW PROFILE Reflow profile TSMIN Temperature Min Preheat TSMAX Temperature Max Preheat tS Time (TSMIN to TSMAX) TL Temperature TP Peak Temperature RUP Ramp-up rate RDOWN Ramp-down rate Time within 5°C of Peak Temperature tP Time t[25°C] to Peak Temperature t[25°C] to Peak tL Time 150°C 200°C 60-180 sec. 217°C 260°C 3°C/s max. 6°C/s max. 10 s 480 s 60-150 s 2SQ3270013-Q SAMPLE PAGE: 5/6 TEL : +86(0)769-38879888 FAX : 86(0)769-38879889 YL P/N: VER: 2SQ3270013-Q S0 PAGE: 6/6 SMD PRODUCT PACKING STANDARD Out-going packing instruction Reel Packing Inner Packing name:reel name:inner box standard:diameter 18cm standard:L19.0xW19.0xH2.5cm material:plastics material:B corrugated paper Carton name:carton standard:L34.0xW22.0xH22.0cm material:AB corrugated paper(10 boxes enter) L1 L1 L1 The label instruction Label Drawing Mark Name of Article Spec. L1 条码标签 1.Date Code Bar Code 2.Lot No. Label 3.Part No. (Chintz Paper) 4.Freq 5.Q'ty Size Printing 75x35mm White Remark Specifications on the label is for the use of templates with different product specifications may vary. If customer specified requirements for labels packaging. please provide the operation procedure.
2SQ3270013-Q 价格&库存
很抱歉,暂时无法提供与“2SQ3270013-Q”相匹配的价格&库存,您可以联系我们找货
