1SQ3270009-Q
1SQ3270009-Q
    YL(惠伦晶体)
    SMD1610_2P
    无源晶振 7pF 90KΩ ±20ppm SMD1610_2P 32.768KHz
1SQ3270009-Q 数据手册
NO.68 Huangjiang Donghuan Road,Huangjiang Town,Dongguan City,Guangdong Province,China TEL :+86(0)769-38879888 Fax :+86(0)769-38879889 E-mail : yl@dgylec.com PRODUCT SPECIFICATION SHEET CUSTOMER PRODUCT TYPE : SMD TUNING FORK 1.6X1.0 NOMINAL FREQ. : 32.768000 KHz FL P/N : 1SQ3270009-Q REVISION : S0 CUSTOMER P/N : CUSTOMER'S APPROVAL&DATE FL CORPORATION APPROVED CHECKED DESIGNED Jay Lee Jin Qi May Zhang MSL1 RoHS Compliant 1SQ3270009-Q TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: CONTENTS S0 PAGE ‧ SPECIFICATION REVISION RECORD SHEET 2 ‧ ELECTRICAL SPECIFICATIONS 3 ‧ DIMENSIONS 4 ‧ RELIABILITY TEST SPECIFICATIONS 5 ‧ PARKING 6 ‧ SPECIFICATION OF THE ENVIRONMENT-RELATED SUBSTANCES 7 ATTACHMENT(optional) ‧ ELECTRICAL CHARACTERISTICS TEST A YES NO ‧ TEMPERATURE CHARACTERISTICS TEST B YES NO PAGE: 1/7 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: 1SQ3270009-Q S0 PAGE: SPECIFICATION REVISION RECORD SHEET Rev. Revise page S0 N/A Revise Contents Initial released Date Ref. No. Reviser 10-Dec-21 N/A May Zhang 2/7 TEL : +86(0)769-38879888 FAX : 86(0)769-38879889 FL P/N: 1SQ3270009-Q S0 VER: PAGE: PRODUCT DESCRIPION Standard atmospheric conditions Unless otherwise specified. The standard range of atmospheric conditions for making measurement and tests are as follow: 25±2℃ Ambient temperature : 40%~70% Relative humidity : If there is no doubt the results, measurement shall be made within the following limits: 25±2℃ Ambient temperature : 40%~70% Relative humidity : Measure equipment Electrical characteristics measured by S&A250B or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode) ELECTRICAL SPECIFICATIONS Electrical Spec. No. Items Remarks Symbol Min Typ Max Units 1 Nominal Frequency FL 32.768000 KHz - 2 Load Capacitance CL 7.0 pF - 3 Frequency Tolerance - ±20 ppm at 25±3℃ 4 Turnover Temperature - ℃ at 25±5℃ 5 Parabolic coefficient - 6 Shunt Capacitance C0 - 1.2 - pF - 7 Motional Capacitance C1 - 6.0 - fF - ppm/year at 25±2℃ 20 25 30 (-0.036±10%) × 10-6/℃2 8 Aging (/1 year) - 9 Operating Temperature - -40 - 85 ℃ - 10 Storage Temperature Equivalent series 11 resistance 12 Insulation Resistance - -55 - 125 ℃ - ESR - - 90 kΩ - IR 500 - - M-ohms at DC 100V 0.1 0.5 uW - 13 Drive Level DL ±3 - 3/7 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: DIMENSIONS unit:mm MARKING S□□□□ *1 *2 *3 *4 *5 *1 Model Name *2 CL (6pF:A, 7pF:B, 9pF:J, 12.5pF:F ) *3 Year of Production( Last digit of year ) *4,5 Week of Production(01~ 52) 1SQ3270009-Q S0 PAGE: 4/7 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: 1SQ3270009-Q S0 PAGE: 5/7 RELIABILITY SPECIFICATIONS 1.MECHANICAL ENDURANCE Test Item Test Methods No. 1 Drop Test 150 cm height, fall freely onto stainless plate 3 times. 2 Mechanical Shock 3 Vibration Device are shocked to half sine wave ( 1000 G ) three mutually pendicular axes each 3 times. 1.0m sec. duration time Frequency range 10 ~ 55 Hz Amplitude 1.52 mm Pendicular axes each test time 2 hours(x,y,z Axis) Total test time 6 hours Immersing depth 260 oC ±5 oC 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol Temperature 4 Solderability solvent ( 1 : 4 ) Pre-heat temperature 5 Resistance To Soldering Heat Pre-heat time 260 +/- 5 oC 5 +/- 1 sec. Test temperature Test time 2.ENVIRONMENTAL ENDURANCE Test Item No. 6 High Temp. Storage 7 Low Temp. Storage o 125 oC 60 ~ 120 sec. JIS C6701 MIL-STD-202F MIL-STD-883E GB/T 2424.172008 / IEC 60068-244:1995; GB/T 2423.282005 / IEC 60068-220:1979 MIL-STD-202F Test Methods o + 125 C +/- 3 C for 500 +/- 12 hours - 40 oC +/- 3 oC for 500 +/- 12 hours Total 100 cycles of the following temperature cycle MIL-STD-883E 1 cycle 125+/- 3 oC 8 Thermal Shock MIL-STD-883E 25 oC -55+/- 3 o C 30 min. 30 min. 10 min. max. 9 High Temp&Homidity 85℃±3℃, RH 85%,500Hrs JIS C5023 TEL : +86(0)769-38879888 FAX : 86(0)769-38879889 FL P/N: VER: PACKING : a 1.28 ±0.05 b 1.79 ±0.05 Dimension(Unit:mm) c d e 8 3.5 4 ±0.2 ±0.05 ±0.1 Dimension(Unit:mm) A B W Φ180 Φ60 13 f 0.65 ±0.1 t 0.2 ±0.05 1SQ3270009-Q S0 PAGE: 6/7 TEL : +86(0)769-38879888 FAX : 86(0)769-38879889 FL P/N: VER: 1SQ3270009-Q S0 PAGE: 7/7 Range Products Packing Material Banned Substances Maximum concentration ppm(mg/kg) Maximum concentration ppm(mg/kg) 1.镉及镉化合物 Cadmium and cadmium compounds 100 100 2.铅及铅化合物 Lead and lead compounds 1000 100 3.汞及汞化合物 Mercury and mercury compounds 1000 100 4.六价铬化合物 Hexavalent-Chromium VI (Cr+6) 1000 100 5.聚溴联苯 PBB Polybrominated biphenyls 1000 N/A 6.聚溴二苯醚 PBDE Polybrominated diphenyl ethers 1000 N/A 7.邻苯二甲酸二(2-乙基己基)酯 DEHP Di (2-ethylhexyl) phthalate 1000 N/A 8.邻苯二甲酸丁苄酯 BBP Butyl Benzyl Phthalate 1000 N/A 9.邻苯二甲酸二丁酯 DBP Dibutyl Phthalate 1000 N/A 10 邻苯二甲酸二异丁酯 DIBP Diisobutyl Phthalate 1000 N/A 11. 氟(F)、氯(Cl)、溴(Br)、碘 (I) Fluorine、Chlorine、 Bromine、Iodine 900、900、900、900 注:Br+Cl<1000 N/A 12.包装材料中重金属(汞、镉、六价铬、 铅、PBB、PBDE)之总量 Heavy metals (mercury, cadmium, lead, Cr+6,PBB and PBDE) in packing materials N/A 100 铅(Pb) + 镉(Cd) + 汞(Hg) + 六价铬 (Cr+6)
1SQ3270009-Q 价格&库存
很抱歉,暂时无法提供与“1SQ3270009-Q”相匹配的价格&库存,您可以联系我们找货
