S P S E MI
ASD(7KW) Series
瞬 雷 电 子
Surface Mount Auto Surge Suppressor
Working Peak Reverse Voltage - 22 to 36 Volts
7000 Watt Peak Pulse Power
Features
Glass passivated chip
7000 W peak pulse power capability with a 10/1000μs waveform,
repetitive rate (dutycycle):0.01 %
Meet AEC-Q101 requirement
Low leakage
Excellent clamping capability
Very fast response time
RoHS compliant
Mechanical Data
Plastic package DO-218AB/SOD-BLOCK
Epoxy: UL 94V-0 rate flame retardant
Polarity: Heatsink is anode
Maximum Ratings (T A =25℃
unless otherwise noted )
RATING
SYMBOL
VALUE
Peak power dissipation with a 10/1000μs waveform(Note 1)
PPP
7000
Peak pulse current wih a 10/1000μs waveform(Note 1)
I PP
SEE
UNITS
W atts
Amps
TABLE 1
Power dissipation on infinite heatsink at TL = 25℃
PD
5
W atts
Peak Forward Surge Current,8.3ms Single Half Sine-W ave
I FSM
500
Amps
Operating junction and storage temperature range
T J , T STG
- 55 to
+175
Notes :
1.Non-repetitive current pulse , per Fig. 2 and derated above TA = 25℃ per Fig. 1 .
REV. 2022. 02. 01
www.spsemi.cn
Page 1 of 4
S P S E MI
ASD(7KW) Series
瞬 雷 电 子
Dimensions (DO-218AB)
DO-218AB
Recommended Mounting Pad Layout
Dimensions in millimeters
Electrical Characteristics
TABLE1
W orking
Peak Reverse
Voltage
ASD
Part Number
Breakdown Voltage V BR@IT
V RW M(V)
V BR(V)Min.
V BR (V)Max.
Max. IR
Max. Clamping
Voltage Vc
@Ipp 10/1000μs
Max. Reverse
Leakage IR
@VRW M
@VRWM
T J =175℃
IR(μA)
IR(μA)
Vc(V)
Ipp(A)
IT(mA)
ASD22A
ASD22CA
22.0
24.4
26.9
5.0
10
150
35.5
197.2
ASD26A
ASD26CA
26.0
28.9
31.9
5.0
10
150
42.1
166.3
ASD33A
ASD33CA
33.0
36.7
40.6
5.0
10
150
53.3
131.4
ASD36A
ASD36CA
36.0
40.0
44.2
5.0
10
150
58.1
120.5
IEC Compatibility
ISO16750 2 Test A Test Waveform
ASD
Part Number
12V system
24V system
100V@400ms 174V@350ms
ASD22A
ASD22CA
ASD26A
ASD26CA
ASD33A
ASD33CA
ASD36A
ASD36CA
Resistance
0. 5Ω
1Ω
2Ω
4Ω
8Ω
Notes :
? :The test results would be different depending on the specific circuit parameters or test environment
Failed
X :
REV. 2022. 02. 01
www.spsemi.cn
Page 2 of 4
S P S E MI
ASD(7KW) Series
瞬 雷 电 子
Ratings and Characteristic Curves (TA=25 ℃ unless otherwise noted)
Fig.2 Pulse W aveform
120
150
I PPM -Peak Pulse Current(%)
Peak Pulse Derating in Percentage of
Peak Power or Current (%)
Fig.1 Power Derating Cure
100
80
60
40
Half Value IPPM
2
50
10/1000uS
W aveform
00
25 50 75 100 125 150 175 200
Ambient Temperature.T A (℃)
1.0
2.0
t-Time(ms)
3.0
4.0
Fig.4 Peak Pulse Power Rating Cure
Fig.3 Steady State Power Derating Curve
8.0
10000
P PPM -Peak Pulse Power (W )
Steady State Power Dissipation, (W )
tr=10uS
Peak Value
IPPM
T J =25℃
Pulse width(td) is defined
ad the Point where the Peak
Current Decays to 50% of IPPM
6.0
4.0
2.0
1000
100
150
200
Lead Temperature.T L(℃)
REV. 2022. 02. 01
www.spsemi.cn
10
100
t d-Pulse W idth (ms.)
Page 3 of 4
S P S E MI
ASD(7KW) Series
瞬 雷 电 子
Recommended Soldering Conditions
Recommended Conditions
Reflow Soldering
IR Reflow Condition
150℃
Temperature Max(T
200℃
s(max) )
Time(Min to Max)(t s)
60-180secs
Ramp up rate(150-200℃)
Reflow
tP
TP
R amp- up
TL
3℃/sec.Max.
Temperature(T L )(Liquidus)
220℃. Min.
Temperature(t L )
60-150secs
Peak Temp(T P )
Temperature
Pre Heat
Temperature Min(T s(min))
245℃
Ramp up rate(220-200℃)
3℃/sec.Max.
Time within actual Peak Temp(tP )
Ramp-down Rate
10-30 secs
Time 25℃ to Peak Temp(T P )
6 min.Max.
Do not exceed
245℃
tL
T s (max)
T s (min)
ts
Preheat
25
3℃/sec.Max.
time to peak temperature
(t 25℃ to peak)
Time
Marking Code
Cathode Band
Logo
Logo
Serial number
Serial number
ASD22A
Marking Code
ASD22CA
Marking Code
Tape And Reel Specification
Tape Size
24(0.945)
Symbol
Ea Per Reel
REEL DIA
(mm)
Industry Standard
ASD***
750
330
EIA RS-481
A Max.
B Min.
C
330±2.0
13.0±0.50
1.5(0.059)
(13.0±0.079)
(0.51±0.002)
REV. 2022. 02. 01
D Min.
N Min.
G Max.
T Max.
20.2(0.795)
50(1.97)
26.4(1.039)
30.4(1.197)
www.spsemi.cn
Page 4 of 4
很抱歉,暂时无法提供与“ASD33A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+9.21240
- 10+7.92720
- 30+7.22520
- 100+6.42600
- 750+6.06960
