1Z38400002-Q
1Z38400002-Q
    YL(惠伦晶体)
    SMD1612_4P
    无源晶振 38.4MHz ±10ppm 8pF 50Ω SMD1612_4P -30℃~+105℃
1Z38400002-Q 数据手册
No. 68 Huangjiang Donghuan Road, Huangjiang Town, Dongguan City, Guangdong Province, China TEL :+86(0)769-38879888 Fax :+86(0)769-38879889 E-mail : yl@dgylec.com PRODUCT SPECIFICATION SHEET CUSTOMER : PRODUCT TYPE : SMD TSX 1.61.2 NOMINAL FREQ. : 38.400000 MHz FL P/N : 1Z38400002-Q REVISION : B1 CUSTOMER P/N : CUSTOMER'S APPROVAL & DATE FL CORPORATION APPROVED CHECKED DESIGNED Jay Lee Kuro Peng May MSL 1 RoHS Compliant FL P/N REV. CONTENTS 1Z38400002-Q B1 PAGE PAGE ‧ SPECIFICATION REVISION RECORD SHEET 2 ‧ ELECTRICAL SPECIFICATIONS 3 to 4 ‧ CONNECTION DIAGRAM, DIMENSIONS & MARKING 5 ‧ MARKING 6 ‧ SUGGESTED REFLOW PROFILE 6 ‧ STRUCTURE ILLUSTRATION 7 ‧ RELIABILITY TEST SPECIFICATIONS 8 ‧ PACKING 9 to 10 ‧ SPECIFICATION OF THE ENVIRONMENT-RELATED SUBSTANCES 11 ATTACHMENT (optional) ‧ ELECTRICAL CHARACTERISTICS TEST A YES NO ‧ TEMPERATURE CHARACTERISTICS TEST B YES NO 1/11 FL P/N REV. 1Z38400002-Q B1 PAGE 2/11 SPECIFICATION REVISION RECORD SHEET Rev. Revise Page A0 N/A A1 Date Ref. No. Reviser Initial released. 10-May-17 N/A K. Yasuda P.2 Add revision record sheet. 10-Apr-18 N/A K. Yasuda A2 P.3 #3 Change reference temperature from 30℃ to 29℃. 29-May-18 N/A K. Yasuda A3 P.6 Correct Suggested Reflow Profile. 8-Mar-19 N/A Chen XuanRu P.8 Delete Pressure Cooker Storage; P.10 Change packaging requirement; P.11 Change Specification of the environment-related substances. 20-Mar-20 N/A Chen XuanRu P.3 Change ESR, change item 20. P.4 Change item 21. 22-Jul-20 N/A Chen XuanRu Update marking 13-Oct-21 N/A May A4 P.8, P.10, P.11 B0 P.3, P.4 B1 P.6 Revise Contents FL P/N REV. 1Z38400002-Q B1 PAGE PRODUCT DESCRIPION Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: 25±10°C Ambient temperature : 40% to 70% Relative humidity : If there is no doubt the results, measurement shall be made within the following limits: 25±3℃ Ambient temperature : 40% to 70% Relative humidity : Measure equipment Electrical characteristics are measured by S&A250B or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). ELECTRICAL SPECIFICATIONS # 1 2 3 4 5 6 7 8 9 10 11 12 13 Parameters Nominal frequency Oscillation mode Load capacitance Frequency tolerance Tolerance over temperature (reference 29°C) Aging Frequency drift after reflow Operating temperature Storage temperature Equivalent series resistance Quality factor Spurious mode series resistance Pullability 14 Inflection point 15 Insulation resistance 16 Drive level First-order curve fitting 17 parameter Symbol FL CL - Electrical Spec. 38.400000 AT-cut Fundamental 8 -10 +10 Units MHz NA pF ppm (Note 1) At 25±3°C - -12 - +12 ppm At -30~+85°C (Note 2) ESR Q -0.7 -2.0 -30 -40 75,000 - +0.7 +2.0 +105 +105 50 - ppm/year ppm °C °C W NA - 1,100 - - W TS 7 - 16 ppm/pF - 27.5 - 30.5 °C IR DL 500 10 - 200 MW mW C1 -0.4 - -0.1 ppm/°C 18 Second-order curve fitting parameter C2 -4.5 0 +4.5 19 Third-order curve fitting parameter C3 +8.5 10 +11.5 - -100 -50 -100 - +100 +50 +100 Residual frequency stability 20 slope (residual=difference from fifth-order curve fit) 10-4 ppm/°C2 10-5 ppm/°C3 ppb/°C ppb/°C ppb/°C Notes After two reflows (Note 3) ±1MHz At DC 100V (Note 4) (Note 4) (Note 4) Ta=-30℃ to -15℃ (Note 5) Ta=-15°C to +70°C (Note 5) Ta=+70°C to +85°C (Note 5) 3/11 FL P/N 1Z38400002-Q REV. B1 PAGE Units ppb/°C ppb/°C ppb/°C ppb pk-pk ppm ppm % % Notes Ta=-30°C to -15°C (Note 6) Ta=-15°C to +70°C (Note 6) Ta=+70°C to +85°C (Note 6) (Note 7) (Note 8) (Note 8) (Note 8) (Note 8) 4/11 ELECTRICAL SPECIFICATIONS (CONT.) Parameters # 21 5°C small orbit hysteresis 1 22 23 24 25 26 5°C small orbit hysteresis 2 DLD Freq. (Max-Min) DLD Freq. (Repeatability) DLD ESR (Max-Min) DLD ESR (Repeatability) Note 1 Note 2 Note 3 Note 4 Note 5 Symbol FDLD FDLDH DLD10 DLDH3 Electrical Spec. -100 +100 -50 +50 -100 +100 100 (magnitude) 6 0.7 20 10 The load capacitance is measured according to IEC Standard #60444-7. Above 85°C tolerance over temperature bound by third-order coefficient range. Minimum Q value calculated from ESR and L is smaller than this specification. The curve fitting parameter is obtained from the Qualcomm crystal curve fitting algorithm, t 0=29 °C. (Refer to Curve Fitting Calculation Table: 80-V9690-23 rev.D) Condition 1A – Test condition (continuous temperature rate change of ~1.0°C/min): - Measure FT points every 1°C, heating up from -30 to +85°C, subtract a fifth-order polynomial best fit and then calculate the slope of the residual. - The residual slope should be within ±100 ppb/°C for -30 °C to -15 °C, ±50 ppb/°C for -15 °C to 70 °C, and ±100 ppb/°C for +70 °C to +85 °C. Note 6 Condition 1B – Hysteresis 1 test condition (continuous temperature rate change of ~1.0°C/min): - Measure FT points every 0.5°C while cycling temperature over a 5°C small temperature orbit; an example 5°C small orbit temperature cycle is +30°C to +35°C to +30°C. - During every individual heating/cooling cycle, there should be 11 points. Discard the first point of each heating and cooling cycle. This leaves 10 points for each heating and cooling cycle. Subtract the fifth-order polynomial best fit from 1A for each of the 10 points, and then calculate the slope of the residual for each of these heating and cooling 10 point curves. - The residual slope should be within ±100 ppb/°C for -30 °C to -15 °C, ±50 ppb/°C for -15 °C to 70 °C, and ±100 ppb/°C for +70 °C to +85 °C. Note 7 Hysteresis 2 test condition (continuous temperature rate change of ~1.0°C/min): - Measure FT points every 0.5°C while cycling temperature over a 5°C small temperature orbit; an example 5°C small orbit temperature cycle is +30°C to +35°C to +30°C. - During every individual heating/cooling cycle there should be 11 points; discard the first and last point of each heating and cooling cycle, which results in 9 temperature points. Calculate the average measured peak-to-peak frequency difference for these 9 temperature points. Note 8 - The average difference is the magnitude of the small orbit hysteresis 2. 0.01 mW to 100mW to 0.01 mW, number of points: 15 points up and 15 points down =29 total data points. NTC THERMISTOR SPECIFICATIONS TABLE # 1 2 3 4 5 Parameters Operating Temperature Storage Temperature Resistance B-constant Tolerance Symbol - Electrical Spec. -30 +105 -40 +105 100 4250 1 Units °C °C kW K % Notes At 25°C At 25°C - 50°C FL P/N REV. 1Z38400002-Q B1 CONNECTION DIAGRAM DIMENSIONS (Unit : mm) Unit : mm Pad #1 #2 #3 #4 Function Xtal terminal (Input) Thermistor + GND terminal Xtal terminal (Output) Thermistor terminal SUGGESTED LAYOUT PAGE 5/11 FL P/N REV. 1Z38400002-Q B1 MARKING Frequency EX: 38.400MHz = 384 YL lot (2 digits) year month Administrative Symbo 2017 2018 2019 2020 2021 2022 2023 2024 SUGGESTED REFLOW PROFILE Total time : 360 sec. Max. Solder melting point :225 oC Temp. (℃) 10 sec. Max. 260 5 220 60 sec. Max. 180 150 120 sec. Max. Time (sec.) PAGE 6/11 FL P/N REV. 1Z38400002-Q B1 PAGE 7/11 STRUCTURE ILLUSTRATION # COMPONENTS MATERIALS QTY 1 Cap (Lid) Kovar (Fe+Co+Ni) 1 2 Base (Package) Alumina Ceramics (Al2O3) + Kovar (Fe+Co+Ni) 1 3 Pad (Package) Ni + Au 4 4 Crystal Blank SiO2 1 5 Electrode Cr + Nobel material 2 6 Conductive Adhesive Ag 2 7 Thermistor Alumina Ceramics (Al2O3), Ni + Ag+ Sn 1 8 Solder Sn + Ag + Cu 2 FINISH/SPECIFICATIONS Ni plating Silicone resin FL P/N REV. 1Z38400002-Q B1 PAGE 8/11 RELIABILITY SPECIFICATIONS 1. MECHANICAL ENDURANCE Test Item No. 1 Drop test 2 Shock test 3 Mechanical shock 4 Vibration 5 Gross leak 6 Fine leak 7 Solderability Resistance to soldering 8 heat Test Methods 150 cm height, fall freely onto stainless plate 3 times. 150g/150cm height, 3times in the direction of ±x, ±y, ±z on concrete floor. Device are shocked to half sine wave (1000 G) three mutually perpendicular axes each 3 times. 1.0ms duration time. Frequency range Amplitude Perpendicular axes each test time 10 to 55 Hz 1.52 mm 2 hours (x, y, z axis) Total test time 6 hours Standard sample for automatic gross leak detector. Test pressure 2kg/cm2. Helium bombing 4.5kgf/cm2 for 2 hours. Temperature 260°C ± 5°C Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol solvent ( 1 : 4 ) Pre-heat temperature Pre-heat time Test temperature Test time 125°C 60 to 120 sec. 260 ± 5°C 5 ± 1 sec. JIS C6701 IEC-68-02-27 MIL-STD-202F MIL-STD-883E MIL-STD-883E MIL-STD-883E GB/T 2424.172008 / IEC 600682-44:1995; GB/T 2423.282005 / IEC 600682-20:1979 MIL-STD-202F 2. ENVIRONMENTAL ENDURANCE Test Item No. 9 High Temp. storage 10 Low Temp. storage Test Methods + 125°C ± 3°C for 500 ± 12 hours - 40°C ± 3°C for 500 ± 12 hours Total 100 cycles of the following temperature cycle MIL-STD-883E 1 cycle o 11 Thermal shock 125+/- 3 C MIL-STD-883E 25 oC -55+/- 3 o C 30 min. 30 min. 10 min. max. 12 High Temp. & humidity 85°C±3℃, RH 85%, 500 hours JIS C5023 FL P/N REV. 1Z38400002-Q B1 PAGE 9/11 PACKING : (EIA-481-2) Direction of feed Index Mark Direction of products Dimension PKG Type A0 B0 1.45±0.1 1.85±0.1 2016 TSX (8mm) P1 P2 4±0.1 2±0.1 Standard Reel Quantity is 3,000 pcs per reel. K0 0.8±0.10 D1 0.6±0.1 Unit : mm T 0.25±0.05 D0 1.55±0.05 W 8±0.3 P0 4±0.1 E 1.75±0.1 THE INSPECTION FOR TAPE TENSION Appearance ITEM ALL Tape Tension REMARK : NA 8045、7050 6035-12mm 5032-12mm 3225-12mm 3225-8mm 2520-8mm 2016-8mm 1612-8mm 6035-16mm 5032-16mm Defect 1.The tape is not coincidence 2.The bubble overstep 61±6g (55~67g) overstep 40±5g (35~45g) overstep 55±6g (49~61g) overstep 34±6g (28~40g) overstep 34±6g (28~40g) overstep 60±6g (54~66g) Method Visual inspection Pull test F 3.50±0.1 FL P/N 1Z38400002-Q REV. B1 PAGE 10/11 SMD PRODUCT PACKING STANDARD Out-going packing instruction Reel Packing Name:Reel Standard:Diameter 18cm Material:Plastics Name:Anti-Static Shielding Bag Standard:205×250mm Material:APET/CPP Inner Packing Name:Bubble Wrap Standard:430×330+20mm Material:HDPE (15 reels enter) Carton Name:Carton Standard:400×400×280mm Material:AB corrugated paper (4 bags enter) L1 L2 The label instruction Label Drawing Mark Name of Article Spec. 1.Part No. L1 条码标签 Bar Code Label 2.Lot No. (Chintz Paper) 3.Q'ty 4.Freq L2 条码标签 Bar Code Label (Chintz Paper) 1.Part No. 2.Date Code 3.Q'ty 4.Freq Size 70x50mm Printing White 70x50mm White Remark Specifications on the label is for the use of templates with different product specifications may vary. If customer specified requirements for labels packaging, please provide the operation procedure. FL P/N REV. 1Z38400002-Q B1 PAGE 11/11 SPECIFICATION OF THE ENVIRONMENT-RELATED SUBSTANCES Range # Banned Substances Products Maximum concentration ppm (mg/kg) Packing Material Maximum concentration ppm (mg/kg) 1 镉及镉化合物 Cadmium and cadmium compounds 100 100 2 铅及铅化合物 Lead and lead compounds 1000 100 3 汞及汞化合物 Mercury and mercury compounds 1000 100 4 六价铬化合物 Hexavalent-Chromium VI (Cr+6) 1000 100 5 聚溴联苯 PBB Polybrominated biphenyls 1000 N/A 6 聚溴二苯醚 PBDE Polybrominated diphenyl ethers 1000 N/A 7 邻苯二甲酸二(2-乙基己基)酯 DEHP Di (2-ethylhexyl) phthalate 1000 N/A 8 邻苯二甲酸丁苄酯 BBP Butyl Benzyl Phthalate 1000 N/A 9 邻苯二甲酸二丁酯 DBP Dibutyl Phthalate 1000 N/A 10 邻苯二甲酸二异丁酯 DIBP Diisobutyl Phthalate 1000 N/A 11 氟(F)、氯(Cl)、溴(Br)、碘(I) Fluorine、Chlorine、 Bromine、 Iodine 900、900、900、900 注:Br+Cl<1000 N/A 12 包装材料中重金属(汞、镉、六价 铬、铅、PBB、PBDE)之总量 Heavy metals (mercury, cadmium, lead, Cr+6,PBB and PBDE) in packing materials N/A 100 铅(Pb) + 镉(Cd) + 汞(Hg) + 六价铬 (Cr+6)
1Z38400002-Q 价格&库存
很抱歉,暂时无法提供与“1Z38400002-Q”相匹配的价格&库存,您可以联系我们找货
1Z38400002-Q
  • 1+1.26540
  • 30+1.22265
  • 100+1.17990
  • 500+1.09440
  • 1000+1.05165
  • 2000+1.02600
