36 Donghuan Road,Jitigang Village,Huangjiang,Dongguan,Guangdong Province,P.R.China
TEL :+86(0)769-38879888 Fax :+86(0)769-38879889 E-mail : yl@dgylec.com
PRODUCT SPECIFICATION SHEET
CUSTOMER
PRODUCT TYPE
: SMD X`TAL 2.0*1.2
NOMINAL FREQ.
: 32.768kHz
FL P/N
: 2SQ3270006-Q
REVISION
: S0
CUSTOMER P/N
CUSTOMER'S APPROVAL&DATE
FL CORPORATION
APPROVED
CHECKED
DESIGNED
Jay Lee
Jin Qi
Chen XuanRu
RoHS Compliant
2SQ3270006-Q
TEL : +86(0)769-38879888 FL P/N:
FAX : 86(0)769-38879889
VER:
CONTENTS
S0
PAGE
‧ ELECTRICAL SPECIFICATIONS & ENVIRONMENTAL
3
‧ DIMENSIONS AND MAKING LAYOUT
4
‧ REFLOW PROFILE
5
‧ PACKAGING REQUIREMENT
6
ATTACHMENT(optional)
‧ ELECTRICAL CHARACTERISTICS TEST
A
YES
NO
‧ TEMPERATURE CHARACTERISTICS TEST
B
YES
NO
PAGE:
1/6
VER:
2SQ3270006-Q
S0
PAGE:
2/6
SPECIFICATION REVISION RECORD SHEET
Rev.
Revise page
S0
N/A
Revise Contents
Initial released
Date
Ref. No.
Reviser
20-Sep-19
N/A
Chen XuanRu
TEL : +86(0)769-38879888 YL P/N:
VER:
2SQ3270006-Q
S0
PAGE:
PARAMETER
VALUE
NOMINAL FREQUENCY
32.768 kHz
FREQUENCY TOLERANCE AT 25°C
±20 PPM MAX
TURNOVER TEMPERATURE
25°C ± 5°C
-6
TEMPERATURE CHARACTERISTICS(25℃±5℃
(-0.03±0.01)×10
/℃2
LOAD CAPACITANCE
12.5 pF
EQUIVALENT SERIES RESISTANCE
55 kΩ MAX
DRIVE LEVEL
0.1±0.01μW
MAXIMUM DRIVE LEVEL
1μW max.
SHUNT CAPACITANCE
1.9pF typ. (at 1MHz)
MOTIONAL CAPACITANCE
9.9fF typ.
±3 PPM
AGING (FIRST YEAR,AT 25℃)
INSULATION RESISTANCE
500 MΩ MINIMUM
OPERATING TEMPERATURE RANGE
-40°C to +85°C
STORAGE TEMPERATURE RANGE
-40°C to +85°C
±5ppm max 75 cm drop test in 3 axes onto a
SHOCK RESISTANCE
hard surface or 3000gx0.3msx1/2 sinewave in 3 axes
3/6
VER:
1.Out Line Drawing
2.MARKING
*1
*2
*3
*4,5
Specification
CL ( 7pF:B、9pF:J、12.5pF:F )
Year of Production( Last digit of year )
Week of Production(01~ 52)
3.Lead Connection
2SQ3270006-Q
S0
PAGE:
4/6
VER:
REFLOW PROFILE
Reflow profile
TSMIN
Temperature Min Preheat
TSMAX
Temperature Max Preheat
tS
Time (TSMIN to TSMAX)
TL
Temperature
TP
Peak Temperature
RUP
Ramp-up rate
RDOWN
Ramp-down rate
Time within 5°C of Peak Temperature tP
Time t[25°C] to Peak Temperature
t[25°C] to Peak
tL
Time
150°C
200°C
60-180 sec.
217°C
260°C
3°C/s max.
6°C/s max.
10 s
480 s
60-150 s
2SQ3270006-Q
SAMPLE
PAGE:
5/6
YL P/N:
VER:
2SQ3270006-Q
S0
PAGE:
6/6
SMD PRODUCT PACKING STANDARD
Out-going packing instruction
Reel Packing
Inner Packing
standard:diameter 18cm
standard:L19.0xW19.0xH2.5cm
material:plastics
material:B corrugated paper
Carton
standard:L34.0xW22.0xH22.0cm
material:AB corrugated paper(10
boxes enter)
L1
L1
L1
The label instruction
Label Drawing
Mark Name of Article
Spec.
L1 条码标签
1.Date Code
Bar Code
2.Lot No.
Label
3.Part No.
(Chintz Paper) 4.Freq
5.Q'ty
Size
Printing
75x35mm White
Remark
Specifications on the label is for the use of templates with different product specifications may vary.
If customer specified requirements for labels packaging. please provide the operation procedure.
很抱歉,暂时无法提供与“2SQ3270006-Q”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.97236
- 30+0.93951
- 100+0.90666
- 500+0.84096
- 1000+0.80811
- 2000+0.78840
